2011 MINI Cooper S SQ build - HAT, JL, Alpine, Knu, SecondSkin, SDS, PWK - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 11-21-2011   #1
Neil_J's Avatar
Rep Power: 95 Neil_J is a jewel in the roughNeil_J is a jewel in the roughNeil_J is a jewel in the roughNeil_J is a jewel in the roughNeil_J is a jewel in the roughNeil_J is a jewel in the roughNeil_J is a jewel in the roughNeil_J is a jewel in the roughNeil_J is a jewel in the roughNeil_J is a jewel in the roughNeil_J is a jewel in the rough
Default 2011 MINI Cooper S SQ build - HAT, JL, Alpine, Knu, SecondSkin, SDS, PWK
I humbly submit to you my first SQ build. I will get into the details in a minute, but first, here is some hardcore auto pornography:
+ YouTube Video
2011 MINI Cooper S :: [build log]
HAT L6SE, L3SE, L1 Pro R2. 4x Alpine SWR-843D, JL XD700/5, XD500/3, Alpine H800, RUXC800, CDA-117
Neil_J is offline   Reply With Quote Quick reply to this message
Old 11-21-2011   #2
Neil_J's Avatar
Default Re: 2011 MINI Cooper S SQ build - HAT, JL, Alpine, Knu, SecondSkin, SDS, PWK
OK, now for the boring part
Vehicle:
2011 Chili Red MINI Cooper S, custom ordered May 9 and built in the Oxford England plant, delivered June 23.
Complexity of installation:
11 out of 10. Probably a few watts / CPU cycles away from finding the Higgs Boson.
Competency of installer (me):
Pretty damn competent until my fifth beer or so.
Goals:
  1. To get as many Ess Que's as possible. These are mythical and subjective, so see below for my definition and requirements.
  2. It should be able to get LOUD but still sound good doing so. I don't trust people who don't listed to music at loud volumes from time to time. If I'm going through the trouble of recreating a concert-like soundstage, I would like to reproduce the concert-like sound pressure level as well. Admittedly, I am also a basshead and love the occasional Dubstep song or two.
  3. To have as much fun as possible working on my car, which is sort of a Zen thing for me. Not so much an ends to a means, but rather a journey of gathering real-world experience and enlightenment. The fact that I get something cool at the end is a bonus.
Install Summary:
  • Sound deadening: The stock MINI does make use of some clever sound deadening techniques, but they just don't cut it. Will be done in multiple stages: First, the front doors, hatch area and rear quarter panels. Then, the floor, firewall, and headliner. A few packs of Second Skin audio Damplifier Pro CLD tiles have been purchased, and several rolls of Sound Deadener Showdown closed-cell foam and mass-loaded vinyl.
  • Head unit: Currently using the stock MINI head unit. I've taken frequency response measurements with a scope and test tone CD, and they look like shit. The radio equalizes the signals pretty hard to overcome the stock 3" speakers, driving most frequencies into cutoff if the volume is too high, with nasty harmonics up in the khz region. There is no volume readout on the rotary encoder, so I must be cautious never to turn the knob within 9 clicks of full volume. 20 Hz is attenuated to almost nothing. Obviously some serious processing will be needed, which leads us to…
  • DSP/Processing: The system was built around a JBL MS-8. My home system has Pro Logic surround and quite like it. The MS-8's Logic7 processing was a major selling point, along with the center channel and binaural phase averaging. I'm fully confident in my ability to tune a full-manual DSP box with TA, EQ, crossover settings, etc., but I'll still be happy if the MS-8 does all this for me.
    MS-8 Channel 1: FL midrange L3SE, tweet L1 Pro R2
    MS-8 Channel 2: FR midrange L3SE, tweet L1 Pro R2
    MS-8 Channel 3: FL midbass L6SE
    MS-8 Channel 4: FR midbass L6SE
    MS-8 Channel 5: RL wideband TB3" and midbass SLS6
    MS-8 Channel 6: RR wideband TB3" and midbass SLS6
    MS-8 Channel 7: FC midrange L3SE, tweet L1 Pro R2
    MS-8 Channel 8: Subwoofer, 4x SWR-843D
  • Front stage: Hybrid audio Legatia SE series three-way in the doors/a-pillars, and eventually a center channel (this will be very challenging to integrate into the dash, but should be well worth it).
    • L1 Pro R2's in custom aluminum A-pillar pods (made by diyma user Headshok). These are by far the crown jewel of my system. They sound positively lurvely.
    • L3SE's temporarily mounted in the stock door location, and eventually in fiberglassed A-pillar pods.
    • L6SE's in the stock 100mm door location. Lots of fabrication required to squeeze these in.
  • Rear stage: I'd like to accomplish two mutually exclusive things with my rear stage. I will be able to flip a switch to do either: #1 provide Logic 7 surround, or #2, provide midbass reinforcement to the front L6SE's at the sacrifice of soundstage. I'll accomplish this with a relay and some custom RCA cables.
    • Tang Band TB W3-1364SA widebanders in custom ear-level pods
    • Peerless SLS 830946 6.5" mounted in the stock rear 6x9 location near the passenger's elbows
  • Sub stage: I chose 4x Alpine SWR-843D's for a few reasons: they are super cheap, have shorting rings, low Le, and get loud without much distortion. I am trying to eliminate muddiness, boominess, and harmonic distortion / non-linearities as much as possible (the idea here being that "up-front-bass" can be achieved as long as higher frequencies do not give away the true position of the subwoofers). Step response should be instantaneous. Using four of them should minimize excursion. I would also like the box to dig as low towards 20 Hz, although I'm not sure if this can be pulled off. Pete from PWK Designs is currently designing a sealed box to meet these requirements. It will be placed in the hatch / storage area in a false-floor setup, with the speakers pointing towards the roof.
  • Amp rack: I chose to go with four of the JL Audio XD series amplifiers. Amplifier size is the biggest requirement here, with low THD/IMD a close second. The MINI's hatch area is big enough for a grocery bag or two. This ruled out a lot of great amps that were simply too large. They will be set up as follows:
    JL XD700.5 #1, channel #1: FL tweeter L1 Pro R2 (4 ohm, 75W)
    JL XD700.5 #1, channel #2: FR tweeter L1 Pro R2 (4 ohm, 75W)
    JL XD700.5 #1, channel #3: FL midrange L3SE (4 ohm, 75W)
    JL XD700.5 #1, channel #4: FR midrange L3SE (4 ohm, 75W)
    JL XD700.5 #1, channel #5: Subwoofer #1 (2x 4-ohm voice coils in parallel, 300W)
    JL XD700.5 #2, channel #1&2: FL midbass (bridged, 4 ohm, 200W)
    JL XD700.5 #2, channel #3&4: FR midbass (bridged, 4 ohm, 200W)
    JL XD700.5 #2, channel #5: Subwoofer #2 (2x 4-ohm voice coils in parallel, 300W)
    JL XD500.3 #1, channel 1: FC tweeter L1 Pro R2 (4 ohm, 75W)
    JL XD500.3 #1, channel 2: FC midrange (4 ohm, 75W)
    JL XD500.3 #1, channel 3: Subwoofer #3 (2x 4-ohm voice coils in parallel, 300W)
    JL XD500.3 #2, channel 1: RL midbass SLS6 (4 ohm, 75W)
    JL XD500.3 #2, channel 2: RR midbass SLS6 (4 ohm, 75W)
    JL XD500.3 #2, channel 3: Subwoofer #3 (2x 4-ohm voice coils in parallel, 300W)
    JBL MS-8, channel 5: RL sideband TB3" (8 ohm, 15W)
    JBL MS-8, channel 6: RR sideband TB3" (8 ohm, 15W)
  • Crossover settings:
    • Subsonic filter: 20 Hz, 24dB/octave Linkwitz-Riley via MS-8
    • Sub to midbass: ~63 Hz, 24 dB/octave Linkwitz-Riley via MS-8
    • Midbass to midrange: ~200 Hz, 24 dB/octave Linkwitz-Riley via MS-8
    • Midrange to tweet: ~4-5KHz, 12 dB/octave State-Variable / Sallen-Key via JL XD700/5
  • Installation:
    • The installation theme will make heavy use of genuine carbon fiber, chrome, carbon techflex, and possibly a chili-red fiberglass panel or two
    • The passenger compartment and dash must remain stock. The hatch area must look stock after a carpet-covered panel is placed over it.
    • All RCA and signal cabling will be DIY'd using red Canare Star Quad signal cable. All RCA and signal cabling will have its braided shielding tied to chassis ground on the transmitting end
    • All exposed cables will be wrapped in carbon techflex
    • All unexposed cables will be wrapped in fleece tape
    • All cables will be secured every 6 inches using stock BMW/MINI wiring mounts
    • All LED's will be changed to amber-orange to match stock MINI color scheme
    • All parts should be USA-made or purchased from a local or privately-owned company when possible
Old 11-21-2011   #3
Neil_J's Avatar
Default Doors
The stock MINI midbass speakers were roughly 5 inches or so diameter. After seeing necrophidious's Build log, I decided to follow suit and squeeze a pair of 6.5's in their place.
First, remove the door skin and enlarge the basket hole.
Then, I designed a set of MDF rings in CAD and had them laser cut via Ponoko Personal Factory. I'm still trying to dig up a picture of the laser cut sheet as it arrived.
Non-hardening modeling clay was liberally applied to keep everything air-tight, and add some mass
Now I need to fabricate some badass custom grills
Old 11-21-2011   #4
Neil_J's Avatar
Default Power wiring
The BMW/MINI engineers were nice enough to provide a watertight passage through the firewall that was large enough for the Knu 1/0 AWG Kollossus Fleks Kable
Fleece tape will be added on top of the techflex, and will be routed down the passenger side of the vehicle
Techflexed and heat-shrunk. The fuse block is an Audison/Connexion SFH-11WP. I hadn't decided how the heck to mount it at this point. I will probably be making a custom mount sometime in the future. For now, it's ziptied into a pretty inconvenient spot underneath the plastic cowl.
Old 11-21-2011   #5
astrochex's Avatar
Rep Power: 172 astrochex has a reputation beyond reputeastrochex has a reputation beyond reputeastrochex has a reputation beyond reputeastrochex has a reputation beyond reputeastrochex has a reputation beyond reputeastrochex has a reputation beyond reputeastrochex has a reputation beyond reputeastrochex has a reputation beyond reputeastrochex has a reputation beyond reputeastrochex has a reputation beyond reputeastrochex has a reputation beyond repute
Nice work!
I hope the stock HU does not prevent you from meeting your SQ dreams.
You've given me an idea to remount my midbass on the outside of the door panel. I also look forward to your grill ideas.
Alpine CDA-9887 | Imagine I6 midbass, L1V2, P69, GZHA 4150XII, and B2 Precision waiting for install |
astrochex is offline   Reply With Quote Quick reply to this message
Old 11-21-2011   #6
Neil_J's Avatar
Default Sound Deadening part 1
Care package from Don at Sound Deadener Showdown. Not shown are the packs of Second Skin audio Damplifier Pro
Removed stock quarter panels
I gave him a beard:
My favorite way to do the Damplifier Pro. Cut in half. Then cut into 3" and/or 2" strips. I use a hobby self-healing cutting board and a carpeting razor blade.
All of the stock sound deadening is being removed. First go at it with a gasket scraper until it looks like above. Then remove residue with 3M General Purpose Adhesive Remover. Let Car air out for about a day.
MLV rough-cut to size
Passenger door panel
Old 11-21-2011   #7
Neil_J's Avatar
Originally Posted by astrochex View Post
I hope the stock HU prevents you from meeting your SQ dreams.
That's kind of a mean thing to say, lol
The stock HU won't really prevent me from doing anything. I'll be wiring an Apple Airport Express under the seat, which will give me A2DP audio streaming from my iPhone and iPad directly into the JBL MS-8 aux input. I don't listen to CD's or FM radio, and XM/Sirius never sounded great to begin with. This should at least guarantee me a direct signal path where it counts (my iTunes collection)
Old 11-21-2011   #8
Neil_J's Avatar
Default Door Midbass wiring
Stock midbass wiring was ~20 or 22 AWG. All door wiring runs through a door jamb connector, which makes it difficult to upgrade. Fuck you, BMW/MINI!
12 AWG Dayton Speaker Wire was spliced into the harness within 1" on both sides of the connector. Ohm's law works in my favor here... The voltage drop across the pins and 1" 22AWG pigtails isn't much in the grand scheme of things.
Old 11-22-2011   #9
quality_sound's Avatar
Rep Power: 234 quality_sound is just really nicequality_sound is just really nicequality_sound is just really nicequality_sound is just really nicequality_sound is just really nicequality_sound is just really nicequality_sound is just really nicequality_sound is just really nicequality_sound is just really nicequality_sound is just really nicequality_sound is just really nice
I can't wait to see how you squeeze 4 amps in here. I'm going to do dual HD900/5s in my Clubman and that's been interesting to lay out. Are you going to use the underseat areas at all.
Old 11-22-2011   #10
Rep Power: 79 whodat90 will become famous soon enoughwhodat90 will become famous soon enoughwhodat90 will become famous soon enoughwhodat90 will become famous soon enoughwhodat90 will become famous soon enoughwhodat90 will become famous soon enough
You are the king. I've been wondering every single time I saw someone drill out the connector and mash a bunch of wires through why they didn't just add pins to the empty sockets. So much cleaner and more serviceable.
whodat90 is offline   Reply With Quote Quick reply to this message
Old 11-22-2011   #11
Neil_J's Avatar
The JBL MS-8 ain't a looker, so it's going under the passenger seat
The four amps are about 37" across, so they should fit perfectly above the four subs in the false floor box. I've modeled it up in CAD, and it looks pretty damn sweet. The wiring will be exposed like those oldschool installs did it, where they feed down through a rubber grommet past a plywood floor. All the wiring will go to hidden terminal blocks on the underside and will be able to be rerouted to try different configurations.
Old 11-22-2011   #12
Rep Power: 123 slade1274 will become famous soon enoughslade1274 will become famous soon enoughslade1274 will become famous soon enoughslade1274 will become famous soon enoughslade1274 will become famous soon enoughslade1274 will become famous soon enough
Where in florida?
build log 08 BMW 135i
slade1274 is offline   Reply With Quote Quick reply to this message
Old 11-22-2011   #13
Neil_J's Avatar
Melbourne. If anyone else from Florida is up for a mini diyma get together, let me know...
Old 11-22-2011   #14
ecbmxer's Avatar
Rep Power: 88 ecbmxer will become famous soon enoughecbmxer will become famous soon enoughecbmxer will become famous soon enoughecbmxer will become famous soon enoughecbmxer will become famous soon enoughecbmxer will become famous soon enough
Looking good!
2010 Subaru WRX: H-Audio Enigma, Trinity and Ebony, sealed IDQ10v3, Massive Audio NX5 (sub+midbass) and NX4 (mid+tweet) amps, Alpine INA-W900BT with H100 Imprint, RAAMat/Ensolite, KnuKoncept/DIY wiring
ecbmxer is offline   Reply With Quote Quick reply to this message
Old 11-22-2011   #15
Interest- St. Pete area here- just across the state.
Old 11-22-2011   #16
astrochex's Avatar
I missed my crappy typo....
Not many MINI builds out there, and yours is really squared away.
Do you plan on competing?
Old 11-22-2011   #17
GLN305's Avatar
Car Audio Junky
Rep Power: 804 GLN305 has a reputation beyond reputeGLN305 has a reputation beyond reputeGLN305 has a reputation beyond reputeGLN305 has a reputation beyond reputeGLN305 has a reputation beyond reputeGLN305 has a reputation beyond reputeGLN305 has a reputation beyond reputeGLN305 has a reputation beyond reputeGLN305 has a reputation beyond reputeGLN305 has a reputation beyond reputeGLN305 has a reputation beyond repute
I just bought a used 2008 Cooper S and I am accumulating equipment right now for it. Interested to see what you come up with in the boot.
GLN305 is offline   Reply With Quote Quick reply to this message
Old 11-22-2011   #18
t3sn4f2's Avatar
Rep Power: 220 t3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to all
Nice Build man. I'm really interested in your venture to reverse engineer the MS-8's common functions, which you mentioned in another thread. Hope that goes well.
Question about the APE idea. Did you mean wireless digital audio (ie Apple encrypted wireless ALAC transmission) instead of Bluetooth audio A2DP? Because I don't think the APE has that bluetooth or any bluetooth option really.
If so and assuming you'll be running Airplay, I then suggest you see how your iphone will function when it is not connected to the internet on the APE's end. Naturally, how it would be in a Car solution. I've tried my iphone with my home router unplugged from the cable modems input. It messed up a bunch of apps like weather and maps. Dunno how it would behave today though after so many OS revisions though. Just a heads up.
Have you considered hardwired solutions like a Pure i-20? Better quality analog out, 2V RMS output, digi out option, DC input, VERY fast boot/sync, affordable ($100), and won't compromise the phones network functions. It also doesn't loose sync while pausing and trackfowarding which on all but the most competant DAC will result in pops and ticking noises.
Pure i-20 Digital iPod Dock Analog Output RMAA Measurements
Old 11-22-2011   #19
Rep Power: 117 MaxPowers will become famous soon enoughMaxPowers will become famous soon enoughMaxPowers will become famous soon enoughMaxPowers will become famous soon enoughMaxPowers will become famous soon enoughMaxPowers will become famous soon enough
Nice so far! In the next few weeks I will be putting a Pioneer Stage 4 3 way in my chili red/silver Coupe. How much work did you do getting the 6.5" in the doors, any problems with depth? Do you have any more door pics?
MaxPowers is offline   Reply With Quote Quick reply to this message
Old 11-22-2011   #20
GLN305's Avatar
Car Audio Junky
I removed my door panels and measured the dimensions. To the front edge of the factory speaker, there is 3.5'', a 6.5'' mid will fit BEHIND the panel easily. If you go on top of the panel, you have more than 4'' of depth. For the midrange in the door, the biggest OD is 4.5'' and the opening is 3 3/4'', depth without trimming is 2'', with minor trimming is 2.5''.
Old 11-22-2011   #21
Neil_J's Avatar
No worries. I will hopefully be competing in IASCA and other competitions. I've read the rules and think I may be able to get a competitive edge in the rookie/amateur class for the first year or two, for both sound quality and install points. after that who knows, I'd probably go broke trying to keep up with the other advanced classes.
That's still in the cards, after I get everything installed. The idea is to add an Atmega328 microprocessor between the display and MS-8, so that I can have instant access to certain functions without having to navigate through menus. Unfortunately it will be a one-off project with no chance of sharing the source code or schematics for legal reasons.
iPhones and iPads should be able to access an Apple Airport Express ad-hoc without much trouble. The Airport Express has a line audio output that will connect to the MS-8. The hardest part is getting Power to it (I'll be hacking it open to feed it a regulated 5V source rather than using a 115V AC inverter). I have one and have played around with it a bit.. I've seen it done here on diyma without much issue. I'll definitely check out the Pure i-20. I miss my Pioneer deck that had really good ipod support. With the A2DP you have to manually start/stop and select the wireless access point every time you start your car. Kinda lame for day-to-day driving, but still worth it on long drives or SQ judging lanes.
I've put a metric fuck-ton of work into the doors… I could write a book on it. Still not even 50% done with them at this point. Probably 20-30 hours per door. That's including designing the MDF adapter, upgrading the cabling, sound deadening, and research. I will be elaborating on the construction over the next few days/weeks.
Old 11-22-2011   #22
derickveliz's Avatar
Rep Power: 107 derickveliz will become famous soon enoughderickveliz will become famous soon enoughderickveliz will become famous soon enoughderickveliz will become famous soon enoughderickveliz will become famous soon enoughderickveliz will become famous soon enough
Awesome!
My system may not blow your ears, but it will sweeten your senses.
Mercedes Benz CLA 250, Pioneer P-99, IDQ12d4v3 Subwoofer, ... ID min Horns, 6.5" Midbass!
derickveliz is offline   Reply With Quote Quick reply to this message
Old 11-23-2011   #23
Rep Power: 0 tilsim will become famous soon enoughtilsim will become famous soon enoughtilsim will become famous soon enoughtilsim will become famous soon enoughtilsim will become famous soon enoughtilsim will become famous soon enough
Great job being done.
Kenwood ddx8036bt; focal polyglass 165v30; focal access 130CA1; JVC CS CN100; Infinity Ref 1250w; Zapco Ref. 360.4; Pioneer gm6400f; Innovation 50.2; Streetwires & Dynamat extreme..
tilsim is offline   Reply With Quote Quick reply to this message
Old 11-23-2011   #24
Rep Power: 104 Oblivi0us will become famous soon enoughOblivi0us will become famous soon enoughOblivi0us will become famous soon enoughOblivi0us will become famous soon enoughOblivi0us will become famous soon enoughOblivi0us will become famous soon enough
Send a message via AIM to Oblivi0us
Have you considered an iStreamer? It will charge your iPhone/iPad and give you an analog output. It's what I was looking to use for my iPad integration.
Oblivi0us is offline   Reply With Quote Quick reply to this message
Old 11-23-2011   #25
Rep Power: 67 bigdexxx will become famous soon enoughbigdexxx will become famous soon enoughbigdexxx will become famous soon enoughbigdexxx will become famous soon enoughbigdexxx will become famous soon enoughbigdexxx will become famous soon enough
I really like where your Build is going, the attention to detail is fantastic. I've always wanted a Mini, but I never will pull the trigger on one. I look forward to this Build and keep up the great work.
2014 Toyota Prius (Three) Blizzard Pearl
Saving gas and gas savings making my car payment
bigdexxx is offline   Reply With Quote Quick reply to this message
