DIYMA Build Logs A showcase forum for pictures and videos your installs. This is not a question and answer section.
Old 06-03-2009   #426 (permalink)
bertholomey's Avatar
Default Re: My 2008 F150 SuperCrew install
This truck did sound very good at the meet last week - I wish I could have heard it with the BM hooked up. I wish you had been able to listen to my set up with one SI Mag - let me know if you make it over to the Greensboro area sometime if it is before our mini-meet.
e46 BMW 325i
Build Log
bertholomey is offline   Reply With Quote
DIYMA
Sponsored links
Old 06-03-2009   #427 (permalink)
ARCuhTEK's Avatar
Thanks! I am so new to this, it was good to get input, though not many people save me input on the scene (more post thread remarks, which is good too).
I did want to hear your ride, but it was full most of the day. Sheesh had to take a ticket! Although, if you saw my comment from the meet thread, you know I am about as useful for feedback as a warthog with t**ts.
I guess that makes it seem like all take and no give....but you dont know how much I wish I have the anatomical audio tools to give you feedback.
ARCuhTEK is offline   Reply With Quote
Old 06-06-2009   #428 (permalink)
what are the door cards? I've seen you mention it quite a few times but still dont know what you're referring to.
BlackFx4InTn is offline   Reply With Quote
Old 06-06-2009   #429 (permalink)
ARCuhTEK's Avatar
Fancy term for the plastic door panels.
Old 06-06-2009   #430 (permalink)
-when you relocated the remote module, did you have to drill any new holes behind that trim piece, or did you use 2 of the few holes already existing there?
-What kind of distro blocks are those? They look like stingers, but whats the model #. Also the second set of distro blocks (+/-) feeding off the 4 ga, what are those?
Sorry for all of the questions, I'm just now relocating my amps to the back wall and your build has helped me out a lot. I'm sure I can think of more.
Old 06-09-2009   #431 (permalink)
ARCuhTEK's Avatar
When I relocated the remote module, I used sheet metal screws and made new holes. It literally took about 5 mins to relocate it from start to finish.
The main distro block are:
Ground: Stinger, Model: SHD21
Stinger SHD21 Car Audio 1 (1/0Ga Input) 4 (4Ga Outputs) HPM Distribution
Power:
Stinger. Model SHD821
Stinger SHD821 Car Audio 1 (1/0Ga Input) 4 (4Ga Outputs) Distribution
or
Singer HPM MIDI Fused Distribution Block
I have several of these left over if you need one or more.
The triangular one in the photos allows me to input 4 ga and output 8 ga....but I use it to output 12 ga.
It is a P3 Platinum Distribution Block 1x4
http://www.parts-express.com/pe/show...number=263-672
There are so many distribution blocks on the market (fused and non-fused) it is not even funny!! I recommend Parts Express and Darvex and good, reliable sources.
Old 06-09-2009   #432 (permalink)
Power:
or
Parts-Express.com:P3 Platinum Distribution Block 1x4 | distribution power block amplifier p3powerbloc
cool, exactly what I needed to know. thanks
Old 06-21-2009   #433 (permalink)
Cool Re: My 2008 F150 SuperCrew install
Do you have any pictures of the finished product?
jr5166 is offline   Reply With Quote
Old 06-21-2009   #434 (permalink)
ARCuhTEK's Avatar
Other than the photographs above, not really. The truck looks 100% stock on the inside. So that would not look any different than perhaps any other F150. The last photos I posted were the ones with the back seat off showing the amp wall. That is all that is particularly interesting about my install. Nothing exciting, from a custom standpoint, but I suppose more informative from the "challenge" standpoint on getting amps and etc. on that back wall.
Old 06-21-2009   #435 (permalink)
Where did you mount the sub? I only saw door speakers installed.
Old 06-21-2009   #436 (permalink)
ARCuhTEK's Avatar
You only saw doors speakers installed in this thread? Really? Hmmm. I just checked and post 205 has some good pics of the amps, sub, etc.
Old 06-21-2009   #437 (permalink)
Sorry, yes I saw the great job on the amp mounts and I am going to do something similar in my 2009. I just have a few concerns on sub box location. I still didn't see a sub in the pics unless that grey plastic in the lower right hand corner of the last picture was it?
Old 06-21-2009   #438 (permalink)
ARCuhTEK's Avatar
Yes that "grey plastic" with the speaker wires running to the sub amp is my sub enclosure.
Old 08-05-2009   #439 (permalink)
Do you have a link to those clips you used for wire organization?
EDIT - Just out of curiosity, did you take a look at the enclosures from supercrewsounds before deciding on the Q-Logic? I'm thinking about picking up one for my '09 SCrew.
mears is offline   Reply With Quote
  DIYMA.com » Installation Discussion » DIYMA Build Logs
2006 Toyota Tundra Double Cab - My Install Log txbonds DIYMA Build Logs 149 12-14-2009 08:02 PM
I'd like to hear from ALL F150 owners.... Fish Chris DIY Mobile Audio - SQ forum 7 01-18-2009 02:21 PM
My attempt at a stealth install: 07 FJ cruiser AAAAAAA DIYMA Build Logs 63 10-19-2008 07:28 AM
thinking about getting a ford f150 supercrew scott_fx Off Topic 47 08-03-2008 12:56 AM
Install Question BlackLac DIY Mobile Audio - SQ forum 7 05-21-2007 07:55 PM
