| DIY Mobile Audio - SQ forum The heart of DIYMA - Discussions related to Sound Quality in mobile audio. |
#26 (permalink) |
Doing a little research myself lately.
Here's what I'm finding. There aren't many boards with PCI, and dual video out. AMD boards seem to be the easiest to find. Here's an AMD based board though. Newegg.com - JetWay JNC62K AM2+/AM2 NVIDIA GeForce 8200 Mini ITX AMD Motherboard - AMD Motherboards If you prefer ATI graphics and would like HDMI for running the 60" plasma on your dash. Newegg.com - JetWay JNC81-LF AM2+/AM2 AMD 780G HDMI Mini ITX AMD Motherboard - AMD Motherboards Then you could do an M-Audio 1010LT in THIS case with the PCI bus extender. 4th Gen Mini ITX Case for Carputer Car PC with PCI Slot [MCS-BIC-PCI] - $97.00 : Mobile Computing Solutions: For Your Car PC Carputer and Kiosk Computer |
Sponsored links
#27 (permalink) | ||
Palladium Position:
TOE iTrader: (1) |
I did not know about the Opus stuff. Nice that it looks to be standard ATX power supply sized!
Another possibility - I actually have one of these in my office, but we decided against an outboard PS for the boats, opting to use the pico ones from mini-box. Wow, I might recommend that we move from inverter power to one of those opus's when the situation calls for a shuttle. Quote:
Are you running any software to do xover or time correction? I'd really really like to use a PC as a primary source and have it handle the active xover. Quote:
#28 (permalink) |
Maybe I'm misreading some of this stuff, but...
* Why mini-ITX? I just bought a mini-computer, prefab. * Why not USB or firewire sound? Then you don't have the PCI requirement. My USB card doesn't need external power either (the Gigaport mentioned above). * FYI, I've been running "carputers" since 2000. I don't think I've ever had a hard drive failure. It's a non-issue, IMO. The temperature variations are probably more likely to kill it, but it sounds like you've got that under control. |
#29 (permalink) | ||||
I have two questions, one about PCI: Do I need a case that has a PCI slot? Do I always need that wire adapter? And second about USBs: I see all these assembled cases have a nice metal wrap around the outputs, do the motherboards come with it so it's trimmed depending on what connections it offers? What if I want more than 4 USBs, is there a way to get 8 total on that panel without going external? Quote:
External cards don't seem to have the same quality DACs. They cost double. Take up too much space, again might as well get two motherboards. Use an USB connection. Most need external power. PCI cards come with pre-amps, the external ones that do most definitely need power. That's nice to know. I've been reading on solid state vs. conventional harddrive and I really like the solid state concept. I don't plan to write on it too much so I will benefit a heck of a lot more with the first versus the later. Quote:
I have a 300w inverter allready on board but it would be on the other side of the car with hot equipment and lots of power gear, that's a lot of power runs, and I'd rather not if I can help it. Quote:
What is your guys' taste on the M-audio 1010lt, Audiotrak Prodigy, Axus Sonar? I need 7.1 or 8 analog outs, the emu is out. This is the fun part! Well it's all fun ![]() What's your processor duty at? |
'00 Blue Honda Accord Pegging all sorts of stupid meters AE IB15, Seas CA26, Scan Speak Revelator & Illuminator and last but not least Carputer.
#30 (permalink) | |
I love the Bit One software interface. The only thing I wish to be better the ability to assign xo points by physically entering a number. |
#31 (permalink) |
Acura Audio Installs Position:
Director iTrader: (0) |
The opus PSU will work with any 24 pin input on any motherboard. The mb cannot tell the difference between a regular psu and an auto psu. Heck I think some guys are using this to run standard ATX boards in their cars. My CPU runs at 25% load most of the time. I currently running GPS, bluetooth, local LAN, and music storage on mine. No TA or Xover at this time
I modded my SFF (it's an Aopen EZ482 Cube PC). I pulled out the standard PSU and put the opus in. You may want to look into these cards by Azuntech Auzentech, Inc. Sound Cards. Audio You Can Believe In. World First soundcards for Music, HTPC, and Gaming. The Asus cards have 7.1 out |
#32 (permalink) |
Cvjoint you have the same gen accord as mine. check it out, i had a carputer too.
![]() before: ![]() after: ![]() ![]() Made it to look pretty factory. I was using an: - Via M10000 miniItx motherboard - GPS usb reciver - Slot loaded dvd rom/burne - 512 stick of ram - iGuidance GPS software - Centrafuse frontend I kinda miss my Carputer at times. I bought a Delta 1010LT recently and it has 8 analog ins/outs each so I have the capability to do a lot of processing just using the computer alone. I could probally loop the radio through the computer Input to get radio too so it can process that too. or get an expensive radio card. |
#33 (permalink) | ||
#34 (permalink) |
Palladium Position:
TOE iTrader: (1) |
I found the group buy thread:
Still not "cheap" for me - but within reach. HippoHiFi Bloat The specs are REALLY impressive, but your ears will be the judge. Considering this one for a couple different uses. I'd like to stack this up against the onboard stuff. |
#35 (permalink) | ||||
You are giving me some very nice ideas, not to mention I didn't even think the motherboard would fit in the back of the screen. I can A/C cool it even easier from there and frees up trunk room! Quote:
Logic Supply - Leaders in Mini-ITX & Small Form Factor Solutions That's VGA, DVI, PCI, PCIe, and 8 USB all on one card! I can run 4gb of memory and a 2.26GHZ processor. Quote:
#36 (permalink) |
is there any kind of carputer with similar components and processing capabilities that are already built? I always wanted one but im too stupid to put it together.
2006 350z.....Clarion DRZ9255.....3way DLS Iridium active front stage.....jl w6v2 10'' sub for now....DLS RA20, RA40 and jl 500/1 amps
#37 (permalink) |
Not a carputer. I would go with the Alpine W505 P1 combo with the Bit One if you don't want hassle. However, I am convinced with a little more effort the carputer will surpass the above combo in every way but simplicity.
#38 (permalink) |
I'll definately be watching this. I started up a few weeks ago doing research on the carPC route. If I decide to go that route, I'll still need to decide if I want to let the bitone or PC do DSP. This thread should prove very useful. Good timing, man!
#39 (permalink) | |
Palladium Position:
TOE iTrader: (1) |
Another potential gotcha is if you put it in a case - That the case needs to be tall enough to handle the expansion cards. A lot of mini stuff does not handle any expansion cards at all. Looks like you might investigate the case free design, which really is slick there Mega! As for the HippoHiFi Bloat - discussed in the group buy thread, and also on hippohifi and mp3car is that the Bloat handles ASIO and should work just fine with thuneau's processing, and console. That means you get xover, TA, TC, etc. Just a thought. I don't remember if you had a dedicated xover or what, but I thought the idea was to handle processing in-PC. Man, this thread just reeks sticky now. TONS of info in here. |
#40 (permalink) |
Since we're sharing pictures. Here are some of mine. Currently the PC is for GPS, music and movie storage, local LAN, weather and Bluetooth (sort of). It connects via the aux in on the Pioneer FH-P800BT. Something simple for now. Expandability and flexability options are unlimited. I'm doing some other things right now so not too much time to play around with it. I am using centrafuse as my frontend.
Centrafuse | CarPC Front-end Software An 8" widescreen touchscreen is used to control things up front. ![]() It sits in the trunk ![]() The opus PSU can be seen here. It has the white pugs going into it. The case is just tall enough for the video and sound cards to fit
#41 (permalink) | |
Also the LCD was hardwired to the computers PSU and I wired it to a relay. So when I remote start, the computer is already booted when I get to the car, but the lcd is still off until I put my key in. yea I routed the ac into the computer to keep it cool too. Only complaint I have with the computer being behind dash is fan noise. That fan is soo tiny and loud. if you do it behind a dash use bigger fans! |
#44 (permalink) |
Palladium Position:
TOE iTrader: (1) |
#46 (permalink) |
There is an app for the iPhone that turns the iPhone into a router that broadcasts. So you can tether the iphone to the computer. No extra charges from your SP. So you could probally get google maps with live traffic reports!
#47 (permalink) | |||
would you need 4 of those HippoHiFI cards on 4 usb's to make a 4 way work out? Quote:
Could I perhaps use no fan at all for cooling if I fit it behind the screens? I figuered I might be able to get a moster sized aluminum fin sink strapped to the processor and toghether with the A/C it may do well. Is the harddrive noisy too? I'm seriously considering solid state. BTW I think I figured out a way to make dual touchscreen work: XENARC 706TSA Notice it says Multi Monitor touchscreen support. I have no idea how it works but the Xenarc screens seem to be the only ones with this feature. It's not translucent but it does have high brightness, and a sensor for automatic brightness level. I will have to break the bank to buy two though
#48 (permalink) | ||
Palladium Position:
TOE iTrader: (1) |
As for me, if I can get the wife to approve - I think I'm going with a hodgpodge system of sorts - AI have a ton of cpu parts that she's been begging me to get rid of - so I'll get a shuttle up and running from them, and Do myself some research on ASIO and the best option for an 8 ch xovered output using Allocator. I played with the demos quite extensively last night, and I managed to make it work just fine on onboard audio - the ALC889A. I only had one pair of headphones and one set of 2.0 speakers on the computer, but I could definitely tell there wasn't any extraneous pops and shivers like I hear folks getting from time to time, and most importantly - the xover worked! Each 3.5mm was like an output from an active crossover. I have hi, mid 2, mid 1, and low at my disposal, and infinitely adjustable. I think Allocator and Virtual Audio Cable, and the ASIO USB (maybe that prodigy hd2 dunno yet) are all I need to buy to make it work. Since the cpu stuff is free. Quote:
