Old 08-07-2008   #1 (permalink)
simplicityinsound's Avatar
Supporting Vendor
Simplicity In Sound
owner
Default 2000 Land Cruise SQ install completed Pics
Well, totally done with mo2vation's 2000 Toyota Land Cruiser
For build up pics, please see this thread:
My Install - 2000 Toyota Land Cruiser (preparation Pt 1)
anyway, goals:
1. excellent sound quality
2. classy and simple design with a little bit of show factor
3. the hatch install needs to be EXTREMELY strong to withstand pounding from diving tanks, drum sets on a regular basis
so...lets get started.
the signal source starts with a pioneer 6000UB ipod enabled CD player, this is a more or less temporary solution, he will switch to a double din of sometime down the road.
front stage consists of a set of a Seas Lotus reference 6.5" two way components, the tweeters are molded into the A pillars, and covered in tan vinyl. as you can see, this A pillar is very long and extends all the way to the B pillar:
the midbass are in vinyl trimed fiberglass kick panels, aimed on axis with the opposite listener:
and here is the front stage as a whole:
grilles were made for the kicks:
and here is what htey look like attached:
take off a stock pop off panel on the left side of the dash, and the USB cable for the zapco DSP control can be accessed, plug in an extension, and tune away from the driver seat:
www.simplicityinsound.com
Old 08-07-2008   #2 (permalink)
Supporting Vendor
Simplicity In Sound
owner
Default Re: 2000 Land Cruise SQ install completed Pics
moving onto the cargo area, i built a side mounted amp rack/subbox, in the end, it only took up about 3" of real trunk space, meaning the space that goes beyond the wheel well cover. this also allows him to retain back seat fold down ability to pass long cargo through. the rack is VERY sturdy, i can sit my 200lb butt on it and you can grab it and shake the entire truck with it...
on top of a vinyl cutout window with mesh and land cruiser logo that sits above the two amplifiers, a Zapco DC reference 650.6 powers the front stage (180watts for midbass 100 for tweets), and a DC 500.1 power a single IDQ10v3 with 500 watts. the mesh not only hides th amps from plain view, but also provides adequate heat dissipation. the sub is flushed into a vinyled opening, and a plexi window looks into the Distribution blocks. the front and back sides
have a grilled cutout on them to allow air to flow though the entire structure, this will ensure the zapco am's fans, whcih draws air from one side of the amp and out hte other, does not just circulate dead air. the entire rack is finished in tan carpeting:
fold the backseat down and you see the other vented covering panel:
a grille was made to go over the sub and D block rack:
and here is the grille on the rack, the carpet is fully breathable so it does not affect the sub's output.
and finally, a few shops of the naked rack showing hte wiring and layout:
with just a standard file loaded onto the amps now, it sounds pretty good arleady, stage is surprisingly high, with good solid midbass impact. taking her down to LA tommorow and gonna tune it some more with Eng.
Old 08-07-2008   #3 (permalink)
slvrtsunami's Avatar
nice, very nice. I am sure ken will love it. Unfortunately, I will not be able to make the Aug. 9th meet so I can't see it in person.
Off topic: about your avatar. Gotta love the Major!!
slvrtsunami is offline   Reply With Quote
Old 08-07-2008   #4 (permalink)
wow that looks beautiful. Simple yet oh so nice. I hope to one day be able to do work like that.
jdc753 is offline   Reply With Quote
Old 08-07-2008   #5 (permalink)
dual700's Avatar
Send a message via AIM to dual700
Meh.
J/K!
Damn, I miss having SUV back!
Npdang is a sexy mofo
www.mobilesq.com
dual700 is offline   Reply With Quote
Old 08-07-2008   #6 (permalink)
Very nice!
I'm noticing the DC and Lotus combination work well together : )
sr20det510 is offline   Reply With Quote
Old 08-07-2008   #7 (permalink)
Supporting Vendor
Simplicity In Sound
owner
yeah i like the DC cuase its set and forget, less wires, no need to access back there once its on
i will have it at the meet on saturday
Old 08-07-2008   #8 (permalink)
Nice to see a different style install from the ones we usually see. Good job.
Question: Because they have the DC Reference amps, there is no external processor, correct? So the USB connector comes from both amps? i.e. one connector daisy chained?
(no need to answer if you've already done so on my350z)
dvflyer is offline   Reply With Quote
Old 08-07-2008   #9 (permalink)
mom has same car. white 2000 landcruiser
im so tired of those 2 4" vented subs in the back cargo area where your new box amp rack is. but i bet it was a simple install car is easy to mess with.
nice work bing
Iamamp3pimp-Sundownz-Kpr10is-Premier-Audio-Raamaudio-Mr.Marv-Wheelieking71-go-go-thrash-Gymfreak101-Mobieous-JmanPc-
theothermike is offline   Reply With Quote
Old 08-07-2008   #10 (permalink)
Supporting Vendor
Simplicity In Sound
owner
hey mike,
you just run one usb cable back, little telephone cords daisy chain all the amps together, you can i think chain up to 10 or 15 amps and tune it off one cable upfront
b
Old 08-07-2008   #11 (permalink)
those grills you made are impressive.
spliflover is offline   Reply With Quote
Old 08-07-2008   #12 (permalink)
H-Audio - AKA - Here-I-Come's Avatar
H-Audio Inc USA
National Product Director
Nice, I like it.
"Its All About What Sounds Right"
Mark A. Brooks
H-Audio Inc. USA
Website: H-Audio Inc USA
H-Audio - AKA - Here-I-Come is offline   Reply With Quote
Old 08-07-2008   #13 (permalink)
drake78's Avatar
stunning work as usual
drake78 is offline   Reply With Quote
Old 08-08-2008   #14 (permalink)
Looks great!!!
The rear solution for hauling looks like it will hold up just fine...
B-
Never quite done!!!!
moosejuice is offline   Reply With Quote
Old 08-08-2008   #15 (permalink)
why black grilles?
Whiterabbit is offline   Reply With Quote
Old 08-08-2008   #16 (permalink)
drake78's Avatar
Originally Posted by Whiterabbit View Post
why black grilles?
the blacker the grill....the sweeter the sounds
Old 08-10-2008   #17 (permalink)
shinjohn's Avatar
Bing,
Nice work as usual!
Just curious: do you really need venting at the front and rear of the rack, or was that more of an aesthetic decision?
edit: and congrats to mo2vation on the install!
shinjohn is offline   Reply With Quote
Old 08-10-2008   #18 (permalink)
Very nice install. If I was on your coast, Id defiantly give you my truck to work on. Just no one I cant trust anymore around here.
Seems like you use the lotus set a lot. Just curious what crossover settings you find to be best with them, assuming you went active with the zaps? And any eq cuts you tend to address usually with the set.
Eclipse AVN6600 > Kenwood x4r & x1r > Rainbow Profi Kick > Morel MT23 > SSA Icon 12
tyroneshoes is offline   Reply With Quote
Old 08-10-2008   #19 (permalink)
cheesehead's Avatar
Very nice!
I especially liked the amp/sub box in the hatch.
"Perfection is not attainable, but if we chase perfection we can catch excellence. -Vince Lombardi
cheesehead is offline   Reply With Quote
Old 08-10-2008   #20 (permalink)
Supporting Vendor
Simplicity In Sound
owner
shinjohn, well, i cant say for sure if i need it or not but i know only three facts:
1. socal gets much hotter than us on average
2. the zapco dc amps do indeed run pretty hot and definetly utilizes its fans
3. it cant hurt to have the box flow air through it
so...
hehe
b
Old 08-10-2008   #21 (permalink)
Thumbs up Just got home and got to see the rig up close!
My wife and I just landed from Bonaire (diving, etc.)
Rolled in, and there in the driveway is my truck. Haven't see it for quite awhile...
I get in, and the faceplate is off of the head unit... I'm thinking, "I know Bing, dude either put it in the glovie or in the console - we'll try the glovie..."
There it is. Snap it right on, and fire it up. I need to move the truck out of the driveway to get the 8 bags through the garden gate to the rinse station so I can dunk all of this dive gear and stuff.
So of course, I had to fire up the system to, you know, move the rig out of the driveway...
This task took about 20 minutes, as I called over my wife, had her get in and we drove the thing around the block 6 or 7 times.
I had sent Bing a couple of CD's that provided a sample of the stuff I like to listen to. He took the liberty of creating a reference CD of stuff not too far askew from that and left it in the head unit - so I got in, snapped on the face plate and up came some music.
Nice touch.
It sounds very good. Solid, punchy, quiet. There is a depth to the silence which I appreciate, as it delivers the perception of greater dynamics to the entire system. This isn't easy as I have the world's worst aftermarket windshield install....its like sticking your head out the window the is so much wind noise. This isn't a wacky car show punch and sizzle - this is a grown up's audio system. It makes me smile, as I haven't had a true SQ system since back in my Concord, linear Power, Zapco PEQ, ADS days. Its been awhile, and this system crushes that one.
I'm a drummer, and Bing included a studio drum session on the CD. I know what I want a kit to sound like, and dude nailed it.
The install is first rate. Thanks for cutting the front floor mats around the kicks - they look great. The back mat looks very good, too. Everything looks just like it does in the eMails and pictures we've been sending back and forth, but its real now.
COOL!
This head unit will go in my wife's Rav 4 sometime before long when I bring the LC back up for the double din DVD / NAV upgrade.
Again, I SO wish I was here for the grand unveiling and hand off. I'll call you later, Bing - I want to hear all about the SoCal M&G and have you walk me through some of the finer points of the system.
Thanks again.
Anyone in SoCal - it is SO worth it to make the drive up to this guy and have him do your work for you. I'd only seen his stuff on this site, walked through his posts, saw the peer respect he garners, listened at how he spoke of audio and his passion for SQ and there was no doubt that Bing was the guy for me.
The vision is described to him - a bullet-proof box sitting over the rear wheel well that will be out of the way and house the sub - he took another step further and added the D-blocks, Amp rack, some "tasteful flash" and little extras (like the venting, the matching grills, the LC logos, etc.)
Of course the SQ is there, but the install is classy, rugged, functional, stealthy and will serve every purpose I laid out in the very first eMail Bing and I exchanged back in April.
Bing - thanks again. You pour yourself into every install, and I'm very fortunate to have gotten to know you, receive excellent recommendations from you and have you complete a stellar custom install on my Land Cruiser.
Thanks again, buddy.
Ken
mo2vation is offline   Reply With Quote
Old 08-10-2008   #22 (permalink)
Default Re: Just got home and got to see the rig up close!
why black grilles?
Old 08-10-2008   #23 (permalink)
why black grilles?
Because he knows this is a working truck. That means lots of mud and sand from diving, flyfishing and other outdoor activities.
I'd bigfoot all over tan grills and they'd look pretty bad very quickly.
Ken
Old 08-11-2008   #24 (permalink)
Supporting Vendor
Simplicity In Sound
owner
why black grilles?
cuase i took a gander at the stock tan grilles he had on the stock door and sub woofers, and made a pretty quick and easy decision on black grilles. long term durability is more important for sure. those stock grilles were pretty much a few shade darker with black streaks all over the place hehe
also, from a cosmetic stand point, it is my opinon that unless you can match the factory tan/beige perfectly twih your own grille cloth, its best not to try, and instead, with the black tweeter grilles of the A pillar, its an overall better match cosmetically. when you see the black in pics its easy to say, well, cant you go tan, but then you go and try to match the stock tan to your book of 8 different grille cloth colors and nothing comes too close...thats another story hehe
Old 08-12-2008   #25 (permalink)
Thanks Bing. I completely understand about the tan interior (now that I drive a tan interior car) I can't believe how susceptible they are to black scuff marks from shoes. Disappointing at best. I can't imagine the effect of moving a drum set around repeatedly has had on tan paneling in the back.
I appreciate the explanation.
2000 4runner install - kicks, doorpods and deadening jmelan DIYMA Build Logs 164 06-12-2009 02:48 PM
My 2000 Ford Ranger Install BKJT05 DIYMA Build Logs 15 08-14-2008 09:18 PM
Thy 2000 GMC Sierra "NO LIMITS" install begins...AGAIN! smgreen20 DIYMA Build Logs 1 05-02-2008 08:45 AM
Old Car Audio & Electronics magazines 89grand Classifieds 12 02-14-2008 12:14 AM
New install 2000 Acura integra H-Audio - AKA - Here-I-Come DIYMA Build Logs 6 09-12-2006 01:38 PM
Second Skin Spectrum
