Old 07-08-2009   #1
Default Tang Band W6-1139SI 6-1/2" Subwoofer - midbass?
Curious to see if anybody used these as midbass in doors. Would like to hear your thoughts. I currently have 8" Morel waiting to go in as part of 2 way with Foundtek full ranges. If that doesn't work and I end up with 3way, how would they do as dedicated midbass?
Thanks.
Parts-Express.com:Tang Band W6-1139SI 6-1/2" Subwoofer | subwoofer 6" subwoofer neodynium subwoofer tangband tb speakers tangband-22008
Alpine 9887 - PPI Art 300.2 - PPI Art 600.2 - PPI Art 600
7" Peerless HDS - Vifa XT25 - Mach 5 15" IB
Mless5 is offline
Old 07-08-2009   #2
89grand's Avatar
Default Re: Tang Band W6-1139SI 6-1/2" Subwoofer - midbass?
I only use one as a sub, but they should work awesome as a midbass. I'd say they are power hungry though so you don't want to loaf along with just 50 watts or so.
Last edited by 89grand; 07-08-2009 at 10:35 PM.. Reason: added "don't" which changes everything I said.
89grand is offline
Old 07-08-2009   #3
I wonder if sub less 3 way a possibility with these?
Mless5 is offline
Old 07-08-2009   #4
89grand's Avatar
They are pretty good for their size, but they are just a 6.5". I could see two doing pretty decent as long as you aren't a bass head and don't expect them to sound like two 10's. In a quiet car, I can see not needing a sub.
I'd probably step up to the 8" version if I really wanted to go without a sub.
89grand is offline
Old 07-09-2009   #5
Parts-Express.com:Tang Band W6-1721 6-1/2" Underhung Midbass Driver | Tang Band W6-1721 midbass underhung Tang Band TB Speakers compact speaker
tspence73 is offline
Old 07-09-2009   #6
I would love to try these guys, but it seems kind of a waste to use in a 3 way where he will probably be crossing the midbass at 200hz or so. Seems these would make a much better 2 way, especially since they look good up to about 4k.
el_chupo_ is online now
Old 07-09-2009   #7
I think Candisa on here is using or going to use a pair of these in each door for midbass. Might shoot her a PM.
fish is offline
Old 07-09-2009   #8
Sorry, but of a thread steal, but...
When people say something is "power hungry" -- what exactly does that mean?
I assume we aren't just talking low efficiency (and thus... to get some SPL you need some watts)... or are we?
Assuming a 50w amp gets "loud enough", if you put a 1000w amp (and level matched to the 50w)... is there some positive impact you should expect?
Sillyboy is offline
Old 07-09-2009   #9
ehkewley's Avatar
In my experience it's been about headroom. Underpowering a driver that clearly needed more power would result in compression, reduced output, and distortion (if turned up enough) for me.
ehkewley is offline
Old 07-09-2009   #10
89grand's Avatar
What I mean is, well they're not very efficient. They are going to want some power to get loud. I'm running one with a rated 120 watts and it seems I could use even more than that. I mean of course they'd play off 50 watts, but you'd wish you had more power if you did.
89grand is offline
Old 07-09-2009   #11
I used them as midbass and I wasn't very happy with them. They didn't seem to have the snap of a good midbass IMO. I had them installed in my doors by the way off 100wrms.
beerdrnkr is offline
Old 07-09-2009   #12
89grand's Avatar
Doesn't seem like anything an eq can't fix.
89grand is offline
Old 07-10-2009   #13
Hmm, how about IB setup with these for a small coupe?
Mless5 is offline
Old 07-10-2009   #14
The tiny tiny Vas wuoldn't lend itself to IB use.
If it is being marketed as a sub, generally it wouldn't be the best thing to use for a midbass. You could have a high inductance to limit upper end response.
83 db for a 6...that thing is power hungry in a bad way.
thehatedguy is offline
Old 07-10-2009   #15
Sundownz
Thanks.
I used them for mid-bass before - they rocked.
I had 200 RMS per side on mine.
- Jacob Fuller
- Owner, Sundown Audio
sundownz is offline
Old 07-10-2009   #16
Sundownz
On paper it doesn't look good IB... but mine IB in a well dampened door was great.
- Jacob Fuller
sundownz is offline
Old 07-10-2009   #17
What freq did you run them up to?
BeatsDownLow is offline
