Old 01-27-2010   #1 (permalink)
Niebur3's Avatar
Default PLEASE HELP Tuning Problem - I have 3 Discs with Pink Noise and they RTA different!
Someone help!
I am trying to re-tune my system after changing amps. I have the USACi CD (which is a CD USACi burned), a pink noise track I downloaded from the internet (WMA File which I burned) and the Focal Tools CD (Actual CD Focal Produced).
When I RTA, the USACi and Downloaded File RTA about the same but when I put in the Focal Disc, it is way off. I would assume the Focal disc is wrong, but when doing the RTA, I can get the RTA plot to stay very even for long periods of time, while the USACi and downloaded track is very jumpy in the plotting. I am attempting to RTA to 1db/octive variance.
Thanks for any and all help!
Niebur3 is offline   Reply With Quote
DIYMA
Sponsored links
Old 01-27-2010   #2 (permalink)
DIYMA Psychopath
Default Re: PLEASE HELP Tuning Problem - I have 3 Discs with Pink Noise and they RTA differen
having it 'jump' is just a matter of averaging.
The differences you are getting, though, may be due to the actual differences of the 'pink noise' tracks themselves.
Are they all the same: stereo or mono (uncorrelated or correlated)?
Buy, try, sell. x10
North Alabama GTG #3. April 17th.
Old 01-27-2010   #3 (permalink)
Niebur3's Avatar
The only difference between them is the Focal disc says Pink Noise - Ref -14db Fs. Seems like the same to me, just 14db lower in volume.
Old 01-27-2010   #4 (permalink)
DIYMA Psychopath
Have you listened to them, though?
I've got all sorts of pink noise tracks. Some are stereo and some are mono. You will get different results from the two.
Buy, try, sell. x10
Old 01-27-2010   #5 (permalink)
Niebur3's Avatar
No, I guess I am not sure. I believe the USACi disc says Stereo, but I am tuning 1 side at a time so would it even matter?
Old 01-27-2010   #6 (permalink)
post some plots! easier to see what the problems are and perhaps someone could see the reason.
did you adjust the volume so that the measured level are the same for all discs? If the volume are different, than the speakers behavior could vary over volume.
spag_bace is offline   Reply With Quote
Old 01-27-2010   #7 (permalink)
DIYMA Psychopath
Yea, it will matter. The RTA is picking up EVERYTHING that's going on. If the source isn't the same, and even the levels aren't within reason you're going to have different results.
Again, keep in mind you're measuring the entire space and it's effect on response. IME, levels will matter.
Throw a set of headphones on and listen. Mono vs. Stereo. Each has it's benefit.
Buy, try, sell. x10
  DIYMA.com » Audio Discussion » DIY Mobile Audio - SQ forum
