Old 06-24-2012   #1
Rep Power: 91 Ultimateherts will become famous soon enoughUltimateherts will become famous soon enoughUltimateherts will become famous soon enoughUltimateherts will become famous soon enoughUltimateherts will become famous soon enoughUltimateherts will become famous soon enough
Default Stuffing a port on a ported subwoofer box makes it sealed???
Back when I just started getting into car audio years ago a friend told that he had stuffed the port on his subwoofer box with socks to make it a sealed enclosure!!!
Other than altering the enclosure size, can you stuff a port or do you have to physically remove it in order to make the box sealed?
New SUV System:
I am never done!!!
Ultimateherts is offline   Reply With Quote
Old 06-24-2012   #2
underdog's Avatar
Rep Power: 28 underdog will become famous soon enoughunderdog will become famous soon enoughunderdog will become famous soon enoughunderdog will become famous soon enoughunderdog will become famous soon enoughunderdog will become famous soon enough
Default Re: Stuffing a port on a ported subwoofer box makes it sealed???
Layered Front Baffle
In addition to strength benefits if u counter sink ur sub , the double (maybe for you triple) baffle makes your box look better\neater too.
Use lots of adhesive
underdog is offline   Reply With Quote
Old 06-24-2012   #3
BuickGN's Avatar
Rep Power: 96 BuickGN is a name known to allBuickGN is a name known to allBuickGN is a name known to allBuickGN is a name known to allBuickGN is a name known to allBuickGN is a name known to allBuickGN is a name known to allBuickGN is a name known to allBuickGN is a name known to allBuickGN is a name known to allBuickGN is a name known to all
As far as I know, once you block the port off, it no longer functions as a port. It would be like throwing a piece of PVC inside of a sealed box, no effect other than a tiny amount of volume taken up. I would probably use something a little more solid than socks if you want to seal up a ported box like MDF.
'06 TL. Front stage- Dynaudio 110, 430, 182.... AE IB15s....JL HD600/4, HD900/5....PS8....SecondSkin....
BuickGN is offline   Reply With Quote
Old 06-24-2012   #4
trojan fan's Avatar
Rep Power: 111 trojan fan has a brilliant futuretrojan fan has a brilliant futuretrojan fan has a brilliant futuretrojan fan has a brilliant futuretrojan fan has a brilliant futuretrojan fan has a brilliant futuretrojan fan has a brilliant futuretrojan fan has a brilliant futuretrojan fan has a brilliant futuretrojan fan has a brilliant futuretrojan fan has a brilliant future
I'm sure a sock only would have substantial air leaks
trojan fan is offline   Reply With Quote
Old 06-24-2012   #5
trojan fan's Avatar
Old 06-24-2012   #6
BEAVER's Avatar
Rep Power: 94 BEAVER will become famous soon enoughBEAVER will become famous soon enoughBEAVER will become famous soon enoughBEAVER will become famous soon enoughBEAVER will become famous soon enoughBEAVER will become famous soon enough
I believe he suggesting to add a layer of MDF to the front of the enclosure. Seals the hole and creates a stiffer baffle, as well.
Have stuff. Makes noise.
BEAVER is offline   Reply With Quote
Old 06-25-2012   #7
Rep Power: 25 lbp775 will become famous soon enoughlbp775 will become famous soon enoughlbp775 will become famous soon enoughlbp775 will become famous soon enoughlbp775 will become famous soon enoughlbp775 will become famous soon enough
I'm actually using a Hsu subwoofer in my theater that allows you to tune it by plugging up the ports with a pair of really dense foam pieces.
Check out the pics.
VTF-2 MK4 Subwoofer
lbp775 is online now   Reply With Quote
Old 06-25-2012   #8
Victor_inox's Avatar
Rep Power: 25 Victor_inox will become famous soon enoughVictor_inox will become famous soon enoughVictor_inox will become famous soon enoughVictor_inox will become famous soon enoughVictor_inox will become famous soon enoughVictor_inox will become famous soon enough
Check out the pics.
VTF-2 MK4 Subwoofer
B&W and KEF doing that all the time.
BRUTE FORCE - IF IT DOESN'T WORK, YOU'RE JUST NOT USING ENOUGH !
In that case fuck all you shit talking pussy motherfuckers suck my cock you stupid fucking cunt bags.
Victor_inox is offline   Reply With Quote
Old 07-07-2012   #9
Rep Power: 0 prion will become famous soon enoughprion will become famous soon enoughprion will become famous soon enoughprion will become famous soon enoughprion will become famous soon enoughprion will become famous soon enough
If you have a round port, use a Test Ball pneumatic plumbing plug. Works great for testing purposes, could also be a long term solution.
prion is offline   Reply With Quote
Old 07-07-2012   #10
Rep Power: 18 for2nato will become famous soon enoughfor2nato will become famous soon enoughfor2nato will become famous soon enoughfor2nato will become famous soon enoughfor2nato will become famous soon enoughfor2nato will become famous soon enough
A sealed enclosure does not a sock make!
Sent from my SGH-T989 using Tapatalk
for2nato is online now   Reply With Quote
Old 07-08-2012   #11
Rep Power: 139 sqshoestring is a jewel in the roughsqshoestring is a jewel in the roughsqshoestring is a jewel in the roughsqshoestring is a jewel in the roughsqshoestring is a jewel in the roughsqshoestring is a jewel in the roughsqshoestring is a jewel in the roughsqshoestring is a jewel in the roughsqshoestring is a jewel in the roughsqshoestring is a jewel in the roughsqshoestring is a jewel in the rough
It mostly works. If you stuff something in a port somewhat hard it will not flow enough air to matter to the sub, it will act very close to sealed. Though the ported box should be larger than ideal sealed, that would tune it a little lower. I know everyone on here says seal the crap out of everything but in reality the problem is noises from not sealing, the problem is not changing the response of the speaker until the leak gets large enough to flow a percentage of air. I don't know that percentage, but I know leaky boxes and IB don't care much about it far as the speaker response....leaks within reason of course. I've made mock ply boxes screwed with no sealant and fast hand skilsaw cuts that were not perfect, they worked fine. Likely made some noises from the leaks but I certainly could not hear them in the car with box in trunk. Made a permanent box and it sounded exactly the same. Speaker cone moves pretty fast, so the leak has to flow that fast too and a little tiny crack is not going to do that. Also your relationship of depth is like a port, meaning if the leak is deep it will tune like a port and not be out of phase and cancel everywhere. Such as a drill hole in 3/4 material, it would have to be a larger drill to tune high and cancel or unload (if it could flow enough to unload the driver).
sqshoestring is offline   Reply With Quote
Old 07-08-2012   #12
Rep Power: 39 Spyke will become famous soon enoughSpyke will become famous soon enoughSpyke will become famous soon enoughSpyke will become famous soon enoughSpyke will become famous soon enoughSpyke will become famous soon enoughSpyke will become famous soon enough
^ What he said...I think. Yes as long as it is mostly sealed it will function as a sealed box. If you push the cone in(evenly and firmly/and don't smash the dustcap) it should come back out slowly. If you push the cone in and it comes back too fast then it's not sealed well enough. I saw a box once that had removable plugs for the ports and I laughed. Reason being is that like Sq said a ported box is likely larger than it's sealed counterpart for the same sub. IMO, if it sounds good to you there's nothing wrong with it. However you could pick up a dual sub box for about 50 bucks so why bother with it.
EMPTY speaker BOXES from Parts Express ship same day and come with 45 day money back guarantee. Free Shipping Available. Order free 10,000 product catalog.
Spyke is offline   Reply With Quote
Old 07-08-2012   #13
Thats the thing, if you have tons of test equipment and are tuning for an exact response, or you don't want any funny whistling/vibration noises in your SQ system then this is important to you. Some quality workmanship should avoid the issues anyway. I suppose plugging a port is more tuning options than none, but I just build the box to tune the way I want in the first place. It could be helpful with bought boxes even if the tuning is not entirely proper, I mean what else do you do with them. It would be cool to have an adjustable port and you could make the box smaller by inserting things inside. Unless its terrible you can do it all with electronics anyway.
If you take your ported box and stuff something in the port you will find it does not take much to make it inoperative, unless you lay some big power on it. Of course you lose the big spl bump from the port. Some guys have made boxes they change the ports for SPL and back to daily driver, but it may take some searching to find the threads. IIRC they don't go sealed both setups were ported on ones I saw.
Old 07-08-2012   #14
Rep Power: 0 jonbuilds will become famous soon enoughjonbuilds will become famous soon enoughjonbuilds will become famous soon enoughjonbuilds will become famous soon enoughjonbuilds will become famous soon enoughjonbuilds will become famous soon enough
Can of worms potential here very high...but if you want a sealed enclosure, then make a sealed enclosure by assuring that any openings are at LEAST as air tight as the least air-tight part of the rest of the enclosure, using a material at least as rigid as the rest of the box. (so I guess if your box is made of sox...) Sealed enclosures change the response characteristics of the enclosure and its interaction with the driver as compared to ported enclosures. I personally prefer a heavy, sealed enclosure designed with the speaker mfg's specs in mind, but that's just me. No reason to add ANOTHER variable (socks, tissue, rubber baby bumpers) if you can help it, since the size, placement, material, input power, and driver performance already give you plenty enough to think about and improve upon.
All that said, can't hurt to play with it. You might stumble on your vehicle's happy harmonic.
Best of luck
Jonathan
“A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools.” - Douglas Adams
jonbuilds is offline   Reply With Quote
Old 07-13-2012   #15
Rep Power: 45 ChaunB3400 will become famous soon enoughChaunB3400 will become famous soon enoughChaunB3400 will become famous soon enoughChaunB3400 will become famous soon enoughChaunB3400 will become famous soon enoughChaunB3400 will become famous soon enough
Just never understood why anyone would want to do this, if you want a sealed box build a sealed box, if you want a ported box build a ported box
ChaunB3400 is offline   Reply With Quote
Old 07-13-2012   #16
I agree. I enjoy building enclosures and my audio storage room is proof. However, not everyone has the means to do so, imho.
Old 07-14-2012   #17
Rep Power: 73 Catman is on a distinguished roadCatman is on a distinguished roadCatman is on a distinguished roadCatman is on a distinguished roadCatman is on a distinguished road
Check out the pics.
VTF-2 MK4 Subwoofer
I agree with the above. What you are doing is making an
aperiodic membrane.
Loudspeaker enclosure - Wikipedia, the free encyclopedia
It depends on how tightly you pack the sock. I have socks in a pair of speakers I'm using in a guest bedroom. They sound better. I thought the speakers needed a little more damping.
Also ...what others have said is true. In general a speaker requires a specific enclosure to meet specific applications. If you need a sealed ...build a sealed. You are getting into a bit of 'Voodoo science' with aperiodic membranes unless you have the ability and equipment to test what you are doing.
If money is the root of all evil, why do churches beg for it?
Give me liberty ...or I'll get up and get it myself.
An armed man is a citizen ...an unarmed man is a subject.
Catman is offline   Reply With Quote
Old 07-14-2012   #18
KSUWildcatFan's Avatar
Rep Power: 90 KSUWildcatFan will become famous soon enoughKSUWildcatFan will become famous soon enoughKSUWildcatFan will become famous soon enoughKSUWildcatFan will become famous soon enoughKSUWildcatFan will become famous soon enoughKSUWildcatFan will become famous soon enough
Send a message via AIM to KSUWildcatFan Send a message via Yahoo to KSUWildcatFan
EEEEEEEP. Why do this?! Whyyyy?! I guess if the size is right then whatever. Can't imagine how it'd be close though..
'94 Mustang GT convertible layout:
Pioneer DEH-P01/DEX-P99RS (still need to buy one!), Image Dynamics CD2/Arc Audio 2050CXL, Image Dynamics X57/Arc Audio 2100CXL, 2x Stereo Integrity Mag V4/Arc Audio 1500DR
KSUWildcatFan is offline   Reply With Quote
Old 08-06-2012   #19
Socks are pretty dense, you pack them in and it is not AP its just an oversized sealed. Air has to flow through the membrane to be AP and it does not take much to stop that, excepting maybe some hard low bass notes, and that does not really count.
I can see how plugging ports could tell you different tuning is better/worse. IMO it does not matter how big a sealed is anyway, just different tuning and can be different power handling. I always made them larger than they said when I used them, though I tend to not use sealed much. But I will admit I would duct tape a port shut if it sounded better and all I had was tape and that box.....the sound is what counts.
Old 08-06-2012   #20
Rep Power: 0 scott0482 will become famous soon enoughscott0482 will become famous soon enoughscott0482 will become famous soon enoughscott0482 will become famous soon enoughscott0482 will become famous soon enoughscott0482 will become famous soon enough
Check out the pics.
VTF-2 MK4 Subwoofer
I wanted to do this years ago.
In a simplistic world. Plugging both ports would be sealed. But it would be a rather large sealed box. Plugging one port would be tuned lower, but removing both plugs would tune it higher.
It started to get complicated though. To really get what I wanted, I would have had to have the 2 ports be different diameters and 2 different lengths, but both have the same volume as each other so it could be run with both ports open. It would have given me 3 different tuning points, as well as sealed, but any calculation mistakes would have probably made it sound like crap.
scott0482 is offline   Reply With Quote
Old 08-07-2012   #21
I hear you! Luckily Hsu has done the research and development for me. All I had to do is insert or remove the foam pieces to my liking.
Old 08-31-2012   #22
Columbus Car Audio
12v Product Specialist
Rep Power: 22 D-Bass will become famous soon enoughD-Bass will become famous soon enoughD-Bass will become famous soon enoughD-Bass will become famous soon enoughD-Bass will become famous soon enoughD-Bass will become famous soon enough
before i built my kickpanels, I once had a discussion with larry fredericks about taking my currently sealed kickpanels and porting them up into the dash with long flexible ports that would be stuffed with polyfill. seemed like it would model ok. i may still try it some day, but for now they sound great as is.
D-Bass is offline   Reply With Quote
