#1 (permalink) |
A large corporation Position:
Custom Fabrication/Install iTrader: (4) |
So far I've bought a brand new laptop(came in yesterday
and was originally going to be used as a deticated tuning laptop), TrueRTA(1/3 octave), I'm waiting on my 3sixty.2 to get here. I've read the whole thread on the $100 RTA and someone mentioned another mic, the dbx RTA, instead of the ECM8K. Which one is the better of the two or are the any other mics that I should consider for a low price? I'm not looking to spend $800 on a mic unless I had a "real" RTA. Although, for the price of the laptop I could have gotten a real RTA. But, you cant paybills, run the 3sixty.2, chat on DIYMA, or look at porn on an RTA so I went with the laptop.
Alpine 9887 - Image Dyanmics CX64v2(mids) - Seas Neo TAFNC/G(tweets) - Image Dynamics IDMAX 10 - Rainbow iPaul 4.300(mids/tweets) & JL 500/1v2(subwoofer) DSP - 3Sixty.2
#2 (permalink) |
big daddy
iTrader: (7) |
parts express now carries a calibrated mic that is strikingly similar to the ECM but has been measured to be more accurate.
#3 (permalink) |
#4 (permalink) |
^ i don't think that calibrated mic comes with the data to actually make it calibrated, does it?
Dayton EMM-6 - Home Theater Systems - Electronics and Forum - HomeTheaterShack ![]() Here's cal'd ones for $70. Cross·Spectrum - Calibrated Dayton Audio EMM-6 Microphones for Sale |
Buy, try, sell. x3.
Ignorance is housed in complacency. |
#5 (permalink) | |
#6 (permalink) |
In that case, buy a cal'd behringer mic and call it a day.
Money well spent. Heck, I've got a spare ecm8000 (non-cal'd) I'm not using. Would be willing to sell it for about $40 if you're interested. |
Buy, try, sell. x3.
#7 (permalink) |
IIRC I don't think you'll be able to calibrate your soundcard with the truerta 1/3 octave version. It's been a while since I bought it but I originally wanted to buy the 1/3 but had to get the 1/6 for its soundcard calibration ability. I'm not 100% possitive about this but you might want to check it out.
#8 (permalink) | |
#9 (permalink) |
Son of a bitch...... I have to upgrade to level 3 to calibrate my sound card. What all in envolved in calibrating your sound card? Any special tools or equipment needed?
#10 (permalink) |
Too tired to write it all out now so hopefully these links will help.
TrueRTA Calibration Tutorial TrueRTA-for-dummies - AVS Forum |
#11 (permalink) | |
Why would I need to calibrate my soundcard if the mic mate is USB? |
#12 (permalink) |
If you're using the mic mate then you're bypassing your soundcard so just calibrate without looping the in/out on the soundcard. I hope you get a flat line with it. FWIW I was never able to get a flat line using the mic mate with my laptop. I ended up getting a mobile-pre and that solved my problem. Good luck
#13 (permalink) | |
That doesn't make any sense to me because you would then be calibrating to your laptop speakers via sweep? Very confused and frustrated here.....
#14 (permalink) |
Ah, screw it. I'm just gonna go with a new MobilePre and the dbx RTA mic.
Thanks everyone! |
#15 (permalink) |
hey man I know it has been months sense last you posted here but I just wanted to know how things have worked out I want to set something up much like you have but I figured I would go the cheaper way and use arta unless you can help me with why not to. I am confused on what preamp and mic to use. I figure you have gone threw all the problems and might be willing to help a friend out over the last 3-4 months. Thanks man
