#1 |
Audio Adrenaline Position:
Sales/Shop Manager/Custom Installer iTrader: (14) |
Hey Guys I Have The Non-C3 Unit
I have 14 of them Looking to sell them for $112 + Shipping I will get you papers for your car if you intend on installing it.. Here is the info 1 mile range Keyless entry Remote Start STANDARD COMPONENTS: ·6 Channel Keyless Entry and Remote Car Starter with 5 on-board MICRO relays for parking lights, starter, accessories, ignition 1&2 and one additional relay / socket for starter disable. ·Range of up to ONE MILE. ·New MANCHESTER CODE encoder. ·NEW STYLE Two-way, window mount SUPER EXTENDED RANGE transceiver antenna module. ·TWO 5-button extended range FM, Standard 900-megahertz SLIDE COVER remote transmitter. ·Plug-in super bright mini-BLUE LED and push-type valet/override switch. ·Easily upgraded to Two way by just adding XT-90 LCD or XT-100 OLED Remote KEYLESS ENTRY FEATURES: ·Six Channels of outputs (3 dedicated to lock/unlock, trunk and remote start / 3 auxiliary outputs) ·Two 4-button standard remote transmitter with two car operation. ·Code learning / Anti-scan receiver with programmable code hopping. ·Back-up memory system ·Selectable Chirp Confirmation ·Comfort Feature with OEM systems having key/remote control power window roll-up ·Dedicated remote panic and car locator ·Passive locking and by-pass from the remote ·Parking light flash with dual polarity relay on-board ·Dome light illuminated entry output ·Dual polarity (+/-) door lock outputs with optional driver s door priority two step unlock ·Additional positive and negative inputs ·Programmable momentary, latched or timer on 3 auxiliary channels. ·Programmable Single / Double Pulse Unlock (7 new timing adjustments) ·Programmable Parking lights (flash or constant) ·Programmable Pathway Illumination (on / off) ·Programmable horn chirp delete ·Programmable ignition control lock and unlock ·Programmable pulse time for lock and unlock (.9 sec. / 3 sec.) REMOTE CAR STARTER FEATURES: ·5 On-Board Relays: Ignition 1 Ignition 2 Starter Accessory Parking Light ·3rd Ignition (-) output ·Dedicated Second Start wire ·Dedicated Ground out when running GM- Non starter wire timing compatible ·Ground when start (-) output ·New Turbo Timer feature ·2nd Accessory (-) output ·Selectable one or two push Safety Start ·Programmable gasoline or diesel with 10, 15, or 20 second Wait-to Start ·Hood pin switch safety input (pin switch included) ·Selectable RPM / Voltage Start ·RPM / Voltage / Hi-Low level check ·Timer control start option ·Sensor control output during start ·Temporary Stop Feature ·Factory alarm Disarm and Rearm signal output ·Programmable factory keyless door locking before and after start ·Programmable start status output with shock sensor bypass ·45 second door / dome light bypass after ignition is turned off. ·Programmable Ignition 2 (on / off) ·Programmable 3 hour timer start ·Programmable 1 / 3 hour timer start ·Selectable Run Timer (5/10/20/30 minutes) ·Selectable Gasoline / diesel Selectable Diesel warm-up time
audioadrenalineaz.com
L1 Pro SE, L3, L6~+ (3) Arc8's ARC Audio 4200SE + 2150SE Nominated For The Top 100 Installer List |
#2 |
Interesting
![]() I need a remote start for these damn col New England Winters ![]() Will have to do some reasearch to see if it will cause fits with the Jaguar electrical system or void part/all of the warranty, i'll get back to ya. |
#3 |
Still Have 10, Winter is almost here..
Let me know I can get you wire charts for your car aswell.. |
