your attention to detail on EVERYTHING comes through the screen loud and clear...i really appreciate it when i see small details on the bare wood build up portions of hte install, like how you took time to sand and round off the edges of the wood, how things are cut straight even when they will never be seen...
awesome! bravo!
Thanks man, that's specially flattering coming from you
I did my best, glad to see you guys liked it.
MS-8... Focal Utopia Be drivers... JL Audio 13TW5-3... JL Audio HD900/5... JL Audio Interconnects... Kicker power cable
Mr. Bing is correct, there is a certain sense of pride and pleasure when seeing a build like this. Attention to detail like this wins more points in my book.
2012 MECA World Finals Street National Runner Up!!!
2012 MECA Street National Points Champion!!!
2012 MECA Street Georgia State Champion!!!
2011 MECA Street Georgia State Champion!!!
Thanks to all for your kind comments, from the beginning my install had he goal to be as OEM as it could be, and the main reason for that is the insecurity that we are suffering here in México.
Yesterday my car was robed by two MF with guns, luckily I took measures in case that happened and It worked. I recovered my car a few minutes later, I just lost one key and some money.
So now I have to think a lot about continuing with the planed install or not
Saludos!
Saludos!
That is a scary ordeal...Glad you are Alright and you got your car back. BTW, I love the how clean the install is. Good Job!
Hello, I had the chance to upgrade the OEM battery with an Optima yellow top and put the JL terminals I bought almost since I began the install.
I just upgraded the ground by replacing the OEM cable for two runs of 4 cable and the power cable from the fuse box for one run of 4. I had some trouble with the power cable coming from the alternador because I could not replace it and It was too short, so I just added some 4 cable for the moment, I’ll take it to the mechanic later so I can upgrade that cable without braking something
I just put the fuse holder with double sided tape, in case I case I replace it with the JL fuseholder later.
Saludos.
I finally found the grill I needed to finish the hatch area. I also looked for the carpet in the correct color but I couldent find it, I found one in a closer match so I tryed it.
I routered the pieces so the grill can sit flush
The new carpet matches better the OEM carpet but the previews one looks made of better quality, sorry for the iPhone pics, but you can see the difference… Next weekend I’ll se wich one stays in the car.
You can see that the subwoofer grill does not sit completly, and that’s because I could´t take off the JL grill, that thing is like glued or something … I’ll get back to that next weekend.
Saludos.
I didn´t like the way the fuseholder looked, so I decided to clean a little. I needed to eliminate the fuseholder an just use the fuse.
I isolated everything with a double thermofit.
Now it looks stock
The only thing that I don’t like is the dificulty of change the fuse in case it blows, but it will stay like that until I decide to buy the JL fuseholder.
Saludos.
I think that the black carpet looks the best. Nice work again.
When I first saw that, I was thinking "Cabron!" and then I was like "That's inappropriate," then I realized it wasn't the same word. What does Chingon! mean? My high school spanish is failing me.
Jay
I never took spanish but I pick up languages fairly quickly
it"s mexican slang to describe something ess-tremely awesome
