| DIY Mobile Audio - SQ forum The heart of DIYMA - Discussions related to Sound Quality in mobile audio. |
#176 (permalink) | |
Create a new enthusiast.
Imagine Audio iTrader: (45) |
twisted pair cables can help with some of this noise. RF can affect the power cable and if you run your signal cables right next to a big rfi noise generator, i'll give you three guesses what happens. I've had experience first hand solving noise problems by simply relocating the rca cables away from the power line period starting as early as 1992. If you don't have issues, continue running them wherever you like, just don't tell me it never happens in other peoples vehicles. |
'04 WRX, W200+H701 Billet 4100/475/H1 Hammer. Morel Elate LE's, deciding which sub
'97 S-10, DXZ785usb, possibly Art series and DIY drivers coming '99 Outback W200+esx amps, possibly H701 and DIY drivers coming. '91 Z28, Built driveline, no stereo as of yet. 4" exhaust for "music"Linear Power for sale 2202 and (2) 1502iq's. |
Sponsored links
#177 (permalink) | |
Why doesn't it work when you used to do it? I don't know. Maybe it's worth comparing more detailed installation strategies to get to the bottom of the issue. Or maybe we should try to figure out the exact procedure you're using when you try to eliminate other variables as being the culprit. But the point is that it most certainly IS a valid way of doing things, as evidenced by the fact that lots of people DO it successfully. Again, since you presumably avoid trying to do it, I wouldn't expect you'd have as much experience doing it as other people would. I'm trying to think of an analogy that would demonstrate what I'm talking about a little better. Ok, suppose we both play the Super Mario video game and I tell you about the secret world you can get into if you do X, Y, and Z. Then you do X, Y, and Z and your player always dies. Does that mean that X, Y, and Z doesn't work? Sorry for the 1986 analogy. :P |
#178 (permalink) |
Well, I never said anything about it happening in every car did I?
Someone just put it up as being a myth that you should run cables away from each other. I'm simply stating that it's not a myth, and it's a good practice to be in the habit of. |
#179 (permalink) | |
#180 (permalink) |
Unless you know how to do what? Uncork the magic of running rca's and power cable zip tied to each other noise free? lol Come on...
#181 (permalink) |
Well, there are apparently people (myself included) who manage to do it so that no noise is introduced. There must be something we're doing that you're not. Or vice versa.
#182 (permalink) |
Hmmm... there's people out there that use knives and cut towards themselves, yet they manage not to cut themselves. I still wouldn't say it's a good idea, nor would I say that that person will never cut themselves...
#183 (permalink) |
Big Daddy
iTrader: (6) |
think logically here, what has to happen in that power cable to induce noise on the signal cables. hint: what's NOT happening in that power cable at system idle when noise would be heard
Made with bits of real panther, so you know it's good.
#185 (permalink) |
I've found some expensive wire isn't so good. I installed an amp for a friend using some expensive 4 gauge wire, forgot the brand, but it used a silicone insulator which though flexible and easy to strip, also meant it could get cut and short out easily. Don't go too cheap though because I've bought "4" gauge which had so much insulation the wire inside was about the same as standard 8 gauge cough-Walmart-cough. Touch of the flu seems to be going around
#186 (permalink) |
LOL that's hilarious...if you did that with RAW cow milk straight from the teat, sure, after hours of shaking it would happen. But sans cream and most of the fat removed, and being homogenized, it is impossible to make butter with store bought milk.
#188 (permalink) |
As far as all amps sounding the same (all things being equal)...I know I would not want to take a listening test to pick out the 10k amp out of a lineup. Same goes for speaker wire and cable.
#189 (permalink) | |
You're not alone by any means. I've ran my main power wire right next to my RCA's numerous times and have NEVER had electrical noise in the system. I agree it's a myth. |
#190 (permalink) |
Quality12volt Position:
All of it iTrader: (3) |
just reading through some of these...might be good for n00bs
#191 (permalink) |
Since this thread has been bumped back up to the top, I have an interesting spin on the not running your RCAs near the Power cable. What about unibody vehicles? If the power cable can induce noise, isn't every single piece of sheet metal in a Unibody vehicle one big conducting ground for the electrical system? If my logic is correct, then one would have to suspend their RCAs to reject noise from the power or ground, correct?
Then again, this was just an interesting thought I had.... I only got 3 hours of sleep last night and figured I would ask the experts. |
#192 (permalink) | |
#193 (permalink) |
Like I said earlier in this thread, separating the RCA's from the main power is a waste of time. I've never done it, and I've never had electrical noise.
#194 (permalink) | |
#195 (permalink) | ||
Maybe I am wrong in my line of thinking but if one is going to suffer from induced noise, it can come from either direction meaning power or ground, correct? |
#196 (permalink) |
Well they're ricers...of course they are wrong!
#197 (permalink) |
um....yeah, I got nuthin'
iTrader: (22) |
A new one: The Mag v4 is a 12" midbass driver not a real sub and can't play anything under 40Hz.
Ramstein Air Base, Germany USAF AMMO - I know what REAL boom is. I.Y.A.A.Y.A.S.! |
#198 (permalink) | |
#200 (permalink) |
iTrader: (22) |
Because you changed where it was routed. I'll bet the RCAs were next to something like a relay bank or fuel pump and that was the noise issue.
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| BCF150 |
| Why are you into car audio? | Fellippe | DIY Mobile Audio - SQ forum | 76 | 12-10-2009 01:10 AM |
| My car might be totaled, so i may be getting a new | azngotskills | Off Topic | 95 | 02-06-2008 08:01 PM |
| I'm sticking my neck out here... but I think Home audio is easy compared to car audio | bikinpunk | Off Topic | 22 | 12-14-2007 06:49 PM |
| Car Audio Clips | BassBaller5 | DIY Mobile Audio - SQ forum | 3 | 09-27-2007 12:52 PM |
| WHOA Directed buys polk audio for 136M in CASH | newtitan | DIY Mobile Audio - SQ forum | 24 | 08-30-2006 04:34 PM |
