Hello guys, I’m going to start a new install in my 2011 León 1.8 TSI. Basically I’ll be using the same equipment I had installed in my VW Golf MKIV, I’m just changing the subwoofer and I’m not using a backup battery.
The goal is to preserve the OEM look as posible (that’s why I sold my 12W6v2), the only thing that’s going to break this rule is the front system because the mids an tweeters are going to be in the A pillars. The OEM Head Unit will will stay in place.
The process will be very slow as I don’t have enough time and I want to do everything right and just one time, avoiding an endless install in which I change my mind every month ( I know, we all wish that was possible…)
This is the equipment to be installed:
- JBL MS-8
- JL Audio HD 900/5
- Focal 165 KRX3
- JL Audio 13TW5-3 (I don’t have it yet)
-Dynamat for the doors and the cargo área (I don’t have it yet)
Equipment I possibly add:
-Aftermarket battery
-Set of good coaxials for the rear fill.
The first part of the install is the subbox and the amp rack, everything under a false floor preserving the spare tire is the goal.
First of all this is the car (sorry for the iPhone pics, I promise I’ll get a camera soon):
The hatch área, there you can see the net that I’m taking as the limit in height for the rack:
The entire rack will be bolted to these existing bolts.
I made some sketches of the install in order to define the lay out.
This is a lateral view:
I already have some work done I’ll be uploading the pics this weekend.
Saludos.
MS-8... Focal Utopia Be drivers... JL Audio 13TW5-3... JL Audio HD900/5... JL Audio Interconnects... Kicker power cable
Hello guys, thanks for the kind words. I haven’t had time to work on the install so I’m just gonna show you the pics of the work I already have done.
Firts, this is the 12mm MDF board that is going to work as the base for the amp and sub rack. I chose that thicknes because I want to keep the weight at minimum. You can see that I draw where I needed to cut.
Here is the board already cut.
The rack will be lifted with the help of some shocks and hinges, as I did it with the rack in my Golf, so I added the bases where the hinges are going to be bolted.
Here you can see the rack floor presented on the base and if you look at the corners you can see the metal pieces that will be used to bolt everything to the car.
Very nice! That way you get to keep your spare wheel as well. I couldn't do that in my install, even if I used any of my shallow-mount subs there would be no space for the enclosure; my processor and amps are huge.
Thanks man, the spare tire is very necessary here in México city, the streets are in very bad shape
The X overs where going to be installed at the sides of the sub box.
As you can see the space is tight and I might add another set of Xovers from the rear chanels in the future, so this is the first change in the install, I will try to make the x overs fit under the MS-8 and HD900/5.
If I manage to do this I would have enough space to add another set of (smaller) Xovers in the future.
That’s all for now, I wasn’t kidding when I said this was going to be a very slow built.
Saludos.
I made some space for the Xovers, not exactly perfect cuts but is my first time with the router and that part of the install is going to be out of sight .
I added hinges to the amp rack in order to get easy acces to the Xovers for adjusments.
The shock absorbers will use these bolts, so I did some adjustments so they can fit.
I already cut the cover for the rack so you can get an idea of how everything is going to look.
I Still need to finish with the shock absorbers, make some adjustmens on the height of some parts (you can see the amp cover does not sit perfect) and get the grills for the sub and amp covers, once I have that I can put some paint and carpet to the rack and start mounting the equipment.
Saludos.
2012 MECA World Finals Street National Runner Up!!!
2012 MECA Street National Points Champion!!!
2012 MECA Street Georgia State Champion!!!
2011 MECA Street Georgia State Champion!!!
Hello guys, good news, I had some free days so I made some progress, bad news, I was in such a hurry that I didn’t take enough pics of the process, sorry.
The rack was painted in flat back and placed into the hatch…
Frames for the equipment were carpeted, although I could not find the right colors. Frames in light gray and the main cover will be black. I’ll try to find the right color later.
The shock absorbers didn’t work, the ones I bought are too strong for the rack, I think the ones I used in the Golf were a lot weaker , I’ll see what can I do later.
The next weekend I’ll carpet the main cover, run the speakerwire and make the connections to the OEM HU, completing the firts satage of this install using the OEM speakers, the Focal’s will have to wait.
Saludos.
Hello, some pics of the current state of the install. I still haven’t found the carpet in the right color nor the grill to make the covers, so, for now, the sub is protected for the JL grill and the amp & MS-8 are uncovered.
The HU has a noisy audio input from the USB that I can’t live with, so It might be replaced when everything else is complete. I’m thinking about the RNS-510 but it is very expensive with the iPod controller so an all-in-one aftermarket unit could be a better option, I have to think about it because I don't want to be changing HU's as I usually do.
The system is conected to the OEM speakers and it performs very good, I’m expecting great results with the KRX3 or a 2 way set, if I decide to go that way. The sound it produces with the rear speakers as laterals in the MS-8 is very spacious (Best description I can think of) It is very obvious that the out of face sound is sent to those speakers because in some songs that’s very obvious, but I like it
It performs very well considering its shape and the reduced volume of the box, very clean sounding subwoofer, of course it can't reach the output of the W6 but it has enough to shake my car
your attention to detail on EVERYTHING comes through the screen loud and clear...i really appreciate it when i see small details on the bare wood build up portions of hte install, like how you took time to sand and round off the edges of the wood, how things are cut straight even when they will never be seen...
