Old 09-12-2008   #1 (permalink)
simplicityinsound's Avatar
Supporting Vendor
Simplicity In Sound
owner
Default A true SQL system in a 350z
well, just got finishd with a relatively interesting system in a 350z...a somewhat departure from my norm. did this acutally a coupla weeks ago...but then went on vacation
the goals:
1. Superb sound quality
and
2. A VERY LARGE amount of bass lol
3. utlize the HU, subs, subbox, and amplifiers already provided by the customers to create a clean (not showy at all) install.
well, onto the intsall...
the signal starts with a kenwood excelon 8019 headunit, the unit was already installed in the vehicle and was kept:
the remote bass control for hte subamp was custom intalled into the factory knockout panel in the arm rest area:
as the system features zapco dsp tuning, the usb cable comes out of hte center arm rest to tune via laptop:
front stage consists of a pair of Seas lotus reference 6.5" two way component set. kick panels were built to houes the midbass. i played around with the angling of the speakrs before molding, and found that the further i pushed them against hte firewall, the better they sounded, deeper stage, better tonality...so thats how they were done, a bit further back than the normal kicks i buid. they were wrapped in black suede:
www.simplicityinsound.com
Old 09-12-2008   #2 (permalink)
Supporting Vendor
Simplicity In Sound
owner
Default Re: A true SQL system in a 350z
now a coupla quick build pics on the kicks, first, hre ist he mold and then inside layers wtih a crap load of modeling clay to reduce resonance...ooo multicolors lol
then, another layer of dampening went on top to reduce resonance even further and to holdt he clay in place
this results in a super heavy and dead kick panel wtih zero resonance even at high volumes.
here are the front of the mold:
here is the driver side kickpanel sueded and speakres installed:
here you can see how little they actually protude from the stock kick piece:
same goes for the passenger side:
Old 09-12-2008   #3 (permalink)
Supporting Vendor
Simplicity In Sound
owner
the tweeters were molded into the stock A pillar, off axis firing across at one anther, a lot of aiming to insure they were dead across. they were then wrapped in matching vinyl:
and two quick mold pics of hte A pillar:
the mold sanded:
and then wrapped in vinyl and tweeters installed:
Old 09-12-2008   #4 (permalink)
Supporting Vendor
Simplicity In Sound
owner
moving onto the trunk...so here is where things get a little interesting...the customer provided me with two TC sounds subs (HUGE 10s), a Zenclousure type S dual 10 subbox, and three Sunddown amps...so i basically had to come up with an amp rack design to worked well wtih the subbox...
so here is the view all covered up, as you can see the zenclsoures behind-the-strut subbox , but he rest of hte floor is still relatively stock looking. if you are wondering why there arent any grilles for the subs...thats the customers choice, not mine hehe, not to mention the hugeness of hte subs would make grilles pretty hard to do onto the box
here i want to give a huge thanks to Mike at Zenclosures, a true class act and very professional. He makes a very fine product as i always say, and hecame through in a huge way when the initial box was not the right dimension (NOT mike's fault, but rather a slightly miscommunication becuase this box had to be custom made to fit the subs and its requirements), sending out a replacement on TWO day shipment! working through saturday to get it done. again, HUGE thanks to Mike and Zenclosures
back to the install, lift up the carpet, and a fake floor greets you, coverd in matching black carpet like the subbox: there is a central cutout in the middle:
remove the cover, and the three Sundown amps provided by the customer peer out at you
A big 4 channel is bridged, sending 300-350 watts a piece to each midbass, a two channel powers the tweeter with 100 watts, while a big mono block sends 1500 watts to the dual TC 10s. to fill in the gap between the amps, i put in some copper bars, painted silver metalic, so the theme of black amp with silver trim (already present on the amps) continues across the amp rack.
hidden out of hte way is a Zapco DSP6-SL process providing all the EQ, xover, and time alignment needs to the system.
Old 09-12-2008   #5 (permalink)
Supporting Vendor
Simplicity In Sound
owner
and finally a look at the wiring and build below the floor, everything wire tied, quite a few wires in a small area as you can imagine hehe...a 0 ga and a 4 ga was run back to run the amps.
anyway, after some tuning by leon, this turned out to quite a nice sounding car, with a lot of clarity, wide, and high staging, along with very wlel centered vocals. and the other side of hte system is on tap the minute a bassy song is popped in and the bass knob nudged (yes i said nudged lol)...it can pressurize the cabin something fierce hehe...prolly easily the loudest 350z i have ever done...
my brief impressoins of the subs were pretty good, lots of output, impact, not quite as blending as the more SQ oriented subs i am used to, but we will see overtime after they break in a bit.
the amps are also not too shabby, i am going to ut in a crossflow next week as they from my experince, run a little hotter than the DLS A seies and the zapco DC amps with the dual interal fan mod, in almost identical setups. but then again, the day i finsihed this car, it was well over 100 degress here in cali...over time we will know the true nature of these products i am not that famliar with and i can give you a more fair assessment, but my initial impressions are very positive.
cheers,
Bing
Old 09-12-2008   #6 (permalink)
bjayjr5679's Avatar
You sir are an artist.
Honda Pilot- Alpine/Arc/Cerwin Vega/Knukonceptz
Ebay & CA the same screen name.
bjayjr5679 is offline   Reply With Quote
Old 09-12-2008   #7 (permalink)
looks good. You like that shape in the trunk huh =P?
Morel Ultimo 12" / Arc Audio SE 2300 / Morel LE 3 / Arc Audio SE 4200 / Connections / Second Skin / Hushmat
lyttleviet is offline   Reply With Quote
Old 09-12-2008   #8 (permalink)
Supporting Vendor
Simplicity In Sound
owner
lol i knew someone was gonna say that haha, thats acutally the first two times i used htat shape ever but both installs lent it self well to it, wtih a smaller items in the middle and two large items on both sides hehe
Old 09-12-2008   #9 (permalink)
Boostedrex's Avatar
DIYMA Sneetch
Hey, those are TC OEM 10's! I have one of those that I never got around to installing. I have heard a couple in other people's setups and those things can be output monsters!!!! But I've also heard them actually sound nice too. It's a shame you can't buy them anymore.
Nice install Bing. Those kicks are surely different than your usual ones. Are they aimed towards the firewall or was that just the angle the pics were taken?? Clean work either way it's nice to see a few new pieces to one of your installs.
Zach
Old 09-12-2008   #10 (permalink)
amazing install as always. Truly inspiring.
I am looking forward to your more experienced thoughts on the sundown amps. I am currently using a Sax100.4 and a 1500D (hasn't been used yet as I am waiting on the subs.) The 100.4 has been working great for me soo far and I can yet to find a problem, however I am pretty new at this stuff so curious to see how it compares to the bigger boys such as Zapco.
Always great to see nice clean installs in those cars, seems they are just begging for a system with how they are designed. I think some of the cleanest installs I have seen are in 350Z's
2005 Ford F350 Crew Cab
///Alpine - Sundown - Polk - Stereo Integrity
Build Log: Working on It!!
jdc753 is offline   Reply With Quote
Old 09-12-2008   #11 (permalink)
great work as always!
dalucifer is offline   Reply With Quote
Old 09-13-2008   #12 (permalink)
AzGrower's Avatar
one question, why not use black screws for the subs instead of the silver ones? That way the "dots" dont stick out?
**FOR NOW**
Stock 2008 Chevrolet Suburban Z71 (Sad to say with Bose system <--the wifey's choice)
AzGrower is offline   Reply With Quote
Old 09-13-2008   #13 (permalink)
fcarpio's Avatar
Send a message via AIM to fcarpio Send a message via Yahoo to fcarpio
nice, very nice.
erutangis on
fcarpio is offline   Reply With Quote
Old 09-13-2008   #14 (permalink)
Great job. I really like what you did with the amp mounting, nice attention to detail with the copper bars between the amps. It makes for a nice blending of the silver/black theme across all the amps like you stated.
I'm curious about that too.
Bought from: Doola36 (CA.com), ThE1BiGMiKe (Mazda6Club.com)
Sold to: tijuana_no (DIYMA)
Pantani is offline   Reply With Quote
Old 09-13-2008   #15 (permalink)
Abaddon's Avatar
Incredible work.....
What do you charge for a job like that?
Team "YOUR MOM" PDX 4.100, 2.150 & 1.600 3Sixty.2
Seas P18RNX & 27TAFNC/G (7" Poly & Neo Aluminum)
10w6v2 with Mr. Marv Custom Enclosure
Abaddon is offline   Reply With Quote
Old 09-13-2008   #16 (permalink)
Supporting Vendor
Simplicity In Sound
owner
hey guys...
a few answers:
AZgrower: well, yo uhave to ask TC that question, well, not anymore apparently lol, those are the specific screws they supplied with the sub, silver ones with a tall hex top, i wanted to use them beucase with how big the sub is, i wnated to make usr ehte screws fit into the screw openings perfectly and theirs are designed to do it. the funny thing is, they give you a hex wrench in the box, just a normal L wrench, as if nayone was gonna screw in the sub with that hand wrench heheh
i am not sure why hte kicks look like they are aimed inward, cuase in the car, they are not, they are pretty much aimed directly off axis...if you look at hte pic of the kick outside of hte car, taken from the top, you will see what i mean...i think the lighting in some of hte pics makes it look like htat. but in the car, they are aiming directly sideways, if not a little towards the front hehe
b
Old 09-13-2008   #17 (permalink)
Boostedrex's Avatar
DIYMA Sneetch
Very cool. Thanks for the quick answers Bing.
Old 09-13-2008   #18 (permalink)
Very nice, clean and simple install. Love it!
Irishfocus06 is offline   Reply With Quote
Old 09-13-2008   #19 (permalink)
Not really feelin' the shape of that amp trim piece, but I see why you shaped it like that.
Too bad they didn't want to do Dash Pods.
dvflyer is offline   Reply With Quote
Old 09-13-2008   #20 (permalink)
dual700's Avatar
Send a message via AIM to dual700
Great speakers, so so install
Awesome job, Bing!!!
Npdang is a sexy mofo
www.mobilesq.com
dual700 is offline   Reply With Quote
Old 09-13-2008   #21 (permalink)
DIYMA Psychopath
Bing, have you worked on a newer model Civic by any chance? I'd be curious to see what you did for midbass/midrange drivers if you did a kick install.
Buy, try, sell. x3.
Ignorance is housed in complacency.
Old 09-14-2008   #22 (permalink)
Supporting Vendor
Simplicity In Sound
owner
funny you should ask, check backwtih me in a coupla months, hehe...or check wtih mr dvflyer
Old 09-14-2008   #23 (permalink)
Supporting Vendor
Simplicity In Sound
owner
you forgot to mention "worlds best DSP", thank god i didnt use that h701 junk favorite by ghetto ass indos!!! lol
you driving up with Ron end of this month to tune my car or waht? lol
Old 09-14-2008   #24 (permalink)
love your work. I bet that Z sounds amazing... I've always been a fan of TC, esp. since I'm from SD myself
douggiestyle is offline   Reply With Quote
Old 09-14-2008   #25 (permalink)
dual700's Avatar
Hey hey hey!!
I'd drive with Ron if you baby sit my kids?
You should drive down here, leave your car with me for couple of days...
www.mobilesq.com
Setting up a PC based loudspeaker measurement system npdang DIYMA Tutorials 195 10-20-2008 01:29 PM
Getting ready for USACI regionals in Tulsa, OK. ItalynStylion DIY Mobile Audio - SQ forum 58 08-29-2008 10:18 AM
Case study - system frequency response Ge0 DIY Mobile Audio - SQ forum 24 02-29-2008 06:37 PM
My first impressions of new system... dbphelps DIY Mobile Audio - SQ forum 3 06-12-2007 06:50 AM
what is the weakest link in my system... af22 DIY Mobile Audio - SQ forum 3 09-22-2005 05:43 AM
