Old 02-18-2012   #26
Rep Power: 58 vwguy383 will become famous soon enoughvwguy383 will become famous soon enoughvwguy383 will become famous soon enoughvwguy383 will become famous soon enoughvwguy383 will become famous soon enoughvwguy383 will become famous soon enough
Default Re: IBciv IZ gone Loco for some 8ohm Drivers :o
How do those SS sound?
Thanks
Justind
vwguy383 is offline   Reply With Quote
Old 02-18-2012   #27
IBcivic's Avatar
Back Yard Installer
Rep Power: 98 IBcivic has a spectacular aura aboutIBcivic has a spectacular aura aboutIBcivic has a spectacular aura aboutIBcivic has a spectacular aura aboutIBcivic has a spectacular aura aboutIBcivic has a spectacular aura aboutIBcivic has a spectacular aura aboutIBcivic has a spectacular aura about
The mini dsp is being used as a 2-way x-over for the mid-range and tweeters, Left and Right.
Center channel it is used as a 3-way x-over
Press here
IBcivic is offline   Reply With Quote
Old 02-18-2012   #28
IBcivic's Avatar
Back Yard Installer
Thanks
Justind
Have not fired them up, yet
There were a few good reviews about the ref 4.920 that were done on DIYMA
Press here
Old 02-18-2012   #29
You've got a lot of faith in them if you haven't fired them up yet!! Can't wait to hear how they sound.
Thanks
Justind
Old 02-18-2012   #30
IBcivic's Avatar
Back Yard Installer
Thanks
Justind
Sure, no problem, it's only a 23 hr drive
Press here
Old 02-18-2012   #31
Rep Power: 21 Hdale85 will become famous soon enoughHdale85 will become famous soon enoughHdale85 will become famous soon enoughHdale85 will become famous soon enoughHdale85 will become famous soon enoughHdale85 will become famous soon enough
Woot I may of found a pair of 830881's
How do you like yours? I was looking at those sound stream amps as well, but trying to work a deal for an X-Ion 70.6 first.
Hdale85 is offline   Reply With Quote
Old 02-19-2012   #32
InjunV18's Avatar
Rep Power: 65 InjunV18 will become famous soon enoughInjunV18 will become famous soon enoughInjunV18 will become famous soon enoughInjunV18 will become famous soon enoughInjunV18 will become famous soon enoughInjunV18 will become famous soon enough
You keep changing your name! But I found ya... Lookin good man, excited to see the results
Stupid boat
InjunV18 is offline   Reply With Quote
Old 02-19-2012   #33
IBcivic's Avatar
Back Yard Installer
Hey Vee! Still working on that mini?
Press here
Old 02-22-2012   #34
InjunV18's Avatar
Man I did a buddy's Mini and the improvement was great. I'm desperate to start mine but I'm doing another guys 68 Firebird vert right now. Will finish in early March and then will start the Mini. Just acquiring all the parts now
Stupid boat
Old 02-22-2012   #35
IBcivic's Avatar
Back Yard Installer
I hope you plan posting your buddies' builds, you are very creative and it would be a shame, not to share...
Press here
Old 02-22-2012   #36
TSAudio
Installer
Rep Power: 34 computerjlt will become famous soon enoughcomputerjlt will become famous soon enoughcomputerjlt will become famous soon enoughcomputerjlt will become famous soon enoughcomputerjlt will become famous soon enoughcomputerjlt will become famous soon enough
so your signal is going from digital (cd) to analog (rca outs) to digital (ms8 a/d input), to analog (ms8 out) to digital (minidsp input) then back to analog before you hit the amps?
yikes
computerjlt is offline   Reply With Quote
Old 02-22-2012   #37
IBcivic's Avatar
Back Yard Installer
yikes
I think you have a few too many "analog/digital" in your comment...is that to increase the YIKES factor?
Maybe you should have started at the recording studio....
Press here
Old 02-22-2012   #38
TSAudio
Installer
i was just going off of your pic that shows the setup.
and it shows d-a, a-d-a, a-d-a (the two a-d-a being ms8 and minidsp).
i'm not hating; that's just a lot of unnecessary conversions going on there; each time you lose resolution. imo i'd go with a analog active xover between the ms8 and the amps (unless you plan on using some ta or crazy slopes in the minidsp).
i'm not a fan of the ms8 as its only analog in; from experience the longer you keep the signal digital the better and the fewer d-a a-d conversions you have in the chain the better imo.
Old 06-03-2012   #39
IBcivic's Avatar
Back Yard Installer
CLEAR!
Press here
Old 06-03-2012   #40
IBcivic's Avatar
Back Yard Installer
I scored a 1 ft.sq. slab of 3/4" solid pvc for free. So I decided to use this to make some pillar baffles for my new drivers.
Here are a couple of test fitting pics, before I make look better.
I will be recycling my existing pillar pods, since their internal volume is perfect for the peerless HDS 4 driver.
I already stripped the previous wooden baffle, from the f-glass and tested the bonding strength between pvc and f-glass, using a poly-urethane glue.
Press here
Old 06-03-2012   #41
benny's Avatar
turn the gain up dummy
Rep Power: 85 benny is just really nicebenny is just really nicebenny is just really nicebenny is just really nicebenny is just really nicebenny is just really nicebenny is just really nicebenny is just really nicebenny is just really nicebenny is just really nicebenny is just really nice
lookin good. I'm actually headed out to the garage right now to whittle out a pair of similar baffles for dayton rs100-t8s and morel dms30s
benny is offline   Reply With Quote
Old 06-03-2012   #42
Nice work! Can't wait to see what they look like up there.
Old 06-03-2012   #43
IBcivic's Avatar
Back Yard Installer
Thanx, guys!
The 2nd baffle that I made looks much better, so I will pick up some more pvc tomorrow to make 2 more (3 total...left, right and center).
Press here
Old 06-04-2012   #44
Rep Power: 93 Jroo will become famous soon enoughJroo will become famous soon enoughJroo will become famous soon enoughJroo will become famous soon enoughJroo will become famous soon enoughJroo will become famous soon enough
A quick question, and by no means am I bashing anything you are doing. I was looking at the diagram and wondering why run the ms8 at all instead of just getting another mini dsp? I thought the dsps did everything the ms8 could do?
Jroo is offline   Reply With Quote
Old 06-04-2012   #45
IBcivic's Avatar
Back Yard Installer
I already have the MS-8 and I just want to see if I can make it better or not.
Press here
Old 06-04-2012   #46
Notloudenuf's Avatar
Rep Power: 72 Notloudenuf is on a distinguished roadNotloudenuf is on a distinguished roadNotloudenuf is on a distinguished roadNotloudenuf is on a distinguished road
I am very interested in your take on the Vifa ring rad tweeter you have installed.
Please post back with your opinion.
Notloudenuf is online now   Reply With Quote
Old 06-04-2012   #47
IBcivic's Avatar
Back Yard Installer
Picked up another 2 sq ft of 3/4" PVC at lunch and dug up the perfect looking screws for the job. M4 zinc oxide button heads.
Press here
Old 06-14-2012   #48
IBcivic's Avatar
Back Yard Installer
I finally had time to glass my PVC baffles in.
Things are not pretty, yet...but you get the picture
Left, Right and Center channel are shown (above dash drivers)
Press here
Old 06-15-2012   #49
IBcivic's Avatar
Back Yard Installer
A little side project....
A few weeks ago, I scored a $50 H-D gift card, at work. So I decided to use it to finance my home stereo speaker build. I was able to get a sheet of 3/4 mdf , a box of screws and have them cut all the panels to the sizes that were needed.
The woofer is a Peerless xls/hds8. I scored 4 of them, bnib, when they were being sold on the forum for roughly $75/pair.
Enclosure volume is 1.28 cu.ft, tuned @ 29hz.
Here is my first box, in the rough.
It still needs to be finished and the port tube is missing.
Here is a semi finished pic of my home speaker project.
I still need to figure out a grill that will give the design some character and raise the funds for some Solen designed X-overs.
Press here
Old 06-15-2012   #50
basshead's Avatar
Rep Power: 70 basshead has a spectacular aura aboutbasshead has a spectacular aura aboutbasshead has a spectacular aura aboutbasshead has a spectacular aura aboutbasshead has a spectacular aura aboutbasshead has a spectacular aura aboutbasshead has a spectacular aura aboutbasshead has a spectacular aura aboutbasshead has a spectacular aura about
Be careful not to break all that nice chinaware with heavy bass track
2012 IASCA SBN SQi Champion "Pro/Am"
2011 IASCA North American Runner-Up and SQi Champion "Pro/AM"
2011 IASCA Canadian Champion "Pro/Am"
2010 IASCA North American Champion "Rookie"
basshead is online now   Reply With Quote
