| DIY Mobile Audio - SQ forum The heart of DIYMA - Discussions related to Sound Quality in mobile audio. |
It looks like you're enjoying our web site but haven't created an account yet. Please take a minute to register so that you can gain access to all of our forums and the ability to post your own messages, communicate directly with other members. Register now! Already a member? Login at the top of this page to stop seeing this message. |
#1 (permalink)
***as a courtesy I've stickied this thread, but that does not mean I endorse no guarantee this product in any manner
-Npdang Hi Guys (and probably Gals), After several months of delays, I am announcing that the DSPower! supply from Envision Electronics is ready for preorder. I am manufacturing the first 40 by hand due to upstart expenses being a bit costly to support right away. After all, I'm not a big company and my current resources are limited. I expect to be shipping the first orders by Sept 14th. The introductory cost is $119 (normally $139) including free shipping to the CONUS. My site is being completed for this sale, and will be online by the end of the week. I just need to get a headcount of those immediately interested and ready to purchase. Please send your inquiry, along with any questions to: envisionelec_at_woh.rr.com I will return your email with information regarding your order and how to place the order. I will also send you the link to the new webpage www.envisionelec.net when it is "online". As WhiteRabbit (Steve) has posted in the original DCX Mods thread, the units perform noise-free and reliably. I sent Steve a pair of the supplies back in June to use at Marv's BBQ and for general beta testing. Although Steve's setup is highly unusual, with the 'guts' of the Behringer processors strewn about the interior of his trunk and passenger compartment, Steve reports excellent performance of the DSPower. He can't say so much for his unshielded ribbon extenders, however. Preliminary pictures of the unit are available at these links. These are mere prototypes of the final unit, although appearance and performance are similar.http://i21.photobucket.com/albums/b2...DCX2496001.jpg http://i21.photobucket.com/albums/b2...DCX2496002.jpg Needless to say, I am very happy with the engineered performance of these supplies. They emit very low levels of EMI, relegated to 2MHz. You can place a portable radio within 6" of an unenclosed DSPower and be able to pick up any AM or FM station without added noise or interference. Let me go over some of the features of this power supply which is designed to directly replace the AC input section of the Behringer DCX/DEQ2496: 1. True Plug and Play Operation. The installation takes less than 15 minutes to perform. The supply fits the OEM chassis frame and includes a terminal block for 12V attachment. No drilling holes. No cutting wires. Installation is 100% reversible. 2. OEM JST jumper connector. I went to great pains to buy the original design connector for this power supply. It is a 75mm long JST PH-terminated connector with a board-in and wire-to-board connector. Simply put, the supply will plug in just as easily as the OEM power supply. 3. Low Noise, slow risetime switching operation. Fast-switching edges produce the most high frequency noise into a conductor, whether a wire or the air. I've developed the supply and magentics (transformer) to give a trapezoidal waveform that slowly switches on and off to significantly reduce emitted noise (EMI) from the supply. This waveshape combines the efficiency of a square wave with the low-noise performance of a sine wave. 4. Fully Isolated Input-to-Output 100% isolation means that there is no chance of introducing ground loops using the DSPower! Supply. 5. Oversized MosFETs. The dual IRLR014N FETs in this design are oversized by a factor of 300%. You can short the outputs all day and nothing will blow up (although it might get hot). The supply is fully protected against reverse voltage, thermal overload and short circuit. A 3A onboard fuse handles extreme overcurrent situations and provides a measure of safety. 6. Double Sided, Blue Soldermask, Gold Plated PCB. It's PRETTY. 7. Diagnostic Green LEDs give immediate visual indication that any of the 5 output voltages are functional. They are not blinding, however, and will not leak light outside the chassis. 8. Mixed SMD and Through Hole design. Maximizes longevity and reliability. Surface Mount (SMD) filter capacitors require additional mechanical fixing (blobs of glue) and are subject to capacity loss during the soldering process. Therefore, the filter capacitors, inductors, transformer and terminal connectors are all through hole mount. __________________________________________________ __________________________________________________
Envision Electronics is based in Dayton, OH and has been in business since 2001. Envision started as a contract manufacturing consulting firm and continued into the audio hobbyist kit market with the introduction of the Point Zero Servo Compensated LM3886 Amplifier under the trade name EZAmps.com located at www.ezamps.com. Today, Envision Electronics continues to lead the kit industry with the first viable ICE (in-car entertainment) solution to cleanly interfacing the powerful, versatile Behringer Professional Audio Products DCX and DEQ devices with the DSPower! power supply conversion kit. |
Sponsored links
#2 (permalink) |
I'm glad you posted this. A local buddy needs a processor and I was exploring that behringer thats in the forsale forum right now as a solution, but I hadn't heard from you in awhile!
The supply is worth more than the $140 price tag. Especially for the DCX2496 the supply promotes extremely robust operation, highly stable. And it's literally a 5 minute modification and the processor is up and running. Aaron forgot to mention another design feature: No turn on or turn off pops. Designed into the supply so you dont have to worry about it. |
#3 (permalink) |
Big Daddy
iTrader: (6) |
You fuggin rock!
Congrats on a finished product, you deserve it! |
Made with bits of real panther.
#4 (permalink) |
Guest
Posts: n/a
Sounds like a very well-engineered solution !!
The importance of #4, isolated design, cannot be emphasized enough
#5 (permalink) |
I couldn't say it any better.
Behringer DCX2496 ~$250.00 Power Supply mod ~$140.00 $400.00 for a processor that absolutely ROCKS is amazing. I won't need one for quite a while, but if you have a hard time getting 40 buyers in a timely manner hit me up, and I'll take one. It would be quite a ways down the road before I used it, so I would prefer that people that would use it in the near future have first dibs. I can't imagine you'd have a hard time selling these.
#6 (permalink) |
man.... i'll be gettin one for sure. not now but someday
Coming soon... DRZ9255 - Linear Power DPSQ50 & (2) 2.2HV's - Dayton 10HO - CSS SDX7 - Peerless 830987 - Alpine SPX PRO ring radiators
#7 (permalink) |
What voltages can it do? I need a +/- 15 volt, +15 volt, and a +5 volt...and about an amp of current on the +/- 15 volt for my Rane RPM88.
#9 (permalink) |
Guest
Posts: n/a
maybe we should commission some Rane supplies ....
![]() one of my all-time favorite processors is the Rane RPM26Z ... it will be gentle on your supply, I promise
#10 (permalink) |
anyone know if the behringer will function without the display / front controls connected?
#12 (permalink) |
Guest
Posts: n/a
the 26Z and others in the RPM series are "multiprocessors" .... EQ, xover, time alignment. And the Rane engineering, including analog and DSP, is top-shelf ... no matter what anybody else might say
Best part ... some schematics are readily available And you'll find a wealth of info in the classic Rane tech notes, as well as their philosophies on analog and digital processing done right for audio.www.rane.com www.rane.com/library.html |
#13 (permalink) |
Ez, could you please completely dumb this down for the newbies that might want to buy and use this product.
![]() So I take the power supply out of the Behringer unit, and swap it for yours? In order to use the DCX, do I need to use a head unit that has balanced outputs? Thanks! |
#14 (permalink) | |
The DSPower outputs +/-15V at 100mA, +9V at 500mA, +5V at 250mA and +3.3V at 400mA. These are pretty much set in stone because of the transformer windings. But you can make the basic supply drive anything if you rewind the transformer and re-engineer the secondary side. Note that the warranty is VOID if you attempt this... |
#15 (permalink) | |
short answer is it'll work just fine. Kenny, no problems running unbalenced. That is the configuration I run right now. search for xlr-rca conversion and youll find which pins to short. I believe 1 and 3? |
#16 (permalink) | |
No, you do not need any special headunit. This is the beauty of such a design. I run a plain-Jane Kenwood in my wife's car with 4V outputs and I receive excellent results. The only limiting factor is - well, there is NONE. |
#17 (permalink) | |
Hows the overall noise floor running unbalanced rcas ,Steve? |
Excelon DNX8120*Dynaudio System 362&MW190's IB*TRU Tech SSLD6/S44/S500
"The intuitive mind is a sacred gift and the rational mind is a faithful servant. We have created a society that honors the servant and has forgotten the gift." |
#18 (permalink) | |
I was considering the P9 or Alpine 701 combo. Has anyone used those and the DCX unit and would like to compare? Sorry to dump on your announcement thread, but I think this might lead to more business for you. Especially if there's no noise in the analog signal transfer.
#19 (permalink) |
DIY forum. Give it a try.
#20 (permalink) |
installers r us Position:
installer iTrader: (0) |
this is indeed very interesting.
i vote npdang the newest and sexiest e-celebrity to hit the car audio realm!!
#21 (permalink) |
#22 (permalink) |
no noise.
What I would most like someone to try is for someone to add a DEQ2496 to their existing processor system. Say, someone has an H701 and is running optical from the alpine radio, no C701. (or heck, add a c701 makes no difference.) I would like someone to experiment adding a DEQ2496 in line and testing the features out. Most notably the width adjustments and the 61 band RTA. its nice that the DEQ2496 has optical inputs and outputs... ...or could even simultaneously pass 15-30 ms delayed balenced outputs leaving the optical output untouched going to the H701... ----------------------------------------- Something key to say is that the behringer units are broken down into individual PCA's when assembled. Thus, the power supply for the DCX or DEQ is simply labeled PSU2496, rather than being a smaller part of a greater product. Thus, ANY behringer equipment that contains the PSU2496 inside should work plug and play converted. Noone should be limited to JUST the dcx2496 or deq2496. |
#23 (permalink) |
Too bad it doesn't have the current ability for the Rane.
#24 (permalink) |
If I were to do a supply for "X" product, I wouldn't feel right making a "universal" replacement. It wouldn't work properly, wouldn't fit properly and wouldn't give you the best overall experience. If you feel the Rane is a widely used system, or want to pay me $5k to build one just for you then I'll consider it.
LinkBacks (?)
LinkBack to this Thread: http://www.diymobileaudio.com/forum/diy-mobile-audio-sq-forum/19371-dspower-behringer-power-supply-retrofit-preorder-available.html
| MP3Car.com - View Single Post - Behringer DCX2496 -- dc power supply | This thread | Refback | 01-11-2009 06:50 AM | |
| Phoenix Gold Phorum // View topic - Behringer Power Supply Retrofit | This thread | Refback | 01-07-2009 09:31 PM | |
