Old 03-09-2010   #1 (permalink)
Default Control Smell from Resin
I recently started my first attempt at fiberglass work in my car. My garage shares a common wall with another space. I did my fiberglass work outside of my garage but have received several complaints from the people on the other side of the wall about the smell. They're really upset. I've done everything I can to keep doors open and ventilate the space. Not to mention all of the resin has been used outdoors. I even left my enclosure outside over night to cure. I don't know what else I can do and these peoples say the smell in their space is horrible. Any suggestions? What do professional shops do to control the smell?
Alpine CDA-9887 w/Imprint, Morel Elate SW 6, Morel MT23, Morel Ultimo SC 12, 2x Genesis Dual Mono, and the works from Cascade Audio
remeolb is offline   Reply With Quote
Old 03-09-2010   #2 (permalink)
Greg S's Avatar
My garage
Lone guy
Default Re: Control Smell from Resin
You might have to switch to epoxy resin. It generally has much less of a stink to it but cost a lot more. It's just a general fact that poly resin stinks and the smell does get everywhere. Other choice is to not glass where you are doing it.
Greg S is offline   Reply With Quote
Old 03-09-2010   #3 (permalink)
Would Evercoat's marine resin be considered an epoxy resin? I'm currently using their automotive resin.
Old 03-09-2010   #4 (permalink)
chad's Avatar
big daddy
Move, some people are sensitive to two part stuffs, I'm married to one. Even bondo makes her angry.
Can you imagine going to your boss and saying "hey, I can improve distortion figures from .004% to .0004% by adding twice as many parts." They'll tell you to go shit in your hat.
Old 03-09-2010   #5 (permalink)
fourthmeal's Avatar
Shops don't give a F-. LOL.
But yeah, the fumes are pretty rough, I admit.
Epoxy resin should be easier on them, but rougher on your wallet.
'08 Tribute ~ F900BT (modded)^H-Audio Ebonys^Alpine SPX tweets^TB 6.5 X 4^Kenwood X4R & X1R...'99 TL ~ AVH-P3200DVD^ND20FA^AE10DH2 X2, 3sixty.2, SS HRU.4 & DTR1.1700
fourthmeal is offline   Reply With Quote
Old 03-09-2010   #6 (permalink)
Have you guys found that doing work outside is enough to at least reasonably control the problem?
Old 03-09-2010   #7 (permalink)
fourthmeal's Avatar
I run the resin a little hot, that way it doesn't reek for days on end as it cures. Also when the mold is complete I use the milkshake technique (a little hot as well) and for some reason that doesn't smell nearly as bad.
Baking soda boxes help a bit.
Old 03-09-2010   #8 (permalink)
chad's Avatar
big daddy
Round up a bunch of ferrel cats, male, to piss all over their bushes, this way they have a smell that's more pungent to worry about.
Old 03-09-2010   #9 (permalink)
fourthmeal's Avatar
I was going to say that if they are Indian then you could turn around and complain about their Curry...but I figured that would be out of line.
Old 03-09-2010   #10 (permalink)
This is my favorite suggestion yet, except for the part where I have to deal with cats.
Old 03-09-2010   #11 (permalink)
fourthmeal's Avatar
Ammonia passes for the same thing!
On a more serious note and to help you for real, ... either switch to a different brand of resin first, OR go Epoxy resin and see if things get better.
Old 03-09-2010   #12 (permalink)
fourthmeal's Avatar
...or burn a tire while you do it.
Old 03-09-2010   #13 (permalink)
chad's Avatar
big daddy
/thread due to extreme win.
Old 03-09-2010   #14 (permalink)
fourthmeal's Avatar
YAY! I hardly ever score the winning point.
OP...what brand of resin are you using?
Old 03-09-2010   #15 (permalink)
scooter99's Avatar
You could try a fan too! When you glass, is your garage open when you do it? If it is, you can either shut your garage that way fumes don't go sit in there, or you can put the fan in it facing the driveway that way the fumes get vented out. Then give them the finger and say you're doing everything you can, deal with it!
Pioneer - AVHP4200DVD, GEXP20HD, AVDW7900 / Audison Bit One / LRx 4.1K - Hertz HT 25 tweets + HL 70 mid range / LRx 2.9 - Hertz Millie 165 midbass / LRx x2 1.1K - Hertz x2 HX300D subs / LRx 2.4 - Hertz HSK 165 Rear fill / Audison Connection / Kinetik HC1800 + x2 HC1400
scooter99 is offline   Reply With Quote
Old 03-09-2010   #16 (permalink)
94VG30DE's Avatar
Would this help?
How to make a ghetto paint/sanding booth
94VG30DE is offline   Reply With Quote
Old 03-09-2010   #17 (permalink)
scooter99's Avatar
that's a great idea but the issue is the smell in the area not to him but his neighbors. Wouldn't that just blow the smell into the air?
Old 03-09-2010   #18 (permalink)
chad's Avatar
big daddy
it's going to smell, it's going to smell all over, that's all there is to it... it smelled in my GD BASEMENT when I did mine and it made it there faster than I can run there.
Old 03-09-2010   #19 (permalink)
I'm using Evercoat's automotive resin
Old 03-09-2010   #20 (permalink)
fourthmeal's Avatar
Oh, that's pretty good stuff. Well you got your options, choose whatever works. Another thing to do is to befriend a local audio guy who has a HOUSE.
Old 03-09-2010   #21 (permalink)
sands1's Avatar
Just a shot in the dark here but if you already have a basic mold and its out of the car but you still want to do more to it, find a large thick plastic garbage bag big enough to drop your mold with room to spare. A big lid or large ring with a hole cut in it , a fist full of bounce dryer sheets and some tape .As soon as your ready to let it cure get it in the bag , use the dryer sheets to mock up a vent on the ring/lid and tape it to the top of the bag. You might need something to keep the bag from touching the mold as much as possible.
This really isn't a fix more of a reducer in the smell problem over a longer time period . While it cures it heats up and the smell spreads . Maybe the dryer sheets will let thru enough air to have flow and perhaps taint/reduce the resin smell ? By restricting the air flow it may take much longer to fully cure though.
Just an idea, not saying this would work, might be worth a shot though
sands1 is offline   Reply With Quote
Old 03-09-2010   #22 (permalink)
chad's Avatar
big daddy
sounds like a fancy no-smell gravity bong to me.
Old 03-09-2010   #23 (permalink)
sands1's Avatar
That exactly what it is! It's it great how different endeavors with similar problems have similar solutions.
Old 03-09-2010   #24 (permalink)
I was afraid those were the only options I have. I was hoping there would be some sort of awesome "oh I never thought of that" type solution.
Old 03-09-2010   #25 (permalink)
94VG30DE's Avatar
Unfortunately it doesn't sound like it. This is the problem with living in close proximity to other folks that usually don't share your tolerance for the smells of the hobby. Same thing I had to deal with when I lived in an apartment complex. Turns out people don't like hearing a circular saw going through a full sheet of MDF on the common lawn. Oh well, never got kicked out. Just try to be courteous, and get the glassing done ASAP, and assure them that the fumes will not permanently damage anything
  DIYMA.com » Installation Planning, Prep and Discussion » DIYMA Fabrication
Second Skin Spectrum
