Truck cab air vents - please, shush-up.... - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 04-30-2012   #1
Rep Power: 88 tulse will become famous soon enoughtulse will become famous soon enoughtulse will become famous soon enoughtulse will become famous soon enoughtulse will become famous soon enoughtulse will become famous soon enough
Default Truck cab air vents - please, shush-up....
There are two vents in the rear of the cab in my truck. They were a secret to me until recently. I have the rear bench seat out at the moment, and that's how I discovered the bastards. Those things are loud!
Is there a common fix for this - a baffle or such. Or, can I just kill them with some CDL.
Are they really necessary for ventilation? I don't want to suffocate and turn blue, but anything short of that is fine by me.
Thanks
tulse is offline   Reply With Quote Quick reply to this message
Old 04-30-2012   #2
jcollin76's Avatar
Rep Power: 101 jcollin76 is just really nicejcollin76 is just really nicejcollin76 is just really nicejcollin76 is just really nicejcollin76 is just really nicejcollin76 is just really nicejcollin76 is just really nicejcollin76 is just really nicejcollin76 is just really nicejcollin76 is just really nicejcollin76 is just really nice
This will give you some of the pros and cons of sealing them...
Rear Wall Cabin Vents in Truck? SEAL OR NO??
08 Chevy Silverado ccsb >>>Pioneer DEX-P99RS>>>JL HD600/4×2, JL HD1200/1>>>Rainbow cal28>>>Pioneer ts-s062prs>>> Rainbow w175 platinum>>>JL zr800>>>Diyma R12 ×4 sealed>>> lots of Second skin, Raamaudio, and knuconcepts
jcollin76 is offline   Reply With Quote Quick reply to this message
Old 04-30-2012   #3
BuickGN's Avatar
Rep Power: 160 BuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to beholdBuickGN is a splendid one to behold
Default Re: Truck cab air vents - please, shush-up....
What's funny is I recently went back and really sealed up my IB setup as airtight as I could get it. I've also been complaining that I need to replace the cabin air filter because output is pretty bad. It didn't occur to me that it might have been from sealing the trunk off (which is where the vents are)from the cabin. I need to try it with a window down to see if it's the lack of vents that's causing it.
'84 GN 10.60@ 127mph.
'07 Epic Expert
'06 TL.
Old 04-30-2012   #4
jcollin76's Avatar
When I had mine sealed up, output easily doubled on my AC when I cracked a window/ door.
The cab got so pressurized, you could hear the air being forced out of the seals.(from outside the truck) Lol yeah, had to fix that.
Old 04-30-2012   #5
Thanks, I'm really thinking about throwing together some simple baffles then.
What did you end up with? Any tips on a design?
The vents are bloody 7"X3"-ish. No wonder why there's so much noise in cabs. I just replaced my obnoxious muffler with a dynoflow turbo, too. It's MUCH nicer, but those vents have to be tamed.
Old 04-30-2012   #6
jcollin76's Avatar
Honestly, haven't gotten to it yet. Plan was to address it when I pull the rear seat again. Haven't gotten that far...
Passenger vent is covered to help with exhaust noise. Driver side is open, and ill be messing with it in the future.
Noise is not as bad as open, and the pressure situation isn't as bad... but could be better.
Old 04-30-2012   #7
BuickGN's Avatar
I had a few paragraphs written but then I realized I forgot to ask the most basic question. These vents contain flappers that only let air travel out but not into the cab, right? Is the problem with outside noise getting in through the vents or is it the flappers making noise when the bass hits?
'07 Epic Expert
'06 TL.
Old 04-30-2012   #8
It's outside noise that's the problem. The vents do look like they have flappy, one-way louvers, though. The vents are behind the trim. I'll pull it off and get a better look tomorrow.
Old 04-30-2012   #9
BuickGN's Avatar
I wish I could help but I've never had a Car with vents in the cabin. You can always cover them up temporarily and see if it makes a difference. I can't imagine it making a huge difference though, they're normally closed unless the HVAC is being used. I'm interested to hear your results though.
'07 Epic Expert
'06 TL.
Old 04-30-2012   #10
No problem. I appreciate it. Should be prety easy to do some trial and error stuff.
Old 05-01-2012   #11
mojozoom's Avatar
Rep Power: 65 mojozoom will become famous soon enoughmojozoom will become famous soon enoughmojozoom will become famous soon enoughmojozoom will become famous soon enoughmojozoom will become famous soon enoughmojozoom will become famous soon enoughmojozoom will become famous soon enough
I heard that these vents were also there to vent pressure during airbag deployment.
2008 Mazda3: RF 3sixty.3, JL XD600/6, Silver Flutes, Hertz ET20, JL 250/1, Infinity 860W
mojozoom is offline   Reply With Quote Quick reply to this message
Old 05-01-2012   #12
pjc
pjc's Avatar
Rep Power: 126 pjc has a reputation beyond reputepjc has a reputation beyond reputepjc has a reputation beyond reputepjc has a reputation beyond reputepjc has a reputation beyond reputepjc has a reputation beyond reputepjc has a reputation beyond reputepjc has a reputation beyond reputepjc has a reputation beyond reputepjc has a reputation beyond reputepjc has a reputation beyond repute
I guess u need to look into it further too. But I completely covered mine when I Raammatted my truck. I actually just went right over them with a piece of raammat. I've noticed a quieter ride. And never noticed any extra noise with the AC on. And no airbag deployment yet so I can't vouch for that part.
Panny Bottlehead.... The rest... Who knows.
pjc is offline   Reply With Quote Quick reply to this message
Old 05-01-2012   #13
BuickGN's Avatar
I'm sure they help with airbag deployment. However, my airbagless GN has roughly the same vent area as the TL. That probably means nothing though. For all I know it might mean the difference in blown eardrums. Hopefully my IB15s would have a little give in the event of airbag deployment but I'm sure they can't come close to covering the amount of volume the airbags displace.
I did try rolling the windows up and down with the fan on high today and there was no difference. I guess it really is just time to change the cabin filter.
'07 Epic Expert
'06 TL.
Old 05-02-2012   #14
Rep Power: 66 MUGWUMP will become famous soon enoughMUGWUMP will become famous soon enoughMUGWUMP will become famous soon enoughMUGWUMP will become famous soon enoughMUGWUMP will become famous soon enoughMUGWUMP will become famous soon enough
This should take care of that shouldn't it?
Requested pictorial of big meat rear sub box
MUGWUMP is offline   Reply With Quote Quick reply to this message
Old 05-02-2012   #15
Aaron'z 2.5RS/WRX's Avatar
Rep Power: 283 Aaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond reputeAaron'z 2.5RS/WRX has a reputation beyond repute
The vents are there to equalize pressure, when you close a door, when you turn on the fan....ect....
Rip the flappy out or seal over it... you've got one of 2 choices..
Rip it out, run the risk of water/dust, cover it and pressurize the cabin constantly, I've done both...
Aaron'z 2.5RS/WRX is offline   Reply With Quote Quick reply to this message
Old 05-02-2012   #16
I'm going with option somewhere-in-the-middle.
Passenger side vent is getting covered. It's right over the muffler, basically. For the driver's side, I'll make a simple foam lined, right angle baffle. How does that sound? That should get rid of that high frequency wind sound, I'd guess.
I was actually mistake about the louvers. They do not move (are not hinged).
Old 05-02-2012   #17
Timelessr1's Avatar
Action Audio
Whipping post
Rep Power: 92 Timelessr1 will become famous soon enoughTimelessr1 will become famous soon enoughTimelessr1 will become famous soon enoughTimelessr1 will become famous soon enoughTimelessr1 will become famous soon enoughTimelessr1 will become famous soon enough
what kind of truck? I know on mine (2010 F150) the "louvers" only move when you choose to blow aire NOT using the recycle air feature. when you use the recycle air feature, the louvers do not move at all....
Timelessr1 is offline   Reply With Quote Quick reply to this message
Old 05-02-2012   #18
Right, because on the "recycle" setting, you are recycling the air, not taking any from outside... .
Come on man, think a minute...
Old 05-02-2012   #19
Timelessr1's Avatar
Action Audio
Whipping post
haha..i know that....
but the op said his didnt move...and i find it hard to believe that they dont...i have a feeling he tested it and looked while he had it in "recirculate " mode. I know when i had my back apart and had the air setting in normal mode it sounded like a freight train was back there.
Old 05-24-2012   #20
Rep Power: 95 iregret will become famous soon enoughiregret will become famous soon enoughiregret will become famous soon enoughiregret will become famous soon enoughiregret will become famous soon enoughiregret will become famous soon enough
If someone figures out a way to quiet those things down, I'd love to hear it.
iregret is offline   Reply With Quote Quick reply to this message
Old 05-24-2012   #21
Hahahaha troof...lol
Sent from the other side using mind bullets...(YapaTalk)
Old 05-24-2012   #22
The way is here.. remove them or cover them...
Old 05-24-2012   #23
BuickGN's Avatar
Its off topic but does anyone know the percentage of air that has to be fresh when in recycle? I knew it once but can't remember.
'07 Epic Expert
'06 TL.
Old 05-24-2012   #24
I didn't think any came in fresh on recycle, besides what leaks in/out through the "vent of hell"..
Old 05-24-2012   #25
minbari's Avatar
DIYMA super monkey!
Rep Power: 192 minbari is a name known to allminbari is a name known to allminbari is a name known to allminbari is a name known to allminbari is a name known to allminbari is a name known to allminbari is a name known to allminbari is a name known to allminbari is a name known to allminbari is a name known to allminbari is a name known to all
highly doubt it.
They are there so that the heater/air conditioner can pull air into the cabin. good test if you have them sealed up. turn the "recirculate" on and see if volume increases alot.
Original post whore!
Bent Nail Brewery
2013 Fiesta, Stock Sync HU |AC LC2i | Phoenix Gold EQ215i | Soundstream SA120 -> ID CD1eMH | Phoenix Gold T500.2 -> ID X65 | JL 500/1 -> (2) 15" Pyle PL1590BL in IB
