Old 01-11-2011   #51
Rep Power: 0 aturcotte127317 will become famous soon enoughaturcotte127317 will become famous soon enoughaturcotte127317 will become famous soon enoughaturcotte127317 will become famous soon enoughaturcotte127317 will become famous soon enoughaturcotte127317 will become famous soon enough
Default Re: Post your Subwoofer Pics
15" RF T2
aturcotte127317 is offline   Reply With Quote
Old 01-11-2011   #52
TxHouse's Avatar
Rep Power: 33 TxHouse will become famous soon enoughTxHouse will become famous soon enoughTxHouse will become famous soon enoughTxHouse will become famous soon enoughTxHouse will become famous soon enoughTxHouse will become famous soon enough
Dang, thats a lot of different setups. In your opinion which one of those setups sounded the best?
2010 Ram Crew Cab Laramie
Front Stage: Focal 165krx2, Mosconi AS100.2, Audiocontrol LC8i
Sub Stage: 2 x 12w6v2, JL 1000/1v2
TxHouse is offline   Reply With Quote
Old 01-11-2011   #53
Sounded the best? Honestly probably when I had the Fi BTL in my audi, or my RD HW in the eclipse when it was tuned to 33Hz
I think my loudest was my DD 9915 when i had it on an American Bass 500.1 only at 2 ohms and hit a 147.x
Old 01-11-2011   #54
Actually the T2 sounded pretty dman good when i did sub back port back on the MTX 1500D Modded to run at 1 ohm... The T2 actually took the 1800+rms pretty well!!!
Old 01-11-2011   #55
mattyjman's Avatar
Rep Power: 71 mattyjman will become famous soon enoughmattyjman will become famous soon enoughmattyjman will become famous soon enoughmattyjman will become famous soon enoughmattyjman will become famous soon enoughmattyjman will become famous soon enoughmattyjman will become famous soon enough
do spl guys care about quality install at all?
mattyjman is offline   Reply With Quote
Old 01-11-2011   #56
sqoverspl's Avatar
Rep Power: 52 sqoverspl will become famous soon enoughsqoverspl will become famous soon enoughsqoverspl will become famous soon enoughsqoverspl will become famous soon enoughsqoverspl will become famous soon enoughsqoverspl will become famous soon enough
nope they tend to switch more often
Rebuilding my rebuild
sqoverspl is offline   Reply With Quote
Old 01-11-2011   #57
jhmeg2's Avatar
Action Auto Sound and Security (Virginia), Audio America (California)
former installer
Rep Power: 48 jhmeg2 will become famous soon enoughjhmeg2 will become famous soon enoughjhmeg2 will become famous soon enoughjhmeg2 will become famous soon enoughjhmeg2 will become famous soon enoughjhmeg2 will become famous soon enough
There are some nice subs in here...
at first look I acctualy liked the RF cutout and window.
aturcotte127317. where in WIS are you at?
////Alpine, Eclipse, Load Boss, Pheonix Gold, MB Quart, Digital Desings, Memphis, Stinger, Periphial, MTX, Visualogic....... AND stuff Team Action, Team Gates, Team Deadly Hertz
jhmeg2 is offline   Reply With Quote
Old 01-11-2011   #58
chapdawg1971's Avatar
Rep Power: 42 chapdawg1971 will become famous soon enoughchapdawg1971 will become famous soon enoughchapdawg1971 will become famous soon enoughchapdawg1971 will become famous soon enoughchapdawg1971 will become famous soon enoughchapdawg1971 will become famous soon enough
My install is quality, just not sunk under beauty panels and trimmed out in suede. All of my cables are neatly routed and I even spaced my zip ties pretty evenly. The only thing that looks crappy in mine, is the trim at the opening, which is about to be covered/sealed.
chapdawg1971 is offline   Reply With Quote
Old 01-11-2011   #59
jhmeg2's Avatar
former installer
ouch... I think not as much as SQ guys do, because they tend to change out equipment so often, it dosnt pay to do a full clean finished install, if your going to teaar it out in three days or less.
At first look, I liked the RF cut out and window.
Also, with the Critical Mass 5000, what is the port design on that, I like how port and sub fire in, the back is really clean. Is it a slot port, or a "square" port? clean none-the less.
aturcotte127317, Where is WIS are you at?
sorry, kind of a dbl post.
Old 01-11-2011   #60
Eh to a point, I will clean up an install once I am satisfied with it, but that is rare
I am in Sheboygan WI, yourself? I would like to meet some more close by WI people because i swap out and sell and buy equipment ALOT
Old 01-11-2011   #61
jhmeg2's Avatar
former installer
I'm a bit north of Portage. Def. wanna meet up. I've got quite a bit of equipment to move as well.
Old 01-11-2011   #62
Rep Power: 71 matthewo will become famous soon enoughmatthewo will become famous soon enoughmatthewo will become famous soon enoughmatthewo will become famous soon enoughmatthewo will become famous soon enoughmatthewo will become famous soon enough
Originally Posted by aturcotte127317 View Post
18" Eclipse Ti PRO
at first i thought you stole my pictures LOL
WTB mine was a quad coil 1.4 15, and wow did that sub take a beating. the 8 layer flat wound coil was amazing. i daily drove that thing in 6 cubes ported at 35hz with 2 kicker 2500.1s running at .7 ohm daily each. you know the kickers put out 2800 rms at 2 ohm, they will do well over 3000 each at 1ohm and under.
matthewo is offline   Reply With Quote
Old 01-11-2011   #63
its a slot port, it turns and goes directly toward the left and cuts another L toward the back off the box. its tuned to around 33hz, with about 25-30sq inches of port area i think
Old 01-11-2011   #64
jhmeg2's Avatar
former installer
bravo, I like it. I can assume that the corners are 45ed, and with that its smooth.
Old 01-12-2011   #65
Rep Power: 0 gumbysmoke will become famous soon enoughgumbysmoke will become famous soon enoughgumbysmoke will become famous soon enoughgumbysmoke will become famous soon enoughgumbysmoke will become famous soon enoughgumbysmoke will become famous soon enough
Nice pics everyone. I'll post mine when I get 30 posts.
gumbysmoke is offline   Reply With Quote
Old 01-12-2011   #66
Why is that?
Old 01-18-2011   #67
Rep Power: 46 ChaunB3400 will become famous soon enoughChaunB3400 will become famous soon enoughChaunB3400 will become famous soon enoughChaunB3400 will become famous soon enoughChaunB3400 will become famous soon enoughChaunB3400 will become famous soon enough
Originally Posted by skittlesRgood View Post
I remember the build on that box, it looks amazing
ChaunB3400 is offline   Reply With Quote
Old 01-18-2011   #68
PSI Omega
Old 01-18-2011   #69
AP Axis
Old 01-18-2011   #70
Bad Packing
Old 01-18-2011   #71
gfs ride
Old 01-18-2011   #72
sonic fx beast of a sub i miss it
Old 01-18-2011   #73
DD3515 I forget which motor
Old 01-18-2011   #74
RD Alpha V1, I won during there promotional give away
Old 01-18-2011   #75
FI BL
