Old 09-30-2009   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Default audison bitone subwoofer output question
i have a bit one with a simple 2 way front stage and a single 12" subwoofer, the audison bitone you can set up for a single subwoofer or a Right Left subwoofer, right now i have the bitone setup for 1 rca output or the single subwoofer output. i then have the rca split into 2 with a y adapter then it goes into the amp. do you think its better to run the left and right output for the bitone setup, so i can get a more powerful signal and a true 2 rca output into the amp.
matthewo is offline   Reply With Quote
Old 09-30-2009   #2 (permalink)
GregU's Avatar
A large corporation
Custom Fabrication/Install
Default Re: audison bitone subwoofer output question
Where did you get the bit one from?
Alpine 9887 - Image Dyanmics CX64v2(mids) - Seas Neo TAFNC/G(tweets) - Image Dynamics IDMAX 10 - Rainbow iPaul 4.300(mids/tweets) & JL 500/1v2(subwoofer) DSP - 3Sixty.2
GregU is offline   Reply With Quote
Old 09-30-2009   #3 (permalink)
a guy on here named southsyde
Old 09-30-2009   #4 (permalink)
GregU's Avatar
A large corporation
Man, I've been tryin to find one for some time now.
Sorry, didn't mean to threadjack ya'.
Old 09-30-2009   #5 (permalink)
I should get my BitOne.1 tomorrow or Friday. I probably will ask this same question when I set it up.
I think I heard from someone a while back mention that his sub hit harder and louder when he using the 2 rca instead of using the y adapter.
Why don't you give the 2 rca output a try and let us know what you found out?
duckymcse is offline   Reply With Quote
Old 09-30-2009   #6 (permalink)
Buzzman's Avatar
Ignition Mobile Hi-Fi
The relevant question is whether the amp you are using requires a stereo signal or a mono signal at its input. I use a DLS A6 and it requires a stereo signal at its input, which is then summed to mono. Thus, from the Bit One you send a stereo signal using two outputs. If your amp requires only a mono signal, you use just one channel from the Bit One to that amp.
Eclipse 55090 + Audison Bit One.1 + Phass (AT 28 Evo Tweeters, MD0875 Midbasses; RE50 + TP4.100 + AP2.25i Amps) + Micro Precision Z100 Mk. III Midranges + Morel Ultimo 12 Sub + Celestra DA2K Amp.
Buzzman is offline   Reply With Quote
Old 10-01-2009   #7 (permalink)
quality_sound's Avatar
Send a message via AIM to quality_sound Send a message via Yahoo to quality_sound
I'm using a KS500.1 Mini and it'll take a stereo or mono input but after trying both methods the sub sounds stronger with bout outputs from the B1.1 used. Just make sure you link the sub outputs and make sure you use the same T/A settings on those channels and you're good.
Ramstein Air Base, Germany
USAF AMMO - I know what REAL boom is. I.Y.A.A.Y.A.S.!
quality_sound is offline   Reply With Quote
Old 10-01-2009   #8 (permalink)
My head unit(Eclipse CD7200mkII) use the 2 RCA output for the subwoofer. Do I connect to the input of the BitOne subwoofer and center channel? Or I just only need to connect to the subwoofer channel only?
LinkBacks (?)
LinkBack to this Thread: http://www.diymobileaudio.com/forum/diy-mobile-audio-sq-forum/66614-audison-bitone-subwoofer-output-question.html
Posted By For Type Date
DIY MOBILE AUDIO This thread Refback 11-19-2009 03:12 PM
