The rear side of the baffle is equally important to the front one. The speaker cone needs space to "breathe", aka move freely. When making a tunnel like that, you essentially create a bottleneck for the air to move, thus disturbing the movement of the cone. This usually makes it sound muffled and compressed.
Hugo, you can still fix this (up to a point). Take the whole thing out and chamfer the inside, leaving it thick only where the screws attach to the door card. That way you'll get more space for the air.
I was going to do that, but I though the gain would no be enough or worth the effort, I guess you disagree
Anyway, I might do that the next time I have vacations, right know I need to take care of the tweeter issue.
The song that causes more problems is "The One and Only" from Adele, played by the iPod via MEDIA-IN, and some others but not so much that I can notice easily. My crossover settings are:
Sub: from 20hz to 70hz
MB: from 70hz to 450hz
Mid:from 450hz to 9000hz
Tweeters from 9000hz and up
All with a -24db slope (just the 20 hz filter on the sub is -12db)
MB are doing great playing from 70 htz, they blend with the subwoofer effortless, I'm very happy with that. I need to play with the xovers on the mids, I'm still not happy with that, but first I need to fix the tweeter problem.
I've been listening to some CD's and the sound is really really good and I don't hear a noise, It might be the source , although I haven't heard the song that makes them sound pretty bad, I'll look for that CD and listen.
MS-8... Focal Utopia Be drivers... JL Audio 13TW5-3... JL Audio HD900/5... JL Audio Interconnects... Kicker power cable
Super impressive install. Your attention to detail, which has already been stated numerous times, is exemplary. I myself will soon be using a Krx3 setup for my front stage and I was stuck on keeping the mid and tweeter together in the apillar. You may have just changed my mind as I am not trying to advertise my system to the world.
Very slick. Very clean. Very well executed.
And depending on your car, your PLDs will work better in your favor.
Derick Veliz, My system may not blow your ears, but it will sweeten your senses. Toyota Yaris Sedan Pioneer P-99, I6SW Subwoofer, - Legatia L6 bass, - HL-70 3" Mids, - Pioneer DS-425A Tweeters
Thanks man, it really works. Good luck with your installation
Hello, Yesterday I did some tests with 2 different sets of tweeters and guess what?... the noises are there also, but a little less noticeable.
I suppose the TN53K make those noises more noticeable because they are better tweeters than the ones I used yesterday, hence they produce a more detailed sound.
Next step is to listen the songs that produce the noises in an audio system and be sure that the noises are in fact on the songs and it isn't my car audio system clipping or something else
The songs in which I hear the noises are:
"Till The Sky Falls Down" from Dash Berlin, between 4:45 and 5:05
"One And Only" from Adele, between 4:45 and 5:05
I tried with these from my iMac and my iPod
SHURE SE535
I can hear the noises in the song "Till The Sky Falls Down" although not so clear, it is enough to say it is the song, not my tweeters . With the song from Adele, I can't really say if the noises are there, I might need to check with a better system.
Maybe one of you guys can help me to verify by listening these songs in your systems, I can send you the lossless files, so let me know please.
Saludos.
Sorry man, I'm not really sure what you meant with that, I know Focal tweeters are known for being "too crisp", but are they also known for failing or producing noises and that's what you meant?
Am a Focal user @ heart and what I meant with my post was that Focal tweeters are so crisp, they bring out flaws in some recordings (and sometimes in some systems )
Kelvin
Lycan
Kelvin
Ok, I'm with you now
I just need to find out what else is causing those noises, I wish I had a pair of Grande Utopia at home
FTW is an abbreviation of For The Win, an idiom used lately to show that something is... well, good.
You couldn't fit the Grande Utopias in your house, even if you had a massive villa. Sadly I've heard them lots of times in showrooms and exhibitions, and not once have they blown me away. They're so analytical and precise that you need to position them extremely carefully to get 100% of their capabilities.
Maestro Utopia for me all the way, or even more realistically, B&W 802D.
Same as car audio, is not enough to buy the "best speakers" yo have to build a place to put them, I just can't imagine how much $ would you have to spend to build a room where those speakers can perform at its best
This has nothing to do with the tweeters of the KRX3, I confirmed it was something on the songs and not the tweeters making those noises, in fact the speakers are sounding better the ever, I really enjoy every drive, but some weeks ago I saw a good deal on this utopia No 6 and I could's resist the temptation
I always wanted a set of utopias and to be honest, I love how they look, with the grills on, they will look like OEM speakers, my goal for this install.
I hope I can have these sounding soon.
Saludos.
I had to midify the bafle for the midbass because the mounting diameter for the utopia is bigger and the utopia's grills are smaller so I wraped the pods with some leather from BMW seats, hoping that helps with the looks.
Are those alley-key screw terminals right on the frames of the midbass and midrange? That's a super-clean wiring termination - more manufacturers should do that.
No, they are for a slotted screwdriver and the utopia kits include a set of screwdrivers for the different screws found in the speakers and crossovers.
