Old 05-06-2012   #1
Rep Power: 0 slodat will become famous soon enoughslodat will become famous soon enoughslodat will become famous soon enoughslodat will become famous soon enoughslodat will become famous soon enoughslodat will become famous soon enough
Default How do I use my "male" template to make a "female" piece
I have a 1/4" thick template that is a "rounded corner-ish rectangle". I want to make it's mate - an opening in a larger piece of sheet that this template would exactly fit in.
For the life of me, I can't figure out how to do this.
Photo of template:
slodat is offline   Reply With Quote
Old 05-06-2012   #2
Auto1
installer
Rep Power: 59 Soloact will become famous soon enoughSoloact will become famous soon enoughSoloact will become famous soon enoughSoloact will become famous soon enoughSoloact will become famous soon enoughSoloact will become famous soon enough
There are a few options,depending on what you're wanting to do with the final pieces,ie: paint,wrapped in some kind of fabric,etc.A router with a flush trim bit and bearing would work great.
Sent from my ADR6350 using Tapatalk 2
Soloact is online now   Reply With Quote
Old 05-06-2012   #3
Aaron'z 2.5RS/WRX's Avatar
Default Re: How do I use my "male" template to make a "female" piece
This
Make a negitive of the plug out of scrap, (so you've got the doughnut, not the hole) THEN, router around the inside of the template, leaving a hole for your plug..
Old 05-06-2012   #4
Bulk Sales Pass
Mic10is's Avatar
Rep Power: 99 Mic10is will become famous soon enoughMic10is will become famous soon enoughMic10is will become famous soon enoughMic10is will become famous soon enoughMic10is will become famous soon enoughMic10is will become famous soon enoughMic10is will become famous soon enough
Trace on to wood. rough cut it. Cover the male piece is tape and release agent. put it in the other piece. bondo around the edges to fill in all the gaps,
let dry
remove other piece. lightly sand.
Now you have an exact piece that you can either use or use as a router template
2011 MECA SQL Spirit Award
2012 USACi Japan Finals Judge
Mic10is is offline   Reply With Quote
Old 05-06-2012   #5
Rep Power: 32 emilime75 is on a distinguished roademilime75 is on a distinguished roademilime75 is on a distinguished roademilime75 is on a distinguished roademilime75 is on a distinguished road
let dry
What he said.
emilime75 is offline   Reply With Quote
Old 05-06-2012   #6
This is only half of the process as it would result in a piece with a hole that is too big. The second step would be to use a template bushing to route the actual piece. Your template bushing size would be determined by the router bit size you use to make the template in step one.
Originally Posted by Aaron'z 2.5RS/WRX View Post
This
This too would result in a piece that is the wrong size. The amount of size difference would be determined by the size of the bit used.
Your 2 best methods to try would be either the oversize template with a guide bushing, or what Mic 10is said with the rough cut template and filler. They would both result in what you're looking for, just 2 different routes(pun intended) to get there.
Old 05-07-2012   #7
Here's what I did.. I stapled the buck to 1/4 luan. I cut 5/16" wide strips of 3mm PVC board and chipboard. I put the chipboard around the border of my male template and stapled the PVC firmly to the edge all the way around - heating it to get it to conform to the corners. It worked well. Would have been easier if I would have had 6mm PVC board.
I removed the male template and the chip board and took the rest to the router table. Using a flush trim bit, I guided the bearing carefully against the PVC. The chipboard gave even material clearance all the way around.
I glued a piece of 3mm PVC to the luan and routed the opening with the flush trim bit. Everything looked good so I glued 1/8 closed cell foam to the top. Once the glue set up for a while, I used a 1/2" round over bit on the router table to round the edge of the stack of materials that make up the opening. Then I wrapped it in a piece of vinyl to check everything out.
This was a test panel to ensure my method was going to get me the desired result. I do this often. It really helps to work the kinks out on a small test piece.
Old 05-07-2012   #8
Well, it looks like you came up with your own way to do it, looks good.
By the way, what's PVC board? What is it typically used for?
Old 05-07-2012   #9
I am a custom car upholsterer. PVC foam board is sold under brand names like Sintra and Komatex. You can get it from plastics suppliers and perhaps sign shops. I use it for making panels. Especially for panels with shape and curves. Right now I am making a "hard" headliner for a '34 Ford pickup. You can form the PVC with an industrial heat gun and machine it with woodworking tools. Holds it's shape well. Is light weight. All around great material. 3mm is about $26 for a 4' x 8' sheet where I live.
I used it in the process I showed two posts up because it conformed to the curves of my template very well.
Old 05-09-2012   #10
Rep Power: 73 kwhitelaw will become famous soon enoughkwhitelaw will become famous soon enoughkwhitelaw will become famous soon enoughkwhitelaw will become famous soon enoughkwhitelaw will become famous soon enoughkwhitelaw will become famous soon enough
let dry
billy brown training
kwhitelaw is offline   Reply With Quote
Old 05-10-2012   #11
I don't get the reference...
Old 05-10-2012   #12
quality_sound's Avatar
Rep Power: 164 quality_sound is a jewel in the roughquality_sound is a jewel in the roughquality_sound is a jewel in the roughquality_sound is a jewel in the roughquality_sound is a jewel in the roughquality_sound is a jewel in the roughquality_sound is a jewel in the roughquality_sound is a jewel in the roughquality_sound is a jewel in the roughquality_sound is a jewel in the roughquality_sound is a jewel in the rough
let dry
Or you can do this but with a slightly larger rough cut. Then you put a layer of double-sided tape in the plug (don't peel the tape from both sides though) before you add your filler. This will give you the clearance to wrap the pieces. If you need more clearance (vinyl/carpet on both sides) then you would use two layers.
That's how the RF guys showed us how to do it and it's quick and easy.
quality_sound is offline   Reply With Quote
Old 05-10-2012   #13
Bulk Sales Pass
Mic10is's Avatar
agreed
lots of lil tweaks and ways to do things just depending on how it will be finished.
Old 05-13-2012   #14
Rep Power: 46 kmarei will become famous soon enoughkmarei will become famous soon enoughkmarei will become famous soon enoughkmarei will become famous soon enoughkmarei will become famous soon enoughkmarei will become famous soon enough
I was going to suggest adding a nasally nagging voice
And making it in a horrible mood once a month
But I think the other suggestions are better
kmarei is offline   Reply With Quote
Old 05-13-2012   #15
Rep Power: 28 taibanl will become famous soon enoughtaibanl will become famous soon enoughtaibanl will become famous soon enoughtaibanl will become famous soon enoughtaibanl will become famous soon enoughtaibanl will become famous soon enough
Too funny
JBL MS-8 + Rainbow SL 100 NG (C) & Infinity Kappa 42.9i (rear)
JL Audio XD600/6 + Rainbow SLC 210.25 & Kicker SSMB8 (L/R)
Alpine MRD-M300 + Image Dymamics ID10 D4 v.3 in VP Electricity Stealth Enclosure
taibanl is offline   Reply With Quote
Old 05-13-2012   #16
I accomplished the same thing by using the chipboard around the outside edge of the buck. The end result is what I was going for.
Old 05-13-2012   #17
Bulk Sales Pass
Mic10is's Avatar
Hilarious that you referenced that....I was never able to go.I picked it up from someone or somewhere else tho.
Old 05-13-2012   #18
Audio Express
Install Manager
Rep Power: 44 iasca judge will become famous soon enoughiasca judge will become famous soon enoughiasca judge will become famous soon enoughiasca judge will become famous soon enoughiasca judge will become famous soon enoughiasca judge will become famous soon enough
Hey mic, you didnt miss much. Billy learned most of his tricks from jeff head
iasca judge is offline   Reply With Quote
Old 05-18-2012   #19
Rep Power: 47 oldturd will become famous soon enougholdturd will become famous soon enougholdturd will become famous soon enougholdturd will become famous soon enougholdturd will become famous soon enougholdturd will become famous soon enough
His class was still fun. I got to go when I worked at Tweeter. the little class exercise pieces we build are still in my tool box somewhere.
oldturd is offline   Reply With Quote
Old 05-18-2012   #20
Bulk Sales Pass
Mic10is's Avatar
Ironic, I think i learned it from Steve Head...lol
Old 05-20-2012   #21
AB elektronics
Rep Power: 61 abdulwq will become famous soon enoughabdulwq will become famous soon enoughabdulwq will become famous soon enoughabdulwq will become famous soon enoughabdulwq will become famous soon enoughabdulwq will become famous soon enough
nice job
abdulwq is offline   Reply With Quote
