How do you find the cubic ft. in an odd shape? - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 04-21-2011   #1
Rep Power: 105 vwguy383 will become famous soon enoughvwguy383 will become famous soon enoughvwguy383 will become famous soon enoughvwguy383 will become famous soon enoughvwguy383 will become famous soon enoughvwguy383 will become famous soon enough
Default How do you find the cubic ft. in an odd shape?
I am planning on building an subwoofer box for my wifes Car but I want to conceal it. It is going in a Saturn Vue under the rear floor by the rear tire. I want to keep the spare tire and Build around it. (there is plenty of room) I want it to go about a quarter of the way around it. What I was planning on doing is making a mold out of Pink Rigid Foam Insulation and then fiberglassing around it. But my question is how do I find out the the cubic ft of the inclousere with it being odd shaped?
Thanks
Justind
vwguy383 is offline   Reply With Quote Quick reply to this message
Old 04-21-2011   #2
SoundJunkie's Avatar
Rep Power: 113 SoundJunkie has a spectacular aura aboutSoundJunkie has a spectacular aura aboutSoundJunkie has a spectacular aura aboutSoundJunkie has a spectacular aura aboutSoundJunkie has a spectacular aura aboutSoundJunkie has a spectacular aura aboutSoundJunkie has a spectacular aura aboutSoundJunkie has a spectacular aura aboutSoundJunkie has a spectacular aura aboutSoundJunkie has a spectacular aura about
Send a message via Yahoo to SoundJunkie
Mock up your mold, fill it with styrofoam peanuts then empty the peanuts into a known enclosure volume to check it. Not scientific by any means but gets you close.
Sent from my DROIDX using Tapatalk
2013 Kia Optima Hybrid - Pioneer ODR, Mosconi Steg Illusion Audio Gladen Aerospace Focal Blackhole
2013 USACi Super Modified Q Champion
2011 USACi Modified Q Champion
Team ORCA Team Audionutz
SoundJunkie is offline   Reply With Quote Quick reply to this message
Old 04-21-2011   #3
TrickyRicky's Avatar
Rep Power: 146 TrickyRicky is a splendid one to beholdTrickyRicky is a splendid one to beholdTrickyRicky is a splendid one to beholdTrickyRicky is a splendid one to beholdTrickyRicky is a splendid one to beholdTrickyRicky is a splendid one to beholdTrickyRicky is a splendid one to beholdTrickyRicky is a splendid one to beholdTrickyRicky is a splendid one to beholdTrickyRicky is a splendid one to beholdTrickyRicky is a splendid one to behold
Default Re: How do you find the cubic ft. in an odd shape?
Using formulas from middle school, lol. They have formulas to find volume for any shape (circles, spheres, cylinders, squares, triangles, ect). Atleast this way all you need is measurements and a calculator. Plus if you have measurements already you wont have to lift your rear from the seat, and do it from your desk, lol.
We are caged by our cultural programming. Culture is a mass hallucination, and when you step outside the mass hallucination you see it for what its worth. -Terence McKenna.
TrickyRicky is offline   Reply With Quote Quick reply to this message
Old 04-21-2011   #4
Rep Power: 0 MIK3CT will become famous soon enoughMIK3CT will become famous soon enoughMIK3CT will become famous soon enoughMIK3CT will become famous soon enoughMIK3CT will become famous soon enoughMIK3CT will become famous soon enough
Thanks
Justind
Check out this link:
Subwoofer Enclosure Calculators, Fraction to Decimal, Parallel, Series, Port Length and Volume Calculators
MIK3CT is offline   Reply With Quote Quick reply to this message
Old 04-21-2011   #5
Rep Power: 102 yuri will become famous soon enoughyuri will become famous soon enoughyuri will become famous soon enoughyuri will become famous soon enoughyuri will become famous soon enoughyuri will become famous soon enoughyuri will become famous soon enough
Thanks
Justind
fill it with water , 1 Imperial pint = 0.0200679649 cubic feet
its a great way to check if it leaks as well ........
yuri is offline   Reply With Quote Quick reply to this message
Old 04-21-2011   #6
I have heard about the packing peanuts idea. The shape of the box is going to be L shaped with a rounded part that will be by the tire. The other question I had was how do I mount a subwoofer to it? Do I need to put a round piece of wood in it so I can screw the sub too it or will the fiberglass be enough? Also will it effect the sound if I down fire it with a rectangle shaped port out the side? kind of like the some of the JL stealth boxs that go under truck seats?
Thanks
Justind
Old 04-21-2011   #7
t3sn4f2's Avatar
Rep Power: 220 t3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to all
I would not use water as a medium to determine volume. Say you have a leak around the MDF baffle that will likely be used. It is now not only a leak but also a swollen ruined area on the box.
Old 04-21-2011   #8
Rep Power: 189 tyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura about
Sand is the best and most accurate way.
Old 04-21-2011   #9
Rep Power: 82 9mmmac will become famous soon enough9mmmac will become famous soon enough9mmmac will become famous soon enough9mmmac will become famous soon enough9mmmac will become famous soon enough9mmmac will become famous soon enough9mmmac will become famous soon enough
Mock it up as best you can using a giant cardboard template. Then, if you have to, carve it back up into geometric shapes you can find the volume of. Somebody else had the excellent idea of using plain popcorn in place of the packing peanuts.
9mmmac is offline   Reply With Quote Quick reply to this message
Old 04-21-2011   #10
Thanks
Justind
The enclosure needs to be as rigid as possible to resist flexing and you need a solid, flush mounting surface. Dependent upon the physical weight of the driver and its excursion capabilities you should start with a minimum of 1/2" MDF; the thicker the better. Up or down firing you will have to play with together with phasing to see which works best in your vehicle.
Hope that helps.
Old 04-21-2011   #11
nineball's Avatar
Rep Power: 145 nineball is a jewel in the roughnineball is a jewel in the roughnineball is a jewel in the roughnineball is a jewel in the roughnineball is a jewel in the roughnineball is a jewel in the roughnineball is a jewel in the roughnineball is a jewel in the roughnineball is a jewel in the roughnineball is a jewel in the roughnineball is a jewel in the rough
build the enclosure and then use the packing peanuts. if you have too much airspace then fill some in with expanding foam or blocks of 2x4. if you have too little use polyfill.
Freedom of speech includes the freedom to offend people. - Brad Thor
nineball is offline   Reply With Quote Quick reply to this message
Old 04-21-2011   #12
the op said he was making it with ridge foam and fiberglass .. but even if uses an mdf baffle ,its easy to coat it with some resin to prevent water penetrating into the mdf .
sand ,peanuts etc wont find small leaks
Old 04-21-2011   #13
Thanks guys for all of the info!! There have been some great ideas. If anyone else has any more ideas bring it on!
Thanks
Justind
Old 04-21-2011   #14
Rep Power: 107 JasonB will become famous soon enoughJasonB will become famous soon enoughJasonB will become famous soon enoughJasonB will become famous soon enoughJasonB will become famous soon enoughJasonB will become famous soon enough
The standard polyester resin used for fiberglass will dissolve styrofoam almost instantly, not sure if this applies to the pink styrofoam as well but you might want to keep that in mind.
Jason
JasonB is offline   Reply With Quote Quick reply to this message
Old 04-21-2011   #15
I thought you could use some type of resin that didn't dissolve it? And then when your finished you can pour I think acetone in the box and it will melt the pink styrofoam? I will have to look into that. My bro in law went to school for an engineering degree in composite materials and I'll have to ask him again about the process.
Thanks
Justind
Old 04-21-2011   #16
I believe epoxy resin won't eat styrofoam.
Old 04-22-2011   #17
Rep Power: 98 Brian10962001 will become famous soon enoughBrian10962001 will become famous soon enoughBrian10962001 will become famous soon enoughBrian10962001 will become famous soon enoughBrian10962001 will become famous soon enoughBrian10962001 will become famous soon enough
Peanuts, OR, make it, play it, don't like it, reduce it or stuff it.
Brian10962001 is offline   Reply With Quote Quick reply to this message
