Old 08-18-2012   #1
Rep Power: 0 OS Audio will become famous soon enoughOS Audio will become famous soon enoughOS Audio will become famous soon enoughOS Audio will become famous soon enoughOS Audio will become famous soon enoughOS Audio will become famous soon enough
Default DMM?
Looking to get a new Digital Multi Meter. Who makes a good DMM???
I have a cheap DMM from Harbor Freight, its served me well but would like to purchase something better.
OS Audio is offline   Reply With Quote
Old 08-18-2012   #2
Rep Power: 16 mwright will become famous soon enoughmwright will become famous soon enoughmwright will become famous soon enoughmwright will become famous soon enoughmwright will become famous soon enoughmwright will become famous soon enough
Fluke probably makes the best DMM's you can buy. A little pricey but you know what they say, "You get what you pay for!!"
mwright is offline   Reply With Quote
Old 08-18-2012   #3
t3sn4f2's Avatar
Default Re: DMM?
Here's a nice one on the top
"HIGH-END BENCH DMM (revised 4/15):
A surprising number of people are trying to make audio measurements with typical portable DMM’s. And the readings are often grossly wrong without even realizing it. True RMS measurements are not trivial. In effect, the meter has to accurately measure the “area under the curve” and time average it—see True RMS Measurements for more information. This proves to be rather difficult across a wide range of frequencies if you want to maintain reasonable accuracy at high frequencies and not have the reading “hunt” up and down at low frequencies. The fact is, most DMM’s priced under a few hundred dollars that claim “True RMS” are really only accurate around 60hz—i.e. power line frequencies. Some will measure sine waves accurately across the audio band, but many will not even do that. I have a $150 “True RMS” Extech meter--a relatively well regarded brand--that’s off by nearly 6 dB at 20 Khz compared to 60 hz on a sine wave and is a joke above 1 Khz on non-sinusoidal waveforms. And really complex rapidly changing waveforms like white/pink noise or real music drive such meters crazy. To do it right, you need expensive true RMS circuitry and the ability to optimize the sample rate and averaging for the waveform being measured. Good high end bench DMM’s, like the Agilent 344xx series, let you set these parameters. They also read directly in dB. I use a 6 1/2 digit Agilent true RMS bench DMM that's extremely accurate and flat from 10 hz - 100 Khz for exact levels and other measurements. It has resolution down to 0.1 microvolts so it can even be used to measure noise."
NwAvGuy: Testing Methods
t3sn4f2 is offline   Reply With Quote
Old 08-18-2012   #4
Rep Power: 20 Sound-In-Waves will become famous soon enoughSound-In-Waves will become famous soon enoughSound-In-Waves will become famous soon enoughSound-In-Waves will become famous soon enoughSound-In-Waves will become famous soon enoughSound-In-Waves will become famous soon enough
Default Re: DMM?
Fluke and Keithley
Sound-In-Waves is offline   Reply With Quote
Old 08-20-2012   #5
Rep Power: 0 RollinSingle will become famous soon enoughRollinSingle will become famous soon enoughRollinSingle will become famous soon enoughRollinSingle will become famous soon enoughRollinSingle will become famous soon enoughRollinSingle will become famous soon enough
Default Re: DMM?
I highly suggest Fluke
RollinSingle is offline   Reply With Quote
Old 08-20-2012   #6
pjc
pjc's Avatar
Rep Power: 77 pjc has a reputation beyond reputepjc has a reputation beyond reputepjc has a reputation beyond reputepjc has a reputation beyond reputepjc has a reputation beyond reputepjc has a reputation beyond reputepjc has a reputation beyond reputepjc has a reputation beyond reputepjc has a reputation beyond reputepjc has a reputation beyond reputepjc has a reputation beyond repute
Love my Fluke. I've been rough with it in the past and it's very durable.
2012 Tundra Crewmax...its a work in progress.
pjc is offline   Reply With Quote
Old 08-20-2012   #7
Rep Power: 15 nadams5755 will become famous soon enoughnadams5755 will become famous soon enoughnadams5755 will become famous soon enoughnadams5755 will become famous soon enoughnadams5755 will become famous soon enoughnadams5755 will become famous soon enough
Default Re: DMM?
i have a fluke automotive kit i'm very happy with. it's about 12 years old too.
they're pricey though.
nadams5755 is offline   Reply With Quote
Old 08-24-2012   #8
Rep Power: 63 What? will become famous soon enoughWhat? will become famous soon enoughWhat? will become famous soon enoughWhat? will become famous soon enoughWhat? will become famous soon enoughWhat? will become famous soon enough
Default Re: DMM?
How about a TPI440 DMM with O-scope? As cheap as a new Fluke DMM plus O-scope.
What? is offline   Reply With Quote
