| DIY Mobile Audio - SQ forum The heart of DIYMA - Discussions related to Sound Quality in mobile audio. |
#101 (permalink) | |
Harman International Position:
Product Manager iTrader: (0) |
Global Product Line Manager, JBL Car Audio
Harman Consumer |
Sponsored links
#102 (permalink) | |
Why in the WORLD would you not care what caused the over power issue? Why would you not want to find the true point of failure? In your "silly logic"... WTF... its blown... give me a new one... la-la-la... <fingers in ears don't want to hear reality>..... something caused the failure I didn't say that clipping, distortion or any SPECIFIC thing ALWAYS caused the failure... I simply said that in order to REACH a thermal or mechanical failure SOMETHING causes it... its not just "oh gee... my speaker let the Genie out"..... EDIT * I am asking a serious question here..... what is the ROOT cause of the failure? saying it was "cooked" (thermal) or "maxed" (mechanical) is not the answer... WHY did the speaker fail? why did the speaker REACH that thermal/mechanical limit? I can take the speaker & plug it into a wall socket to get either answer. I can take a torch & heat up the magnet/Vc & get it to fail... what in the signal/power chain failed? Rob |
#103 (permalink) | |
It seemed correct since I wasn't anywhere near maxing out the gain. In fact, the gain was just a few pinches higher than the 14.8v setting.
#104 (permalink) | |
back in the IASCA days of flash, displays & excess, you had to fuse anything that had current... As I said above... i'm just a 40 year old moron, testing 25+ years of audio stupidity.. never a blown speaker... thanks Andy for reinforcing the concept Rob |
#105 (permalink) | |
Speaker thermal limit: More wattage is reaching the voice coil than it's designed for, for a longer period of time than it can safely dissapate the heat. The voice coil burns out thermally due to too much input wattage for too long of a time. So, those are the two ways I figure you ruin a speaker. Either by exceeding it's designed specs and not using it for it the intended application or by exceeding it's thermal limits. Either way, distortion is not likely going to cause a failure as long as the input is limited to the driver's mechanical and thermal specs. |
#106 (permalink) |
That's my point. The amp doesn't produce 19V RMS withut some clipping. Now we have to determine whether you have an RMS meter or not. IF you got a square wave out of the amp designed to provide 14.8 V RMS you'd have 14.8 x 1.4 or 20.72 volts. This us why the DMM method sucks unless you know at precisely what voltage the amp clips.
Harman Consumer |
#107 (permalink) | |
um....yeah, I got nuthin'
iTrader: (25) |
Because the root cause is simple, it was the user turning it up too loud. All of this other crap you're throwing out there is a smokescreen. The final ultimate cause is the owner. Happy? Jesus fucking christ... |
Ramstein Air Base, Germany USAF AMMO - I know what REAL boom is. I.Y.A.A.Y.A.S.! |
#108 (permalink) | |
I am trying, like so many other posts, to give others who are having the issue something to grab on to.. some logic.. if you over extend a 12" woofer with Legacy/Pyramid power... shame on you... no warranty for you!... if you send a 4" coax to below 50hz... I revoke your Driver's license & smack you on the head... those are givens... but naturally there are failures in well designed/planned systems... what is the REAL failure? Rob |
#109 (permalink) | |
Now as for all the other installs, I would have to say one subwoofer failed because it was defective a year ago. I was pushing it's limits I admit, but I didn't exceed them and it failed. So, that might answer your question. defective equipment. Live and learn. |
#110 (permalink) |
God I hate the *DMM gain setting method* more than life itself. It's maddening to see people even try and do such a silly thing. Thanks, Andy, for explaining it with figures and relative examples.
#111 (permalink) | |
you FINALLY said what no one wants to say... "no control over their right wrist" or "left wrist" overseas... combined with Deaf ears... But... you opened the door..(thanks very much)... why would turning the volume up too much cause the speaker to fail?... the thermal & mechanical limits are the final failure... is that say a GAIN problem? a signal/noise problem? a distortion/clip problem?.... You do realize I am egging you on right? the bottom line to speaker failure is a FAILURE to control the wrist on the volume control past the point where music becomes noise... nothing else.. you can argue "thermal/mechanical" all you want... there is a fundamental failure BEFORE the thermal or mechanical limit of the speaker. Its HUMAN error... Like soooo many "engineer types" who sleep, jerk off & caress their O-Scopes & DMM... the thing we all seek is an EMOTIONAL attachment to the musical experience... It doesn't matter how much I or anyone else screams "perfection"... if it doesn't sound right... it doesn't sound right, & unless you are trying to please a "judge" in one of the many sanctioning bodies, a person's daily experience has NOTHING to do with thermal/mechanical limits... if he blows up shit... he is blowing up shit... & there is a REASON he is hitting those limits... education over "theory".... TEACH don't preach... Rob |
#112 (permalink) |
It isn't clipping or distortion. It's simply too much power for too long that causes thermal failure. The cause? The person applying too much power.
The cause of mechanical failure is more difficult to determine unless there's a hole iin the cone or surround. That's why companies will take broken speakers back without a fight but won't often provide warranty replacement for burned coils. |
Harman Consumer |
#113 (permalink) |
It might if there is no load connected to the amp. Amps generally will put out a bit more voltage before clipping when there is no load on the amp which is generally how people using the dmm method do it to prevent blowing their speakers during gain setting.
#114 (permalink) |
You're thinking about it the wrong way.
Put a 20w amp on a 2000w sub and clip it all you want. The speakers not going anywhere. On the other hand give a 20w speaker 2000 watts of clean power and see what happens. The engine analogy is a bad one because speakers don't need lubrication to function. |
#115 (permalink) | |
But guns don't shoot themselves. They need someone to pull the trigger. So ultimately, while the gun happened to be the method of delivery....the real reason that person was killed via gunshot was because someone pulled the trigger. So is it more accurate to blame the gun for the death (the method of delivery), or the person who pulled the trigger? In the same sense, clipping may result in excessive power being delivered to a speaker, causing it to exceed it's mechanical or thermal limits and ultimately being damaged. Clipping in this instance happens to be the method of delivery, but it's not the true cause. It only damaged the speaker because the resultant power exceeded the mechanical or thermal driver limits. If it hadn't exceeded one or both of those limits, no damage would have been done. It's better to explain to someone why the clipping is potentially damaging (due to excessive power exceeding the speaker's limits), rather than just blaming the clipping itself. As you yourself said....teach, don't preach ![]() Don't preach the perils of clipping without teaching what is perilous about it. |
Come down, Get off your fucking cross, We need the fucking space to nail the next fool martyr - TOOL
#116 (permalink) |
I think it's far more likely that he was measuring a seriously clipped signal with an RMS meter or measuring peak voltage with a non-RMS meter.
Harman Consumer |
#117 (permalink) |
Event Horizon Position:
Bending the laws of physics iTrader: (0) |
04 Z16 Z06 #479/Alpine9886/PXA-H100/Arc 4150XXK/ID oem's /Vifa XT25s/Arc 2500XXK/CV VmaX 15 |
#118 (permalink) |
what is wrong with you people!
edit> j/k. |
#119 (permalink) |
Without using a scope to see exactly what's going on nobody knows for sure what's happening. All I'm saying is that it is possible for an amp without a load to produce more voltage than with a load. Take the Linear Power 1002 I tested, it put out 13.91v@4ohm (48.37w) with a load connected before clipping and without a load connected it did 19.6v (96.04w@4ohm) before clipping.
#120 (permalink) |
but did it clip hard, or soft?
at what frequency did you test? what does phase angle have to do with clipping, and is it better that an amp can produce mild clipping or that it just hits the wall? |
#122 (permalink) |
"Do it yourself" originally referred to combining different speakers from different applications (mostly home audio, some pro audio and car audio) not just installing pre-packaged component sets without the help of a professional installer.
-Evan
#123 (permalink) | |
Its saying the same thing, but with a different twist I hadn't considered. thanks again. Rob |
#125 (permalink) | |
| Why are you into car audio? | Fellippe | DIY Mobile Audio - SQ forum | 76 | 12-10-2009 12:10 AM |
| My car might be totaled, so i may be getting a new | azngotskills | Off Topic | 95 | 02-06-2008 07:01 PM |
| I'm sticking my neck out here... but I think Home audio is easy compared to car audio | bikinpunk | Off Topic | 22 | 12-14-2007 05:49 PM |
| Car Audio Clips | BassBaller5 | DIY Mobile Audio - SQ forum | 3 | 09-27-2007 11:52 AM |
| WHOA Directed buys polk audio for 136M in CASH | newtitan | DIY Mobile Audio - SQ forum | 24 | 08-30-2006 03:34 PM |
