Old 11-01-2010   #1
Rep Power: 39 Sarthos will become famous soon enoughSarthos will become famous soon enoughSarthos will become famous soon enoughSarthos will become famous soon enoughSarthos will become famous soon enoughSarthos will become famous soon enough
Default Add optical output to a CD changer?
Okay, a while ago I read an article about adding digital outputs to a headunit on this site (link below)
http://www.diymobileaudio.com/forum/...s-hu-%246.html
Now, I'm running an Eclipse in-dash CD changer, with an Eclipse flip-out headunit, and an Eclipse 39011 DSP. I just got this stuff, and was excited to hear the processor has 24 bit DAC...not so happy when I found out that the signal from the changer to the processor was analog. So this means my changer uses its 1-bit DAC, sends the signal to the DSP, which then converts it to digital for processing, EQ, time alignment, then goes through the 24 bit DAC. If possible, I'd rather skip the extra stages of the changer's DAC and the processor's ADC, and just run digital signal directly to the optical inputs on the processor, so I suffer less signal degradation.
Does anybody think it's really possible for me to run digital signal from the player to the processor? I think it might be, but my only concern is whether doing this would cause any problems with things like controlling the changer through my HU still. Is there a good way to test whether that can be done before I go through all the work of adding the digital output?
Anyway, any input on this would be much appreciated!
Sarthos is offline   Reply With Quote
Old 11-09-2010   #2
Rep Power: 150 cajunner has a reputation beyond reputecajunner has a reputation beyond reputecajunner has a reputation beyond reputecajunner has a reputation beyond reputecajunner has a reputation beyond reputecajunner has a reputation beyond reputecajunner has a reputation beyond reputecajunner has a reputation beyond reputecajunner has a reputation beyond reputecajunner has a reputation beyond reputecajunner has a reputation beyond repute
Default Re: Add optical output to a CD changer?
this is a very complicated problem.
from what I've gathered, the controller unit/head, is supposed to send a proprietary software message to the changer, if it's digital out capable, to get digital to actually go from the changer to the controller.
this is how I've read Sony does it, and when you have an analog in/out controller, you can't get digital out of the changer because the signal to have the changer start outputting digital isn't there.
If it's both digital units, the information gets passed, and the units work together digitally with the analog pre-amp eventually outputting signal, or the digital out of the head unit sending out digital, like they should.
if you tap into the digital out of the changer at the D/A converter entrance, I imagine if you have a digital head (you do) and the changer was operated as if it was sending analog out, you could take that digital output from the changer and send it into your head unit, but it is possible your head unit won't get the software message to accept a digital input, and you are just shooing flies for your troubles.
that's just one opinion, though..
cajunner is online now   Reply With Quote
Old 11-09-2010   #3
Well that's not exactly what I'm trying to do
I'm running a flip-out head unit, but also an external DSP. The DSP has 2 optical inputs and 1 digital rca input.
I'm thinking if I can add the digital output to the changer, I can have the headunit set on the changer setting so it will run the changer, but have the DSP set on the digital input, the changer will play normally but the signal will be digitally transmitted to the DSP, rather than going through multiple digital/analog conversions. If that makes any sense?
Old 12-01-2010   #4
I added a 12 disc trunk changer to the system. Does anyone think if I sent it off to them they could add a digital output to the changer so I could see if it makes any difference? I'd assume the trunk changer would be easier to modify, it's bigger so there might be more room inside.
