Old 02-01-2011   #26
Rep Power: 68 TXwrxWagon will become famous soon enoughTXwrxWagon will become famous soon enoughTXwrxWagon will become famous soon enoughTXwrxWagon will become famous soon enoughTXwrxWagon will become famous soon enoughTXwrxWagon will become famous soon enough
Default Re: Subaru GTB Wagon Build - SQ on a shoestring
LOL I am glad you took that with the constructive intent it was given.
If you look at the graph of response for the single-reflex enclosure, YES on paper it is higher, flatter, & more "responsive" on the graph... the GRAPH is assuming you have one HELL of a midbass that can pick up at say 55 or 65Hz to fill in before that brick wall drop starting at about 75-80hz...
Like I said, Single & dual reflex (single/dual "bandpass") enclosures were the rage in the late 80s through the late 90's for SPL machines looking to make a dedicated shot at a given range of frequencies. They are NOT musical. They are VERY one-sided. They go low, they are VERY efficient in the range, usually 1, maybe 2 octaves.
If you are aiming for SQ or Even SQ+ type competition or trying to showcase Sound Quality... Sealed is easiest to tune, Ported will get you a lil more depth & impact, but does require, like the bandpass, a VERY strong midbass transition.
From a seamless, Sound quality point of view, your current set up, ported is going to destroy anything the bandpass may have offered and, most importantly be more MUSICAL.
You are an an amazing build journey. Can't wait to see it unfold. Glad that the bandpass wasn't in the cards... you will be too, once its all done... Cheers!
Rob
Originally Posted by blazit08 View Post
Hmm, i don't know but this arrogant jack-ass (txwrxwagon) is giving me a headache. Do you have a life? Do you just like looking like a immature non helpful dick-head?
Nope... Just to help debunk some of the stupidity of DIYMA..
TXwrxWagon is offline   Reply With Quote
Old 02-01-2011   #27
taking it one step further....
look at the BLUE line (ported) it has a prominent peak, which is fine... but guess what? The natural cabin gain of YOUR car will give you that in a sealed enclosure as well. So now in the ported configuration, you may have a nasty PEAK to deal with transitioning between the sub & the midbass to get the overall SQ balanced.
If you look at the graphs, the SEALED (black line) gives you the smoothest, most consistent response with no peaks, spikes, dips, or sharp roll off. If you are buiilding a Demo car for SPL then the bandpass is the way to go, the ported a close second.
If a SQ car is what you are building, the sealed enclosures "conservative" curve will actually blend better with the rear fill & front stage better.
Not to mention, if you caclulate the 1/4 wave length of the port frequency of the bandpass enclosure it will likely (I didn't run the math) be well outside the car anyway... so the bandpass will definitely likely be a "crowd pleaser" not a car occupant pleaser...
Rob
Old 02-01-2011   #28
sinister-kustoms's Avatar
Rep Power: 53 sinister-kustoms will become famous soon enoughsinister-kustoms will become famous soon enoughsinister-kustoms will become famous soon enoughsinister-kustoms will become famous soon enoughsinister-kustoms will become famous soon enoughsinister-kustoms will become famous soon enough
Thanks for the insight! There is always someone out there more knowledgable than oneself, so I try and keep an open mind. My grandfather always told me 'The day you stop learning, is the day they put you in the ground'.
Now...if you have any words of wisdom on how to cram 10lbs of shit into a 5lb bag, I'm all ears
sinister-kustoms is offline   Reply With Quote
Old 02-01-2011   #29
nope... LOL... you are on the right track... at least in my feeble opinion.
I would think about building the enclosure ported. Add some dead materials to see how it sounds sealed, then remove & try the ported. Your ears are the most important set. Just Saying.
I would get it all done & do some SERIOUS listening with whatever the main source you will use. If you are an iPod guy... great... set up the system, listen as you will listen.
tune & adjust as you prefer.
Rob
Old 02-01-2011   #30
Yea the thought of doing a removable panel to block/unblock the port had crossed my mind. It won't be hard to do, so I will go ahead with it.
I still prefer to listen to good old CD's (vintage!? ) so I will tune as such. Hannah uses MP3's and isn't fussed about recording quality aslong as she can listen to her favorite song whatever it maybe at any given time
Old 02-01-2011   #31
Aaron'z 2.5RS/WRX's Avatar
Originally Posted by eviling View Post
thats interesting because fusion is JUNKKKKKKK over here, we're talking BOSS qulity crap here. just pure junk, in fact, i almost had to pay sombody to take a amp\sub combo pack i had laying around off my hands just for them to take it
BOSS read ZED...
Fusion, possibly the same...
Doesn't really matter the name, if ZED built it, it's likely SOLID..
Old 02-01-2011   #32
LOV the Leggy Waggy BTW...
That, laid out (even if it's not), on black wheels...Now that's straight Sinister..!!
Old 02-27-2011   #33
Finally got some time in on this build over the weekend. This year has been nuts so far!
Trim/insert panel for the amp rack done
Routered out the back so the insert and 3.5mm acrylic sit flush. I used speaker grill clips to attach the trim panels to the amp rack.
Just need to source some carbonfibre vinyl for the insert panel and then I can permanently install the acrylic and LED's.
Got the framework that holds up the false floor mostly done. Just got to finish sussing out the hinges to hinge the sub box. I've used 8mm riv nuts and caphead bolts to secure the frame to the floor. Solid as!
Old 03-07-2011   #34
Rep Power: 31 slpery will become famous soon enoughslpery will become famous soon enoughslpery will become famous soon enoughslpery will become famous soon enoughslpery will become famous soon enoughslpery will become famous soon enough
great work kiwi. Im wanting to do something similar in my Falcon. Cant wait to see more.
slpery is offline   Reply With Quote
Old 03-07-2011   #35
Rep Power: 112 Mless5 will become famous soon enoughMless5 will become famous soon enoughMless5 will become famous soon enoughMless5 will become famous soon enoughMless5 will become famous soon enoughMless5 will become famous soon enough
Looks great!
What is the angle of the router bit you have used on the cutouts for plexiglass?
Thanks.
Pioneer 880 :: Aura NS6 :: Morel MDT12 :: ED 13ov.2 :: a/d/s/ ph15.2
Mless5 is offline   Reply With Quote
Old 03-08-2011   #36
Rep Power: 38 jackp311 will become famous soon enoughjackp311 will become famous soon enoughjackp311 will become famous soon enoughjackp311 will become famous soon enoughjackp311 will become famous soon enoughjackp311 will become famous soon enough
Love the amp rack. Weird how some brands release quality equipment in one part of the world and rebranded stuff in another.
jackp311 is offline   Reply With Quote
Old 03-27-2011   #37
Rep Power: 30 AKMetal will become famous soon enoughAKMetal will become famous soon enoughAKMetal will become famous soon enoughAKMetal will become famous soon enoughAKMetal will become famous soon enoughAKMetal will become famous soon enough
ahhh.. how much do you have invested making this rack? my subie would love to have its trunk at the end of my build but i dont think i can afford it.
AKMetal is offline   Reply With Quote
Old 03-28-2011   #38
Originally Posted by Mless5 View Post
Looks great!
Thanks.
Thanks mate. It's 45 degree bit, hope that helps!
Um, including the amps, I've got probably around NZD $200 in the rack. I'm guessing I'll have around $5-600 all up in the trunk once it's completed including the equipment (not including sound deadening).
The Subru build is on the backburner untill May. I'm currently working on getting my '58 Volkswagen project done and on the road for an event in April. Keep an eye out for that install in the next few weeks
Old 03-28-2011   #39
wow, not bad considering how well built it is. but, factoring in hours you've spent building its worth considerably more i imagine
Old 03-30-2011   #40
Rep Power: 29 samos69 will become famous soon enoughsamos69 will become famous soon enoughsamos69 will become famous soon enoughsamos69 will become famous soon enoughsamos69 will become famous soon enoughsamos69 will become famous soon enough
Hey man, nice build - should keep the mrs happy!
I'm not far from you being down in Wellington... what event is on in April you're trying to get the vw to?
samos69 is offline   Reply With Quote
Old 03-30-2011   #41
Thanks man. She better be happy, or I'll be getting all Jake the Muss on her
Aiming for the VW Nationals in Orewa. The furtherest I've driven it so far is around the block so hopefully the air-cooled gods will be with me
Old 03-30-2011   #42
Thanks. That's the thing about DIY I guess, you never factor in the (countless) hours you put into projects when it comes to their worth!
Old 03-31-2011   #43
Mobile communications sevice
Installer
Rep Power: 0 War Bandit will become famous soon enoughWar Bandit will become famous soon enoughWar Bandit will become famous soon enoughWar Bandit will become famous soon enoughWar Bandit will become famous soon enoughWar Bandit will become famous soon enough
Hey, I'm Just on the other side of the hill to you (Upper Hutt). I was just wondering where you picked up you IDQ10 from? I'm dying to get my grubby little hands on one or two =D.
War Bandit is offline   Reply With Quote
Old 03-31-2011   #44
Hey mate, check out the classified section on NZ ICE Magazine Rogan on there was importing ID gear for a while so theres a fair bit of stuff floating around. I think he may even have some IDv3's left.
Old 03-31-2011   #45
Yer though they are normally pretty easy to please, components, sub, favorite pop song on the ipod - job done
The bug will make it, days are getting cooler so that'll help some
Old 04-03-2011   #46
Car Tunes Stereo Center
Installation Manager
Rep Power: 79 JayinMI will become famous soon enoughJayinMI will become famous soon enoughJayinMI will become famous soon enoughJayinMI will become famous soon enoughJayinMI will become famous soon enoughJayinMI will become famous soon enough
Being an aircooled VW guy (a couple of times) I'm looking forward to the bug build. What are you doing for charging system upgrades?
Jay
Originally Posted by nadams5755
weeeer wub wub wub weeer wub wub wub waaa
Old 04-03-2011   #47
Rep Power: 30 memphiskane will become famous soon enoughmemphiskane will become famous soon enoughmemphiskane will become famous soon enoughmemphiskane will become famous soon enoughmemphiskane will become famous soon enoughmemphiskane will become famous soon enough
Really like the amp rack on the subie
memphiskane is online now   Reply With Quote
Old 04-03-2011   #48
I'll just be doing the big 3 upgrade with 4 gauge for now and will look into a HO alt later down the track. I'm quickly running out of time to get the car done for the event, so I'll just be running a temp system to get me by (H/U powered fronts and mabey a small amp & sub) and then do the main system when I get back. I don't want the final install to be rushed!
Thanks man, I'm itching to get back ito it!
Old 04-03-2011   #49
Good call. In my '70 I ran a Pioneer CD Player, Sony XM-4040 (160W 4 channel) and crossover. I had comps in the front doors in my first ever 'glass pods, and a 1.0ft3 box for an Orion XTR 10. This was in '91. The generator held up surprisingly well.
Good call on not rushing it. Looking forward to more pics of it.
Jay
Old 05-16-2011   #50
So I finally found some time to blow the dust of this project and make some progress.
I fully ran out of time to do anything with the VW project, but did manage to get the interior stripped out and the first bit of sound deadening started over the weekend. I'll start the build log hopefully in the next few weeks once I've made some decent progress.
Some of my original plans have changed. I'm just going to run with a 2-way setup now. Being my first active install, I think it will be a whole lot easier tuning with just the 2-way, not to mention a whole lot less work. I'll use the 2 spare channels on the 3566 to power some Infinity Reference co-axials in the rear doors.
I brought a 3Sixty.2 for the VW a while back, but recently picked up a P80RS so will use that in the dub, and the 3Sixty will go into the Suby. So much for a budget build!
I've also ditched the IDQ for a VDO Dayton HPS12. Hannah listens to a lot of Dubstep/DnB aswell as the usual girly poppy stuff, so I think the 12 will suit her tastes better, plus the IDQ will be safe from any abuse the system will encounter when she and her GF's are doing their thing.
I scrapped the custom distro idea after coming across this honey on the interwebs. The shape suits the trim panel cutout better than the custom one I had planned, plus it has the volt meter and it just looks plain sexy so I had to have it! Tsunami TPFDB-4PG Fused distribution Block. Positive and negative 0awg in with 4 x 4awg out
Got the amp rack trim panel covered in 3M Di-noc. I sprayed it with filler primer and gave it a quick sand to give the vinyl a nice surface to stick to.
This shit is cool!
I routered some channels in the back of the panel for the LED's and wiring, glued the acrylic in, then used cloth tape to help 'direct' the light.
Baseplate for the distro block cut and rabbeted ready to stretch some fleece.
Then postioned and resined in place.
