Old 01-05-2009   #1
less's Avatar
Default Circuit layout for a 12v - 5 volt power converter/stabilizer
I'm running a digital media player as my main source in my car and i get really high quality sound from it by using the digital output optically into the back of my DRZ 9255 h/u. Naturally, I get a nice qualilty output from the unit, but I am too fussy sometimes, and I worry a bit about the impact of any possible power surges or cutouts in its power supply - especially when I am running the heater, the system on high, etc.
The short story is that I would like to build a "power supply" or really more of a power conditioner for my media players use only. I'm thinking along the lines of the type of power supply used with the Clarion, McIntosh and other head units. I'm using a 2.5" hard drive so its less sensitive, but I just want the very best sound I can get within reason - and I just can't imagine one costing much to build from scratch.
If I remember correctly, the power input on the media player is 5 volts, so it needs conversion from 12v too.
Is there anyone here who could help me by either designing such a device or sending me to a site with good information enough to teach me what to do? I'm a fair hand with electronics but I am sure no engineer! I suspect that this is a fairly simple device...
Thanks in advance to anyone who can lend a hand!
Less
CD free for 2+ years & loving it...
Digital media player (500gb audio/video) - Audison Bit 1 - McIntosh/Zapco amps - Scan/Morel/JBL - PC monitor - years of experimentation!
less is offline
Old 01-05-2009   #2
Fing forums
Seated
Default Re: Circuit layout for a 12v - 5 volt power converter/stabilizer
noise wise there can be no problem since EMF doesn't impact light transmission.
Appreciate the OCD in terms of HD lifespan though.
Attack eagle is offline
Old 01-05-2009   #3
M1A1's Avatar
What power supply are you using now that you're "worried" enough about to want to build your own voltage regulator/power supply? Like Attack eagle mentioned, its a good 'OCD' thought, but I'm not sure its warranted.
M1A1 is offline
Old 01-05-2009   #4
Seems like this an area of expertise for the carputer guys. I know there are 12v-5v DC-DC power supplies that those guys use for accessories. I don't think you'd have to build your own.
Something like this? http://www.powerstream.com/dc6.htm
2006 Civic Si Coupe w/ factory nav
capnxtreme is offline
Old 01-05-2009   #5
Harman International
Product Manager
If the digital media player includes a battery and the power supply you plug in is merely a charger, then the battery will suffice as a conditioner.
Global Product Line Manager, JBL Car Audio
Harman Consumer
Andy Wehmeyer is offline
Old 01-06-2009   #6
less's Avatar
Hey folks.
Thanks Cptn. I did get a general power converter as part of the car kit for the media player and have wanted to pick up a spare... as it happens, the sirius power converters use the same power and plug, so now I can pick one of those up easily. I really wasn't worried about emf. I was concerned with getting a stable voltage to the hard drive to avoid speed variations in the output. I was also concerned with preserving the life of the internal components by providing it with a stable source of power - even when I am hitting the volume pretty hard. It does not have a battery to serve as a conditioner and only has a cheap converter that came with the car kit.
Ok, I might have obsessive compulsive disorder when it comes to my system, but I don't think there is anything wrong with trying to build an audiophile quality media player for myself - or modifying mine to make it as good as it can be... If a company released a media player with a seperate hq power supply, someone here would probably consider it a nice addition?
BTW, if you use a 2.5 notebook hard drive, i don't think you have to worry much at all about hard drive life. Mine is almost a year old already and serves as my primary source daily - no issues at all, although I still think a nice conditioner would assist in its preservation.
Less
less is offline
Old 01-06-2009   #7
Infinity's Avatar
If you do have any worries about hard drive life, you could go Solid State on your drives and no amount of vibration/bumping will affect them. Even the slow, cheap, OCZ ones would work perfectly for audio/video.
Kenwood 7019/ Alpine SPX mids/JBL P26T tweets
Kenwood KAC X4R & X1R
2x Sundown Sd1v2
Infinity is offline
A tutorial on gain setting and amplifier power usage npdang DIYMA Tutorials 40 05-17-2010 12:18 PM
12V circuit Breaker? thazy2 DIYMA SQ forum - Technical & Advanced 10 08-08-2007 11:20 PM
Resistors for attenution circut-question lightspeed DIYMA SQ forum - Technical & Advanced 32 03-30-2006 11:09 AM
home theater subwoofer setup? power circuit board ? newtitan Off Topic 8 02-28-2006 01:32 PM
Voltage/High Current Explanation from TIPS newtitan DIYMA SQ forum - Technical & Advanced 19 12-23-2005 07:03 PM
