Old 4 Weeks Ago   #1
simplicityinsound's Avatar
Supporting Vendor
Simplicity In Sound
owner
Default 2010 Lexus IS-F install, pics galore. :)
Hey guys, just completed work on a 2010 Lexus IS-F...a simple SQ install. This is my first IS-F (after doing about half a dozen more pedestrian second gen ISs), so I am super psyched to add this one to my resume.
First, I can’t help but to snap some pics of this thing. When the car first came out and I saw it on TV, I wasn’t that impressed...but when I finally got around to seeing it in person, it really grew on me. There are a LOT of differences, subtle and dramatic, that immediately sets this car apart than a 350 or 250. Where as previously I only focused on the interesting tail pipes, I notice now things like the bulging fenders, the much wider track, the vents in the front fenders, much more aggressive front fascia, and many many other details. Add to the fact that my neighbor had an IS250 that I see every day, this car paints an entirely different, and much more sinister picture right off the bat
I also LOVE the deep pearl white that this car came in.
www.simplicityinsound.com
simplicityinsound is offline
Old 4 Weeks Ago   #2
Supporting Vendor
Simplicity In Sound
owner
Default Re: 2010 Lexus IS-F install, pics galore. :)
Moving on to the goals for the system:
1. To achieve a high sound quality though the Stock Mark Levinson system
2. Keep things as integrated as possible on the interior
3. Build a very simple and clean design in the trunk (focus was not on show due to budget)
Let’s get started.
First is the 0 gauge cable and circuit breaker installed near the battery:
Next a quick shot of the 416HP 5.0 liter beast that powers the car:
Moving onto the interior. To best integrate the stock amplified system, and Audison Bitone was chosen, I ran a USB cable all the way to the glove box, so here is plug n play quick tuning from the front seat via the laptop:
Due to budget constraints, the owner's direction was to just double stick tape the bitone controller on the driver side dash, where three blanking plates give just enough room.
After giving that a shot, it just looked really non integrated, having this big silver box just sticky taped there. So I decided to build some kind of holder for the controller just to make it look a little better.
so here it is, a vinyl wrapped holder with the controller flush mounted, still sitting where it was suppose to be, but with only the front fascia of the controller showing:
This actually turned out to be a pretty difficult and time consuming task since I had to be very precise.
I first laid down a few layers of glass onto the stock panel to serve as back mold:
Once that cured, I carefully trimmed the piece so it’s within a few mm of the edge, this way, once I add in the thickness of the vinyl, it should sit almost flush:
I then glue together strips of hardboard to form the front baffle for the holder, careful to leave just enough room so the controller will slide in with the vinyl attached and be pressure fit in place.
Old 4 Weeks Ago   #3
Supporting Vendor
Simplicity In Sound
owner
Then I pulled grille cloth over the entire shape, applied resin, and then reinforced it from the inside by pouring a mixture of duraglass and resin:
Once that cured, a quick sanding session, and then I pulled vinyl over the entire shape. This was one of the toughest vinyl jobs I have ever done, because it is so small and so square. I used 4 way stretch vinyl with plenty of heat, but finally got it to go on right:
then I ran a screw through the center hole, into one of the blanking plates, and then put a speed clip at the back, fully bonding the holder to the stock trim panel, after that, it’s just about pressing the bit one controller in place.
Moving onto the front stage. A set of Seas Lotus Reference 6.5" two way components was used. The midbass went into the stock location at the lower door. But first both doors were sound proofed using a combination of foam and deamplifier, and new wires ran into the door:
Then I build a few baffle plates both for the front and rear doors. The thin ring at the left is for the fronts, as I utilized the stock speaker mounting baffle to mount the seas, it lined up perfectly, I just had to space it up about 1/8" to ensure it cleared the window properly.
These were then coated with truck bed liner:
So here are the lotus midbasses secured to the stock mounting baffle with a spacer ring in between. The holes lined up perfectly
and how it looks from the back, the inside of the stock baffles received some more sound proofing, though you can’t see it in this picture's dark lighting.
Old 4 Weeks Ago   #4
Supporting Vendor
Simplicity In Sound
owner
A quick shot of the wiring termination at the front door midbasses. The reason why there is foam on the back of the magnet is from a lesson I learned from other IS installs. When the window is down, and you slam the door, the bottom edge of the window tends to move a bit, and when you are within 1/4" from the back of the magnet, this can result in the window contacting the magnet, causing a ringing sound. Since there are no vent holes on the back of the lotus, this was done to prevent this contact.
The speakers were then bolted in place with the stock mounting screws:
The front door panels also received a layer of sound proofing, to help prevent resonance and rattles:
Old 4 Weeks Ago   #5
Supporting Vendor
Simplicity In Sound
owner
The front tweeters were molded off axis into the A pillars. I pushed them as far forward as possible and also high enough to clear the big wiring harness behind the driver side. After spending an hour flipping through my vinyl books, I found a color that matched the dash almost perfectly. The lighting makes it look darker but in reality, it’s very close
Now for a few build pics of the pillars.
First, the pillars were stripped clean of their stock covering, and rings were carefully aimed and attached:
grille cloth was pulled over the shape, resined, allowed to dry, and then the duraglass/resin milkshake was pour onto the inside, making the walls very rigid, you can tell where this milkshake went into by the darkened color showing through the grille cloth.
Then the whole piece was sanded smooth and blended together:
Old 4 Weeks Ago   #6
Supporting Vendor
Simplicity In Sound
owner
Vinyl applied and the tweeters wired up:
And finally, the finished product ready to pop back into the car:
On the back side, I applied a few more strips of sound proofing around the tweeter area:
One stipulation the customer had was to have rear amplified speakers for his child, so it doesn’t get too claustrophobic back there. He supplied me with a pair of Hertz HE coaxial for this purpose.
So the same process was repeated on the back doors, sound proofing and new wires ran into the door:
Termination of the Hertz Coaxial:
Old 4 Weeks Ago   #7
Supporting Vendor
Simplicity In Sound
owner
And finally, the hertz installed with the baffles I made earlier:
now a few shots of the wiring bundle going back, all the wires and cables are zip tied neatly every 6 inches or so to the stock loom, and runs up the sides of the back seat divider into the trunk via the stock grommets:
Old 4 Weeks Ago   #8
Supporting Vendor
Simplicity In Sound
owner
So that’s it for the interior, I also removed the stock sub on the rear deck to open it for better venting into the cabin.
Old 4 Weeks Ago   #9
Supporting Vendor
Simplicity In Sound
owner
Onto the trunk.
The goal here, originally, was to utilize a side fiberglass box and a very simple, carpeted rear facing amp rack. The focus is to remain stealthy and save space.
Looking into the car with everything covered back, it’s hard to notice much:
Closer examination reveals the side fiberglass box, with its press fit grille, and a rear ward facing rack with a cover featuring a raised Lexus F logo. The entire rack ate up only 7" of space at the very bottom, and 3.5 at the top.
A quick note on the box, it is built by my good friend Nick Johnson, a badass installer who currently runs Science of Sound: Science of Sound, Inc. he builds a variety of custom fit fiberglass sub enclosures under his own brand name and also for 4080enclosures. His boxes are some of the BEST products of this nature I have ever used, and this IS box is just awesome, everything from the mm exact fit, to the super thick walls, no drill mounting, and the beautiful pressure fit grille. As I always tell my customers if their cars can utilize one of his boxes, “I can’t build a better box regardless of how much you pay me, so just use this one"
While the original plan was for no flash at all and just plain black carpet. I quickly decided to add a little bit of extra flair to the build, just because this car is cool from the exterior standpoint. It isn’t much but I think it adds just the right amount of show factor to it.
Popping off the two grilles, and you first see an image dynamics IDQ12v3 in the subbox.
Three ID Q amplifiers power the entire system. A Q450.4 bridged into two channels powers the seas midbass with 200 watts RMS per side, another Q450.4 sends 75 watts to the front tweeters and the rear coaxial, and a 600.1 powers the IDQ with 600 watts.
The clean black finish of the ID amps really makes for a smooth look, but I felt that simply butting the three amps together would make for a pretty boring black on black design. so instead, I spaced the amps apart with 1/2" acrylic tubes, clouded over with 150 grit, and set on top of a strip of MDF topped in white vinyl, so the tubes, in daylight, gives off a white appearance to compliment the exterior of the car. I also decided to do a trim cutout in white vinyl, to future give it a nice two tone look.
A quick look at the super snug fitting box:
And a close up of the amp rack display:
On the driver side, I raised the floor of the stock storage holder:
And the audison bitone, is within easy access below it
A quick shot of the trunk from a little further back:
Old 4 Weeks Ago   #10
Supporting Vendor
Simplicity In Sound
owner
Those acrylic tubes do more than just add a little color; they are also wired to glow with white LEDs inserted at both ends. So here is the car in the dark, the trunk light turned on (I also switched that bulb from the stock yellow to white), and the tubes light up:
overall, I am really happy with how the trunk looks, despite this being one of the most simple layouts I have done...I don’t know what it is, if I think about the individual portions, nothing really stands out, but for me, looking at it as a whole, perhaps in combination with the unique nature of the car...I am a proud papa. I don’t usually get this giddy, but I can’t help myself with this one.
So...onto the wiring and builds pics.
The stock amp's output wire is tapped only at the front channels, since the bitone will control the fading and subwoofer controls. the front channels consists of front mid/high and front woofer, so here you see the four pairs of speaker wires tapping into the stock signal.
These were then neatly bundled, and then ziptied to the stock loom all the way to the driver side of the trunk and the bit one.
Here are more wiring pics, the two bundles entering into the car from the interior, and the RCAs and other cables from the bitone to the front. Everything is routed so the stock carpet piece goes on without much if any, modification.
Old 4 Weeks Ago   #11
Supporting Vendor
Simplicity In Sound
owner
A quick shot of the driver side storage bin cut with the new floor made:
And a shot of the subbox outside of the vehicle:
Here are the mdf strips and the acrylic rods, prior to sanding and vinyl wrapping.
Here you see the rods clouded over, and the top of the mdf strips covered in white vinyl, along with the four white LEDs that I will insert into the ends of the rods after pre drilling them.
And here you see the rods secured to the top of the MDF strips, with the leds secured in place. The whiteness of the vinyl shows through the semi transparent rod to give it a more whitish appearance.
As it turns out, this amp rack was quite an exercise in space conservation. The distance between the ceiling and the floor was only about 2" taller than the amps on either end. And the two ends only had about 1.75" to spare. So with in this confine, all the amps cables, distribution blocks had to be wired so it fits.
My decision was to pre wire as much as possible outside of the car, and using barrier strips on all the connections. This means that once I install this rack into the car, I only have the main power and ground cables, the various cables to a barrier strip spot, and the RCAs to plug in.
So here is the beast that came out of this effort, everything done to ensure it still will fit inside the space:
Old 4 Weeks Ago   #12
Supporting Vendor
Simplicity In Sound
owner
Then this rack was loaded into the car...its fits extremely snug against the top and bottom, further secured by four bolts. Here you see all the wires hooked up to the amps:
A few quick shots of the trim plates. First is the cosmetic trim panel, before vinyl application:
And after, the edges of the board were painted black, since white is such a contrasting color, I didn’t want any sliver of whiteness showing through the edges of the front board:
Here is the main front panel, before and after carpeting:
And the front grille plate with its F logo:
After some tweaking, I have to say I am pretty impressed with the bitone in this application. I encountered no problems and the sound is really good. Stage is nice and high with good center focus, width is not too bad, and is actually outside of the A pillars because they are a little further inboard than most cars. Tonality wise it’s very pleasant, and from doing earlier ISs, I can tell the Bitone did a good job of flattening the stock system. Going in, I was worried about potential issues with the unit, but really, it was pretty smooth sailing. I do still prefer the infinitely adjustable 10 band parametric EQ found on the Zapco DSPs, but giving that this is also an OEM interface and summing device, it’s a good overall package. I do think the instructions manual needs to be written in a more simple and easier to understand manner. By far the best sounding second Gen IS I have done...with some more tweaking, there is a good chance you may see this car at norcal MECA comps once in a while for fun
I want to thanks Eric at ID, who found a Q600.1 when non was in stock, Bikinpunk, Chuck Music and many other guys on the various forums who gave me tips on the bitone and the lexus system, Nick for his awesome box, and Larry at elettromedia who also gave me some great info on setting up the bitone.
Anyway, I am on my way to pick up the customer from the train station and then we are gonna go for a quick romp in the twisty hills behind my house! Woot!
Bing
Old 4 Weeks Ago   #13
Send a message via AIM to rimshot
That trunk is gorgeous, looks factory installed. Even though its not as complex as some of your other installs this may be my favorite. Absolutely perfect.
New install in the works: Alpine 9887 - Oz Audio Matrix tweets (90 w)- Fountek fr88ex/Faital pro 3fe20 (45 w) - Top Secret Midbass (320w) - Fi Audio IB3 (1500w) - 2X Clarion APX4361 - Clarion DPX11551 Undecided on processing for 4 way active...
rimshot is offline
Old 4 Weeks Ago   #14
bertholomey's Avatar
Great Build Bing! I have been looking forward to seeing your pics of that car. It sounds like you had a good experience with the Bit One. I'm sure the customer will be thrilled - it certainly looked like you have some nice hills behind the house to thrash around on
e46 BMW 325i
Build Log
bertholomey is online now
Old 4 Weeks Ago   #15
Simple and clean I like it. Can you tell how you made those rings for the tweeters?
Jose - VAG Group Fanatic
fmr. MECA/IASCA SQ Competitor/ fmr. Beyma SQ Competitor
Hope to see ya in a Lane Soon..
AccordUno is offline
Old 4 Weeks Ago   #16
Supporting Vendor
Simplicity In Sound
owner
two hole saws, very carefully cutout with a cordless drill
yeah just got back, we are going out for the drive now!
hehe
Old 4 Weeks Ago   #17
Supporting Vendor
Simplicity In Sound
owner
just got back...wow this thing is impressive. i was kinda scared in some of the really tight corners where we blasted through, traction control doing its things and trees a mere few feet away...very planted and secure feeling...
i drive like such a wuss by comparison
Old 4 Weeks Ago   #18
So when are you getting one?
e46 BMW 325i
Build Log
Old 4 Weeks Ago   #19
Supporting Vendor
Simplicity In Sound
owner
if they made an awd wagon version, i will consider it
Old 4 Weeks Ago   #20
Brian_smith06's Avatar
Very nice install and I agree with you not being a fan of them in the original commercials, until I saw one in person.
I must ask, how you like those ID amps? I am considering swapping out my current amps with what you put in this car except I'll have one more 600.1.
My current amp stage is a dls a2 a4 and a6 for reference of what I am currently running.
04 Cavalier: Alpine W200 w/H701 processor, ID XS65 comps, 2x12" IDMAX, DLS A2, A4,and A6
Brian_smith06 is offline
Old 4 Weeks Ago   #21
Supporting Vendor
Simplicity In Sound
owner
i have used the ID now a dozen or so times...and i like em, they are good quality, solidly built amps. but then again, i never seem to notice a huge difference with amps if they are the main deciding factor.
but in the DLS A series you have one of my favorite amps, i absolutely love how my A5 A4 performs, quiet, great control, just lovely stuff..
so i am not sure if i would put the ID at the exact same level, but of course, keeping in mind, they are about half or 60 percent of price, retail for retail, power for power, than the DLS A in many cases. so...
Old 4 Weeks Ago   #22
Send a message via AIM to moog
I've always been a fan of your work in the G35's.
moog is offline
Old 4 Weeks Ago   #23
Beautiful install, glad to hear that the bitone can sum & flatten the factory signals well.
I've been kicking around ideas with my install guy about a sub in the trunk of my 350. Aside from the 4080 enclosure you used here (which is being considered), have you tried or thought about a sealed single 8" or 10" in the stock location essentially firing through the rear deck? That was another of our ideas.
ISTundra is offline
Old 4 Weeks Ago   #24
Supporting Vendor
Simplicity In Sound
owner
i personally have not done a sub there. that stock location, i have herad a few guys who have swapped a sub that is somehwat of a direct drop in. i think they were jl free air 8s? anyway, well, i listened to them running off 300 watts of power...and to be honest, in many songs, they barely sound that different than the stock sub. sure its a little more output, but really, to me, at least, not worth the effort, not much bottom end or overall impact. and when pushing, the rear deck and all the stuff bolted to it really started to rattle badly.
i think it is possible to do a proper IB off the rear deck, but in order to do it properly so that the actual end result is superior to a sealed box in the trunk like the one i used, yo uwould need to put down a LOT of effort.
b
Old 4 Weeks Ago   #25
I like how you did an exceptional job with the amp rack and the attention to detail using the limited dimensions...great job as always.
Alpine Kicker Polk Audio
Afronaut is offline
