your first instal ?? waouh!!!!!!!!!!!
You 've got to make it your job!!!!!!!!!
wonderful!!!!!! Never heard the DLS speakers, but they should be good!
Félicitations pour tout ce boulot!!(in French)
Pioneer 9300 sd; Focal 165KP(front), 12" Fi btl N2 in a 2.5 ft3 box @34 Hz ; Sundown audio Saz 1500 and Sax 50.4; Stinger 0 ga power & grounds, and accessories. Damplifier pro. Kinetic HC1200 (rear battery). Big3 (still need to do alt to batt +)
The right mirror is completely visible with the midrange in that position and the left mirror only gets slightly blocked on the inside. The vehicle is completely safe to operate
@ NOTORIOUS97200 - First full install yes. In the past I only installed amps and subs in off-the-shelf enclosures etc.
The car was at it first competition this past weekend with the new install and placed second in its class and fourth overall I think. Im pretty happy. IASCA season starts this weekend and I have a little bit of work to do this week to get everything perfected.
Tub is done. (actually looks like one now ) Rubberised the inside to reduce resonance and add some weight.
Terminal cup broke when I attached it to the box. Oh well. Good reason to glass it into the box. Used some premix fiber filler. This thing is going nowhere. The fiber filler also adds some extra weight to the plastic. Not that it would flex to begin with.
Next up is the baffle for the sub. Need to cut this hopefully tonight.
Perfect 280mm circle cut with a $20 jigsaw. Ive had this little beast for 5 years and its still going strong.
Cover test fit
Final layout from the looks of it. Grille height is perfect for the 2 amps. Ill gain around 20mm with the custom amp rack frames that will be suspended on 4mm rubber to reduce vibrations in the amps.
I had to chucle a little there is no way you can compare sony to any other company. If you were to post that you were using a sony head unit for a SQ setup on caraudio.com you would be getting your balls busted sony has become absolute crap. I mean there sold at walmart for crying out loud. I think you would hear the difference instalntly by going with a alpine deck. But if that is what you want that is what you want.
