FS HUGE LOT! MAJOR SELL OFF! PPI Art, Linear Power, Audison, Kicker SX, Pioneer RF!!!
HEADS UP!!! This thread is a merging of over 11 different for sale threads by the seller. Please scan through all the pages to see everything that he has for sale.
Bret
PPI-ART COLLECTOR
Nice shape big belle, actual numbers from the Car Audio Magazine test below:
Class AB Output power @1% THD 1kHz 14.4 volts
Four @ 4 ohms 4 x 80 watts
Four @ 2 ohms 4 x 135 watts
Bridged @ 8 ohms 2 x 163 watts
Bridged @ 4 ohms 2 x 270 watts
Class D Output power @2% THD 1kHz 14.4 volts
Mono @ 4 ohms 1 x 410 watts
Mono @ 2 ohms 1 x 682 watts
Mono @ 1 ohm 1 x 1120 watts
Works nicely, got it from Ebay and the sub channel was dead. Got a local shop to fix it up recently. 6x 30 amp fuses built in... $400 shipped via Canada Post/USPS to the lower 48.
Sick 4 channel, full digital crossover section, DSP.
•Kicker SX900.4 4-Channel amplifier with DSP
•32-Bit User-Programmable Digital signal Processing
•RMS power Rating:
◦107 watts x 4 channels @ 4 Ohms
◦213 watts x 4 channels @ 2 Ohms
◦425 watts x 2 channels @ 4 Ohms Bridged
•UltraMatch Gain Structure, single-band parametric KickEQ (Variable Gain, Boost, and Q), and crossovers ( Variable High and Low-Pass Filters )
•SAMS (Stereo And Mono Simultaneously)
•ISIS (Indicate Status & Input Settings) Interface
•BLAST Port (Bass Level And signal Transfer) Provides Remote Bass Level Control and control signal transfer between multiple SX amplifiers
•Kompressor
•Adjustable Phase Control: 0 - 180°
•EndKaps: Cast aluminum, custom, removable covers to protect and hide all your wiring connections to the amplifier
•SickBay and On Board Diagnostics
•Frequency Response: 20 Hz - 200 kHz
•Variable Input Sensitivity: 1V / 2V / 4V / 8V / 16V
•Signal-to-Noise Ratio: >100 dB
•MOSFET power Supply
•RCA Outputs: 1 Pair
•Remote Gain Control
•Fan Cooling
•Dimensions (With Endcaps): 25-3/4" L x 10" W x 2-1/2" H
The SX900.4 is a four-channel amp, rated to produce 115W x 4 into 4Ω, 225W x 4 into 2Ω and 450W x 2 into 4Ω.
Here is part of a review Dave MacKinnon did on the amp exemplifying its underrated specs:
"I was anxious to get the SX900.4 on my bench for some listening and measurement. First to the power - the amp made 173W per channel at 4Ω and 335W per channel at 2Ω. It didn't seem to care much about supply voltage and efficiency was about 60 %.
Loaded down with a 4Ω bridge on each channel the amp cranked out an incredible 458W per channel at 13V and 518W per channel at 13.6V. What was really cool, thanks to the digital gain control, was that the two channels' output varied by less than 0.00955 dB-effectively identical."
Here are the amp's features:
Built-In 32-Bit Digital signal Processor (DSP)
* 24-bit audio resolution
* 44.1kHz sampling frequency
* 0.7 millisecond response time allows additional, non-digital amplifiers to be used in the system
* Kompressor adjustable expansion / compression system
o Contour Mode fattens bass output at low to moderate listening levels
o Attack Mode enhances the sharp, quick attack in bass and midbass
o Redline Mode controls dynamic peaks for a more even output
* Digital high- and low-pass crossovers
o 10Hz – 16kHz variable high-pass frequency adjustable in 1/12th octave steps
o 30Hz – 20kHz variable low-pass frequency adjustable in 1/12th octave steps
o 6 – 36dB / octave variable crossover slopes
* Digital KickEQ fully parametric equalizer
o 20Hz – 20kHz variable frequency adjustable in 1/12th octave steps
o 0.5 – 10 variable bandwidth (Q) in 0.5 increments
o Boost or cut 0 – 18dB in 1dB steps
* Selectable left / right independent phase
* UltraMatch gain control circuit
o 5-stage input circuit for optimal level matching and the best signal-to-noise (S/N) ratio
o 1, 2, 4, 8, or 16-volt input range selection
o 12dB adjustment in 0.5dB steps for each input range
* Memory presets
o 4 presets for installers or tweak-a-holics
o Each preset is pre-loaded with common settings for easy setup
o Customize each preset for quick access
* Sick Bay diagnostics
o Real-time amplifier diagnostics and troubleshooting
o Keeps a running history of past trouble faults
o Check current voltage and temperatures
o Recall minimum and maximum voltages
o Recall minimum and maximum temperatures
* ISIS Vacuum Fluorescent Display
The flexibility and precision of DSP is just the beginning. The SX series is all about pure, clean, audiophile power, with handpicked tight-tolerance components and a no-holds-barred design philosophy.
Features:
* Audiophile components throughout
o Double-sided glass epoxy circuit boards with large copper traces
o Oversized Litz wound toroidal transformers for improved efficiency
o Large TO-218 bipolar output devices for higher current capacity and reduced resistance
o Triple Darlington output device configuration for lower distortion and excellent sound quality
o Custom-wrapped HFQ electrolytic capacitors for maximum bass impact
o Precision tolerance metal film resistors and poly film capacitors in the audio signal path
* Isolated dual power supplies
* Fan cooled
* Remote level control
* Custom-tooled oversized power and speaker output terminals
* PreAmp Signal Transfer (PAST) output rca lack
* Soft muting circuit controlled by the DSP
* Soft start turn-on circuit for deduced startup load
* Removable cast aluminum EndKaps
My postal code I am shipping from is V4N 0C3, you can fill in your zip code, go from there. Add on a few inches to each dimension for packaging, and a couple of pounds.
Don't know much about this unit, I believe it helps with reducing jitter from the DAC. Some info here: Audio alchemy DTI
Appear to be new. Spec sheet mentions a copyright of 1995, which seems right to me. When was the last time you saw "Made in Japan" on a piece of car audio gear?
$60 shipped CONUS/Canada:
Canada Post/USPS:
FS: Crystal Mobilesound crossovers from 3 way comp set
Crystal XO-643
New, slightly used looking from being in storage
$30 shipped a pair, CONUS and Canada:
Canada Post - USPS:
These came with the CPE/CSC 643 component sets, 6.5"/4"/1" combination. Left over from when I worked in a shop that sold Crystal in the mid 2000's.
Tweeter wires were short, soldered on new ones, heatshrunk them. Tweeters and mids have been metered, all read within spec. Crossovers are stuck together, possibly with two sided tape, can't seem to separate them. No grills, no tweeter hardware, what you see is what you get.
Re: FS: Crystal Mobilesound crossovers from 3 way comp set
Rezdawg, $30 shipped is after the drop. Let me know. Jroo, not sure. I could open one up and check out the values maybe, pretty sure it is 12db/octave.
