Old 02-07-2010   #1 (permalink)
leepersc's Avatar
Default Phoenix Gold TLD-66 Line Driver Help
Help from anyone using a Phoenix Gold TLD-66 Line Driver, or any line driver for that matter. (Did a search and checked the PG Phorum with no luck.)
My head apparently is up my as$! I cannot fathom how to check the voltage on the output side of the line driver. I'm trying to figure out the voltage that I am adjusting the line driver too. HUGE brain fart on this one, sadly I'm stumped.
Thanks all!
leepersc is offline   Reply With Quote
Old 02-07-2010   #2 (permalink)
Hillbilly SQ's Avatar
Default Re: Phoenix Gold TLD-66 Line Driver Help
Just do it by ear. If you clip the inputs on your amps you'll know it. I used to run a tld66 and those gain pots are TOUCHY.
09 Ram Quadcab...880prs...Custom overbuilt Zuki 4ch...H-Audio X-Soul2...PG x400.1...2 RE10's
Sonic bliss is only as difficult as you want it to be.
Hillbilly SQ is offline   Reply With Quote
Old 02-07-2010   #3 (permalink)
leepersc's Avatar
Thanks man! I hear you on the gain pots. This has become a quest to figure out the actual voltage in a numerical form. Driving me nuts!
Old 02-07-2010   #4 (permalink)
TREETOP's Avatar
Have you tried playing test tones or pink noise and DMMing the outputs? That would be my first step.
2004 3-row Tahoe Z71.
DEX-P99RS -> Matrix -> 5 amps -> horns/eights/fifteens/rears. 4kw+ of essque.
TREETOP is offline   Reply With Quote
Old 02-07-2010   #5 (permalink)
leepersc's Avatar
To be completely honest, the whole setup is on a table in the basement. I'm just trying to get all of my rca's and processors figured out as far as placement in the signal path before install. Eventually all of the 'test tones and pink noise' will come into play.
As far as DMMing the outputs, do you mean DMMing the RCA's? (or the output RCA connectors from the line driver) Thanks man.
Old 02-07-2010   #6 (permalink)
DIYMA Psychopath
x2.
DMM and test tones, if you really want to measure the output, but this won't tell you exactly where the outputs clip.
Though, Chris does have a point about listening to it... clipping is audible.. at least the clipping you'll be really setting this up for (see * below).
Does this particular LD have a clipping indicator? If so, you can probably trust it. Out of every amp or component I've tested thus far for others, the clipping indicators have all been nearly spot on when using my scope and a 1khz 0dB tone to check for clipping.
*Keep in mind that a 0dB tone will cause clipping quicker than music.
Buy, try, sell. x3.
Ignorance is housed in complacency.
Old 02-07-2010   #7 (permalink)
89grand's Avatar
I don't really see a reason to check the output voltage. I had a 4.1 that was a line driver and it had clipping indicators on it. I just turned up the gain until the lights would flash then backed it back down a little.
You pretty much want maximum unclipped output from the line driver.
89grand is online now   Reply With Quote
Old 02-07-2010   #8 (permalink)
leepersc's Avatar
x2.
Hmmm, thanks guys for the assistance. I will use a DMM & ear to figure this out. Unfortunately, the processor does not have a clipping indicator. Although, I wouldn't trade the 6 channels it does have for anything!
Old 02-07-2010   #9 (permalink)
DIYMA Psychopath
Originally Posted by leepersc View Post
Hmmm, thanks guys for the assistance. I will use a DMM to figure this out. Unfortunately, the processor does not have a clipping indicator. Although, I wouldn't trade the 6 channels it does have for anything!
The tld is a line driver. Not a processor.
Or, am I missing something?
Buy, try, sell. x3.
Old 02-07-2010   #10 (permalink)
leepersc's Avatar
Sorry man, you are correct. Damn television is distracting me. TLD is a line driver not a processor. Thx for the observation!
Old 02-07-2010   #11 (permalink)
benny's Avatar
GarageWorks Audio
Floorsweeper/Owner
DIY one of these up: Portable audio clipping indicator
For The Love of Bananas!
benny is offline   Reply With Quote
Old 02-07-2010   #12 (permalink)
leepersc's Avatar
Originally Posted by benny View Post
Holy cow man! That is the TRUE definition of DIY! Thanks, I'm going to hang on to that schematic.
Old 02-07-2010   #13 (permalink)
Unfortunately, an oscilloscope and a sine wave frequency generator are required to accurately setup this circuit.
Doh!
AAAAAAA is offline   Reply With Quote
Old 02-07-2010   #14 (permalink)
leepersc's Avatar
Doh!
Ironically, I have access to an Oscilloscope...no Sine Wave Generator though. Maybe next time, eh?
Old 02-07-2010   #15 (permalink)
DIYMA Psychopath
sine wave generator = cd player
Buy, try, sell. x3.
Old 02-07-2010   #16 (permalink)
leepersc's Avatar
Dude, I feel like an absolute fool. Learn something new everyday. 'OWNED'!!!
