Hello everyone. I signed up over here quite a while ago but never posted and kinda forgot about the place. :blush:
I see quite a few names i recognise from other forums and plenty i don't. Anyway, this is my new install in a ford fiesta. I already know the car pretty much inside out having had another one for the last couple of years but it's always fun to start from scratch.
The kit list itself is pretty much the same as my last instal but with a couple of small changes.
Pioneer P90 DEX & DEQ
Genesis profile ultra amplifiers
Hybrid audio L6, L4 and L1. Most likely changing to the L1v2's
The sub is new, was previously using an IDmax but now want to experiment with 8" subs up under the dash.
First of all, a quick look at how it stands at the moment. It seems the car may already have the Ford audio upgrade which to be fair really isn't bad as far as stock systems go.
Here is the original plastic inner skin removed.
Front.
And back.
It's reasonably stiff due to the moulded shape, but it's still very light and not good enough for a proper speaker mounting.
Now i am going to cheat a little bit here, these inner skins will go into my old fiesta, and the inner skins from the old one will be used here as they have already had all the work done. So in a Blue Peter stylee, here's one i made earlier.
This is the back showing the recesses filled with fibreglass filler. This adds a lot of weight and stiffens the skin. The same has been done to the front.
On the front of the inner skin there is also a layer of dynamat extreme to add mass and then a covering of box carpet to eliminate any contact of hard surfaces.
You will notice the speaker mount has also been modified to allow the fitments of the rather large L6 midbass driver.
Front.
And back.
