FS: L18RNX/P $110 shipped OBO - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 07-23-2007   #1
fredridge's Avatar
Rep Power: 146 fredridge will become famous soon enoughfredridge will become famous soon enoughfredridge will become famous soon enoughfredridge will become famous soon enoughfredridge will become famous soon enoughfredridge will become famous soon enough
Default FS: L18RNX/P $110 shipped OBO
I traded for these with Tyroneshoes and will not be using them. They are used
Specs
Seas H1224 7" aluminum cone woofer. The stiff cone coupled with the low loss rubber surround shows no sign of cone edge resonance and distortion associated with soft cones. Tremendous bass precision. A bullet shaped phase plug reduces compression due to temperature variations in the voice coil, avoids resonance problems which would occur in the volume between the dust cap and pole piece and increases long term Power handling. Large magnet for good efficiency. Raised Spider and bumped back plate for increased Power handling and lower mechanical distortion.
Outside diameter 176mm
Cut out 145.2mm
Depth 80mm
25.4mm = 1" = 2.54cm
Nominal Impedance 8 Ohms
Recom. frequency range 40-2500 Hz
Short term max. power 250 W
Long term max. Power 100 W
Sensitivity (1W/1m) 87 dB
Voice Coil Diameter 39 mm
Voice coil height 18.0 mm
Air gap height 6.0 mm
Linear coil travel (p-p) 12.0 mm
Max. coil travel (p-p) 22.0 mm
Magnet weight 0.64 Kg
Total weight 1.92 Kg
Voice coil resistance 6.1 Ohms
Voice coil inductance 1.0 mH
Force factor 6.7 N/A
Free air resonance 33 Hz
Moving mass 14 g
Suspension compliance 1.7 mm/N
Suspension mech. resistance 1.6 Ns/m
Effective piston area 126 sq. cm
Vas 35.0 Liters
Qms 1.89
fredridge is offline   Reply With Quote Quick reply to this message
Old 07-23-2007   #2
durwood's Avatar
Retired from DIYMA Market
Rep Power: 147 durwood will become famous soon enoughdurwood will become famous soon enoughdurwood will become famous soon enoughdurwood will become famous soon enoughdurwood will become famous soon enoughdurwood will become famous soon enough
Default Re: FS: L18RNX/P $110 shipped OBO
WTB: Seas L18RNX or W18NX
durwood is offline   Reply With Quote Quick reply to this message
Old 07-23-2007   #3
fredridge's Avatar
Thanks Durwood. I think he was looking for something a little more Minty
Old 07-23-2007   #4
Rep Power: 187 tyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura about
good luck. I got these from team shimano and they are in perfect working order. Skuffs wont make a diffference.
Old 07-23-2007   #5
Rep Power: 0 avddreamr will become famous soon enoughavddreamr will become famous soon enoughavddreamr will become famous soon enoughavddreamr will become famous soon enoughavddreamr will become famous soon enoughavddreamr will become famous soon enough
hmm 100 shipped, what's your paypal?
Nes
avddreamr is offline   Reply With Quote Quick reply to this message
Old 07-23-2007   #6
Hillbilly SQ's Avatar
iNCORRECT pOLITICALLY
Complacent Audio
Incoherent rambler
Rep Power: 243 Hillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond repute
i never had a problem with them. and keep in mind they were in 2 different door installs (mine and tyrones). i soldered the pigtails on to take all the stress off the terminals during install. if you want a perfect set, pony up and buy them new. if you want a set that's had SOME wear but still in perfect shape, these are great candidates at that price.
2014 Grand Cherokee Limited-bone stock "premium" 10 speaker system for now. In the works-JL Fix, c-dsp 6x8, JL XD800/8, stock rears controlled properly by minidsp 2x4 with rear fill plug-in, Arc 10, SB Acoustics SB17NRXC35-4, Seas neo aluminum
Old 07-23-2007   #7
fredridge's Avatar
Nes, ygm
thanks guys, my only regret is I didn't get to try them, but need the money for something a little extra on my install.
BTW- I really just wanted to use the term "Minty" to describe to condition
Old 07-23-2007   #8
unpredictableacts's Avatar
The Anti-Rice
Rep Power: 154 unpredictableacts will become famous soon enoughunpredictableacts will become famous soon enoughunpredictableacts will become famous soon enoughunpredictableacts will become famous soon enoughunpredictableacts will become famous soon enoughunpredictableacts will become famous soon enough
Minty-fresh.
still have those DLS mids?
unpredictableacts is offline   Reply With Quote Quick reply to this message
Old 07-23-2007   #9
fredridge's Avatar
nope, traded those for these and I think he sold them... I do still have my ir6.3's
Originally Posted by unpredictableacts View Post
Minty-fresh.
Old 07-23-2007   #10
The Anti-Rice
using those?
Old 07-23-2007   #11
fredridge's Avatar
Yep.... Bing will be picking my Car up this weekend and working on the install next week
using those?
Old 07-23-2007   #12
The Anti-Rice
LOL wished i was in cali......could have done several jobs by now....Bing has all the fun.
Old 07-23-2007   #13
fredridge's Avatar
I would say move out here, but tons of competition and very expensive to live... which makes quality workmanship expensive
Old 07-23-2007   #14
Rep Power: 143 poochieone will become famous soon enoughpoochieone will become famous soon enoughpoochieone will become famous soon enoughpoochieone will become famous soon enoughpoochieone will become famous soon enoughpoochieone will become famous soon enough
Fredridge, I am indeed looking for something more 'Minty', but these aren't out of contention.
PM sent.
poochieone is online now   Reply With Quote Quick reply to this message
Old 07-26-2007   #15
skylar112's Avatar
Rep Power: 148 skylar112 will become famous soon enoughskylar112 will become famous soon enoughskylar112 will become famous soon enoughskylar112 will become famous soon enoughskylar112 will become famous soon enoughskylar112 will become famous soon enough
Hey Fredridge,
Im interested in the L18s, if Nes doesn't take them let me know. I have money at hand.
Pioneer AVIC-F90BT, 60gb video ipod,iPhone, Kenwood X1R, JL 10W6V2, rest is stock and happy.
skylar112 is offline   Reply With Quote Quick reply to this message
Old 07-26-2007   #16
fredridge's Avatar
Skylar... Pm'd you, but he did buy them so they are
SOLD
Originally Posted by skylar112 View Post
Hey Fredridge,
Old 07-26-2007   #17
skylar112's Avatar
darn!! oh well Nes is a good guy anyway.
Old 07-26-2007   #18
fredridge's Avatar
seems like it. I think I shocked him when I called him on the phone because I was getting a different city from USPS than the one he gave me
Old 07-26-2007   #19
skylar112's Avatar
I should have mentioned something to Nes about you. Telling him that you were ok from what I saw in the forums. I used to talk to him like everyday.
