Old 08-17-2012   #1
Octave
Rep Power: 35 Octave will become famous soon enoughOctave will become famous soon enoughOctave will become famous soon enoughOctave will become famous soon enoughOctave will become famous soon enoughOctave will become famous soon enough
Default Work truck meets Esotar.....wait WHAT!!
A little unusual one this time. David brought in his work truck for a full system. Not unusual till you hear the equipment. All DynAudio Esotar that's right Esotar. David wanted a serious upgrade to the system he had and I think he got it. We will be adding the Esotar E110, E650 and E1200 in a full active set up.
Now for starters he had another shop do the first install which to say was a little lack luster. I had to gut all the previous wiring before I started. This type of stuff just infuriates me. This is why I tell people you need to get picks everything a shop does.
With the truck back to stock so to say I started in with the doors. The doors will be getting a layer of Hush Mat Ultra sound deadening on the outside skin and inside skin along with a layer of Silencer Megabond foam insulation on the inside skin. The doors will be getting the E650's as well.
Before I did the inside skin I had to close up the big holes in the door skin. I tried something new this time around. I used a piece of 1/8" ABS that I was able to heat form to the contours of the door. With a few screws I had made panels that could be sound deadened and removed to service the door if need be.
Focal | Mosconi | Illusion Audio | Tru Technology | Zapco | Arc Audio | DynAudio | Digital Designs | Rainbow Audio
Mobile Electronics Magazine "Top 100 Installer" 2010, 2011, 2012
www.OCTAVEONLINE.com
Octave is offline   Reply With Quote
Old 08-17-2012   #2
Octave
Default Re: Work truck meets Esotar.....wait WHAT!!
With that done I moved on to the mounting rings for the woofers. True to form I used 3/4" plexiglas and used rivet nut fasteners to fasten them to the doors.
with those done I could move on to finishing the door.
Old 08-17-2012   #3
Octave
Up next was the custom a-pillars to house the E110's. They were laser aligned to the center of vehicle at the listening level as well.
Old 08-17-2012   #4
Octave
I made removable grill covers to conceal and protect the tweeters for daily driving use. The inside edge of the ring I radius to help the sound waves roll off to reduce reflection.
Now as usual with me attention to detail is off the richter scale. On advice from Steven Hill at Straight wire I applied foam tape to the chassis of the truck then ran all the wiring over it will strapping it down with more foam tape. The process is to eliminate mechanical noise from entering the cables. Yes I said mechanical noise. Steve told me that even though you may strap a wire down but it still moves against the chassis of the vehicle and can induce mechanical noise. Now I learn something every day and this is new to me but it makes sense.
Old 08-17-2012   #5
Octave
While on a wiring kick I did the wiring harness for the radio. All connections were soldered and heat shrunk. On the aftermarket wiring harness it had speaker wires out so since I wasn't going to be using them I removed them from the harness. After everything was done fabric electrical tape was used to make it look more OEM.
David went with the Pioneer DEX-P99RS for processing. Now it being a SQ deck only it was a little different in size so a little playing around had to be done with the mounting kit. The radio had to be spaced out a bit to fit inside the dash but it doesn't stick out to far. I actual like the way it looks.
Last thing on the docket was the subwoofer enclosure. I used the BlackHole Stuff enclosure fill to improve the acoustics of the enclosure. This stuff (pardon the pun) does magic.
The E1200 in it's new home. I also made a removable grille for the subwoofer as well.
Old 08-17-2012   #6
Octave
David wanted to use the amplifiers from his previous install for now but a set of Arc Audio Se is on the way so I'll update this build when they go in. Since I was cleaning up everything I cleaned up the wiring going to the amplifiers. The amplifiers before were just screwed to the chassis of the truck this time I mounted them to a piece of carpeted MDF.
Now a final shot of everything installed.
As with the DynAudio Esotar the realism that is produced is something that needs to be experienced. Words don't do it justice but that's the DynAudio Esotar.
For more pics please visit Octave : Orlando and Central Florida source for high end car audio
Old 08-17-2012   #7
kizz's Avatar
Rep Power: 59 kizz will become famous soon enoughkizz will become famous soon enoughkizz will become famous soon enoughkizz will become famous soon enoughkizz will become famous soon enoughkizz will become famous soon enough
looks awesome! nice work. now the guy just needs to figure out how to work out of his truck
PPI Art A600.2, A404.2 & PPI P1000.1, FI X12, Alpine CDA-9887 Dyn Audio Esotar2 650, Dyn Audio Esotec MD130, Arc Audio PS8, JL Audio C5 4"
kizz is offline   Reply With Quote
Old 08-17-2012   #8
chithead's Avatar
That's What She Said
Rep Power: 87 chithead will become famous soon enoughchithead will become famous soon enoughchithead will become famous soon enoughchithead will become famous soon enoughchithead will become famous soon enoughchithead will become famous soon enoughchithead will become famous soon enough
I like the ABS access panel covers on the doors.
2012 Subaru Forester
2010 Dodge Ram R/T
chithead is offline   Reply With Quote
Old 08-17-2012   #9
Rep Power: 16 falstaff will become famous soon enoughfalstaff will become famous soon enoughfalstaff will become famous soon enoughfalstaff will become famous soon enoughfalstaff will become famous soon enoughfalstaff will become famous soon enough
Lookin good there Russ!
Looking forward to getting mine started!
falstaff is offline   Reply With Quote
Old 08-17-2012   #10
BuickGN's Avatar
Rep Power: 97 BuickGN is a name known to allBuickGN is a name known to allBuickGN is a name known to allBuickGN is a name known to allBuickGN is a name known to allBuickGN is a name known to allBuickGN is a name known to allBuickGN is a name known to allBuickGN is a name known to allBuickGN is a name known to allBuickGN is a name known to all
That's awesome. I miss my 650s already. It would definitely make going to work a little more exciting and I totally agree on the realism of the Esotar stuff.
'06 TL. Front stage- Dynaudio 110, 430, 182.... 2x AE IB15.....2x JL HD600/4, Infinity Digital 300, PS8....SecondSkin....
BuickGN is online now   Reply With Quote
Old 08-18-2012   #11
Rep Power: 24 Noobdelux is on a distinguished roadNoobdelux is on a distinguished roadNoobdelux is on a distinguished roadNoobdelux is on a distinguished roadNoobdelux is on a distinguished road
sweet install man
Noobdelux is offline   Reply With Quote
Old 08-18-2012   #12
jrhunkler's Avatar
Rep Power: 0 jrhunkler will become famous soon enoughjrhunkler will become famous soon enoughjrhunkler will become famous soon enoughjrhunkler will become famous soon enoughjrhunkler will become famous soon enoughjrhunkler will become famous soon enough
No Midrange? E430's?
jrhunkler is offline   Reply With Quote
Old 08-18-2012   #13
Niebur3's Avatar
Approved Vendor
High Definition Mobile Audio
Rep Power: 87 Niebur3 is a jewel in the roughNiebur3 is a jewel in the roughNiebur3 is a jewel in the roughNiebur3 is a jewel in the roughNiebur3 is a jewel in the roughNiebur3 is a jewel in the roughNiebur3 is a jewel in the roughNiebur3 is a jewel in the roughNiebur3 is a jewel in the roughNiebur3 is a jewel in the roughNiebur3 is a jewel in the rough
VERY well done!!!
Authorized Dealer for: Dynaudio / ARC Audio / PHASS / Hybrid Audio Technologies / Sinfoni / Tru Technology / Image Dynamics / Rainbow / Cascade Audio Technologies / IXOS / Straight Wire / and more...
www.hidefmobileaudio.com
http://www.facebook.com/pages/High-D...06364726072328
Niebur3 is offline   Reply With Quote
Old 08-18-2012   #14
jrhunkler's Avatar
I have a 2011 Tahoe, (same interior), with The Esotar E110 Tweeters in the dash, the Esotar E430's Midrange in the pillars, Esotec MW182's in the Doors, and a Esotar E1200 in the rear. I am a little surprised at the lack of output with the 1200. (had a ported W7JL 12" sub before this setup with Esotec 362 Dynaudio system, passive) I currently have everything hooked up active with Mosconi Amps / 6to8 Processor.
Thinking about selling it all and oing with Arc Audio Black Series / Amps. Opinions?
Old 08-18-2012   #15
Octave
Thanks guys for the compliments.
No. He wanted to go 2-way first with a possible addition of the 430's at a later date. First up though is new amps.
Lack of output??? I would have to ask what size box you have the 1200 in and how much power you have going to it? I will tell you selling it will be a mistake. If you're not happy, which is amazing, then I would have to say the install needs help. Shoot me some pics and a complete system layout with equipment and I'll see what I can do to advise you, octaveaudio@gmail.com. The Esotar is the pinnacle of speakers and for you not to be impressed by them is shocking.
Old 08-18-2012   #16
... Squirrel!!!...
Rep Power: 419 bikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond reputebikinpunk has a reputation beyond repute
class D amps? that'll NEVER sound good.
(I'm kidding, of course)
Great looking work. Everything looks really clean, man. Digging that sub enclosure!
Follow my blog:
http://medleysmusings.com/
Cool site with subwoofer testing:
Data-bass.com
Old 08-18-2012   #17
Niebur3's Avatar
Approved Vendor
Octave, what size enclosure did you end of using for the 1200?
Old 08-18-2012   #18
BuickGN's Avatar
You can't really compare a ported W7 to a sealed E1200 in sheer output.
Old 08-18-2012   #19
Octave
The enclosure ended up being 1.6cuft.
Agreed. I did a 12w7 in a sealed enclosure once. I don't know how they call that sub one of the finest SQ subs. Ugh. It gets loud that's it.
Old 08-19-2012   #20
sweefu's Avatar
Rep Power: 27 sweefu will become famous soon enoughsweefu will become famous soon enoughsweefu will become famous soon enoughsweefu will become famous soon enoughsweefu will become famous soon enoughsweefu will become famous soon enough
Oh those tweeters! Beautiful.
sweefu is offline   Reply With Quote
Old 08-19-2012   #21
Car Tunes Stereo Center
Installation Manager
Rep Power: 80 JayinMI will become famous soon enoughJayinMI will become famous soon enoughJayinMI will become famous soon enoughJayinMI will become famous soon enoughJayinMI will become famous soon enoughJayinMI will become famous soon enough
Funny part is, most of the 'SQ' guys I've run across that use JL subs, use W6's.
The W7's have a unique sound to them, much like 5 liter Mustangs. You can usually identify them before you see them. They always seemed to get loud, and go pretty deep, but there are definitely better options out there, especially for the money.
Jay
Originally Posted by nadams5755
weeeer wub wub wub weeer wub wub wub waaa
JayinMI is online now   Reply With Quote
Old 08-20-2012   #22
Chaos's Avatar
Addicted to 12 Volt
TAS Electronics
Technician
Rep Power: 122 Chaos will become famous soon enoughChaos will become famous soon enoughChaos will become famous soon enoughChaos will become famous soon enoughChaos will become famous soon enoughChaos will become famous soon enoughChaos will become famous soon enough
Beautiful work. I'm a little surprised that the client wouldn't go with a nice Ddin nav unit in the dash, especially in a "work" truck, but I bet it sounds phenomenal.
I especially like the grills for the tweeters - that really looks nice.
Chaos is offline   Reply With Quote
Old 08-20-2012   #23
Rep Power: 70 mooch91 will become famous soon enoughmooch91 will become famous soon enoughmooch91 will become famous soon enoughmooch91 will become famous soon enoughmooch91 will become famous soon enoughmooch91 will become famous soon enough
I like the carpeted MDF concept. Can you describe this a little bit more? How does that secure to the floor of the truck?
Kenwood DNX7100-RF 3sixty.3-JL Audio 300/4-JL Audio 500/1-Pioneer TS-C720PRS-JL Audio 13TW5
http://www.diymobileaudio.com/forum/...cab-build.html
mooch91 is offline   Reply With Quote
Old 08-20-2012   #24
Octave
David wanting more SQ than any creature comfort. I told him I good retain the steering wheel controls and he said he didn't care. He just wanted it to sound perfect.
Basically if you screw an amplifier directly to the chassis there's a chance you can cause a ground loop. I try to eliminate any possibility by mounting amplifiers to something else other than something that is connected to the chassis. Even when I make a custom metal amplifier rack I make sure to isolate the rack from chassis because the amplifiers are usually mounted directly to the rack and if the rack is mounted to the chassis of the car you are in effect mounting the amplifier to chassis. In this case the piece of MDF is screwed to the chassis and then the amplifier is screwed to it. Isolating the amplifier from the chassis.
Old 08-21-2012   #25
Kellyo77's Avatar
Rep Power: 47 Kellyo77 will become famous soon enoughKellyo77 will become famous soon enoughKellyo77 will become famous soon enoughKellyo77 will become famous soon enoughKellyo77 will become famous soon enoughKellyo77 will become famous soon enough
That's nicer than any work truck I ever had! The install looks fantastic. I'd love to hear a good Dyn setup one day.
Keep Calm and Chive On!
Kellyo77 is offline   Reply With Quote
