Old 02-18-2010   #1 (permalink)
simplicityinsound's Avatar
Supporting Vendor
Simplicity In Sound
owner
Default Simple G35 Coupe SQ install...yes another G35 :)
just got done with an 2005 G35 coupe. Its a simple SQ build and we plan to compete wtih it in MECA, SQ only (no install), street class. starting at autorama this saturday
goals:
1. achieve a nice level of sound quality for daily listening and the occasional sq comp
2. to take up as little room as possible in the trunk since this is a daily driver
3. to create a look that is subdued but carries a little more flare than say just a plain carpet install
acutally, even though i have done quite a few G coupes, this one is somehwat unique, its acutally the first active SQ install i have done in one that still has all the product in the floor. with the other true sq setups, they all involve a side mounted box, and the ones that have it all in the floor have been just passive setups.
lets get started.
first two quick shots of the battery. even though adhering to install rules is not a requirement, i figured i will take two quick pics anyway.
first shows the 0 guage power cable, wrapped in techflex going into the cabin via the stock rubber grommet:
here is a shot of the 150 amp circuit breaker that protects the system, tucked next to the battery and within 18"
the signal starts wtih a kenwood 7014 dvd/nav double din unit, provided by the customre, and is installed via the JDM adapter plate and dual zone climate controller. the ipod cable comes out of the upper cubby:
as the car utilizes zapco tuning, here is the pic of the laptop plugged in and doing some tuning
the front stage consists of a set of seas lotus reference 6.5" two way components, and as usual, the door panels received a layer of foam damping with some normal proofing material near where the speaker mounts. a new baffle was fabricated, coated in truck bed liner, and new wires ran into the door via stock molex plug, here is the driver door:
quick shot of the termination at the driver side midbass:
and the speaker installed in the door:
a close up of the seas lotus reference 6.5" midbass driver:
www.simplicityinsound.com
Old 02-18-2010   #2 (permalink)
Supporting Vendor
Simplicity In Sound
owner
Default Re: Simple G35 Coupe SQ install...yes another G35 :)
same goes for the passenger side:
the backsides of both door cards was heavily sound proofed as well, as the stock door panel is definetly prone rattling and buzzing, this helps cure almost all of those issues:
the tweeters were molded into the A pillars...first, ring baffles were aimed (off axis facing each other), mold cloth pulled, and resin applied. when that cured, a duraglass - resin mixture was poured into the inside to make the pods solid:
then filler was applied and the entire thing sanded smooth:
they were then wrapped in black vinyl to match the dash:
and the tweeters installed:
Old 02-18-2010   #3 (permalink)
Supporting Vendor
Simplicity In Sound
owner
and here they are, installed back into the vehicle, sorry for the dark pics:
the only remaining pic of the interior is the sound proofing of hte rear deck. what i have come to notice in the past, is that the majority of the rattles that eminate from a G35 coupe's rear deck, is from the cardboard rear deck cover buzzing, and also from it boucning up and down against the metal. to the point htat sound proofing the metal part does very little to help. what i have found is that a layer of foam helps greatly here, and this is what it looks like on the underside of the stock rear deck cover.
both rear deck speakers were removed as well for better venting into the cabin:
moving onto the trunk...as mentioned in the goals, the idea is to take up very little room. and here is the normal view with everyhting hidden, and it looks virtually stock:
pull off the carpet, and you see the center section fake floor with a gunmetal CF vinyl insert, with carpeted grilles covering cutouts.
lift those covers and the system is exposed. two image dynamics ID10 subwoofers is upfront, sitting in a sealed enclosure just below a cub foot. they are trimmed in black vinyl. the cutouts in the back showcase a zapco DC reference 650.6, whcih sends 180 watts to the midbass and 100 watts to the tweeter, and a DC reference 500.1, which powers the ID10s with 500 watts total. i also trimmed the stock under carpet to fit beside the fake floor that i built:
Old 02-18-2010   #4 (permalink)
Supporting Vendor
Simplicity In Sound
owner
so here are some quick build pics..
this is the subbox / amp rack combo, prior to going into the car:
once that was secured into the car, the subs and amps were mounted and wired up, here are two pics of hte wiring:
and finally, here is the two piece top fake floor cover, first in bare wood:
and then trimmed in their respective vinyl:
so thats it, simple and straightforward, and it does sound quite good. similar to david's G coupe that competed all last year in iasca. it needs some more fine tuning but we hope to get some more feedback and make some adjustments at the MECA comp on saturday
cheers!
Bing
Old 02-18-2010   #5 (permalink)
Very nice install, I like how all the G35 installs you do have there own look...
B-
Never quite done!!!!
moosejuice is offline   Reply With Quote
Old 02-18-2010   #6 (permalink)
Boostedrex's Avatar
DIYMA Sneetch
I look forward to getting a listen to this car at the show on Saturday. Nice work as per usual Bing. I take it you'll be at the show along with your customers? There are a few things I wanted to talk to you about if so.
Zach
Originally Posted by Andy Wehmeyer View Post
Sometimes the audio industry makes me feel like I'm wrestling the guys from "The Big Bang Theory" in an inflatable pool full of snake oil.
Team H-Audio and Team Stereo Integrity member
Old 02-18-2010   #7 (permalink)
Supporting Vendor
Simplicity In Sound
owner
yeah i will be there, along with either 3 or 4 of my guys see you in a coupla days Zach
Old 02-18-2010   #8 (permalink)
bing, i always notice that ur seas tweeters are always installed quite 'low' compared to the setups i audited here in my country. any reasons ?
bafukie is offline   Reply With Quote
Old 02-18-2010   #9 (permalink)
perfecxionx's Avatar
also, why do so many people on this board fire them off axis?
and last, specifically what kind of foam did you use on the rear deck? closed cell foam?
perfecxionx is offline   Reply With Quote
Old 02-18-2010   #10 (permalink)
Supporting Vendor
Simplicity In Sound
owner
1. my preference is always to push the tweeter as far forward as possible, to me that works best, and that usually means, having them as low as possible on the pillar
2. for me, as i mentioned a lot, i prefer off axis, for one cosmetic reasons, i hate having on axis tumors hehe, but also, i find htat off axis to me gives better depths and sometimes, less in your face kind of response. but i would say the first is the primary reason but to me, off axis so far works well in the cars i have done
the foam is edead v4 teklite...no idea what kind of foam it really is, its just foam to me
Old 02-18-2010   #11 (permalink)
Bing, gotta thank you. You did a great job. When I got home after work, I think I stayed inside the car for a good extra 20 minutes just listening to it.
And it sure didn't seem "simple" to me but atleast it was a little different from the other G35s you've done.
I'm going to dread the days when I get a loaner from the dealer when my car is in for service..
Can't wait for Saturday.
ntrinsik is offline   Reply With Quote
Old 02-18-2010   #12 (permalink)
lucipha's Avatar
I like it, simple yet effective. Is there any type of grill over the subs and if not do you have any problem with the subs slapping the bottom of the carpet?
Alpine F#1--->Genesis Dual Mono(X4)--->HAT L631 Pro SE+Genesis 12"
lucipha is offline   Reply With Quote
Old 02-18-2010   #13 (permalink)
Supporting Vendor
Simplicity In Sound
owner
i think there is a pic showing the grilles in place over both the amps and the subs?
Old 02-19-2010   #14 (permalink)
nirschl's Avatar
Need more time!
Another beautifully executed install, Bing!
Team Hybrids JAPAN
Carrozzeria- Arc Audio- Hybrid Audio Technologies- Stereo Integrity
Toyota Alphard
nirschl is offline   Reply With Quote
Old 02-19-2010   #15 (permalink)
FLYONWALL9's Avatar
I really like this install. Very clean and befitting of the car, almost as if it were a high end option offered by the factory.
Is that silver Neffy Wrap used on the inner rig of the amp rack? If so, have you ever tried to clear coat it?
MAN, I wish I lived in Cali so I could just drop off my car and have you do it!!
FLYONWALL9 is offline   Reply With Quote
Old 02-19-2010   #16 (permalink)
Send a message via AIM to Oblivi0us
Incredible work as usual. I swear I look thru your installs consistently as inspiration for my own install.
Oblivi0us is offline   Reply With Quote
Old 02-19-2010   #17 (permalink)
bigabe's Avatar
Can't wait to see the cars this Saturday!
And I REALLY can't wait for April to come around. Driving around with my busted stereo is painful.
2004 BMW 330i
Zapco/Seas Lotus/Phass/Dynaudio/Alpine
bigabe is offline   Reply With Quote
Old 02-19-2010   #18 (permalink)
DarkScorpion's Avatar
Wow,awesome install. Do you still have access to the spare? Or did you completely pull it out?
DarkScorpion is offline   Reply With Quote
Old 02-19-2010   #19 (permalink)
The spare was completely pulled out. The spare won't fit over the front brakes when I upgrade to the G37S calipers anyways so it wasn't a hard choice to make.
Old 02-20-2010   #20 (permalink)
lucipha's Avatar
I guess I skipped that pic. Great install!
Old 02-20-2010   #21 (permalink)
GSlider's Avatar
Nice install bud! Love the trunk. Its turned out beautiful.
GSlider is offline   Reply With Quote
Old 02-20-2010   #22 (permalink)
Supporting Vendor
Simplicity In Sound
owner
congrats Anthony...on your first place finish in street class SQ in your first MECA comp
i think there are still definetly kinks we need to work out on the tuning...so it can only improve from here
would love to see a show down between this car and nismov35 (david's) almost identically setup G coupe hehe
Old 02-21-2010   #23 (permalink)
Thanks Bing! That show down sounds fun
Old 02-21-2010   #24 (permalink)
Great looking clean install and great selection on the drivers.
jobrizzle7481 is offline   Reply With Quote
Old 02-21-2010   #25 (permalink)
That is a really nice looking amp rack/enclosure combo there Bing.
