HIGHER END AMP SQ IS A MYTH - Page 139 - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 01-26-2017   #3451
Rep Power: 59 BMW Alpina will become famous soon enoughBMW Alpina will become famous soon enoughBMW Alpina will become famous soon enoughBMW Alpina will become famous soon enoughBMW Alpina will become famous soon enoughBMW Alpina will become famous soon enough
Default Re: HIGHER END AMP SQ IS A MYTH
Originally Posted by Elektra View Post
Trust me.... I have many $1000's in equipment at home waiting to be installed....
But right now .... I have a std OEM system in my E90 wide band mids in the door bass under your butt rears and no tweeters and my IPhone connected to the BMW AUX and for now it's decent enough to listen to music while I drive
For some reason the E90 sounds a lot better than my F10 OEM system....
I use to have a 2005 E90 with the second from the base sound system,
it was before the facelift on the E90... no bluetooth too.
it came with sub under the seat, mid in the door and tweeter in the a pillar.
Mine is the RHD version back in my home country...
yours don't have tweeter?
anyway, yes it sound quite good for standard OEM system...
BMW Alpina is offline   Reply With Quote Quick reply to this message
Old 01-26-2017   #3452
Rep Power: 68 Elektra is on a distinguished roadElektra is on a distinguished roadElektra is on a distinguished roadElektra is on a distinguished roadElektra is on a distinguished road
Mine has no tweeter also RHD... pretty decent actually
Elektra is offline   Reply With Quote Quick reply to this message
Old 4 Weeks Ago   #3453
Rep Power: 58 ssclassa60 will become famous soon enoughssclassa60 will become famous soon enoughssclassa60 will become famous soon enoughssclassa60 will become famous soon enoughssclassa60 will become famous soon enoughssclassa60 will become famous soon enough
Interesting, I'm a big Sounstream guy (my handle) and am in the midst of install in my older E39 M5. Had the dsp system with 2 IB 10s. Sounded decent but had to put my old stash to some use. Now running Reference 10Rs and 2 Class A Picasso's
HU - Dynavin E39 N6
Midbass - SI TM65 Mid/Tweet - BG Neo8PDR Subs - Soundstream 10R IB (soon) Processing - Phoenix Gold/DSP tbd Amps - Soundstream MC500, Reference Class A Picasso
ssclassa60 is offline   Reply With Quote Quick reply to this message
Old 4 Weeks Ago   #3454
Rep Power: 55 mbradlawrence will become famous soon enoughmbradlawrence will become famous soon enoughmbradlawrence will become famous soon enoughmbradlawrence will become famous soon enoughmbradlawrence will become famous soon enoughmbradlawrence will become famous soon enough
E90 is the easiest upgrade EVER. Stock locations are good, depending on HU, signal is flat. Morel is almost a straight swap (need to make thin adapters -- or call Musicar). Even without DSP, these cars are just great for stock location upgrades. woofers under the seats only play 70-200 so no need for upgrade there!!!!!!
BMW >> Mobridge DA3 >> Arc 600/4 to Morel 230 tweets/Morel Hybrid 4" mids and Arc 600/4 to stock Harmon Kardon 8" mid-basses and single 10W3.
mbradlawrence is offline   Reply With Quote Quick reply to this message
Old 4 Weeks Ago   #3455
Gonna run a passive system - kit 7 with crossblock and a Sony and a HV Venti for the fronts and Thesis Due for the subs - gonna use either one or 2 Focal 33WX subs
Old 4 Weeks Ago   #3456
Curious, redo door to put 6.5 in? That's way more work than my simple "plug and play" with slim woofers underseats.
Old 4 Weeks Ago   #3457
Yeah that's my plan redo the door to fit the midbass drivers - use possibly the stock 4" position for the midrange and sail for the tweeters
Just need to investigate the PLD on the drivers to try get them close to each other on each side
Use the limited Sony DSP and hope for the best - all else fails - Helix DSP PRO MKii will be used
Old 2 Weeks Ago   #3458
Rep Power: 0 Rainstar will become famous soon enoughRainstar will become famous soon enoughRainstar will become famous soon enoughRainstar will become famous soon enoughRainstar will become famous soon enoughRainstar will become famous soon enough
I come from the speaker home theater world.
Using the same pair of speakers, cables, power brick, and just changing the amp.
Class A 40wpc Single Ended Triode tube amp $6000msrp
vs
Class D 100wpc solid state amp $3000msrp
The tube amp is better at everything. bass is not as flabby, vocals are smoother. and highs are not overly bright and shrieking.
I am not sure why the class A at a lower power rating using 87db/1W efficiency speakers are a lot louder than the class D amp.
Suffice to say I sold the class D and I now love tubes.
I went to a purist meet someone using An Audionote $100,000 tube amp 45wpc, I was jealous of how that sounded. TLDR it is just my opinion that you do hit the glass ceiling, louder is not better, there are huge diminishing returns at some point. but overall I do see higher end amps > an average amp.
One day Ill be on time.
Rainstar is offline   Reply With Quote Quick reply to this message
Old 2 Weeks Ago   #3459
vs
I did a test with a HV Venti and a Brax MX2 and if I was put in a room and did a blind test I would not only tell a difference but I'll be able to tell you which amp is being played
Such was the difference between the 2... 2 very different sounding amps both excellent at what they designed to do...
Old 2 Weeks Ago   #3460
I800C0LLECT's Avatar
Rep Power: 135 I800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of lightI800C0LLECT is a glorious beacon of light
Sent from my Pixel XL using Tapatalk
My '13 Jetta build...not finished
I800C0LLECT is offline   Reply With Quote Quick reply to this message
Old 2 Weeks Ago   #3461
Victor_inox's Avatar
Victory Sonics
Victory Sonics
Rep Power: 155 Victor_inox is a jewel in the roughVictor_inox is a jewel in the roughVictor_inox is a jewel in the roughVictor_inox is a jewel in the roughVictor_inox is a jewel in the roughVictor_inox is a jewel in the roughVictor_inox is a jewel in the roughVictor_inox is a jewel in the roughVictor_inox is a jewel in the roughVictor_inox is a jewel in the roughVictor_inox is a jewel in the rough
What I find absolutely amusing is that all of you praising high end gear getting rid of your high end amplifiers right after such topic pops up on the forum again.
Here is life story for you....
Once upon a time I was a friend with very famous jazz musician.
In his band he has 2 drummers, one old and another young and energetic.
young dude was crazy fast , older dude not as much.
when I asked what is the deal with two drummers, he said:
" young dude still looking for his style, old one already found it."
Old 2 Weeks Ago   #3462
AudioHeir's Avatar
Rep Power: 0 AudioHeir will become famous soon enoughAudioHeir will become famous soon enoughAudioHeir will become famous soon enoughAudioHeir will become famous soon enoughAudioHeir will become famous soon enoughAudioHeir will become famous soon enough
In theory, different amps are built with different components, thus offering up different levels of distortion. This can obviously affect the sound signature. In most cases, if one amp has a cleaner sound, and it is audible, it will be due to the distortion percentage of that particular amp being lower than the one it sounds better than.
AudioHeir is offline   Reply With Quote Quick reply to this message
Old 2 Weeks Ago   #3463
Porsche's Avatar
Rep Power: 131 Porsche has a brilliant futurePorsche has a brilliant futurePorsche has a brilliant futurePorsche has a brilliant futurePorsche has a brilliant futurePorsche has a brilliant futurePorsche has a brilliant futurePorsche has a brilliant futurePorsche has a brilliant futurePorsche has a brilliant futurePorsche has a brilliant future
not this again, stick meet horse
2015 Macan Turbo (white), 2015 991 Turbo S (agate grey), 1996 993TT (guards red), 1970 Challenger (B5 blue), 1968 912 (?, in the bodyshop, trying to decide color), 1966 GTO (light blue), 1966 Fastback (gloss black)
Porsche is offline   Reply With Quote Quick reply to this message
Old 2 Weeks Ago   #3464
DC/Hertz's Avatar
Rep Power: 85 DC/Hertz will become famous soon enoughDC/Hertz will become famous soon enoughDC/Hertz will become famous soon enoughDC/Hertz will become famous soon enoughDC/Hertz will become famous soon enoughDC/Hertz will become famous soon enough
You might want to test yourself and see when you can hear distortion.
Also the speakers themselves cover up most of it.
Basic consensus. Nobody is hearing 1% THD, I barely hear 5%
You control the amplifiers distortion level.
DC/Hertz is offline   Reply With Quote Quick reply to this message
Old 2 Weeks Ago   #3465
strakele's Avatar
Rep Power: 126 strakele has a spectacular aura aboutstrakele has a spectacular aura aboutstrakele has a spectacular aura aboutstrakele has a spectacular aura aboutstrakele has a spectacular aura aboutstrakele has a spectacular aura aboutstrakele has a spectacular aura aboutstrakele has a spectacular aura about
Then do it. There are a couple people out there offering large sums of cash to anyone who can reliably do this.
Living Room System Build Log
Old 2 Weeks Ago   #3466
Victory Sonics
Victory Sonics
reliably is a key word. Everyone suddenly lost confidence in their abilities. It`s comical really.
Old 2 Weeks Ago   #3467
t3sn4f2's Avatar
Rep Power: 225 t3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to all
I'd say the absolute minimum is more around .3% (-50dB). I can consistently get down to .5%. But your point is still valid though since there isn't an amplifier out there worth its salt that has a sub clipping distortion level over .1%.
Old 2 Weeks Ago   #3468
Rep Power: 134 cmusic will become famous soon enoughcmusic will become famous soon enoughcmusic will become famous soon enoughcmusic will become famous soon enoughcmusic will become famous soon enoughcmusic will become famous soon enough
I guess your talking about the infamous Richard Clark $10,000 Amp Challenge. In reality the challenge was just a simple scientific test, a test that was actually testing ones hearing, not the amps. In a scientific test one eliminates all variables except for the one being tested. What was being tested was the listener's ability to hear differences between two amps that were adjusted to perform identically. Clark would tune all the amps, even down to adding filters and eq to the amps, to get them to produce the SAME signal at one volume level below clipping. The amps were adjusted to be identical. Then you had to go through several rounds of testing before he would pay out the money, which statistically cut down the listener's chance of winning the challenge. Every listening test of every round had to be perfectly picked or the challenge was over. I know of two people that actually won the challenge and afterwards Clark retested the amps and found one of them not to be adjusted equally with the other one being tested. He voided the challenge and would not pay out the money.
My opinion is that in the real world where amps are not adjusted to sound the same, amps can and do sound different, and although Clark was controversial and a real big bullsh!tter in the car audio world of the '90s, his technical teachings about car audio are valid.
Pioneer DEX-P99RS
Helix DSP Pro MKII w/ Director and HEC USB
Zapco Z150.6 LX, Z400.2 LX
Audiofrog GB10, GB25, GB12D4
Scan Speak Illuminator 18WU/4741T-00
cmusic is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to cmusic For This Useful Post:
bbfoto (2 Weeks Ago)
Old 2 Weeks Ago   #3469
Hillbilly SQ's Avatar
Blue Collar Audiophile
Complacent Audio
Incoherent rambler
Rep Power: 253 Hillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond reputeHillbilly SQ has a reputation beyond repute
Anyone ever thought about having high end amps on display in your ride at a competition just for eye candy but have something inexpensive but effective tucked away in hiding dishing the power? Would be a good way to really mess with people. I'd be willing to bet money that for a lot of people those decoy higher end amps would make the system sound better to people who weren't aware of the smoke and mirrors going on.
'14 Grand Cherokee Limited, OEM U-Connect 8.4a, JL Fix 82, c-dsp 6x8, Arc xdi1200.6v2, Soundstream tn1.1200d, stock rears controlled properly by minidsp 2x4 with rear fill plug-in, Alumapro Alusonic 12 ported, SB Acoustics SB17NRXC35-4, Seas Neo Aluminum...Rearfill done properly is a helluva drug!
Old 2 Weeks Ago   #3470
PPI_GUY's Avatar
Rep Power: 134 PPI_GUY will become famous soon enoughPPI_GUY will become famous soon enoughPPI_GUY will become famous soon enoughPPI_GUY will become famous soon enoughPPI_GUY will become famous soon enoughPPI_GUY will become famous soon enough
I've thought about that scenario as well. Of course it wouldn't take long for the cat to get out of the bag. You might get 4-5 people to audition the system before word would get around the event. That is, IF you came clean with the listeners as to what was really going on.
Would be an interesting experiment nonetheless.
Absolutely State Of The Art!
PPI_GUY is offline   Reply With Quote Quick reply to this message
Old 2 Weeks Ago   #3471
Victory Sonics
Victory Sonics
Im working on scenario like that since no one accepted my challenge yet.
Sent from my SAMSUNG-SM-G925A using Tapatalk
Old 2 Weeks Ago   #3472
Victory Sonics
Victory Sonics
I have very small amplifiers easy to hide. And very high end amps for looks.
Old 2 Weeks Ago   #3473
Porsche's Avatar
who cares, this is the stupidest test there ever was. it proves nothing other than to feed ones ego, you have zero to gain except to say "i told u so", i guess that makes one feel accomplished
Old 2 Weeks Ago   #3474
I level matched the Brax MX2 and HV Venti exactly and one amp you could hear sibilance and the other you could not...
But hey I must have imagined it....
Old 2 Weeks Ago   #3475
Victory Sonics
Victory Sonics
It shows people to pay attention to what really matters.
