Old 06-05-2007   #1
Send a message via Yahoo to cam2Xrunner
Default Pioneer RCA preout noise prevention
For those who have ever had noise issues with their 880PRS or other deck, this post might help.
as far as the noise issue with the RCA's... i've seen it a million times. the very last thing you want to hook up with these units, is the RCA's at the head unit. too many times i have seen people hook up the RCA's at the head unit first, and then ground the center pin of the RCA's accidently. even with the unit unplugged, the capacitors hold a small charge, and that small charge can take out the final RCA output transistors, and also the caps themselfs.
the result is, noise. sometimes serious noise, that the unknowlegeable "fix" by grounding the RCA sheilds... but some noise still remains until the transistors and caps are replaced.
bottom line, to avoid this, make all connections of the system, and the very last thing to do, is plug the RCA cables into the head unit. since the 860/880 has a detachable RCA harness, best to leave the harness unplugged until last.
He's an EE and does repairs, and new product R&D for Pioneer, Alpine, JL, etc.
cam2Xrunner is offline
Old 06-06-2007   #2
chad's Avatar
big daddy
Default Re: Pioneer RCA preout noise prevention
Well, I was under the impression that it popped a Pico fuse. Regardless to touching the pin to ground it's still a shitty implementation. I've made MILLIONS of connections, even ones that naturally touch ground (shield on a 1/4") and have NEVER popped an output stage, or input stage for that matter on an ocsasional pahntom powered hot patch.
Poo Poo to pioneer for that output design, it's poor and that's undisputed.
Good call on the caps though I wrote this in a PM to a member which may give a bit of insight as to why this happens.
Generally the problems arise after reading this.... "All I did was hook it up and un-hook it" there is no concrete answer of any amplifier grounding scheme that causes the failure but more of an issue of connection/disconnection. I would suspect even sometimes hot-swapping...... Bla Bla Snip
A schematic would certainly give me a "yep this is how it wants to run" and I find it pretty awful that pioneer is keeping so hush about this and not telling us WHY this is happening. So for now I recommend complete power disconnection during patching and certainly no "hot swapping" with everything powered up.
The output is more than likely cap coupled, I was experiencing issues while trying to run balanced input with this because the caps would develop a charge then discharge during on/off or mutings. This discharge of the caps during connection is what could be causing the pico fuse to blow, a cap, no matter how big, will try to deliver an infinite amount of current during a shorted discharge and will draw an infinite amount of current while charging with no current limiting. I'm thinking this paired with an under sized protection scheme (most heads just use like a 0 or 1 ohm FP 1/4W resistor) is causing the issues, which, are blown pico fuses. A simple fix for a service center wanting to make a quick buck unfortunately.
So does anyone with a manual want to elaborate on a hook-up scheme from pioneer? Is it power last or RCA last?
Can you imagine going to your boss and saying "hey, I can improve distortion figures from .004% to .0004% by adding twice as many parts." They'll tell you to go shit in your hat.
chad is offline
Old 06-06-2007   #3
For safety, to prevent noise on pioneer HUs, power is the last to connect, no hot swapping(change to get noise is very high)
kyheng is offline
Old 06-06-2007   #4
Lightninghoof's Avatar
Thumbs down Re: Pioneer RCA preout noise prevention
This is somewhat unrelated, but I've had too many Pioneer/Premier HU's fail over the past 15 years to give them any more of my money. From faceplate backlights failing, to whine/ground issues that pop up out of nowhere, to CD read errors, etc. Just feels like disposable car audio to me.
It's funny, I have home audio equipment that has lasted 20+ years and still going strong, but car audio equipment won't last for more than 2 or 3 years without malfunctioning, and I baby this stuff. Your average teenager probably gets 6 months to a year of use out of it, if he is lucky.
Lightninghoof is offline
Old 06-06-2007   #5
MidnightCE's Avatar
KaleCoAuto
Doggy
your house doesn't constantly vibrate and jar, or subject the stuff inside to 130+ degree temperatures. Or require as much stuff to be packed into one little space.
04 Vette. Alpine, ARC, Dyn stuffs.
MidnightCE is offline
Old 06-06-2007   #6
Boostedrex's Avatar
DIYMA Sneetch
Not to mention that the power supply for your home gear is constant and doesn't fluctuate.
Boostedrex is offline
Old 06-06-2007   #7
chad's Avatar
big daddy
I have my own 25KVA pole pig and it's still all over the place. I couldn't imagine sharing with others like I used to, it was REALLY all over the place then.. The only thing you can count on with home AC is that it will always be spot on 60 cycles.
chad is offline
Old 06-06-2007   #8
Unhappy Re: Pioneer RCA preout noise prevention
It still blows balls to purchase a $600 HU, baby it, and only have it last for 16 months.
Old 06-06-2007   #9
Here's another reply he typed afterwards.
completely forgot to address the ground problem issue... what people refer to the microfuse.
i've also seen this happen. a lot of times, when people dont have a good ground to their amps, or in some cases, forget to connect a ground altogether, the amp trys to get ground through the RCA cables. after all, with no main ground, the only path to ground is the RCA cable shields through the head unit.
this will take out the microfuse, which results in a lot of noise.
is it a bad design ? well... yes, and no. i've had Alpines, Eclipses, Clarions, Kenwoods, etc, etc, that have had this done to them, and the damage suffered is always worse than on the Pioneers.
on the other hand, they do seem a little overly sensitive. safe thing is to always make positive that your amps are properly grounded before turning the system on.
Old 06-10-2007   #10
solacedagony's Avatar
Send a message via ICQ to solacedagony Send a message via AIM to solacedagony Send a message via MSN to solacedagony
As per a yellow paper saying "Warning" on it:
"Always remove a connector from the (-) battery terminal before beginning any connection or installing work.
When installing this unit, always connect he ground wire first. Ensure that the ground wire is properly connected to metal parts of the car's body. (Fig.3)
When connecting the power amp (sold separately) to this unit ensure that the ground wire for the power amp is properly connected to metal parts of the car's body. Connect the ground wire of the power amp with a different screw from the one you used to connect the ground wire for this unit or any other device. Should the screw for the power amp's ground wire loosen or fall out, it may result in this unit emitting [magic] smoke or malfunctioning. (Fig.3)"
So they're saying to not use a common ground and to hook up the ground wire FIRST. What about if your ground wire is on a harness? Constant, memory and ground will all be connected simultaneously.
2003 Ford Ranger Std. Cab
Pioneer P880PRS | Seas Neo/Exclusive 7" | DIYMA12
solacedagony is offline
Old 06-10-2007   #11
Send a message via AIM to Nathan P Send a message via MSN to Nathan P Send a message via Yahoo to Nathan P
I'd say make sure the batt is disconnected and you'll be fine. I didn't do this, but I guess I got lucky. I always disconnect the batt when I do stuff, guess I forgot this time good thing it turned out okay, that'd be an $$ mistake.
Nathan P is offline
Old 06-11-2007   #12
So is there any write-up or anything of that nature that shows how to fix this problem? I only ask because unfortunetly I am one of the many that has been effected by this problem and to top it all off I am just past warranty. I would much rather try and fix this problem then to try and fork over another 350 for a hu.
dalinkwent is offline
Old 06-11-2007   #13
chad's Avatar
big daddy
That, and if it's TRULY an issue of charged caps... and the caps are doing their job.... with no bleeder resistors.... we are still shot.
chad is offline
Old 06-11-2007   #14
60ndown's Avatar
i paid $145 locally to have my noise fixed
if your good with a soldering gun and electronics i guess you might be able to do it yourself for $4?
im not that good with it tho.
Reducing a signal (electrical or otherwise) into its component parts is not the outcome of scientific inquiry or discoveries. It's merely the application of mathematical (ie. logical) transforms applied to a measurable quantity (all good amps sound the same)
60ndown is offline
Old 06-11-2007   #15
So you're pretty much trying your luck every time you hook this thing up?
Old 06-11-2007   #16
chad's Avatar
big daddy
If I say yes would I be a hater?
Without seeing the guts or a schematic I can not give a definate answer so I will remain quiet
Chad
chad is offline
Old 06-11-2007   #17
Chad
If it's easily tear-apart-able I'll get some gut pics for you. If not, we'll be in the dark forever
So the problem is with these capacitors in the pre-outs? Should you discharge them every time you unhook the unit or what?
Old 06-11-2007   #18
60ndown's Avatar
880,
http://i11.tinypic.com/2gwukom.jpg
60ndown is offline
Old 06-11-2007   #19
chad's Avatar
big daddy
God only knows..... I believe the majority of the issues WE ae having are with blown pico fuses protecting the shield I imagine. I'm wondering if they are not coming up in charge with nothing attached then when attached or coming in contact with ground blowing the pico fuse.
Is the shield on a working 880 ground? or floating?
Chad
chad is offline
Old 06-11-2007   #20
60ndown's Avatar
http://www.elitecaraudio.com/forums/...hreadid=137088
60ndown is offline
Old 06-11-2007   #21
Chad
How can I tell? Is there a way I can measure continuity to find out?
Old 06-11-2007   #22
effenay's Avatar
Great thread Cam! Thanks for the info.
Who is the source of the original quote in the first post?
Link available?
DRZ > PRS > PRS
CD7000 > crap factory speakers
effenay is offline
Old 06-11-2007   #23
if anyone has any DIY repair info for these HUs it would be nice. my 860 has bad noise now, and the wire around the rca ground doesnt help any more.
Mat Dope is offline
Old 06-11-2007   #24
chad's Avatar
big daddy
If the shield of the RCA connector measures close to 0 ohms in respect to chassis ground/harness ground. If it measures low then starts climbing to infinity then it's cap coupled. If it measures say 200 ohm then it's isolated by a 200 ohm resistor.
These could be the Pico Fuses: (red circle near the top, tough to see around that cable)
Now... Does that big blue cap DC isolate the ground?
Chad
chad is offline
Old 06-11-2007   #25
Will I have to have it plugged in to check that? Or can I do it without it being plugged in?
And none of that probing will result in a blown pico fuse, right?
LinkBacks (?)
LinkBack to this Thread: http://www.diymobileaudio.com/forum/diyma-sq-forum-technical-advanced/13889-pioneer-rca-preout-noise-prevention.html
Posted By For Type Date
Basic EBP SH - Page 2 - Preludepower.com This thread Refback 3 Weeks Ago 09:42 PM
Garage507.com • View topic - PROBLEMA CON EL RADIO (AYUDA) This thread Refback 3 Weeks Ago 12:14 AM
AVIC411.com • View topic - the infamous Pioneer microfuse problem Post #0 Refback 07-27-2010 12:46 PM
Issues and possible replacement of my Pioneer 880PRS - CarAudioForum.com This thread Refback 07-24-2010 11:33 PM
Issues and possible replacement of my Pioneer 880PRS - CarAudioForum.com This thread Refback 07-20-2010 10:45 PM
Issues and possible replacement of my Pioneer 880PRS - CarAudioForum.com This thread Refback 07-20-2010 10:14 PM
Inštalácia Accent, rusenie | Autohifi | forum | Auto HI-FI club CZ - stránky o ozvuèení automobilù. Autorádia, autozesilovaèe, reproduktory do auta, rady a návody, diskuse, soutìže This thread Refback 07-14-2010 10:23 AM
SQ style ICE - Page 20 This thread Refback 07-11-2010 09:33 AM
trinituner.com • View topic - Pioneer RCA preout noise prevention This thread Refback 06-27-2010 04:42 PM
AUDIO HELP!!! Subs are pulsing with no sound - Scionlife.com This thread Refback 06-18-2010 12:10 AM
MySpace This thread Refback 06-09-2010 04:59 AM
AVIC411.com • View topic - altinator wine This thread Refback 05-31-2010 03:15 PM
AVIC411.com • View topic - Rookie Mistake - HELP! This thread Refback 05-31-2010 12:55 PM
AVIC411.com • View topic - Rookie Mistake - HELP! This thread Refback 05-26-2010 06:15 AM
AVIC411.com • View topic - the infamous Pioneer microfuse problem Post #0 Refback 05-13-2010 05:49 PM
AVIC411.com • View topic - the infamous Pioneer microfuse problem Post #0 Refback 05-09-2010 04:53 AM
AVIC411.com • View topic - the infamous Pioneer microfuse problem Post #0 Refback 05-08-2010 11:06 PM
Pioneer Headunit Out Again - CarAudioForum.com This thread Refback 05-06-2010 06:00 PM
AVIC411.com • View topic - Rookie Mistake - HELP! This thread Refback 05-05-2010 06:02 AM
AVIC411.com • View topic - Rookie Mistake - HELP! This thread Refback 05-03-2010 12:29 AM
ÊÚáã æÇÕÈÍ ãÍÊÑÝ Ýí ÊÑßíÈ ÓíÓÊã áÓíÇÑÊß - ÇáÕÝÍÉ 11 - :: äÜÜÇíÜÜá ãÜÜæÊÜÜæÑÒ:: - :: NileMotors.net :: This thread Refback 04-26-2010 07:58 AM
AVIC411.com • View topic - Rookie Mistake - HELP! This thread Refback 04-19-2010 09:17 AM
How to Repair Pioneer Pico-Fuse???? This thread Refback 04-14-2010 03:00 PM
Pioneer Premier DEH-P880PRS... This thread Refback 04-10-2010 02:04 AM
Amp/components HELP!!! - CarAudioForum.com This thread Refback 04-07-2010 12:02 PM
Amp/components HELP!!! - CarAudioForum.com This thread Refback 04-07-2010 11:54 AM
Sound System Problems - Scionlife.com This thread Refback 04-05-2010 12:42 AM
How to Repair Pioneer Pico-Fuse???? This thread Refback 04-04-2010 12:33 AM
Popping sound from speakers after big 3 - Ford Explorer Ranger Enthusiasts "Serious Explorations"® This thread Refback 04-01-2010 08:52 PM
Pioneer Head Unit Noise - This thread Refback 03-31-2010 06:55 PM
Pioneer Headunit Out Again - CarAudioForum.com This thread Refback 03-24-2010 04:42 PM
Amp Got shhhhh sound This thread Refback 03-03-2010 10:21 AM
AVIC411.com • View topic - Rookie Mistake - HELP! This thread Refback 03-01-2010 12:56 AM
How to Repair Pioneer Pico-Fuse???? This thread Refback 02-27-2010 03:00 PM
Car Audio Help Needed - All Sex Resources Forums This thread Refback 02-23-2010 08:06 PM
Car Audio Help Needed - All Sex Resources Forums This thread Refback 02-22-2010 02:45 PM
Amp Got shhhhh sound This thread Refback 02-18-2010 09:37 AM
Amp Got shhhhh sound This thread Refback 02-16-2010 10:20 PM
AVIC411.com • View topic - Rookie Mistake - HELP! This thread Refback 02-15-2010 01:46 PM
AVIC411.com • View topic - Rookie Mistake - HELP! This thread Refback 02-11-2010 08:35 AM
880prs pico fuse location? This thread Refback 02-11-2010 06:22 AM
amp install help - loud static - Ranger Power Sports Forum This thread Refback 02-10-2010 09:43 PM
amp install help - loud static - Ranger Power Sports Forum This thread Refback 02-10-2010 08:16 PM
Amp Got shhhhh sound This thread Refback 02-07-2010 11:52 AM
Amp Got shhhhh sound This thread Refback 02-07-2010 05:56 AM
Amp Got shhhhh sound This thread Refback 02-07-2010 04:22 AM
>>>Engine whine and ground loop fixes... take two This thread Refback 01-27-2010 07:48 PM
Inštalácia Accent, rusenie | Autohifi | forum | Auto HI-FI club CZ - stránky o ozvuèení automobilù. Autorádia, autozesilovaèe, reproduktory do auta, rady a návody, diskuse, soutìže This thread Refback 01-26-2010 03:04 PM
Pioneer Premier DEH-p390mp winding noise, I need it gone! This thread Refback 01-26-2010 11:16 AM
How to Repair Pioneer Pico-Fuse???? This thread Refback 01-25-2010 02:34 PM
AVIC411.com • View topic - Rookie Mistake - HELP! This thread Refback 01-22-2010 07:48 AM
Pioneer Premier DEH-p390mp winding noise, I need it gone! This thread Refback 01-18-2010 01:09 PM
>>>Engine whine and ground loop fixes... take two This thread Refback 01-16-2010 06:33 PM
How to Repair Pioneer Pico-Fuse???? This thread Refback 01-15-2010 08:08 PM
How to Repair Pioneer Pico-Fuse???? - Car Audio Forum - CarAudio.com This thread Refback 01-10-2010 10:30 PM
AVIC411.com • View topic - altinator wine This thread Refback 12-31-2009 11:01 AM
AVIC411.com • View topic - Rookie Mistake - HELP! This thread Refback 12-24-2009 12:25 PM
MySpace This thread Refback 12-17-2009 02:03 PM
? Leggi argomento - problema con p88 This thread Refback 12-14-2009 06:42 PM
Pioneer Premier DEH-p390mp winding noise, I need it gone! - Page 2 - Car Audio Forum - CarAudio.com This thread Refback 12-11-2009 03:14 PM
AVIC411.com • View topic - Rookie Mistake - HELP! This thread Refback 12-05-2009 01:31 PM
? Leggi argomento - problema con p88 This thread Refback 11-19-2009 08:19 AM
trinituner.com :: View topic - Help! noise in meh music. This thread Refback 11-16-2009 12:31 PM
? Leggi argomento - problema con p88 This thread Refback 11-12-2009 01:35 PM
? Leggi argomento - problema con p88 This thread Refback 11-10-2009 10:47 AM
? Leggi argomento - problema con p88 This thread Refback 11-10-2009 06:49 AM
? Leggi argomento - problema con p88 This thread Refback 11-10-2009 06:43 AM
Pioneer DEH-P860MP RCA grounding problem - Page 2 - diyAudio This thread Refback 11-09-2009 06:15 AM
Pioneer Premier DEH-p390mp winding noise, I need it gone! - Page 2 - Car Audio Forum - CarAudio.com This thread Refback 11-06-2009 03:27 PM
Inštalácia Accent, rusenie | Autohifi | forum | Auto HI-FI club CZ - nejhlasitìjší klub na webu nejen o autohifi ... This thread Refback 11-04-2009 12:35 PM
trinituner.com :: View topic - Help! noise in meh music. This thread Refback 11-03-2009 09:12 AM
trinituner.com :: View topic - Help! noise in meh music. This thread Refback 11-03-2009 04:05 AM
trinituner.com :: View topic - Help! noise in meh music. This thread Refback 11-02-2009 08:23 PM
Inštalácia Accent, rusenie | Autohifi | forum | Auto HI-FI club CZ - nejhlasitìjší klub na webu nejen o autohifi ... This thread Refback 11-01-2009 03:05 PM
Recommended Head Units - Page 2 - Ford Explorer Ranger Enthusiasts "Serious Explorations"® This thread Refback 10-19-2009 06:40 PM
Inštalácia Accent, rusenie | Autohifi | forum | Auto HI-FI club CZ - nejhlasitìjší klub na webu nejen o autohifi ... This thread Refback 10-14-2009 09:48 AM
AVIC411.com • View topic - Rookie Mistake - HELP! This thread Refback 10-13-2009 10:38 AM
Inštalácia Accent, rusenie | Autohifi | forum | Auto HI-FI club CZ - nejhlasitìjší klub na webu nejen o autohifi ... This thread Refback 10-10-2009 10:06 AM
AVIC411.com • View topic - the infamous Pioneer microfuse problem Post #0 Refback 10-08-2009 05:23 PM
Pioneer DEH-P6000UB - Background Hiss - This thread Refback 09-22-2009 10:36 PM
Inštalácia Accent, rusenie | Autohifi | forum | Auto HI-FI club CZ - nejhlasitìjší klub na webu nejen o autohifi ... This thread Refback 09-21-2009 03:16 PM
Inštalácia Accent, rusenie | Autohifi | forum | Auto HI-FI club CZ - nejhlasitìjší klub na webu nejen o autohifi ... This thread Refback 09-15-2009 01:29 PM
Car Audio Forum - CarAudio.com - >>>Engine whine and ground loop fixes... take two This thread Refback 09-12-2009 05:59 AM
Inštalácia Accent, rusenie | Autohifi | forum | Auto HI-FI club CZ - nejhlasitìjší klub na webu nejen o autohifi ... This thread Refback 09-12-2009 05:12 AM
Inštalácia Accent, rusenie | Autohifi | forum | Auto HI-FI club CZ - nejhlasitìjší klub na webu nejen o autohifi ... This thread Refback 09-11-2009 01:11 PM
Inštalácia Accent, rusenie | Autohifi | forum | Auto HI-FI club CZ - nejhlasitìjší klub na webu nejen o autohifi ... This thread Refback 09-11-2009 04:47 AM
Inštalácia Accent, rusenie | Autohifi | forum | Auto HI-FI club CZ - nejhlasitìjší klub na webu nejen o autohifi ... This thread Refback 09-11-2009 02:39 AM
AVIC411.com • View topic - Rookie Mistake - HELP! This thread Refback 09-11-2009 02:31 AM
Inštalácia Accent, rusenie | Autohifi | forum | Auto HI-FI club CZ - nejhlasitìjší klub na webu nejen o autohifi ... This thread Refback 09-11-2009 02:21 AM
Pioneer DEH-P860MP RCA grounding problem - Page 2 - diyAudio This thread Refback 08-28-2009 01:04 AM
AVIC411.com • View topic - Rookie Mistake - HELP! This thread Refback 08-22-2009 06:56 PM
How should I go about setting up my my amp? (Not just a gain question) - CarAudioForum.com This thread Refback 08-12-2009 08:28 AM
Acceleration sound through speakers??? - CarAudioForum.com This thread Refback 08-09-2009 01:53 PM
Did I screw up my HU? - CarAudioForum.com This thread Refback 08-08-2009 05:23 PM
How should I go about setting up my my amp? (Not just a gain question) - CarAudioForum.com This thread Refback 08-06-2009 11:01 AM
Rookie Mistake, NEED HELP! - CarAudioForum.com This thread Refback 08-02-2009 07:44 PM
AVIC411.com • View topic - Rookie Mistake - HELP! This thread Refback 07-31-2009 05:40 PM
Problème sur 2 pioneer (9600MP et 77MP) - Discussions pratique & montage - FORUM CarAudioVideo This thread Refback 07-25-2009 05:51 PM
ICIXSound.COM Forums - Pioneer RCA FIX **Tutorial** This thread Refback 07-21-2009 03:11 AM
AVIC411.com • View topic - altinator wine This thread Refback 07-16-2009 01:59 PM
AVIC411.com • View topic - Rookie Mistake - HELP! This thread Refback 07-16-2009 05:20 AM
AVIC411.com • View topic - Rookie Mistake - HELP! This thread Refback 07-13-2009 11:22 PM
Voltage to high? - CarAudioForum.com This thread Refback 07-12-2009 11:24 AM
AVIC411.com • View topic - altinator wine This thread Refback 07-02-2009 05:33 AM
Acceleration sound through speakers??? - CarAudioForum.com This thread Refback 07-01-2009 08:01 PM
Acceleration sound through speakers??? - CarAudioForum.com This thread Refback 06-30-2009 05:54 PM
ICIXSound.COM Forums - Yet another alternator whine thread. This thread Refback 06-26-2009 03:51 PM
Alternator Whine - CarAudioForum.com This thread Refback 06-24-2009 11:00 PM
Alternator Whine - CarAudioForum.com This thread Refback 06-24-2009 08:28 AM
Alternator Whine - CarAudioForum.com This thread Refback 06-24-2009 01:18 AM
Buzzing Noise through Subs - CarAudioForum.com This thread Refback 06-23-2009 11:55 AM
AVIC411.com • View topic - Rookie Mistake - HELP! This thread Refback 06-19-2009 06:35 AM
Did I screw up my HU? - CarAudioForum.com This thread Refback 06-16-2009 04:02 PM
Pioneer DEH-P6000UB - Background Hiss - This thread Refback 06-14-2009 05:04 PM
Pioneer Head Unit Noise - This thread Refback 06-13-2009 05:06 AM
AVIC411.com • View topic - the infamous Pioneer microfuse problem Post #0 Refback 06-11-2009 09:15 PM
AVIC411.com • View topic - Rookie Mistake - HELP! This thread Refback 06-11-2009 08:51 PM
AVIC411.com • View topic - Rookie Mistake - HELP! This thread Refback 06-09-2009 02:02 PM
Pioneer Head Unit Noise - Crutchfield Community This thread Refback 06-07-2009 12:40 PM
AVIC411.com • View topic - Rookie Mistake - HELP! This thread Refback 06-04-2009 05:51 PM
Ground Question...?? - CarAudioForum.com This thread Refback 06-01-2009 03:14 PM
AVIC411.com • View topic - Rookie Mistake - HELP! This thread Refback 05-27-2009 12:20 AM
AVIC411.com • View topic - Rookie Mistake - HELP! This thread Refback 05-23-2009 01:38 AM
AVIC411.com • View topic - Rookie Mistake - HELP! This thread Refback 05-21-2009 09:45 PM
FMOD Crossovers not working??.... tweets are playing mid/lows!!! static with HPF - CarAudioForum.com This thread Refback 05-21-2009 05:53 PM
AVIC411.com • View topic - altinator wine This thread Refback 05-21-2009 07:29 AM
Rookie Mistake, NEED HELP! - CarAudioForum.com This thread Refback 05-20-2009 07:50 PM
Rookie Mistake, NEED HELP! - CarAudioForum.com This thread Refback 05-20-2009 04:29 PM
AVIC411.com • View topic - Rookie Mistake - HELP! This thread Refback 05-20-2009 02:04 PM
Rookie Mistake, NEED HELP! - CarAudioForum.com This thread Refback 05-20-2009 12:38 PM
A few things - CarAudioForum.com This thread Refback 05-17-2009 09:54 AM
Recommended Head Units - Page 2 - Ford Explorer Ranger Enthusiasts Serious Explorations This thread Refback 05-11-2009 10:51 AM
trinituner.com ::: View topic - Pioneer RCA preout noise prevention This thread Refback 05-10-2009 09:06 AM
AVIC411.com • View topic - the infamous Pioneer microfuse problem Post #0 Refback 05-07-2009 11:10 AM
AVIC411.com • View topic - altinator wine This thread Refback 04-30-2009 07:00 AM
Popping sound from speakers after big 3 - Ford Explorer Ranger Enthusiasts Serious Explorations This thread Refback 04-26-2009 03:33 PM
background noise - Car Audio Forum - CarAudio.com This thread Refback 04-19-2009 05:04 PM
FMOD Crossovers not working??.... tweets are playing mid/lows!!! static with HPF - CarAudioForum.com This thread Refback 04-16-2009 03:40 PM
Help speakers Buzzing!! - CarAudioForum.com This thread Refback 04-15-2009 11:36 PM
Help speakers Buzzing!! - CarAudioForum.com This thread Refback 04-11-2009 01:53 AM
Tundra Solutions Forum - View Single Post - Installed AMP, ALT noise, Pioneer Microfuse? HELP! This thread Refback 04-09-2009 11:26 PM
Help speakers Buzzing!! - CarAudioForum.com This thread Refback 04-08-2009 10:31 PM
Head unit - CarAudioForum.com This thread Refback 03-28-2009 10:18 AM
Head unit - CarAudioForum.com This thread Refback 03-28-2009 09:37 AM
Head unit - CarAudioForum.com This thread Refback 03-28-2009 04:32 AM
Popping sound from speakers after big 3 - Ford Explorer Ranger Enthusiasts Serious Explorations This thread Refback 03-22-2009 03:36 AM
Popping sound from speakers after big 3 - Ford Explorer Ranger Enthusiasts Serious Explorations This thread Refback 03-22-2009 02:34 AM
AVIC411.com • View topic - altinator wine This thread Refback 03-22-2009 12:29 AM
AVIC411.com • View topic - altinator wine This thread Refback 03-16-2009 06:19 AM
Lower Ball Joint Replacement, Oem Ball Joint For A Honda 400 Foreman, Honda Ball Joint - A2Zrotors This thread Refback 03-10-2009 06:04 AM
Horrid noise issues - CarAudioForum.com This thread Refback 03-08-2009 05:30 PM
ICIXSound.COM Forums - 880PRS Installation This thread Refback 03-07-2009 12:01 PM
Trailblazer Ball Joint Replacement, Traditional Vs Suzuki, Trailblazer Replacement Parts For The Interior - Ethosgas This thread Refback 03-07-2009 02:39 AM
High Pitch Hum - CarAudioForum.com This thread Refback 03-06-2009 08:36 PM
diyAudio Forums - Pioneer DEH-P860MP RCA grounding problem - Page 1 This thread Refback 03-04-2009 06:24 PM
ScionLife View topic - Sound System Problems This thread Refback 02-25-2009 09:16 PM
DIY Headunit Repair - Pioneer Premier 860mp. How Do I Keep Moving. Need circuit acess - CarAudioForum.com This thread Refback 02-25-2009 04:55 PM
ICIXSound.COM Forums - noise problem This thread Refback 02-24-2009 03:41 PM
Ground Question...?? - Page 2 - CarAudioForum.com This thread Refback 02-23-2009 06:12 PM
880prs pico fuse location? - Car Audio Forum - CarAudio.com Post #0 Refback 02-15-2009 11:42 AM
Pioneer Premier DEH-P880PRS... - Car Audio Forum - CarAudio.com This thread Refback 02-15-2009 11:17 AM
Ground Question...?? - CarAudioForum.com This thread Refback 02-14-2009 09:42 PM
880PRS vs 800PRS - Page 2 - CarAudioForum.com This thread Refback 02-13-2009 07:17 AM
caraudiovideo | forum - autoradio, gps, multimédia - Voir le sujet - Problème sur 2 pioneer (9600MP et 77MP) This thread Refback 02-12-2009 09:48 AM
pioneer bad pre out - MySpace Web Search This thread Refback 02-10-2009 07:06 PM
Dreaded Ignition Noise!!!! - CarAudioForum.com This thread Refback 02-07-2009 06:56 PM
EMOTIVA emotions? - Page 124 - AVS Forum This thread Refback 02-07-2009 08:20 AM
DEH-P800PRS ....I am a MeatHead - CarAudioForum.com This thread Refback 01-31-2009 10:36 PM
background noise - Car Audio Forum - CarAudio.com This thread Refback 01-26-2009 01:06 PM
AVIC411.com :: View topic - the infamous Pioneer microfuse problem Post #0 Refback 01-25-2009 12:37 AM
High Pitch Hum - CarAudioForum.com This thread Refback 01-24-2009 05:44 PM
ScionLife View topic - AUDIO HELP!!! Subs are pulsing with no sound This thread Refback 01-23-2009 12:51 AM
Horrid noise issues - CarAudioForum.com This thread Refback 01-19-2009 10:33 PM
Pioneer DEH-P6000UB - Background Hiss - Crutchfield Community This thread Refback 01-16-2009 12:30 AM
High Pitch Hum - CarAudioForum.com This thread Refback 01-14-2009 01:03 AM
Engine Noise - Page 2 - CarAudioForum.com This thread Refback 01-14-2009 12:16 AM
DIY Headunit Repair - Pioneer Premier 860mp. How Do I Keep Moving. Need circuit acess - CarAudioForum.com This thread Refback 01-14-2009 12:07 AM
Horrid noise issues - CarAudioForum.com This thread Refback 01-13-2009 11:58 PM
headunit: not enough RCA inputs - CarAudioForum.com This thread Refback 01-13-2009 11:49 PM
Speaker Buzz - CarAudioForum.com This thread Refback 01-11-2009 07:24 PM
Pioneer Vs Alpine Vs Eclipse - Page 2 - Car Audio Forum - CarAudio.com This thread Refback 01-04-2009 05:45 AM
Installed D3, now have buzzing - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum This thread Refback 12-31-2008 07:41 AM
Finally kciked the AVIC Z2 to the curb... need a new HU / Nav... advice? - CarAudioForum.com This thread Refback 12-31-2008 12:05 AM
Second Skin Spectrum
