Old 02-25-2011   #1
Rep Power: 44 TOOSTUBBORN2FAIL is a jewel in the roughTOOSTUBBORN2FAIL is a jewel in the roughTOOSTUBBORN2FAIL is a jewel in the roughTOOSTUBBORN2FAIL is a jewel in the roughTOOSTUBBORN2FAIL is a jewel in the roughTOOSTUBBORN2FAIL is a jewel in the roughTOOSTUBBORN2FAIL is a jewel in the roughTOOSTUBBORN2FAIL is a jewel in the roughTOOSTUBBORN2FAIL is a jewel in the roughTOOSTUBBORN2FAIL is a jewel in the roughTOOSTUBBORN2FAIL is a jewel in the rough
Default 98 Dodge Neon Build, First Timer SQ
Well, time to start my first audio build. The car is a 98 Dodge Neon R/T. This will be a sound quality only build. No 150 db spl monster subs. It will be done in 2 stages, the first which will happen over the next month and a half. Total investment so far is around $3600+.
Equipment for stage 1:
Headunit - Denon DCT R1
Processor - JBL MS-8
Sub - Kicker CVX 10", prefab Kicker ported box
Mids - Hybrid Audio Imagine 6.5"
Highs - Hybrid Audio Imagine 25mm
Sub amp - Kicker ZX1x500
Mid/High amp - Kicker ZX2x200 (this will change to a JL HD600.4 soon after install)
Power Wires - Streetwires 0 and 4 gauge
Speaker Wires - Kicker X-Series 12 gauge
Sound deadening - Second Skin Damplifier Pro, Luxury Liner Pro, Overkill
This first stage is mostly focused in front of the front seats. The mids will go into the kicks, in vented fiberglass enclosures, aimed in between the front seats. The tweeters will be in the a-pillars, aimed at the center of the windshield. I have 70 square feet of Damplifier Pro to go in front of the front seats. Three layers on the front floor, three on the firewall, three on the lower a-pillers. Over that, a continuous layer of Luxury Liner Pro. The dash is completely out of the car, as well as the HVAC, and pretty much everything else. I'm currently finishing pulling the stock junk deadening, as it wasnt stuck on too well in some places. I'm using Hybrid Audio for all mids and highs.
On to pics.
Denon Head Unit
0.008% Distortion
110 db signal to noise ratio
Head Unit and Damp Pro
Damp Pro and back of Head Unit
36 Square Feet of Luxury Liner Pro
9 Square Feet of Overkill
JBL MS-8
Low, High and Bandpass crossovers, anywhere between 20-20000hz
Automatic room correction
Time Alignment
8 Channels
31 Band Equalizer
TOOSTUBBORN2FAIL is offline   Reply With Quote
Old 02-25-2011   #2
slowsedan01's Avatar
Rep Power: 67 slowsedan01 will become famous soon enoughslowsedan01 will become famous soon enoughslowsedan01 will become famous soon enoughslowsedan01 will become famous soon enoughslowsedan01 will become famous soon enoughslowsedan01 will become famous soon enough
Send a message via AIM to slowsedan01
Default Re: 98 Dodge Neon Build, First Timer SQ
Nice equipment, should be a good build.
slowsedan01 is offline   Reply With Quote
Old 02-25-2011   #3
Thanks, hang in there over the next day as i get the rest of the pics up. My superlow post count is slowing down my ability to post pics.
Old 02-25-2011   #4
Hybrid Audio Imagine 6.5" Mid
http://www.hybrid-audio.com/Imagine_...nual_Final.pdf
Hybrid Audio Imagine Tweeter
Same link as above
Now on to the car
Well, I got the rest of the stock deadening out today, and a lousy coat of primer, mostly so it doesnt rust. It was dark and 48 degrees out, so not ideal weather to paint in. Tomorrow when its light out, I'll wet sand the primer, and lay another good coat down, around 10am, then around 3pm I'll lay a coat of white down, and that'll be it. Its mostly to make sure theres no bare metal under the deadening.
I should add, I couldn't have done all of this without my wife. She bought me the head unit, helped remove the deadening with the heat gun and putty knife, helped sand the leftover bits down and wiped everything down with acetone before I sprayed the primer.
Lousy night pics
Vent for the right mid
Old 02-25-2011   #5
Last junk post before real work gets done. Got the paint down today, gonna smooth it tomorrow, and start making templates for the sound deadening, and get to cutting it. Wednesday the first layer or 2 will go in.
Old 02-25-2011   #6
simplicityinsound's Avatar
Diyma Ninja
Simplicity In Sound
owner
Rep Power: 121 simplicityinsound is a jewel in the roughsimplicityinsound is a jewel in the roughsimplicityinsound is a jewel in the roughsimplicityinsound is a jewel in the roughsimplicityinsound is a jewel in the roughsimplicityinsound is a jewel in the roughsimplicityinsound is a jewel in the roughsimplicityinsound is a jewel in the roughsimplicityinsound is a jewel in the roughsimplicityinsound is a jewel in the roughsimplicityinsound is a jewel in the rough
holy crap...your FIRST build?!?! what do you do for a living?!
cant wait to see the rest!
Old 02-25-2011   #7
Brian_smith06's Avatar
Rep Power: 77 Brian_smith06 will become famous soon enoughBrian_smith06 will become famous soon enoughBrian_smith06 will become famous soon enoughBrian_smith06 will become famous soon enoughBrian_smith06 will become famous soon enoughBrian_smith06 will become famous soon enoughBrian_smith06 will become famous soon enough
not going to lie, when I saw the title with first time sq and neon all in the same title I had my doubts but I can already tell you mean business and have some badass equipment so you sir have def proved me wrong!!!!!
I cant wait to see progress
Alpine, Eric Stevens, Stinger, Second Skin
Brian_smith06 is offline   Reply With Quote
Old 02-26-2011   #8
I'm currently a trash truck driver with a wife that loves me. Oh, also I'm a perfectionist, which means I usually never get things done. I want to make this my first fully finished project.
Working on getting a higher paying job, so I can start stage 2. Legatia SE 3way, HD amps, rest of the car sound deadened, and FI IB subs.
Old 02-26-2011   #9
You'll fit in perfect here and especially with car audio overall. There is always something to alter/swap/or plan for
yum and yum
Old 02-26-2011   #10
jorgegarcia's Avatar
Rep Power: 66 jorgegarcia will become famous soon enoughjorgegarcia will become famous soon enoughjorgegarcia will become famous soon enoughjorgegarcia will become famous soon enoughjorgegarcia will become famous soon enoughjorgegarcia will become famous soon enough
I'm subscribed. Love this over the top installs. Take lots of pictures, we love audio install porn around here.
Planning & Install [00%]
Parts [100%]
Buying new car. The cycle starts all over again.
jorgegarcia is offline   Reply With Quote
Old 02-26-2011   #11
leepersc's Avatar
Rep Power: 49 leepersc will become famous soon enoughleepersc will become famous soon enoughleepersc will become famous soon enoughleepersc will become famous soon enoughleepersc will become famous soon enoughleepersc will become famous soon enough
Also subscribed!
XSPower VCM, 240 Amp Alt., Alpine HU & Old School 3617 DSP, Soundstream Digi-Q, 2 Audiocontrol EQL's, 2 4XS crossovers, Epicenter, 2 PylePro PDN8's per door, Dayton 4” & tweet in A-Pillars, 2 MBQ 15's. Alpine MRP-F600 x3, MRP-M1000 x2. Install In progress.
leepersc is offline   Reply With Quote
Old 02-26-2011   #12
Diyma Ninja
Simplicity In Sound
owner
just becareful about the perfectionist thing, i started out like that and it led me to trying to remold and build the entire interior of my truck, it ended up being sold a few months later in half built condition...
but i wish you the best of luck!
b
Old 02-26-2011   #13
Rep Power: 0 Mixerdriver will become famous soon enoughMixerdriver will become famous soon enoughMixerdriver will become famous soon enoughMixerdriver will become famous soon enoughMixerdriver will become famous soon enoughMixerdriver will become famous soon enough
subscribed
Mixerdriver is offline   Reply With Quote
Old 02-26-2011   #14
b
Thanks for the advice. I'm more just trying to stay away from the local shops. The one good shop in the area, got raided by PD and shut down, for taking money and not finishing projects. Sadly, they were the only ones that did quality work around here. I have until the end of this year to get stage 1 where I want it, and then I go on a 6 month break, as I'll be going through the police academy. After I get out, I'll be able to start stage 2.
I'm gonna use this first part of the install as a learning process. I've never worked with fiberglass, so I bought the cheap bondo crap before reading up more, but if I can do half decent with that, I'll use US composites next time. If not, I can practice with the cheap stuff some more until I'm ready for the good stuff.
I actually have someone else doing the interior remold work for me. He works with carbon fiber, so I'll be slowly sending him pieces I have laying around not being used, and he'll be making a mold, and redoing the whole thing in pure CF. I've had 3 neons, and 2 were gutted race cars, so I can do this without leaving this car torn apart, and just swap parts as I go.
Old 02-26-2011   #15
Diyma Ninja
Simplicity In Sound
owner
sweet, are you in cali or canada? if cali, where are you that you only have ONE good shop around you?
Old 02-26-2011   #16
Visalia, CA.
I should say, we dont have any good SQ shops around here. Seems every shop here specializes in SPL builds. We had a HAT, Hertz, and Morel dealer here, based in a custom car shop, but that shop got raided and shut down, a week after a meca show.
They've had a few meca shows at a shop in fresno, but when I was there, it was 90% SPL cars, and the SQ cars were from out of town.
The #1 shop in visalia still tells people that speakers can distort from not running enough power, and they dont mean from clipping either. They also kind of change their prices based on who you are, you pay above MSRP if your not one of their favorite, which is ok for me, because all they sell there is kicker and RF.
Old 02-26-2011   #17
Diyma Ninja
Simplicity In Sound
owner
oh roadshop eh? we were there last october for the finals.
actually, audio innovations in fresno, Ray and Ryan are REALLY REALLY friggin good at building SQ cars...its just their clientel prefer SPL...you should really hit them up...i would easily trust them to do my own car.
Old 02-26-2011   #18
Rep Power: 54 ALL4SQ will become famous soon enoughALL4SQ will become famous soon enoughALL4SQ will become famous soon enoughALL4SQ will become famous soon enoughALL4SQ will become famous soon enoughALL4SQ will become famous soon enough
Nice system design and gear choices. Looking forward to following this build.
Mike Peterson
Link to build pictures of my Car: www.all4sq.com
ALL4SQ is online now   Reply With Quote
Old 02-26-2011   #19
Rep Power: 66 ReloadedSS will become famous soon enoughReloadedSS will become famous soon enoughReloadedSS will become famous soon enoughReloadedSS will become famous soon enoughReloadedSS will become famous soon enoughReloadedSS will become famous soon enough
Lots of good work so far, I wasn't sure what to expect from the title, but I am definitely following along.
ReloadedSS is offline   Reply With Quote
Old 02-26-2011   #20
Nice I'm a future officer as well woot woot.
Old 02-26-2011   #21
Yep, I was there spectating last oct. Wanted them to do some work for me, but then they were shut down.
Audio Innovations was where I was talking about in fresno, I actually considered taking it there, but at the time, my wife had been laid off from her CO job, and then I decided I'd like to learn for myself, plus save myself some money. Your probably right, all the cars I saw there were SPL cars, although its probably the area more then the actual shop. I think once the installs done though, I'll head up there if I need help tuning anything (which is likely, being a noob)
Old 02-26-2011   #22
Looking forward to seeing more. This thread should deliver. Nice job for a first timer. I am not a first timer but I cant swing a list of equipment like that. Keep your wife happy!
Old 02-26-2011   #23
Thanks. Ya, I love my wife. Helped me remove sound deadening in two cars now, with a heat gun and scraper. Helped my acetone this one, and put in sound deadening today. I just need to get her civic's deadening done as a thank you to her. Its sad that stock for stock, a 2010 civic ex is at loud on the freeway as a 1998 dodge neon.
Old 02-26-2011   #24
Well, sicker then crap, but I got a little done. Didn't rain, but was cold, so it was hard to mold the deadening to form. The aluminum on this stuff isn't nearly as flimsy as on dynamat. When I would heat dynamat with a heat gun to get it flexible, the dynamat would fold under its own weight. This second skin damplifier pro doesnt.
Got part of the floor done. I'm trying to avoid putting any damp pro over the caulking for the seams, as thats where the stock stuff wasnt sticking to. I'll go over it with luxury liner pro. More cutting for me, but less worries later.
There will be three layers everywhere forward of the seats. It may be past the point of diminishing returns for road noise, but I'm bolting speakers that take a lot of power to the floors. I don't want any vibrating panels, and one layer just wont cut it for that.
So, neon owners know that the bezel around the headlight switch rattles. Its also not completely removable, so I didn't feel to bad about doing this...
No more annoying rattles over bumpy roads, or during the 50 mph roads that seemed to make it resonate so bad.
Old 02-26-2011   #25
req
req's Avatar
Send a message via AIM to req
crazy install so far man, just take your time and try not to cut corners. it will bite you in the ass in the long run. i didnt wire my car that way i should have when i first installed my stereo, and i just ripped it all out and redid it haha.
so do it right the first time man!!
req is offline   Reply With Quote
