1" Baltic Birch vs MDF - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 05-12-2017   #1
Rep Power: 0 serlvz will become famous soon enoughserlvz will become famous soon enoughserlvz will become famous soon enoughserlvz will become famous soon enoughserlvz will become famous soon enoughserlvz will become famous soon enough
Default 1" Baltic Birch vs MDF
I am very much a newb, but I try to learn. I read a lot. Try to absorb.
All other considerations ( cost, weight, etc. ) aside... In terms of a simple sealed enclosure, isn't the layered wood much preferable to shop MDF? If so, please state why. I have my own thoughts and theories but I'd like to hear from more knowledgeable people.
Thanks, Scott
serlvz is offline   Reply With Quote Quick reply to this message
Old 05-12-2017   #2
SkizeR's Avatar
DIYMAddict
Apicella Auto Sound
Janitor
Rep Power: 214 SkizeR is a name known to allSkizeR is a name known to allSkizeR is a name known to allSkizeR is a name known to allSkizeR is a name known to allSkizeR is a name known to allSkizeR is a name known to allSkizeR is a name known to allSkizeR is a name known to allSkizeR is a name known to allSkizeR is a name known to all
Default Re: 1" Baltic Birch vs MDF
from a purely acoustic standpoint, birch is stiffer/stronger than mdf which helps
Old 05-12-2017   #3
Rep Power: 323 gijoe has a reputation beyond reputegijoe has a reputation beyond reputegijoe has a reputation beyond reputegijoe has a reputation beyond reputegijoe has a reputation beyond reputegijoe has a reputation beyond reputegijoe has a reputation beyond reputegijoe has a reputation beyond reputegijoe has a reputation beyond reputegijoe has a reputation beyond reputegijoe has a reputation beyond repute
There is a difference between baltic birch plywood, and void free baltic birch plywood. Assuming it's good quality, the birch has the advantage. It generally loses the advantage because void free plywood is much more expensive and more difficult to find that mdf.
2005 Subaru Impreza RS:
Old 05-12-2017   #4
Rep Power: 63 gregerst22 will become famous soon enoughgregerst22 will become famous soon enoughgregerst22 will become famous soon enoughgregerst22 will become famous soon enoughgregerst22 will become famous soon enoughgregerst22 will become famous soon enough
Not sure what the OP is trying to get at but wood in general has poor damping or absorption properties. I'd be surprised if one is much better than the other.
gregerst22 is online now   Reply With Quote Quick reply to this message
Old 05-12-2017   #5
DC/Hertz's Avatar
Rep Power: 86 DC/Hertz will become famous soon enoughDC/Hertz will become famous soon enoughDC/Hertz will become famous soon enoughDC/Hertz will become famous soon enoughDC/Hertz will become famous soon enoughDC/Hertz will become famous soon enough
Birch-Lighter, strong, way less mess when cutting, looks better stained. Cost more.
DC/Hertz is online now   Reply With Quote Quick reply to this message
The Following User Says Thank You to DC/Hertz For This Useful Post:
street.terror (05-12-2017)
Old 05-12-2017   #6
Looking for strength and stoutness, acoustically.
I was reading on the various grades and found this...
B/BB: Single piece face and back veneer. Face veneers are considered clear and free of defects with a light-uniform color. Back allows 3-6 color matched patches, which are oval in shape and egg sized. Inner cores are solid birch single piece veneers.
BB/BB: Single piece face and back. Both face and back veneers allow 3-6 small color-matched patches on average and some light mineral streaks. Tight pin knots may be present. Inner cores are solid single piece veneers.
BB/CP: Single piece face and back. The “CP” back veneers are downgraded from “BB” grade veneers, which allow for unlimited patches and sound knots, but does not allow for open defects. Inner cores are solid birch single piece veneers.
CP/CP: Single piece face and back. Face and back grade veneers allow unlimited sound knots and repaired splits and unlimited patches. The panel is sound both sides and designed for laminating.
C/C: Patches, open knots, and small veneer splits allowed. Veneer lap and small core voids permitted. This panel is not sanded and would be used for structural purposes.
Shop Grades: Shop panels are offered in the full 60” X 60” format in all of the grades listed above. Panels allow for 1-3 splits on the face veneer along one edge of the panel in lengths no longer than 10” and no wider than ¼”. Shop grades offered at a substantial discount to the “on grade” prices.
From that I'd imagine one would want only B/BB or BB/BB grade
Old 05-12-2017   #7
Rep Power: 16 dcfis will become famous soon enoughdcfis will become famous soon enoughdcfis will become famous soon enoughdcfis will become famous soon enoughdcfis will become famous soon enoughdcfis will become famous soon enough
Im building a baffle of 2 pieces of 1" Birch and am amazed at how light it is for the thickness. Brain had to adjust for what 2" (1.8" in actual) slab weighed. Also amazed at the cost of a sheet of it.
dcfis is offline   Reply With Quote Quick reply to this message
Old 05-12-2017   #8
Rep Power: 53 dgage will become famous soon enoughdgage will become famous soon enoughdgage will become famous soon enoughdgage will become famous soon enoughdgage will become famous soon enoughdgage will become famous soon enough
I use 3/4" Baltic Birch plywood to build my 18" and 24" HT subwoofers. www.deepseasound.com. I do use 2 sheets for a baffle as well but do not think you'd need to step up to 1", you'd be better off adding internal reinforcements to cut down on the size of unsupported panels. Also, place reinforcements off center so you don't make two panels of the same size, which would resonate at the same frequency.
The Following User Says Thank You to dgage For This Useful Post:
Old 05-12-2017   #9
Babs's Avatar
Scott
Rep Power: 180 Babs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the roughBabs is a jewel in the rough
Just keep in mind you can't just throw any skil saw blade on it or it will tear out on you. But a good quality ply is a great great thing to have in stock. See my thread on that.. Did my IB wall in 7/8" and 5/8" two-layer Russian birch. The wall is probably more solid than the car around it.
2008 Civic Si Sedan - Sony RSX-GS9, Helix DSP Pro-2 & Director, JL Audio XD1000/5v2 (2), Audiofrog GB10/GB25/GB60, Acoustic Elegance SBP12 (2)
Build Log
Babs is online now   Reply With Quote Quick reply to this message
Old 05-12-2017   #10
Automotive Repair Werks
Sales
Rep Power: 9 Iamsecond will become famous soon enoughIamsecond will become famous soon enoughIamsecond will become famous soon enoughIamsecond will become famous soon enoughIamsecond will become famous soon enoughIamsecond will become famous soon enough
Where did you get the Russian birch. I have a source but he will not sell anymore.
Scroungers paradise has some but it has a lot of voids
Iamsecond is offline   Reply With Quote Quick reply to this message
Old 05-12-2017   #11
We're you able to get by with only 4x8 sheet?
I know one thing, for sure, this triple B, or B/BB is not cheap!
Old 05-12-2017   #12
Babs's Avatar
Scott
That's where I got mine. The sheets I got looked good.. They had many different grades though.
Build Log
Old 05-12-2017   #13
IT was sold in 4x4 sheets
Old 05-12-2017   #14
True Baltic Birch is void-free and usually is only available in 5'x5' sheets. If it isn't void free then it is using the term Baltic Birch but is a copy.
Old 05-12-2017   #15
Only available in 5x5 is false. I read that on the internet too when researching and IRL there are numerous sizes and vary among retailers as to how they demand it to be packaged. A large national cabinet maker here specs them however they want them and got me in touch with a reseller in town that had them in 4x4 among other sizes
Old 05-12-2017   #16
Babs's Avatar
Scott
Stuff I got was 5x5' sheets and a bunch of ply layers. The 7/8" has like 15 layers in it. Routes lovely.
Build Log
Old 05-18-2017   #17
ndm
ndm's Avatar
Rep Power: 132 ndm will become famous soon enoughndm will become famous soon enoughndm will become famous soon enoughndm will become famous soon enoughndm will become famous soon enoughndm will become famous soon enough
My local Menards used to stock baltic birch and I used alot of it.
Now you have to order it and they get it is a couple days. I usually order 2 sheets at a time for $125.
The advantage is that it also comes with some OSB that they use to package/Band it. So for the $125, I get two sheets BB and two sheets of the cheap OSB.
I love Baltic Birch. I wish I could get it cheaper, I would then never use MDF again.
Dont forget something though!!....3/4 inch BB is not actually 3/4 inch...The tiny difference will certainly throw off your measurements.
2006 Jeep Grand Cherokee SRT8...gone...Got a G8GT...Waited 6 years...traded for a 2013 SRT Jeep!!...Jeep SRT
https://driiive.com/SRTJEEP/SRTJEEP/# ---http://www.cardomain.com/id/SRTJEEP
ndm is offline   Reply With Quote Quick reply to this message
Old 05-19-2017   #18
Rep Power: 77 Manic1! is on a distinguished roadManic1! is on a distinguished roadManic1! is on a distinguished roadManic1! is on a distinguished road
You guys should check out Ultralight MDF (ULMDF). Same strength as regular MDF but 1/2 the weight.
Manic1! is offline   Reply With Quote Quick reply to this message
Old 05-19-2017   #19
It is definitely lighter but for a sub box I'd still use (Baltic Birch) plywood as it is just stronger and more durable. May not matter if you never move your box but if you ever need to take the box out, plywood is just better.
