Old 03-02-2011   #176
req
req's Avatar
Send a message via AIM to req
Default re: 2003 Volkswagen GTi 1.8t - Mosconi, Vifa, Exodus, Helix PDSP, IDMax, carPC *updated*
so i went to the store to try and find some good mounting stuff for the horns, because the other night i was actually laying in bed trying to fall asleep and thinking about mounting options. the blower motor on the passenger side is large and way low, so the driver side horn is going to be much lower than the bottom of the dash. trying to level them out is going to be tricky, so i kind of made a cool thing and some other stuff.
so i found this pipe strap that is thick and has a sweet 2" loop on the back. with a little bending i got the loop to be the same diameter as the CDUltra motor, and i plan on mounting it to the dash support (you can see where i got some screwdrivers through the holes for some temporary aligning i did just before i had to leave for work)
just to figure out where these are going to sit, i got some thick tape to hold them in place so i can figure out where im going to mount the horn.
as you can see, i used a piece of extruded L shaped aluminum on the edge of the horn to extend under the dash to the driver side to get an idea of how low these are actually going to be. its quite low on the driver side, hopefully it will not interfere with the pedals - i think it might be a bit lower than it needs to be due to the middle under dash and the passenger side horn being angled downward a bit. i need to buy a small level. i have a laser level i think im going to try an use. its going to be tricky though!
req is offline   Reply With Quote
Old 03-02-2011   #177
Rep Power: 32 voltij will become famous soon enoughvoltij will become famous soon enoughvoltij will become famous soon enoughvoltij will become famous soon enoughvoltij will become famous soon enoughvoltij will become famous soon enough
Originally Posted by req View Post
lol brian, what kind of duel? like who can finish first duel? im almost done now haha
More like build quality, ideas implemented, and the general public's opinion of the worklog
I have some cool stuff planned... :O
Hey btw should I just post worklog here (DIYMA forums) or other places too?
I see that caraudio.com is kind of retarded as of late...
voltij is offline   Reply With Quote
Old 03-02-2011   #178
req
req's Avatar
ya. i posted over there, and got like 2 replies. and i posted on this other forum, and there is like 12 members. i dont see the point of posting anywhere unless its here or the vwvortex forums (car specific).
the people here are the only ones that really make sense.
oh, and visitors, please feel free to give my thread stars or any of that other thread option stuff if you like or dislike
Old 03-03-2011   #179
okay mr. e-peen
Old 03-03-2011   #180
req
req's Avatar
theheh
Old 03-03-2011   #181
theheh
/threadjack/
i need 8" mid drivers that get loud as fcuk and dont need much volume (sealed)
tell me what's up
Old 03-03-2011   #182
Rep Power: 31 hcaleman will become famous soon enoughhcaleman will become famous soon enoughhcaleman will become famous soon enoughhcaleman will become famous soon enoughhcaleman will become famous soon enoughhcaleman will become famous soon enough
Some good looking work going on here, especially making use of the parking lot and friend's pick-up gate. I should feel ashamed of myself that I whine of lack of space in my detached garage and yard and driveway.
hcaleman is offline   Reply With Quote
Old 03-03-2011   #183
yeldak99's Avatar
Rep Power: 68 yeldak99 will become famous soon enoughyeldak99 will become famous soon enoughyeldak99 will become famous soon enoughyeldak99 will become famous soon enoughyeldak99 will become famous soon enoughyeldak99 will become famous soon enough
To hell with you and you're bragging!!! Us apartment guys get shit done!!!! Well, I'm not included in that. I can't even bring myself to do some tuning in the cold right now.
yeldak99 is offline   Reply With Quote
Old 03-04-2011   #184
req
req's Avatar
so i played around with the horns yesterday, unfortunately i can not go much deeper or much wider than i had them because the passenger side is my limitation.
BUT! i had the horns not level with each other before because i did not realize how different the dash was on each side! its off by like 3 inches, i dont know how i did not see it before!
so with a lot of tape to hold them in place while i figure out where to put brackets (there are some good dash frame spots under there!) this is what i have currently.
it might be kind of hard to understand that - but i bought those pipe hangars that i showed above, and they are awesome! fit right around the motor (with a bit of bending) and i will screw them together with some closed cell foam between them and the speaker.
then i bought a roll of plastic pipe perforated hangey stuff. trying to fab metal and hold the horn in place is hard as crap - so i am using plastic back-strap for a temporary mount, then im going to make metal brackets and remove the plastic so its mega rigid!
after today (friday) i should be done with the horns i hope, and i can put the dash and the glove box back in. then i wait on my baffles in the mail!
im also putting my bumper on today (pics of that when it happens)
and um. i might weld the tabs for the baffle on tonight i think. depends on what the wife and i are doing. i just dropped her off at work. i got home at like midnight from work, and we dropped her car off at the shop for an alignment just now. so im going back to sleep.
see you all soon i guess :P
Old 03-04-2011   #185
Ha, yeah. Well what's really tough is every time I go outside to work on something over the weekend I get dragged into some other task around the house. Really need to teach my wife to be handy. Hmm.. no probably not a good idea.
Never heard horns in a car before curious to see how they perform.
Old 03-04-2011   #186
req
req's Avatar
well when im done you can come over and check them out im headed outside to do some mounting brackets. hopefully its warmer than yesterday
Old 03-04-2011   #187
You guys are just lucky you have the time to do this stuff in the daylight!!
Right now I'm on two jobs, one is M-F 7am-5pm, other is Fri 6-9pm and Sat 10a-9p. Basically leaves only a couple hours per night and Sunday! And the weeknights are cut even shorter due to my recent attempts to hit the gym after work!
Old 03-04-2011   #188
req
req's Avatar
so i replaced my bumper. it has a perfect fitment, almost.
im quite upset with two parts of it. right on the corners of the headlights it does not fit. not like you can shimmy it differently to make it fit, it is about 1\4 inch too wide and there is nowhere for the extra room to go so it bulges here. or, there is something on the side i can not see causing this problem.
other than that, the 1\4 inch of space near the headlights, i love it. but that will bother me to no end.
here are some pictures.
Old 03-08-2011   #189
Rep Power: 38 jackp311 will become famous soon enoughjackp311 will become famous soon enoughjackp311 will become famous soon enoughjackp311 will become famous soon enoughjackp311 will become famous soon enoughjackp311 will become famous soon enough
I love the parcel shelf IB setup. Wonderful build and very original.
jackp311 is offline   Reply With Quote
Old 03-08-2011   #190
req
req's Avatar
thank yuh!
i worked on mounting the horns more today. the driver side is a bit too low for my liking - but i can still drive without problems. the top of my shoe sometimes touches the back of the horn lens when im using the break... but it would be like an inch differece in height if i raised it. the HVAC stuff on the passenger side is totally in the way
i got my 8" flush mount IDQ baffles from my buddy g0a in north carolina - and as usual, they are super awesome perfect. so i will be working on putting those in the doors as well!
i got pics on my phone but it ran out of batteries. ill get them up in a little bit!
Old 03-08-2011   #191
req
req's Avatar
pics here
new baffles, they are like 10 inches!!
horns mounted with metal back strap and speed clips!. they are pretty sturdy!
Old 03-08-2011   #192
Bulk Sales Pass
Mic10is's Avatar
Rep Power: 99 Mic10is will become famous soon enoughMic10is will become famous soon enoughMic10is will become famous soon enoughMic10is will become famous soon enoughMic10is will become famous soon enoughMic10is will become famous soon enoughMic10is will become famous soon enough
coming along nicely. Grill Cloth those horns. just wrap them in grill cloth. Keep them as "invisible" as possible.
and If I finish my new car before you finish your existing install, then you are really slow!!!
2011 MECA SQL Spirit Award
2012 USACi Japan Finals Judge
Mic10is is offline   Reply With Quote
Old 03-08-2011   #193
Rep Power: 52 AccordUno is on a distinguished roadAccordUno is on a distinguished roadAccordUno is on a distinguished roadAccordUno is on a distinguished roadAccordUno is on a distinguished road
What is this car you speak of?
Jose -06 Titan CC SE -See you in the lanes next year
DEX-P01/P9 - DEQ-P9 - XDV-P90 - Beyma Speakers - OS SS Ref Amps
(All Digital Source)
AccordUno is online now   Reply With Quote
Old 03-08-2011   #194
Horsemanwill's Avatar
Rep Power: 177 Horsemanwill has a reputation beyond reputeHorsemanwill has a reputation beyond reputeHorsemanwill has a reputation beyond reputeHorsemanwill has a reputation beyond reputeHorsemanwill has a reputation beyond reputeHorsemanwill has a reputation beyond reputeHorsemanwill has a reputation beyond reputeHorsemanwill has a reputation beyond reputeHorsemanwill has a reputation beyond reputeHorsemanwill has a reputation beyond reputeHorsemanwill has a reputation beyond repute
Send a message via AIM to Horsemanwill Send a message via MSN to Horsemanwill Send a message via Yahoo to Horsemanwill
ah shadup mic lol
HU P01
Tru SB6 running ES ultra full body and (2) jbl w12gti
Tru S25 runing Mids 4 Silver Flute W17RC38-08
Horsemanwill is offline   Reply With Quote
Old 03-08-2011   #195
Bulk Sales Pass
Mic10is's Avatar
i got a new daily driver. 02 Lancer OZ. going to build w my wife for modified class.
BMW is delegated to competition car only
Old 03-08-2011   #196
Great. Now I need to revisit my plans on my car..
Req, car is coming along nicely. Not sure if I could go so long without tunes for this long..
Old 03-08-2011   #197
req
req's Avatar
hehe, thanks for the comments everyone. Mic, i have grill cloth in the house. i am actually going to put some sound deadening on them when i take them BACK out to solder the wires and finalize them! *thank god*
then i get to cut my door panels up im really hoping to have the speakers playing by this weekend. and then ill build a beauty panel for the doors and put everything back together. last thing im going to worry about is making a beauty panel for the shifter\center console area.
Old 03-13-2011   #198
req
req's Avatar
i got my horns soldered up and wired into the car. i got them finally installed. i could not get them to go back much further, maybe like a half of an inch, but they did go outboard a little more. and they are now level with each other. and they are ultra's instead of CD2's! I also put a few bits of cld tiles on them to dampen the vibrations in the horn lense. I also covered them with some partsexpress grille cloth. all i have to do is make a transition from the dash to the driver side horn mouth. but i am going to worry about installing the door speakers first.
i did work on the doors a bit yesterday too. with the help of some tinsnips, a razor with a locking blade, and a sweet pair of plier things i was able to cut out the holes for the larger format flushmount baffles in about an hour. i just need to get the IDQ's mounted properly inside the door now lol.
i am lucky, the leather insert panel is exactly the perfect distance from the corner area that i could fit these so i didnt have to cut it lol. *phew*
hopefully i can get the door speakers installed this week and get things back in a listenable format. i need to take my car to my friends house to weld the mounting tabs to the baffle bracket, then all i have to do is make things pretty!! im almost done!
Old 03-13-2011   #199
Rep Power: 0 SUBSONIC_WARFARE will become famous soon enoughSUBSONIC_WARFARE will become famous soon enoughSUBSONIC_WARFARE will become famous soon enoughSUBSONIC_WARFARE will become famous soon enoughSUBSONIC_WARFARE will become famous soon enoughSUBSONIC_WARFARE will become famous soon enough
Funny how the pics make it look so easy, not counting putting stuff in and taking it out 5000x to get it to fit JUST RIGHT. The center console/shifter area would look really slick with a smooth fiberglass valance with a vinyl or leather wrap, if you ask me. I'm keen to see how you handle it. Props for the progress so far. Now I'm excited to start mine (Last of the parts finally came in, woohoo!)
SUBSONIC_WARFARE is offline   Reply With Quote
Old 03-13-2011   #200
req
req's Avatar
thats the kind of idea i was going to toy with. im going to try and make a beauty panel to attach to the front of the console to cover the transmission\shifter hole that is left from removal of the forward console area. then im going to try and make a beauty panel under the center console that is tucked back as far as possible under the dash to help the horns in the car environment more
