NOTE: 25 photo 3 PAGE SUMMARY OF 5 YEARS OF WORK, PLAY AND TINKERING!
It's finally what I'll call done! Years of work (all by my rookie hands!) - thousands of dollars invested & hundreds of products tested in the process. Although the end result isn't as perfect as the many great installations here, I'm quite proud of the result.
I'm posting this now because unemployment has me close to selling things off, so this is my way of documenting the work and preserving the memories... and hopefully inspiring some of the people who've inspired me along the way! The pics over the next 3 pages show the end results, skipping all the things I've tried along the way - including:
Here is how its ended up...
THE SUBJECT: CIVIC COUPE EX - 2006
DAMPING/DEADENING
CONSTRUCTION
(END PAGE ONE - CONTINUED)
Head Unitless Digital Audio and even HD video using up to 500gb HDD portable media players although I also tried several top h/u systems: W200/h701, DRZ9255, P880, Audison Bit One and more
40ish drivers: Woofers - Morel 9, Focal Utopia, Rainbow Plat & more - Mids - Scan 12ms - Tweeters - Hiquphon OW1f, Scan Air Circ, Illuminators, old F-1 - Subs: ID Max and JBL GTI 12"
Many custom speaker mounts: Custom fiberglass pods, Wooden baffles to house 9" door drivers, Apillar mounts, MDF/Glass/Sand fiberglass composite sub enclosures
Various battery/wiring options: Big 3, Relay boards, Dual battery and more
DAMPING/DEADENING
CABIN FLOOR/FIREWALL: Main cabin has 2-3 layers of Raammat BXT - covered by: 1 layer of ensolite and 1 layer of 3/8" RV soundproofing (not pictured). I did most of this before some of the new superior damping methods became available - but the overall level or road noise has decreased an AMAZING amount regardless!
DOORS: The door was sealed with a plexiglass panel and silicone - 1-2 layers Dynamat (Supreme?), 2-3 layers of ensolite (note: I'll replace this with a current shot - this one is not final)
TRUNK: I was fortunate enough to win a trunk pack of Second Skin's Damplifier Pro through DIYMA - and its the real McCoy.
CONSTRUCTION
SPEAKER MOUNTS: MIDBASS - The civic baffle has the driver buried 3" behind a barely perforated thick plastic baffle & couldn't accommodate the 9"ish Morel MW 265 I wanted to use... so I changed it up a bit! Cut from 6 - 3/4 layers of MDF, and angled slightly back and up, these heavy buggers are bolted in 6 spots and sealed to the door using raammat material. Large gaps were filled with spray foam and each piece was coated with fiberglass resin for durability. Topped with upholstrey fabric, the outer baffle is a single 3/4" sheet seperately bolted with 6 t-nuts to allow for easy removal and driver change/replacement. (A big project to perfect)
SPEAKER MOUNTS: MID/TWEETER PODS - These were designed to allow the drivers to fit as close to the outer edges of the cabin as possible. The pod mounts are easily adjustable and the drivers are easily replaceable if needed. One try of Scan 12ms and I was sold... although I settled on the Illum tweeters for size, the Hiquphons were wonderful too. I tried these on the pillars for a bit, but they simply sound better and build a better stage from down below. They're also more stealthy than the pictures imply.
