Old 07-24-2007   #1 (permalink)
Default 12V circuit Breaker?
All they all very much the same. I see stingers for $40 and i see made in china on EBay for $10.
Any thoughts?
thanks............
89 Honda CRX Si "Add salt to make it sweeter" http://www.villagephotos.com/pubbrow...der_id=1942659
thazy2 is offline   Reply With Quote
DIYMA
Sponsored links
Old 07-24-2007   #2 (permalink)
selftc's Avatar
Default Re: 12V circuit Breaker?
are they all the same ? i don't know, but i doubt it. i was in same dilema as you awhile back. i just went ahead and went with a known reputable brand...stinger. it seems that very few use circuit breakers though. most common reason: if/when they fail, they fail in the closed position. if a fuse fails, it fails open which is more safe. personally, i like having the ability to pop hood and push button to dis-connect all power. unlike most fuses where you have to pop off a cover then use a tool to dis connect. its just easier... my $0.02
selftc is offline   Reply With Quote
Old 07-24-2007   #3 (permalink)
Check out the breakers at Del City. Excellent company. Just make sure u get one that matches your fuse ratings. www.delcity.net Might need to pickup a few other things, cuz theres a 25 dollar minimum order.
silent1 is offline   Reply With Quote
Old 07-24-2007   #4 (permalink)
hard to beat PE
http://www.partsexpress.com/pe/showd...number=079-180
bobditts is offline   Reply With Quote
Old 07-25-2007   #5 (permalink)
I saw the PE and the Stinger version. Is 90 amps PE version adequate for a small civic electrical requirement? I was looking at 150a w/ the stinger. Of course, the audio is on its own direct connect w/ fuse.
Old 07-25-2007   #6 (permalink)
all depends on the power draw of your amps and anything else you are connecting to that breaker. just like a house breaker. you have to figure out your total draw before commiting to a breaker.
Old 07-25-2007   #7 (permalink)
lilmsprelude's Avatar
Save The Boobies!
Originally Posted by bobditts View Post
Thanks for the link! just bought a couple and some battery dist blocks!!!
lilmsprelude is offline   Reply With Quote
Old 07-25-2007   #8 (permalink)
Save The Boobies!
hard to beat PE
Old 07-25-2007   #9 (permalink)
Save The Boobies!
Hey bobditts!!
Old 07-25-2007   #10 (permalink)
Originally Posted by lilmsprelude View Post
Hey bobditts!!
anytime. Partsexpress should be everyones best friend. haha.
Old 08-08-2007   #11 (permalink)
Save The Boobies!
got the circuit breaker and the two positive terminals in a few days ago and the two NEG terms just came in today...!!
Cant wait to get em installed--- was going to do the big 3 this weekend but as I started investigating, all the old Power wire is corroded and needs to be replaced---so i will be doing something like :TheBig 5!" ....LOL! --time to go order a few more parts.
  DIYMA.com » Audio Discussion » DIY Mobile Audio - SQ forum
