static noise coming from subwoofer - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 01-23-2008   #1
The Drake's Avatar
Rep Power: 132 The Drake will become famous soon enoughThe Drake will become famous soon enoughThe Drake will become famous soon enoughThe Drake will become famous soon enoughThe Drake will become famous soon enoughThe Drake will become famous soon enough
Default static noise coming from subwoofer
How do I get rid of the static/hissing noise thats coming from my subwoofer through the receiver? I currently have a Onkyo 7.1 HTIB that I purchased a year and a half ago. I have to keep the gains down very low and the subwoofer level on the receiver on the highest to get it at a decent level without too much noise.
If anyone has any ideas please let me know. I was thinking its just the inferior quality of the receiver that I have and planned on replacing it eventually.
BTW I am not using the subwoofer that came with the system, I am using the Dayton 500W amp and a single 12" Dayton Titanic MKIII.
The Drake is offline   Reply With Quote Quick reply to this message
Old 01-23-2008   #2
Rep Power: 191 tyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura about
Default Re: static noise coming from subwoofer
Does the Dayton amp have a 3 prong plug and the onkyo a 2?
If so thats a pretty common sub hum due to ground issues.
PE sells an inline filter through the tv coaxial that fixed the hum, but weakened the HD signal and had to be removed.
The simple way and cheapest is to go to local hardware store and get a three to two prong adapter for the sub amp. Make sure to connect the gound tap on the adapter though.
Old 01-23-2008   #3
Is it gain issue ? Sounds like the gain is up too high.
Old 01-24-2008   #4
The Drake's Avatar
Gain stays Very low. Yeah the onkyo is only a 2 prong power and dayton amp is obviously a 3 prong.
I heard about the inline for the F-connector, but I dont even use the cable line in my home theater so I fail to see how that would help anyway.
I will check out the adapter although I would think that would cause some safety concerns in doing that...
Old 01-24-2008   #5
remove the receptacle cover , is the box metal or plastic [ silverish or blue in color ].
If it is metal put a screw through the ear on top of plug, then through receptacle cover and into box.
possibly a 10/32 or 8/32nd screw.
then plug amp into adapter.
Old 01-24-2008   #6
havok20222's Avatar
Rep Power: 124 havok20222 will become famous soon enoughhavok20222 will become famous soon enoughhavok20222 will become famous soon enoughhavok20222 will become famous soon enoughhavok20222 will become famous soon enoughhavok20222 will become famous soon enough
Why not just ground the receiver? Most receivers have a place to hook up a chassis ground. Seems like a waste to go through all that other trouble before trying that. See the pic of the lower end onkyo below.
havok20222 is offline   Reply With Quote Quick reply to this message
Old 01-24-2008   #7
havok20222's Avatar
stupid thing didn't attach.
Old 01-25-2008   #8
The Drake's Avatar
I was looking for that on the back of my onkyo and didnt see anything like that. I do want to note I have my dvd player hooked into the receiver too. I may try to take that out and see if that improves anything.
Mute Plug Pictures thapranksta Technical & Advanced Car Audio Discussion 5 05-08-2008 09:19 PM
Abmolech on low noise floor Oliver Technical & Advanced Car Audio Discussion 0 01-05-2008 09:43 AM
another alt whine problem Mat Dope Technical & Advanced Car Audio Discussion 7 04-01-2007 03:00 PM
alternator whine with HU powered off ronp Technical & Advanced Car Audio Discussion 8 03-22-2007 11:56 AM
