2012 Lincoln MKZ Hybrid Door Panel Removal - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 08-14-2011   #1
Rep Power: 0 bjroosevelt will become famous soon enoughbjroosevelt will become famous soon enoughbjroosevelt will become famous soon enoughbjroosevelt will become famous soon enoughbjroosevelt will become famous soon enoughbjroosevelt will become famous soon enough
Post 2012 Lincoln MKZ Hybrid Door Panel Removal
I just retrofitted some speakers on my 2012 Lincoln MKZ Hybrid. Figuring out how to get the door panels off was not straight forward. Postings about some older MKZs and the Ford Fusion gave me hints, but Lincoln has added some extra hidden panels and screws recently. I thought someone might appreciate if I posted pictures of how to get at all of the screws. There are 5 torx 20 screws and 1 hex head bolt that need to be removed before you can use a panel removal tool to pop off to door panel. (Other postings on the Fusion and MKZ are sufficient to figure out how to use a door panel removal tool).
Attached are 4 slides with 8 pictures on how to remove the panel. (Slide content and results are not guaranteed)
Lincoln Door - Slide 1.pdf
Lincoln Door - Slide 2.pdf
Lincoln Door - Slide 3.pdf
Lincoln Door - Slide 4.pdf
bjroosevelt is offline   Reply With Quote Quick reply to this message
Old 08-14-2011   #2
Rep Power: 84 9mmmac will become famous soon enough9mmmac will become famous soon enough9mmmac will become famous soon enough9mmmac will become famous soon enough9mmmac will become famous soon enough9mmmac will become famous soon enough9mmmac will become famous soon enough
Default Re: 2012 Lincoln MKZ Hybrid Door Panel Removal
Very nice piece of work. All these are kind of stock/usual places for screws and such, except for the very last one. That's a gold mine of information right there!
Um... Unusual to post a .pdf. Did you do the workup and formatting yourself? Nice and clean though- exactly what you need; no fluff.
9mmmac is offline   Reply With Quote Quick reply to this message
Old 08-14-2011   #3
I thought that the best path forward for other relative novices such as myself would be to add arrows and circles to highlight the key areas of interest in the photos. The only picture editing software I could think of at 5:00 this morning defaulted to .pdfs......so that's what I posted. There wasn't much thought to it.
Old 09-10-2014   #4
Rep Power: 0 mlosasso will become famous soon enoughmlosasso will become famous soon enoughmlosasso will become famous soon enoughmlosasso will become famous soon enoughmlosasso will become famous soon enoughmlosasso will become famous soon enough
Thank you! Those were incredibly helpful...
mlosasso is offline   Reply With Quote Quick reply to this message
Old 09-10-2014   #5
Rep Power: 97 Pitmaster will become famous soon enoughPitmaster will become famous soon enoughPitmaster will become famous soon enoughPitmaster will become famous soon enoughPitmaster will become famous soon enoughPitmaster will become famous soon enough
Man, I wish the $800 Motors manuals were that clear and concise!
Great info here.
Thankfully those that know it all, can't do it all!
Pitmaster is offline   Reply With Quote Quick reply to this message
Old 09-10-2014   #6
Good Luck on your Retrofit.
Old 09-11-2014   #7
Rep Power: 61 Jepalan will become famous soon enoughJepalan will become famous soon enoughJepalan will become famous soon enoughJepalan will become famous soon enoughJepalan will become famous soon enoughJepalan will become famous soon enoughJepalan will become famous soon enough
Nice. Very generous of you. I might have to go buy a '12 MKZ now that I now how to remove the panels.
Jepalan is offline   Reply With Quote Quick reply to this message
Old 05-30-2015   #8
Rep Power: 0 dano19068 will become famous soon enoughdano19068 will become famous soon enoughdano19068 will become famous soon enoughdano19068 will become famous soon enoughdano19068 will become famous soon enoughdano19068 will become famous soon enough
I was stumped on how to find the bolt and screw under the door handle until I found your post. The pictures made the post perfect!! I was about to find someone to install my new speakers in the MKZ when I found your post.
Thank you
dano19068 is offline   Reply With Quote Quick reply to this message
Old 08-27-2015   #9
Rep Power: 0 sgraveli will become famous soon enoughsgraveli will become famous soon enoughsgraveli will become famous soon enoughsgraveli will become famous soon enoughsgraveli will become famous soon enoughsgraveli will become famous soon enough
this was some awesome info. Now I can replace my drivers side mirror and stop getting comments from the other guys at work. Many Thanks
sgraveli is offline   Reply With Quote Quick reply to this message
Old 01-15-2016   #10
Rep Power: 0 adentdude will become famous soon enoughadentdude will become famous soon enoughadentdude will become famous soon enoughadentdude will become famous soon enoughadentdude will become famous soon enoughadentdude will become famous soon enough
Very helpful! I'm replacing the door handle because the door will not open from the inside.
adentdude is offline   Reply With Quote Quick reply to this message
Old 08-23-2016   #11
Rep Power: 0 KC_in_NY will become famous soon enoughKC_in_NY will become famous soon enoughKC_in_NY will become famous soon enoughKC_in_NY will become famous soon enoughKC_in_NY will become famous soon enoughKC_in_NY will become famous soon enough
Your slides are incredible. I was stumped on the screws in the door handle, so it was a big help.
KC_in_NY is offline   Reply With Quote Quick reply to this message
Old 3 Weeks Ago   #12
Rep Power: 0 kenlreid will become famous soon enoughkenlreid will become famous soon enoughkenlreid will become famous soon enoughkenlreid will become famous soon enoughkenlreid will become famous soon enoughkenlreid will become famous soon enough
Thanks.... i actually broke part of door handle cover trying to pry off....smh. thank you so much!!!
kenlreid is offline   Reply With Quote Quick reply to this message
Old 3 Days Ago   #13
Rep Power: 0 Steamloco will become famous soon enoughSteamloco will become famous soon enoughSteamloco will become famous soon enoughSteamloco will become famous soon enoughSteamloco will become famous soon enoughSteamloco will become famous soon enough
Having trouble finding the slides for this post. May not be available on a mobile device. Any suggestions?
Steamloco is offline   Reply With Quote Quick reply to this message
Old 3 Days Ago   #14
Notloudenuf's Avatar
NCSQ Founding Member
Rep Power: 135 Notloudenuf is just really niceNotloudenuf is just really niceNotloudenuf is just really niceNotloudenuf is just really niceNotloudenuf is just really niceNotloudenuf is just really niceNotloudenuf is just really niceNotloudenuf is just really niceNotloudenuf is just really niceNotloudenuf is just really niceNotloudenuf is just really nice
They are still there.
Look at this page on a different device.
Old 3 Days Ago   #15
Thanks! I found them. Earlier morning search in bed with my phone. Found them when I went to my desktop machine.
