#1 (permalink) |
Supporting Vendor
Simplicity In Sound Position:
owner iTrader: (0) |
just got done with my third Acura TL SQ install...i am really beginning to like these cars hehe...
goals: 1. very good SQ with stock HU 2. stealthy and clean trunk install the signal starts from the stock headunit, front and sub signals were tapped before the stock amp and sent to a rockford 3sixty.2. since hte stock headunit's signal is pretty flat, the 360 is set up just as a processor, no OEM integration/flattening. the front stage consists a pair of Seas Lotus Reference 6.5" comps. the midbass are installed in the stock lower door location, and the entire door dampened. the stock mounting holes had to be widened to accomodate the Seas. the seas ref. tweeter are isntalled in the stock tweeter location on top of the dash, as it proves to work well in the TL, the stock tweeter grilles were filled in, sanded, and painted with texture coat, andt hent he seas tweeter sunk into it. this is hte best shot i can get at them due to the window stickers hehe the stock rear sepakres and stock sub was removed from the rear deck and the deck dampened as well: moving on to the trunk. the customer supplied me with two relatively large amps and an idmax12. my delimma was this: the TL's floor is not flat, its acutally in three stages, at the far front, its at a downward angle, in the middle, it gets slightly shallower, and in the back, it gets shallower still, hence the stock floor cover is in three foldable sections. what this means it hat if i build a new floor, it would either have to be in three sections to conform with the stock floor, or, raise it up qiute a bit and makeit level. in the end, wtih some careful measurements, i managed to avoid both. so here is the trunk covered up, a side fiberglass box with a grille sits ont he driver side, and the stock floor is completely maintained, with the stock floor cover in place. |
www.simplicityinsound.com
#2 (permalink) |
Supporting Vendor
lift the stock floor cover, and pop off the grille and here is hwat you see. a Brax four channels is powering hte front stage fully active, and a zapco reference 1000 watt mono amp feeds the idmax12. there is a new fake floor underneath the stock floor, with cutouts for hte two amps. what i did was to carefully build up the amp support so its precisely at the right height ,did my first floor with cutouts out of 1/2" MDF for support, and then, bonded a very thin piece of 1/8" hardboard to the top and routed it to match the openings, and shaped it and trimmed it so it slides underneath the stock carpet on either side, since its only so thin, it doesnt change the floor at all, and gives a completely flat amp rack floor when you lift the stock cover the top is trimmed in silver CF vinyl.
a detailed prolly no one will notice but i know its there is the matching silver CF trim around the sub and the amp board close up: flick a swtich and the edge lit routed plexi boarder lights up blue: and some night shots: overall, it soundsquite good, the brax produces a lot of power and has a very smooth top end, thoughi dont think the RF 360.2 is quite as good of a proecssor as the zapco DC reference stuff i used in the previous TLs. but very high stage, dead center, and very solid midbass impact and subbass extension. Thanks Leon for tuning the car! ![]() a wiring shot below the floor: and the subbox, whcih i got a rear mold from my freinds over at wickedcas.com, and bolded my front baffle to accomodate the idmax12. here it is finished from the front: now some people have asked me why my boxes, you never see me lay glass ontop of the moldcloth, well, its because i do it from the back, i cut open the back mold, and dampen from the inside, and then seal the back again wtih fiberglass fro the sub opening. it saves a ton of sanding time ![]() and finished and ready to install: |
#3 (permalink) |
What LED's did you use for the blue lighting?
2010 Mustang GT
Saleen Conversion, Brembos, Full Install, etc. all coming soon
#4 (permalink) |
I remember the design for Ron's car that you did on the enclosure. It's nice to see you got the MAX in there. Good job Bing.
USUC World Champion - Stock System Class. Super Street Division. Special Edition Bose 26 piece speaker system with enhanced ported tweeters. 89.2 db Legal, 89.6 db Outlaw.
Vestax's Install
#5 (permalink) |
Supporting Vendor
i always use thin strips from www.oznium.com secure to the outer edge of hte plexi |
#6 (permalink) | |
![]() Just want to make sure.
2010 Mustang GT
#8 (permalink) | |
Supporting Vendor
![]() http://www.oznium.com/thin-waterproof-ribbon b |
#9 (permalink) | |
2010 Mustang GT
#10 (permalink) |
dingles Position:
CEO iTrader: (2) |
This TL is very smooth sounding. Man i love the sound of Brax's topend. Even though this processor isn't quite as 'revealing' as some other units, its very good for beginners who don't want to be over whelmed with too many options.
good job on the dampening bing, the midbass is solid and punchy, integrating very well with the idmax. I had forgotten how good the idmax can sound in a good install... As with the other TL, the dash mounted tweets gave a very stable and high front stage. With a lil bit of T/A, the center was solid and stable. Good job on the install Bing. |
#11 (permalink) |
Another fantastic job! Any pics of how you built the grill for the sub?
#12 (permalink) | |
Supporting Vendor
bsically: 1. a 1/2" MDF ring was routed out 2. steel mesh trimmed and attached to the top with CA glue 3. a piece of 1/2" wide low temp plastic was heated and secure to the edges of the ring with CA glue 4. flip the top and bondoed the edges where the mesh, mdf and low temp plastic meets to make for a smooth surface 5. cover with grille cloth. if you look at the first shot of the subbox while its rying, and how the baffle is made with the flush mount, just imagine the exact same thing except smaller in OD and backwards, thats the grille
#13 (permalink) |
Looks awesome!! Too bad I'm too far away to listen to it or see it in person.
#14 (permalink) |
Hey Bing,
Does this TL belong to someone named Adrian? If so, he's a nice guy and I am the one who sold him the Brax amp. Nice and clean looking install as always! I bet it sounds really great especially after Leon tuned it. George |
#15 (permalink) |
Nice work Bing.
That era TL is a car I've been considering for myself. Good to know nice results can be had with the stock locations. Good idea with reinforcing from the INSIDE of the enclosure. I've always done this as it's great as finish work is cut down with this method. I haven't had to cut the back off an enclosure.....yet.
///Alpine/MBQuart/Soundstream/Phoenix Gold/Image Dynamics
-----Custom baffles and mounting rings....MDF or any material of your choice. PM me.----- Last edited by GlasSman; 04-24-2008 at 09:21 PM.. Reason: too many i's v's and e's |
#16 (permalink) | |
#17 (permalink) |
Supporting Vendor
thanks guys...george, yeah its adrian
great guy, very nice to work with hehe. its cool to seel part of your car lives on ![]() i get hte plastic from selectproducts |
#18 (permalink) |
Every install I've seen you do is very clean and simple. It all looks amazing. I especially like the Vette you did and the Siphoni Bimmer.
#19 (permalink) | |
![]() In #1, you say that you use a 1/2" MDF ring. Then, in #3, you say that you use a 1/2" wide piece of plastic. Is that really the case? If so, what's the point of the plastic if it's the same thickness as the MDF? I'm just trying to visualize it Bing. TIA for your reply. |
#21 (permalink) |
Supporting Vendor
the bimmer was quite controversial
![]() just go to my site: www.simplicityinsound.com you can see most of my installs, just click on the pics in the gallery to go to the threads b |
#22 (permalink) | |
#23 (permalink) |
Supporting Vendor
the CES car
#24 (permalink) | |
you inspire me! keep it up boyet |
| am i ready to begin install? | fearthisskyy | DIY Mobile Audio - SQ forum | 7 | 07-10-2007 10:51 AM |
| Help me decide on the best door install for my RS180's | cheesehead | DIY Mobile Audio - SQ forum | 8 | 06-20-2007 09:58 AM |
| Install log for 2006 STI | Gregor | DIYMA Build Logs | 25 | 06-14-2007 04:36 PM |
| Using one computer to install program on another? | niceguy | Off Topic | 3 | 05-29-2007 07:31 PM |
| New install 2000 Acura integra | H-Audio - AKA - Here-I-Come | DIYMA Build Logs | 6 | 09-12-2006 01:38 PM |
