HAS anyone ever tested head units for voltage output?
I know I have seen a post here and there where someone said a head unit did not clip at full volume.
Makes me wonder what voltage output is on my kenwood excellon 891 and all the others I have tried.
anyone ever tested multiple units to see?
what is the process to test what the voltage output actually is at the end of your rcacable that your about to plug into the amp?
Joseph Goebbels, Nazi propaganda minister during World War II said: “It is the absolute right of the State to supervise the formation of public opinion; truth is the greatest enemy of the State.”
Re: HAS anyone ever tested head units for voltage output?
I tested my Clarion on a meter and a scope... Pleasantly surprised that it output a legit 4V and that it never clipped a 0dB tone, even at 40/40 volume. Not bad considering that I only paid $100 refurb'd for it.
'10 Toyota Corolla S → Dynamat Xtreme & Cascade VB2 → Clarion CZ500 ⱡ JBL GTE422 22-Band EQ ⱡ JBL P660C 6.5" ⱡ RF Punch 200-2 ⱡ JBL P1224 ported 2.3ft^3 @ 28Hz ⱡ RF Punch 300-1 ← 2Ω, all of it
how do you test it with a voltage meter?
I know some of the people have tested some units. never seen a test like they do with drivers.
i tested my old cda 7930, 7949 and 7941. no clip at 0db. sub output will clip on them at +7 at full output (35) my old ivac800 clipped at 28/29 0 db. have not tested my d310 and never got to test my 9815.
Originally Posted by TOOSTUBBORN2FAIL
P99
Doesnt clip on Tweeter, Mid, and Woofer channels, voltage is right around 2 volts at 62/62, tested on a tektronix scope.
Sub channel clips at 62/62, not at 61/62, with everything flat. It showed about 5.4 volts. At 61, is shows somewhere around 4.7
P99 only putting out 2 volts a volume but more than double to sub. interesting.
that is what I would like to know.
anyone test out a older Kenwood excellon?
or tell me what to do to test it myself.
Originally Posted by IDGAF
Where are you in La? We could put it on my little scope. But generally, just probe the amp end of the RCA's with a DMM to get output voltage.
I am in shreveport. I will mess with it.
i did test an older model KENWOOD EXCELON KDC -X969 . this h.u. never clipped at full volume and put out 3.5 volts . it was werid tho because the last few turns it seamed like it would drasticly increase the voltage .
they are not a linear volume know. they do make bigger jumps as you get toward the top of the volume level. every kenwood excelon we've tested did not clip(disclaimer---->) resolution at 35/35 was hard to tell if there may have been a slight clip or not.
i used an smd dd1 to test the h.u. and mine did not clip
I think alpines are the opposite of that. It seems like they increase normally until about 28/35 and then it's very gradual until 35/35. Maybe they did that because they know most people set gains at 3/4 volume. idk.
id prefer more of a gradual increase . my h.u. is worthless below 20 /35
then buy my 9855 as its not needed now. will come out soon
Originally Posted by electro
I dont work much with DMMs I only know how to get the voltage of an amp to speaker. Where would you put the ground for the RCAs?
how can you tell with a DMM that the headunit is clipping?
A local mechanic/Electrician may have a O-Scope you can borrow for a few minutes.
Originally Posted by MarkZ
About Volume Controls
Most audio software nowadays has sliders or even rotating knobs to control the volume. The intention is to simulate the sliders of ‘classic’ audio hardware. Unfortunately, there is one thing about a lot of volume sliders which makes them a pain in the ass: they are LINEAR. You might ask, what could possibly be wrong with a linear slider: it is zero at the one end, 100% at the other end, and neatly linear in between, isn't that just ideal? The answer is a big no.
Just try this: open your favourite audio player, start playing a song, grab the volume slider, and wobble it to and fro at the ‘loud’ end of the volume range. Next, do the same at the ‘silent’ end of the volume range. Chances are that you will experience the following: almost no audible volume variations at the ‘loud’ end, and extreme volume variations at the ‘silent’ end even if you made smaller excursions with the latter. In that case you can be pretty sure the slider is linear.
A few popular applications that suffer from this flaw at the time of this writing, are:
•QuickTime Player
•iTunes (fixed in the newer versions!)
•Windows Media Player
•YouTube and pretty much every other Flash-based video player(1).
The evil has even spread to hardware. Velleman sells a solderable kit of a graphic equaliser, K4302. I don't know if this has been corrected now, but when I bought the kit around 1995 it had linear sliders while they should be logarithmic (C law if I'm correct). Even the G3 iMac's volume control was linear, and I'm afraid that this is just one of many examples. The result is that the most silent volume setting is still way too loud even if the volume increments are small, and the perceived maximum volume level is already reached around the middle of the slider. Ultimately this leads to frustrated people cursing the damn volume control, or feeling uneasy while using your product without really knowing why. Luckily there are lots of products with correct volume controls, but I have the feeling that they are only a minority.
What is going wrong?
Now what exactly is wrong with a linear volume slider? The answer lies within the way our ears perceive sound. The point is that our sensation of ‘loudness’ is LOGARITHMIC.
This means that with silent sounds, we are much more sensitive to small variations in amplitude than with loud sounds. This allows us to cope with a very large dynamic range of sound amplitudes. It also means that with a linear volume slider we have a logarithmic sensation of volume variations, and that just doesn't feel right. At the right you can see a logarithmic curve. Two identical sections are marked on the horizontal axis (read: the volume slider). The vertical axis shows the perceived volume changes. As you can see, the corresponding section marked by the curve at the ‘silent’ end is much larger than at the ‘loud’ end.
The solution to implementing a REAL volume slider is fairly simple: instead of being linear, a volume slider should be EXPONENTIAL. Because log(exp(x)) = x, hence the sensation of volume variations will be linear, and that's what we want.
