Old 06-07-2007   #1
MiloX's Avatar
Seen Rock City
Rep Power: 104 MiloX will become famous soon enoughMiloX will become famous soon enoughMiloX will become famous soon enoughMiloX will become famous soon enoughMiloX will become famous soon enoughMiloX will become famous soon enough
Default Honey, I blew up the G!
Cross posting @ Zapco.com, ICIX & here....
Alright guys….
I have officially blown up the install in the G and am in the process of rebuilding her.
Better…Stronger…More sonic bliss than before.
I’ll add to this thread as things come along.
First… Here is the patient… 2005 Infiniti G35 Sedan 6MT:
And to give you a little flavor of the dash… Nothing is changing here. For now:
Here’s what the trunk looked like before:
I know there is a lot of eD bashing… personally, I loved the way these guys performed. Especially for the money. There was also a Zapco Studio 54 hidden away that pushed the tweeters.
Out with the old… and in with the new!
The catalyst for the rebuild are these:
Two DCREF 1000.4’s courtesy of Mr. Smith at Audio Designs of Atlanta.
So I decided to change things up a bit in the trunk. Here’s a pic of the mock-up. Yeah…. That’s poplar there. Hell of a lot easier to work with for mock-ups… no need to rip MDF etc..
Once I was satisfied with the fitment I ripped the MDF and started at it:
Here’s a peek at the new window:
Brian Young - Infiniti G35 Sedan 6MT
Zapco|Dynaudio|Elemental
Team Zapco|Team Audio Designs
MiloX is offline   Reply With Quote
Old 06-07-2007   #2
MiloX's Avatar
Seen Rock City
Default Re: Honey, I blew up the G!
Update for this week.
FANTASTIC progress…and a minor setback.
First the progress.
Terminal blocks and new speaker cable ran from the rear of the vehicle.
Looks good!
The amp rack is fully wired. I’ve got to say… After installing a whole hell of a lot of amps in my day I just LOVE the flush set terminal blocks. Super clean looking and easy to use.
Amp “A” Wired up:
Relay fused and wired into place:
Amp “B” Wired up:
And power distribution is complete:
Ready to go put in the car:
So… here’s the setback… you know the number one rule of installing? You know.. the “Never drill into a panel unless you know what’s behind it.” Rule?
Yeah.. bit me in the ***. I was installing cable tie mounts on the transmission hump and the smell of petrol nearly knocked me over. I “knew” the gas tank was under the rear seat. I didn’t think there was any way it went up that high on the tranny hump. Well… it does. : Thankfully it was MY car I was working on… AND comprehensive insurance covers stupidity. So… I go to pick her up tomorrow. $500 later.
Could have been worse. Just stupid, stupid, stupid rookie mistake. From someone who knows better. :-[:-[:-[
Old 06-07-2007   #3
MiloX's Avatar
Seen Rock City
Here's a small update for those playing along at home.
With the car in the shop, I decided to turn my attention to the sub-stage.
Driver: Elemental Designs 13.Ov3 D2:
Coil #1:
Coil #2:
Binding posts inside enclosure:
#6 McFeeley's Pan-Head combo drives:
Ready to get snug as a bug:
Spent some time tonight doing some small upholstery work, and getting the amps inside the car.
Yeah... I got it back today. The shop did the work in 2 days. Fast!
On tap for tomorrow:
Changer, H701, signal connections, output to barrier strip connections, power cable cut to size and terminated, and ground to chassis. She may see power late in the day. Who knows with this kind of stuff though. Something always seems to creep up on ya.
Sunday:
Daughter's first birthday party. Made sure to get some stuff for the fellas:
Monday:
Definitely powered-up.
Old 06-07-2007   #4
MiloX's Avatar
Seen Rock City
OK… update time!
Made some great progress over the weekend. Got the amps in, wires cleaned up, and processor and changer mounted. No time spent tuning. But still sounds really good straight out of the box. The Lotus mids are just cranking out some serious midbass.
Picture time.
Passenger side rear terminal block mating amp output to speaker cable bundle:
Power cable entering trunk. I hate loom, but had to use it
Power cable and speaker bundle run:
Driver side rear terminal block:
Fuse block in rear seat pass-thru. Finish panel still to be made:
Look ma! No seats:
Optical changers FTW!!!!:
H701:
Symbilink:
Sub box termination:
Amps:
Still LOTS of work to do. Finish panels, carpeting the trunk, side lighting the window, etc….
Old 06-07-2007   #5
MiloX's Avatar
Seen Rock City
As promised, more pics.
Spent a bit of time in the battery compartment:
Looks pretty good. I just need to yank the stinger piece and go 1/0 with my grounds. Currently have 2 4 GA grounds to chassis. I'll be doing a 1/0 ground to chassis, and a 1/0 ground to the block. With a matching Streetwires terminal.
And back to the trunk. Like I mentioned a few days ago I made some serious progress here.
Side trim panel. CHECK!
Beauty board. CHECK!
Floor. CHECK!
Acrylic Panel. CHECK!
Still need to wire up the lighting. I have 4 white LEDS to side light the window, and have some amber LED strips to throw some orange glow onto the Amps.
As you can tell, I still need to lay carpet on the wheel wells. I'll do that when I have everything pulled out again.
And finally... A random shot of the sub enclosure.
So the thing with this enclosure was that it was made to be used with the factory trim pieces... which I am not using. So it doesn't integrate very well yet. I'll need to fab up some trim panels to flush it in better.
That's it for now.
Will be wiring over the next couple of nights and then heading to Jeff's shop on Saturday to play around with the Dyn 3 ways.
As you were!
Old 06-07-2007   #6
MiloX's Avatar
Seen Rock City
And that should bring you up to speed on the past 6 weeks of this build.
Old 06-07-2007   #7
Rep Power: 108 alphakenny1 will become famous soon enoughalphakenny1 will become famous soon enoughalphakenny1 will become famous soon enoughalphakenny1 will become famous soon enoughalphakenny1 will become famous soon enoughalphakenny1 will become famous soon enough
Send a message via AIM to alphakenny1
so far looks great man. keep up the good work. man you got some processing, h701 and the dc's. crazy...
HU/Processing: W200/H701
Drivers: IDQ12D2v3/Dyn MW160/Lotus RM110/Seas neo Alum
Amps: Alpine PDX 4.150/4.150
alphakenny1 is offline   Reply With Quote
Old 06-07-2007   #8
fredridge's Avatar
Rep Power: 101 fredridge will become famous soon enoughfredridge will become famous soon enoughfredridge will become famous soon enoughfredridge will become famous soon enoughfredridge will become famous soon enoughfredridge will become famous soon enough
looks great, been following it on ICIX, but like the way Vbulletin is setup here better, so glad you are posting.
Incredible wiring. I hope mine ends up looking anywhere near that good
fredridge is offline   Reply With Quote
Old 06-07-2007   #9
MiloX's Avatar
Seen Rock City
lol.. yeah... I am using the H701 for processing and the DC's for boost.
Next year will probably move the 200 & 701 into my wife's ride.
Old 06-08-2007   #10
tr0y_audi0's Avatar
Rep Power: 169 tr0y_audi0 has a reputation beyond reputetr0y_audi0 has a reputation beyond reputetr0y_audi0 has a reputation beyond reputetr0y_audi0 has a reputation beyond reputetr0y_audi0 has a reputation beyond reputetr0y_audi0 has a reputation beyond reputetr0y_audi0 has a reputation beyond reputetr0y_audi0 has a reputation beyond reputetr0y_audi0 has a reputation beyond reputetr0y_audi0 has a reputation beyond reputetr0y_audi0 has a reputation beyond repute
Thats An Awsome Setup..
The detail in the wiring made me go pull my stuff out!
I gotta stepup my dakota install after seeing your's..
Thats one of the coolest..
Peace Troy
Check us out on Facebook
www.Facebook.com/Findlaycustoms
www.Findlaycustoms.com
www.Hybrid-audio.com
Top 100 Installer 2010
tr0y_audi0 is offline   Reply With Quote
Old 06-08-2007   #11
chad's Avatar
DIYMA Psychopath
Rep Power: 867 chad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond repute
Hot Diggity Damn that looks great! Your attention to detail is relentless!
Chad
Old 06-08-2007   #12
Weightless's Avatar
Rep Power: 107 Weightless will become famous soon enoughWeightless will become famous soon enoughWeightless will become famous soon enoughWeightless will become famous soon enoughWeightless will become famous soon enoughWeightless will become famous soon enough
Beautiful work my friend...
I especially love the sub wiring...that's the kind of detail that makes my giggle like a school girl.
Weightless is online now   Reply With Quote
Old 06-08-2007   #13
Rep Power: 87 Robert will become famous soon enoughRobert will become famous soon enoughRobert will become famous soon enoughRobert will become famous soon enoughRobert will become famous soon enoughRobert will become famous soon enough
Send a message via AIM to Robert Send a message via Yahoo to Robert
Great work & the effort put into the little details is excellent.
Robert is offline   Reply With Quote
Old 06-08-2007   #14
Rep Power: 76 hoamic11 will become famous soon enoughhoamic11 will become famous soon enoughhoamic11 will become famous soon enoughhoamic11 will become famous soon enoughhoamic11 will become famous soon enoughhoamic11 will become famous soon enough
Holy crap, you did an awesome job, those speaker terminal blocks gave me an idea about how to clean mine up, just of course now i gotta figure out where to get them as well put them.
what type of eD sub is that?
hoamic11 is offline   Reply With Quote
Old 06-08-2007   #15
backwoods's Avatar
Rep Power: 98 backwoods will become famous soon enoughbackwoods will become famous soon enoughbackwoods will become famous soon enoughbackwoods will become famous soon enoughbackwoods will become famous soon enoughbackwoods will become famous soon enough
holy processing power, batman!
I love those amps, but why did you use the dc's with the 701?
backwoods is offline   Reply With Quote
Old 06-08-2007   #16
Rep Power: 85 dlechner will become famous soon enoughdlechner will become famous soon enoughdlechner will become famous soon enoughdlechner will become famous soon enoughdlechner will become famous soon enoughdlechner will become famous soon enough
Nice work!
dlechner is offline   Reply With Quote
Old 06-08-2007   #17
Arc
Arc's Avatar
Rep Power: 90 Arc will become famous soon enoughArc will become famous soon enoughArc will become famous soon enoughArc will become famous soon enoughArc will become famous soon enoughArc will become famous soon enough
It's a 13ov.3. Same as teh ov.2 just with a black cone.
Arc is offline   Reply With Quote
Old 06-08-2007   #18
DonovanM's Avatar
Rep Power: 91 DonovanM will become famous soon enoughDonovanM will become famous soon enoughDonovanM will become famous soon enoughDonovanM will become famous soon enoughDonovanM will become famous soon enoughDonovanM will become famous soon enough
Looks better every time I see it. Nice work. Really an inspiration to do something similar on my install.
DonovanM is offline   Reply With Quote
Old 06-08-2007   #19
rekd0514's Avatar
Rep Power: 91 rekd0514 will become famous soon enoughrekd0514 will become famous soon enoughrekd0514 will become famous soon enoughrekd0514 will become famous soon enoughrekd0514 will become famous soon enoughrekd0514 will become famous soon enough
Awesome install! You can't get any better than that. I kind of wish you would of shown a little more of those purdy Zapco amps though.
rekd0514 is offline   Reply With Quote
Old 06-08-2007   #20
Rep Power: 88 jearhart will become famous soon enoughjearhart will become famous soon enoughjearhart will become famous soon enoughjearhart will become famous soon enoughjearhart will become famous soon enoughjearhart will become famous soon enough
every time i see a pic of those amps i get happy in the pants!
great install, the wiring especially makes it awsome. i wish i had the patients to do something that well.
New car>2004 Civic EX *stock for now*
jearhart is offline   Reply With Quote
Old 06-08-2007   #21
Boostedrex's Avatar
DIYMA Sneetch
Zuki Audio
Sales and Customer Service
Rep Power: 126 Boostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really niceBoostedrex is just really nice
I enjoyed reading this thread on ICIX and I enjoy reading it just as much here. Great work and I can't wait to see the conclusion of this install.
Old 06-08-2007   #22
MiloX's Avatar
Seen Rock City
Thanks for all of the kind words guys.
The H701 will remain for a while. At this point, everything is a-ok. My plan is to move it to my wife's car, and get a strict SQ deck next year. I would love to see Zapco get their deck released. Controlling the DC's from the deck would be sweet.
As far as displaying more of the amps... that will be resolved tonight.
Old 06-08-2007   #23
ClinesSelect's Avatar
Rep Power: 97 ClinesSelect will become famous soon enoughClinesSelect will become famous soon enoughClinesSelect will become famous soon enoughClinesSelect will become famous soon enoughClinesSelect will become famous soon enoughClinesSelect will become famous soon enough
That is nothing short of jaw-dropping. Incredible work and attention to detail.
ClinesSelect is offline   Reply With Quote
Old 06-08-2007   #24
Boostedrex's Avatar
DIYMA Sneetch
Zuki Audio
What about the Ural h/u? I'm not very familiar with it so I'm not sure if it would meet your needs or not. I would imagine that it's probably a pretty nice piece of gear though.
Old 06-08-2007   #25
lucas569's Avatar
Rep Power: 84 lucas569 will become famous soon enoughlucas569 will become famous soon enoughlucas569 will become famous soon enoughlucas569 will become famous soon enoughlucas569 will become famous soon enoughlucas569 will become famous soon enough
u gonna sell the eD amps?
lucas569 is offline   Reply With Quote
