Old 07-15-2008   #1 (permalink)
simplicityinsound's Avatar
Supporting Vendor
Simplicity In Sound
owner
Default Little SQ install in a E36 M3 :)
just got this one done, its the first SQ install i have done in a E36. this one was a yellow 97 m3 coupe.
goals:
1. very good sound quality
2. clean and stealthy
3. reuse some existing gear provided by the customer
lets get started:
the signal starts with alpine 7898 hiding face headunit that was already installed in the vehicle:
front stage is a pair of Seas Lotus reference 6.5" two way components, the tweeters were installed into the A pillar. this turned out to be a bigger challenge than normal due to the fact htat there is zero room behindt he factory A pillar cover, and the seas tweeter is quite large...so it had to be moled out a bit more than normal:
here are two quick build up pics:
the molding:
and finished vinyling (lots of pulling and cursing lol)
the midbass also presented a challenge, since the stock size houses a 5.25, and the lotus is a rather large 6.5", after some deliberating, what i came up with was to mold a ring baffle into the stock kick panels, cut open the back area some more, and put plenty of clay and dampening into it, so when i install the spekaer and the kick against hte back metal, it forms a decent seal the midbass utilizes hte stock cavity behind the metal.
but here is hwat they look like installed in the car, very stealthy and unobtrusive, the kicks are texture coated:
some build up pics of the kicks:
here you see the ring baffles molded into the stock kick panel:
after texture coating:
the back built up wtih modeling clay and dampening:
www.simplicityinsound.com
Old 07-15-2008   #2 (permalink)
Supporting Vendor
Simplicity In Sound
owner
Default Re: Little SQ install in a E36 M3 :)
passenger side speaker installed:
driver side:
bad pics but the cavity oipened up a bit more and fbuilt up a bit too with clay and dampening:
the front as a whole:
and the USB cable for the zapco processor comes out of hte glovebox for tuning:
moving on to the trunk, a very simple design, here is what it looks like all covered up:
pop off the panels and an image dynamics IDQ10 fires backward, and a macintosh MCC404M 4 channel amp sits in the floor, both are flushed mounted in yellow vinyl.
the macintosh amp poweres the front stage active with 100 watts per channel, while an ppi art 600.2 sends 600 watts to the idq10. both amps were provided by the customer.
here is the wiring below the floor, you can see the PPI amp on the right, and the zapco DSP6 processor infront of hte amp
its not tuned yet, but Leon will get to play with it a bit more, it should sound pretty good in the end, though so far, i am having some reservations about macintosh amps hehe...but we will see how it goes after tuning
Old 07-15-2008   #3 (permalink)
darkknight1999's Avatar
Kinetic Autosports
Looks good.
Why didn't you angle the mids in the kick panels? Seems kinda like you have the sound aimed right at the drivers shoe.
darkknight1999 is offline   Reply With Quote
Old 07-15-2008   #4 (permalink)
glidn's Avatar
IntraLan
IT Technician / Installer
Send a message via MSN to glidn
very nice and simplistic install. good work.
glidn is offline   Reply With Quote
Old 07-15-2008   #5 (permalink)
Damn, I wish I had e36 kicks
Alpine 9887 - PPI Art 300.2 - PPI Art 600.2 - PPI Art 600
7" Peerless HDS - Vifa XT25 - Mach 5 15" IB
Mless5 is offline   Reply With Quote
Old 07-15-2008   #6 (permalink)
Awesome work man...
lashlee is offline   Reply With Quote
Old 07-15-2008   #7 (permalink)
Supporting Vendor
Simplicity In Sound
owner
Originally Posted by darkknight1999 View Post
Looks good.
no point, a big advantage of bmws is their large kick area stock speaker. aiming it on axis would sorta defeat the point of space saving with them...
as far as aiming to the drivers shoe, they arent spotlights my friend of axis response is fine
Old 07-15-2008   #8 (permalink)
Kinetic Autosports
Maybe not spotlight but I can tell you this, if you have your shoe covering the speaker it will detract from the sound quality. Put your hand over a tweeter next time... its the same thing.
Old 07-15-2008   #9 (permalink)
FrankstonCarAudio's Avatar
Frankston Car Audio
Owner / Installer
Very nice install!
I really wouldn't expect anything less from you....
Looks fantastic!
Mark
Team Audison - Australia
Team Morel - Australia
Team Genesis - Australia
FrankstonCarAudio is offline   Reply With Quote
Old 07-15-2008   #10 (permalink)
breathtaking...very clean trunk.
I dare say that what comes out of a tweeter is affected quite a bit more by a hand than what comes out of a midbass, DarkKnight1999. It's not the same at all.
If the off-axis is good in the mid-bass freqs you're working with and there aren't any funcky reflections...and your foot isn't resting against the MB... Heck that foot may just act as a bit of a diffuser.
Of course the man that did that install doesn't need me defending him. Nice job.
JMachan is offline   Reply With Quote
Old 07-15-2008   #11 (permalink)
BLD MOVS's Avatar
bldmovs.blogspot*****
Very nice, once again. That trunk just kicks some ass. Fantastic example of a stealth install.
2007 Shelby GT #0651 door panel removal
Alpine IDA-X001, Android!, Cadence CWM-6, Tweaker pads,
iDMax10D4V.3, Cadence iA4 & iA7
BLD MOVS is offline   Reply With Quote
Old 07-15-2008   #12 (permalink)
Supporting Vendor
Simplicity In Sound
owner
and how does on axis kicks help if you insist that a foot next to a speaker distracts from SQ? i guess we are all mistaken al lthis time doing kick panel installs.
infact, unless you are used to dong dash MIDbasses, can you name a MIDBASS location that is not affected by some part of the body? how is a stock lower door location midbass any different, infact, one can argue that a leg is bigger than a foot hehe...
but i am sure its not my place to be defending off axis kick panel locations in bimmers
Old 07-15-2008   #13 (permalink)
No, the entire car is wrecked because of those kicks. I can dispose of it for him, though.
Seriously, I have no idea about on/off axis, but this install looks awesome as usual.
aboof is offline   Reply With Quote
Old 07-16-2008   #14 (permalink)
Kinetic Autosports
Well I don't know about you but most pro kicks I've seen down or have done myself have at least some kind of angle. But you are right they are a mid bass driver so it is much less important, but for proper imaging they should have an angle on them.
I'll give you that they have them there stock which I guess is why you put them there... but if that is soooo great why even change them at all? Just because a car manufacture put something in place doesnt mean it the best place for it... since all we do is change the car to fit our listening needs. Now there are a 100 reasons to leave them there like that.... I understand that, personal preference, cost(that can be a big one) the style and design... whatever the reason.
I'm not saying you don't do nice work btw because you do. I just disagree with the placement but you may have great reasons to put them there. Either way nice job on the install.
Old 07-16-2008   #15 (permalink)
Send a message via AIM to marbat
What kind of carpet did you use for the trunk color match?
Also if you have a schematic for the dimensions on all the trunk stuff and you don't need it anymore... you know who to PM .
marbat is offline   Reply With Quote
Old 07-16-2008   #16 (permalink)
amapro704's Avatar
Thats very nice, I wish I would have saved myself some time and just did my E36 kicks off axis, it would sound AOK in my book. One thing about using the kick covers as the baffle is that they really need to be screwed to the metal of the kick- both for sealing into the cavity and because they are kind of flimsy. I'm sure you are on top of that I'm more just throwing it out there for people who may want to emulate your work!
amapro704 is offline   Reply With Quote
Old 07-16-2008   #17 (permalink)
If you look at every successful E36 , the mids were straight across off axis. Tony Pasquale, multi IASCA and USAC world champion had JBL10s off axis in his kicks. I had IDQ8s and Genesis Absolute 5s off axis in my kicks.
The location works extremely well off axis.
the primary reason for aiming speakers more on axis to to compensate for very poor pathlength differences between each side so the speakers beam more energy toward the other side and to compensate for poor off axis response of a speaker. a 3rd reason in kick panel installs is b/c most vehicles dont have enough room to recess a Mid into the area, so using the corner area provides more depth clearance so its easier to just aim them more on axis.
2009 MECA Finals Extreme 2nd,2005 IASCA World Finals Champion,2003/2004 IASCA World Finals 2nd
Image Dynamics Elite/Team Autophile
Mic10is is offline   Reply With Quote
Old 07-16-2008   #18 (permalink)
so that Zapco processor let you tune the system? if so what functions does it control? EQ/TA/Crossover?
BeatsDownLow is offline   Reply With Quote
Old 07-16-2008   #19 (permalink)
amapro704's Avatar
Go to their website and download the PDF manual- the thing literally does EVERYTHING! Well, almost...
A question for the OP: The program for zapco, can the window be resized? and how long do the changes take to "load" from the PC to the amp. I have been thinking about using it with a carpc to make adjustments on the fly and I need to know if the window will fit the resolution on my screen and whether or not it responds quick enough while using the system. Thnx
Old 07-16-2008   #20 (permalink)
amapro704's Avatar
I'm guessing those were all 3 ways then with the MB's down there?? If your trying to get a woofer to pair up with a tweeter in the a pillar then you need to get them on axis more. There is no MB speaker with good enough off axis response to match up to a regualr tweet unless you have your tweets playing wicked low (which I HATE doing) or are using a TON of EQ- or else your are just listening to reflections...
Old 07-16-2008   #21 (permalink)
dual700's Avatar
Send a message via AIM to dual700
Nice car, nice equipments, poor install
Awesome, Bing!
Npdang is a sexy mofo
www.mobilesq.com
dual700 is offline   Reply With Quote
Old 07-16-2008   #22 (permalink)
dual700's Avatar
Oooooh, Tony's M3... Great great sounding car!!
What is he running now, Mic?
How's big daddy Mic doin?
www.mobilesq.com
Old 07-16-2008   #23 (permalink)
Supporting Vendor
Simplicity In Sound
owner
the window cannot be resized, well it can, but the part containing the tuning will stay the same size even if you maximize it, normally i dont have it maximizd like that so just the window with the tuning section shows, but i cant let people see all my porn on my desktop!!!
when you make changes on the PC, the change on the amp/eq is immediate. no delay, the minute you doit, you hear hte difference.
i dont suggest doing it on the fly, if you mean while driving, as there are a LOT of functions on the menu so clicking the right one on a small touch screen may be tough, they do sell the DRC-SL remote controller for htat purpose
Old 07-16-2008   #24 (permalink)
Supporting Vendor
Simplicity In Sound
owner
acutally, as far as i know, not all are three ways. if i recall, Tony ran horns?, mic had both kicks midbss and midrange off axis?
also, how much experince doy o uhave with he rt27f? and why do you hate playing tweeters low if you can indeed do so?
well, once again, i am going to leave the theory stuff to you guys hehe, no matter what i say, people arent going to be convinced, I just do the stuff from real world experience, and to me, doing it off axis sounds fine in many occassions.
b
Old 07-16-2008   #25 (permalink)
amapro704's Avatar
b
No I agree it probably sounds stellar, just with those guys winning competitions, I doubt they were able to do it off axis with a standard 2 way set up. Lots of cars sound good-great even-that would probably fail miserably at a competitive level. I have 0 experience with the rt27f, but I have never liked the sound of a 1" tweeter under 3k- Just my opinion I guess and more from a tonality standpoint. I am with you- what works in real life is more important than theory or what looks good on paper. Thanks for the info on Zapco's DSP program
Oh and PS, I dont think you need to convince anyone of anything, having seen your work
'06 Lincoln LS install - My first true SQ LS-N-IT DIYMA Build Logs 29 04-28-2010 01:46 PM
An abbreviated install log of my own car :) simplicityinsound DIYMA Build Logs 122 01-30-2010 11:05 AM
2006 Toyota Tundra Double Cab - My Install Log txbonds DIYMA Build Logs 149 12-14-2009 08:02 PM
Marc's DLS E36 M3 install marbat DIYMA Build Logs 39 07-10-2009 02:03 PM
Just got done with a Lexus Install, with full install log attached :) simplicityinsound DIYMA Build Logs 52 09-21-2008 10:35 AM
