Horn loaded subwoofer enclosures - Page 3 - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 12-22-2007   #51
Default Re: Horn loaded subwoofer enclosures
Jason or anyone else, have you found this [free program ] beneficial ?
http://mywebsite.bigpond.com/dmcbean/
Old 12-22-2007   #52
SSSnake's Avatar
Rep Power: 140 SSSnake will become famous soon enoughSSSnake will become famous soon enoughSSSnake will become famous soon enoughSSSnake will become famous soon enoughSSSnake will become famous soon enoughSSSnake will become famous soon enough
Yes, however it is not set up tapped horns (which right now is piquing my interest).
SSSnake is offline   Reply With Quote Quick reply to this message
Old 12-22-2007   #53
Diyma Ninja
Rep Power: 250 thehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud ofthehatedguy has much to be proud of
You should be able to do tapped horns with it, that is according to the guys on diyaudio.
Old 12-23-2007   #54
SSSnake's Avatar
I'll take a look but from what I understand HornResp for a tapped horn it is more of a more high level approximation.
From DIY Audio Thread
Yes, it looks bad for the tapped horn, but hornresp is not simulating the full story. A tapped horn such as this is a 1/4 wave horn at 18 Hz which is what hornresp shows, but at the same time it is a 1/2 wave horn at 36 Hz. This is what hornresp doesn't show. With the correct driver, the result is that the response is flat and the dips are filled in.
I think that you can do a two pass approach (1/4 wave and 1/2 wave freqs) and get pretty close.
Old 01-03-2008   #55
Rep Power: 116 lilmike will become famous soon enoughlilmike will become famous soon enoughlilmike will become famous soon enoughlilmike will become famous soon enoughlilmike will become famous soon enoughlilmike will become famous soon enough
Hi.
Recently found this place, and stumbled upon this discussion - something I might be able to contribute a bit to.
The current version (17) of McBean's Hornresp will model tapped horn enclosures effectively. It is a bit fiddly, but it can be done. It is relatively accurate based on what I've done so far.
Hornresp is also effective at modeling the long-path horns like Bill F. designs, as well as just about anything else that can be horn loaded.
Tapped horns can be folded, just like any bass horn. It all depends on the shape of the enclosure you're after. When built like Cowan's are, tapped horns are a stupid easy build, anything folded gets complicated quickly.
lilmike is offline   Reply With Quote Quick reply to this message
Old 01-03-2008   #56
Hi.
Old 01-03-2008   #57
Welcome to DIYMA !! lilmike !
Old 01-05-2008   #58
Smaller Acoustic Load Angles
In horn type loudspeakers the acoustic radiation from the horn driver is funneled into an even smaller solid angle than "eighth space" and achieves increased power output as a result of the horn load. The smaller solid angles constitute a "stiffer" acoustic load and draws more power from the source analogous to the way that a lower impedance speaker draws more power from the amplifier driving it. Indeed, horns have been likened to "acoustic transformers" for the way that they can be used to match the impedance of the driving source to the impedance of the load to effect maximum power transfer.
Old 01-07-2008   #59
Rep Power: 138 Fellippe will become famous soon enoughFellippe will become famous soon enoughFellippe will become famous soon enoughFellippe will become famous soon enoughFellippe will become famous soon enoughFellippe will become famous soon enough
Originally Posted by thehatedguy View Post
It might play to 18, but there is no way it is horn loaded to 18...down that low she's either acting as a bandpass or blowing straight through and is acting as a sealed box.
An 18 hertz horn is going to be in the magnitude of 20+ cubic feet.
That's all?
What about that humongous horn loaded setup I sent you in that link? The one that's a tunnel in his own house!
And it's only tuned to 30 hertz!
I don't understand.
Fellippe is offline   Reply With Quote Quick reply to this message
Old 01-07-2008   #60
SSSnake's Avatar
Ooops, I don't have v17. It looks like time to update, I'm on v14. Thanks for the tip.
Old 01-07-2008   #61
Diyma Ninja
You have to remember how long a 30 hertz wave is...and the fact those are full sized horns. Most home horns are designed to be placed near a wall or a corner and use that as an extension of the mouth, and if you go that route, you can make the horn say 3/16 or a 1/4 size of normal. Horns placed in free space need to really be full sized since they don't benefit from barrier loading.
Originally Posted by Fellippe View Post
That's all?
I don't understand.
Old 01-07-2008   #62
Abaddon's Avatar
Rep Power: 128 Abaddon will become famous soon enoughAbaddon will become famous soon enoughAbaddon will become famous soon enoughAbaddon will become famous soon enoughAbaddon will become famous soon enoughAbaddon will become famous soon enough
Just a random side note...
I was humming along this afternoon and realized the best possible example of a horn are our voices. Pretty damn perfect example I would think...
Audiocontrol Matrix -> Custom MiniDSP 4x8 -> PDX 4.100 (Bridged), 2.150 & 1.600
Seas P18RNX & 27TAFNC/G (7" Poly & Neo Aluminum)
10w6v2 with Mr. Marv Custom Enclosure
Abaddon is offline   Reply With Quote Quick reply to this message
Old 01-07-2008   #63
Diyma Ninja
No, not really.
Old 01-07-2008   #64
Abaddon's Avatar
well, horns basic (only?) function is to couple the speaker to the air... right?
Wouldn't our throats and mouth do the exact same thing?
Old 01-07-2008   #65
Diyma Ninja
No, that's not the only function of a horn.
A horn provides increased efficiency and pattern control- it amplifies the work done by the driver.
I don't think your mouth and throat provide any amplification. Considering how small the mouth is and how short your throat is, it wouldn't load the vocal chords below 1k or so.
Old 01-07-2008   #66
Abaddon's Avatar
well yes, but the coupling of the driver to the air, is the reason for the efficiency increase...
So Wouldn't having the human vocal chords acting on a reduced air volume, have the same basic advantages?
I doubt you could get the same volume of the vocal chords external to the human body...
Old 01-07-2008   #67
Diyma Ninja
Above the loading frequency, it would act as a horn...but below that, which is most of our vocal range it wouldn't load.
Old 01-07-2008   #68
Abaddon's Avatar
Ahhhhh... good explanation.. thanks
Old 01-07-2008   #69
chad's Avatar
DIYMA Psychopath
Rep Power: 917 chad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond reputechad has a reputation beyond repute
Must be why a girl's scream hurts sooo Effing bad!
Old 01-08-2008   #70
Diyma Ninja
I wonder if there is a correlation between those loading frequencies of the vocal chords and the Fletcher-Munson curve?
Old 01-08-2008   #71
chad's Avatar
DIYMA Psychopath
Absolutely!
I took the boy roller skating last weekend and there was a group of girls that would scream in unison as one would fall, we are talking like an "at a boy-band concert" scream.
It would make you dizzy it was so horrible, and THEN there was the beat frequency that felt like someone was pounding your head with a tack hammer.
I wanted to hockey-check them.
Chad
Old 01-08-2008   #72
300Z's Avatar
Rep Power: 163 300Z will become famous soon enough300Z will become famous soon enough300Z will become famous soon enough300Z will become famous soon enough300Z will become famous soon enough300Z will become famous soon enough
Send a message via AIM to 300Z
Chad
LOL
1993 VW Corrado
Driver found...
300Z is offline   Reply With Quote Quick reply to this message
Old 01-08-2008   #73
chad's Avatar
DIYMA Psychopath
Originally Posted by 300Z View Post
LOL
Well they skated in a line broad side, they were amateurs, I was on hockey Rollerblades, It was "know WTF you are doing" skate time, and felt like it. It would have been like a 20MPH 200Lb bowling ball. hammer them all in a line going around a corner, never would have known what hit them.....
Old 01-08-2008   #74
300Z's Avatar
Awesome... I got some hockey skates too but mine are quads... Didn't knew you could skate too... what can't you do?
1993 VW Corrado
Driver found...
Old 01-08-2008   #75
chad's Avatar
DIYMA Psychopath
It's a guilty pleasure
Hadn't done it in a LONG time then we took the boy a few times, he got the hang of it, it's getting me in shape, so we go about every week now They have a Wednesday night skate and it's nice to go get some stress out. Saturday mornings it's nice to go because it will knock a slight hangover RIGHT OUT!
My wife is damn good, she can stil do all the old-skool stuff, it's a riot watching a MILF go out there and just throw down.
I had my first epic spill last Saturday after aging, I had no idea a 200Lb man could stay airborne for so long, lest I forget weight has no effect on rate of fall but only energy upon meeting the ground... and that little thing called inertia, ouch
Chad
Inexpensive and easy subwoofer tube enclosures tdgesq How-To Articles Provided by our members 55 12-12-2011 01:08 AM
FS: x2 Dayton 1cf subwoofer enclosures kappa546 Car Audio Classifieds 23 02-21-2008 03:41 PM
Enclosures in car audio Analog_123 Technical & Advanced Car Audio Discussion 1 10-23-2007 09:57 PM
Custom Built, Driver Specific Subwoofer Enclosures! JDBuilder Technical & Advanced Car Audio Discussion 9 09-25-2007 06:55 AM
Horn loaded sub discussion xencloud Technical & Advanced Car Audio Discussion 2 02-16-2006 01:01 PM
