| DIYMA Build Logs A showcase forum for pictures and videos your installs. This is not a question and answer section. |
#1 (permalink) |
Hi, guys.
The day after USACi Finals (Oct 3-4) I took the car apart once again for a full rebuild. I'm tired of the current setup and the idea behind the change is to make the car fully functional again and use the KISS mentality. The install will be fully stealth with a twist since I'll still use it as my "comp" car. I have all the equipment already. Here are some pics. Head Unit: ![]() Amps: ![]() Subs (Two): ![]() Frontstage: The same HAT Legatia L831-3. The only change will be to take the L8's out of the door and into the kicks. J. |
Team Hybrids
Mazda CX-7/Pioneer DEH-P01/HAT Legatia L831 Pro SE-3/1,950 watts of JL Audio HD's in the center console/JL Audio 13tw5 subs |
Sponsored links
#2 (permalink) |
Started making the amp rack for the HD's.
I will have 2 versions. One with my current sub box and then another one with the 13tw5's. This is the version for my current sub box. ![]() The 3 HD amps will be under the sub box. ![]() The gap between the rack and the subbox will be covered with metal grille covered in speaker grill cloth with some fans to force cool air into the amps. ![]() I left the rack with a clearence of 4". The HD's measure 2" in height. The extra 2" will allow some air over them so they dont get too hot. ![]() The subbox will be held in place with a couple of hinges (still not installed). Full access to the amps connections once I take the rear seats down. ![]() I get most of my trunk back and full, easy access to the spare tire and tools. ![]() Now what could posibly hide behind door #1? ![]() How about an all in one power/ground distro block. ![]() J. |
Team Hybrids
#3 (permalink) | |
"There are no guarantees -------!"
#4 (permalink) |
Looks great so far Jorge! I'm car shopping at the moment and will have a new build centered around the P01 as well. Look forward to seeing your progress! I like the idea of the amps under the sub enclosure.
<Pioneer DEH-P01> <JBL 2118H> <Illusion CH-1/B&C DE500> <JBL W15GTi (x3)> <JBL PX300.4 (x2), Crown BPX2200.1>
#5 (permalink) |
Jorge, I don't know if putting all the HD amps below sub enclosure is a good method. As I got a HD750/1 still don't know where to put(now just lay unsecure on top of spare tyre) and it do generate considerable heat even running a 8ohm woofer right now. But compare to class AB amps, it is still cold.
Anyway it is still a good build. |
#6 (permalink) |
Curious about your cooling set up....should you have at least on of the fans draw warm air out?
PS that is a Shitty HU... ...give it to me.
#7 (permalink) |
I'm going to play with several fans and configurations before finishing the build.
The version with the 13tw5's wont have the box on top of the amps. And yes, unpredictableacts. I'll give you the HU. If you paypal $1,200 to doctorjuaristi@gmail.com LOL. J. |
Team Hybrids
#8 (permalink) |
Looks great! I'm looking forward to see the rest
2008 Honda Element SC Tweeterless...
Eclipse CD7200mkii Tangband 3", Peerless SLS 6.5s, Diyma R12 Zapco, JL Audio |
#10 (permalink) |
#11 (permalink) |
Team Hybrids
#12 (permalink) |
Batteries Plus Position:
Local ASM iTrader: (3) |
Did you pull all of you're wiring too?
#13 (permalink) |
Team Hybrids
#14 (permalink) |
Good! it looked like a lot of work went into running all your wiring, including the kill switch.
#15 (permalink) |
Looking good Jorge! Be looking forward to seeing this done.
#16 (permalink) |
wow... and jorge's circle of audio life re begins.
Sydmonster, downunder.
#17 (permalink) |
Loving the usage of the HD amps. Sadly, in Australia, many ill-informed will tell you they are no good as an SQ amp, this goes to show, they surely are!!
Bravo to you Sir!! |
#18 (permalink) |
Car Tunes Stereo Center Position:
Installation Manager iTrader: (3) |
But, but, but, they're *Class D.* They *can't* sound as good as 'a' or 'ab', *everyone* knows that.
j/k Jay |
My opinions are mine alone, and do not necessarily represent those of my employer. Oh, and they're always right, too!
#19 (permalink) | ||
This version will have a lot less wiring (3 vs 5 amps, 1 vs 3 distro blocks). But I'll still do it just like the previous one as far as attention to detail, overkill and OCD. The kill switch stays. It's prewired and I used a quick disconnect plug to be able to easily use any HU I use in the future. But I have some surprises for the kil switch. ![]() LOL. I totally agree. It's my only car, daily driver and "comp car", but this time the first two outweighted the last one. ![]() Quote:
Just to give you an idea, I tested the JL Slash, JL HD's, Zapco DC's, McIntosh, Sinfoni, Arc SE's and several others. ![]() The size/power ratio on the HD's is just amazing. And as far as "SQ" goes, they RAWK. J. |
Team Hybrids
#20 (permalink) |
I think its fantastic that you are keeping the rear functional with access to the spare tire while maintaining a competition system.
2006 Mazda3 S GT
The past is history, the future is a mystery and today is a gift; that's why it's called the present. |
#21 (permalink) |
Stereo Worx Position:
Installer/ Sales iTrader: (1) |
i wanna see some cutting..... bust out the cut off wheel
06 350Z F90BT, H.A.T. L4 & L1Pro, Revelator, SPX-17Pro, JL 10W7v3, JL 500/1, PDX 4.100 & 2.150, Tsunami
350Z Build |
#22 (permalink) |
iTrader: (12) |
#23 (permalink) | |
Patience my friend.
I fear for my personal integrity if my wife finds out ( ), so I need to send her out of town for a weekend before cutting anything.Quote:
But not only frying pans. I also need rubber tv's, rubber candle holders, rubber knifes, rubber plates, rubber toasters, etc, etc, etc, ![]() J. |
Team Hybrids
#24 (permalink) |
Team Hybrids
